Old 04-15-2019, 15:35   #76 (permalink)
Bond.Flasher's Avatar
Member: 2464063
Thanks Meter: 73
Oppo A3s Remove User Lock and Google Account via direct eMMc : https://www.youtube.com/watch?v=FiGmsqgfKkA
The Following User Says Thank You to Bond.Flasher For This Useful Post:
Old 04-15-2019, 17:15   #77 (permalink)
Member: 2550445
Thanks Meter: 26
good . thanks
Originally Posted by icloudboss2016 View Post
3rd. Go to write by vendor select firmware and write the only userdata file in easy jtag plus suite... where firmware?
good. thanks... when I format is hang, only restart,,
after I pay, and flash,
Old 04-18-2019, 15:51   #78 (permalink)
Member: 2066396
Thanks Meter: 2
3rd. Go to write by vendor selact firmware and write only userdata file in easy jtag plus suite .... where firmware?
Just use the same firmware that u read in info
Old 04-18-2019, 16:22   #79 (permalink)
Member: 704044
Thanks Meter: 212
Originally Posted by royalnasim View Post
BRO CAN U SEND Q FIL LINK FOR OPPO A3s CPH 1853
Old 04-28-2019, 05:42   #80 (permalink)
Member: 2464063
Thanks Meter: 73
I hope this video can help with the Oppo A3s problem....
- Oppo A3s Remove User Lock and Google Account via direct eMMc : https://www.youtube.com/watch?v=FiGmsqgfKkA
- Read Firmware Oppo A3S Full Back Up via direct eMMc : https://www.youtube.com/watch?v=_59rZhk2crw
Old 04-29-2019, 15:15   #81 (permalink)
Member: 1501697
Thanks Meter: 13
OPPO A3s CPH 1853 bricked
after trying frp in easy jtag phone bricked
plz help easy jtag team
Old 04-29-2019, 18:13   #82 (permalink)
Member: 2623135
Thanks Meter: 8
write userdata and cache file in a3s qfill firmware b coz ur userdata and cache file wipe
The Following User Says Thank You to Ayan bagwan For This Useful Post:
Old 04-30-2019, 05:29   #83 (permalink)
Member: 2464063
Thanks Meter: 73
- Download QFIL Firmware Oppo A3s CPH1803 Tested 100% : http://suarankri.me/bOKDkBs
- Download Firmware Oppo A3S Full Back Up : http://suarankri.me/nb5dwZVvM
Old 04-30-2019, 05:33   #84 (permalink)
Member: 704044
Thanks Meter: 212
BRO HE NEEDS CPH 1853 ( A3s oem)
Old 05-02-2019, 09:33   #85 (permalink)
Member: 1034743
Sonork: 100.1619212
Thanks Meter: 193
oppo A3s pin password frp how to remove emmc ?
z3x easy jtag market in best emmc repair tool .
but why is solution oppo emmc repair
Old 06-09-2019, 15:33   #86 (permalink)
Nishan_Raja's Avatar
Member: 2554807
Thanks Meter: 612
Oppo a3s hang to logo after format with easyjtag
Oppo a3s hang to logo after format with easy jtag
Unable to format encrypted FS and i wipe data now hang to logo hlp me
Z3X EasyJtag Software ver. 3.6.0.0
Loading eMMC GEN2 Firmware... IO: 1800 mV
Box S/N: 9F43C4B6F8154346, ,FW Ver.: 02.40
CMD Pullup Level:1809 mV
CMD Active Level:1866 mV
Box IO Level:1800 mV
CLK Rate:36000 kHz
Bus Width:1bit,SDR
HiPower mode is off!
---------- eMMC Device Information ----------
eMMC CID : 150100524436344D4201C8F4D0EE1513
eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D
eMMC Manufacturer ID: 0015 , OEM ID: 0100
eMMC Date: 01/2018 Rev.0x1
eMMC NAME: RD64MB , S/N: 3371487470
eMMC NAME (HEX): 524436344D42
EMMC ROM1 (Main User Data) Capacity: 29820 MB , 0x3A3E000 pages , 0x747C00000 bytes
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC RPMB is programmed and written 44157 times
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area)
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Partition info successfully found
------ Android information ------
Detected LINUX(Android) CACHE : 0x001F300000 (256.0MB)
Read EXT fs info
Read EXT fs info
Created filesystem with parameters:
Block size: 888542576498442241
Blocks per group: 0
Inodes per group: 37
Inode size: 0
Inodes: 4294967295
Label:
Unable to format encrypted FS , try to Wipe it
Detected LINUX(Android) USERDATA : 0x015B800000 (23.690GB)
Read EXT fs info
Read EXT fs info
Blocks per group: 0
Inode size: 0
Inodes: 4294967295
Label:
Done.
Old 06-09-2019, 15:56   #87 (permalink)
Member: 2453200
Thanks Meter: 102
Always Use Letest Version EasyJtag_Release_v3.6.1.2.exe
try With New Version
or Do Feature Wipe userdata Without Risk
Old 06-10-2019, 15:20   #88 (permalink)
Member: 2554807
Thanks Meter: 612
yes i try still hang to logo
[QUOTE=Resident_Evil;13687448]Always Use Letest Version EasyJtag_Release_v3.6.1.2.exe
or Do Feature Wipe userdata Without Risk[/QUOTE
yes bro i try still hang to logo
Old 06-10-2019, 16:28   #89 (permalink)
meeza_84's Avatar
Member: 279362
Sonork: 100.1594141
Thanks Meter: 500
bro if you have backup by vendor just write your problem will be solved
The Following User Says Thank You to meeza_84 For This Useful Post:
Old 06-12-2019, 13:40   #90 (permalink)
akash48's Avatar
Member: 1588653
Sonork: imran_Gill
Thanks Meter: 83
write user data file only by easy jtag plus exe & again wipe user data phone 100% ok
The Following User Says Thank You to akash48 For This Useful Post:
Page generated in 0.32557 seconds with 9 queries
