07-12-2019, 11:01 | #142 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Sydney
Member: 153695 Status: Offline Sonork: srkhan Thanks Meter: 788 | Oppo A3s Reset error Z3X EasyJtag Software ver. 3.6.1.9 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 060xxxxxxxxxx, ,FW Ver.: 01.63 CMD Pullup Level:1969 mV CMD Active Level:3093 mV Box IO Level:3300 mV CLK Rate:14000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D4206B2B996E7B57A eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 11/2018 Rev.0x6 eMMC NAME: QE63MB , S/N: 2998507239 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB , 0x1D1F000 pages , 0x3A3E00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is not yet programmed (clear) or RPMB Authentication key not yet programmed EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Writing Recovery Command to MISC (35) mmc_write_blocks(0x2FB00000 , 1000 ), Failed: CMD Timeout Error Done. |
07-13-2019, 02:40 | #144 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Riyadh (KSA)
Member: 452214 Status: Offline Sonork: No warranty Thanks Meter: 394 | OPPO A3s & A7 PASSWORD & FRP done EASY OPPO MODELS A3s CPH1803 A3s CPH1853 A7 CPH1903 https://a.imge.to/2019/07/13/qYYir.jpg https://a.imge.to/2019/07/13/qYOMt.jpg https://a.imge.to/2019/07/13/qYCG0.jpg https://a.imge.to/2019/07/13/qYxlx.jpg https://a.imge.to/2019/07/13/qYb2Z.jpg https://a.imge.to/2019/07/13/qY7t1.jpg https://a.imge.to/2019/07/13/qYoUG.jpg https://a.imge.to/2019/07/13/qY9mq.jpg https://a.imge.to/2019/07/13/qYYir.jpg Last edited by boy_muslim; 07-13-2019 at 02:47. |
The Following 3 Users Say Thank You to boy_muslim For This Useful Post: |
07-13-2019, 09:35 | #148 (permalink) |
No Life Poster Join Date: Feb 2010 Location: india
Member: 1246696 Status: Offline Sonork: 100.1681950 Thanks Meter: 650 | oppo a3s oppo reset done Found 2 serial devices COM1 ACPI\VEN_PNP&DEV_0501 Communications Port (COM1) COM5 USB\VID_0325&PID_0032&REV_0100&MI_00 USB Serial Device (COM5) Selected pinout: EasyJTAG GEN1 ISP Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.6.1.9 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 16160C0455030F93, ,FW Ver.: 01.63 CMD Pullup Level:1980 mV CMD Active Level:2330 mV Box IO Level:2800 mV CLK Rate:14000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D42035C28D80845CC eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 04/2018 Rev.0x3 eMMC NAME: QE63MB , S/N: 1546180616 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 65702 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: QE63MB_1546180616_20190713_1358.extcsd Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 1D1F000 sectors 14.6 GiB Soft (Partitioned) Disk/Image size: 1D1EFBC sectors 14.6 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,30535646 Partition info successfully found ------ Detected 65 partitions ------ P0 (OPPODYCNVBK) [0x5000 0xa00000] Size: 10.0MB P1 (OPPOSTANVBK) [0xa05000 0xa00000] Size: 10.0MB P2 (MODEMST1) [0x1405000 0x180000] Size: 1.500MB P3 (MODEMST2) [0x1585000 0x180000] Size: 1.500MB P4 (PERSIST) [0x1705000 0x2000000] Size: 32.0MB P5 (OPPORESERVE1) [0x3705000 0x800000] Size: 8.0MB P6 (OPPORESERVE2) [0x3f05000 0x4000000] Size: 64.0MB P7 (RESERVE_EXP1) [0x7f05000 0x200000] Size: 2.0MB P8 (RESERVE_EXP2) [0x8105000 0x200000] Size: 2.0MB P9 (FSC) [0x8305000 0x400] Size: 1.0KB P10 (SSD) [0x8306000 0x2000] Size: 8.0KB P11 (SBL1) [0x8308000 0x80000] Size: 512.0KB P12 (RPM) [0x8388000 0x80000] Size: 512.0KB P13 (TZ) [0x8408000 0x200000] Size: 2.0MB P14 (DEVCFG) [0x8608000 0x40000] Size: 256.0KB P15 (SBL1BAK) [0x8648000 0x80000] Size: 512.0KB P16 (RPMBAK) [0x86c8000 0x80000] Size: 512.0KB P17 (TZBAK) [0x8748000 0x200000] Size: 2.0MB P18 (DEVCFGBAK) [0x8948000 0x40000] Size: 256.0KB P19 (DSP) [0x8988000 0x1000000] Size: 16.0MB P20 (DDR) [0xa000000 0x8000] Size: 32.0KB P21 (FSG) [0xa008000 0x180000] Size: 1.500MB P22 (SEC) [0xa188000 0x4000] Size: 16.0KB P23 (ABOOT) [0xa18c000 0x100000] Size: 1.0MB P24 (ABOOTBAK) [0xa28c000 0x100000] Size: 1.0MB P25 (MODEM) [0xa38c000 0x8000000] Size: 128.0MB P26 (DTBO) [0x1238c000 0x800000] Size: 8.0MB P27 (VBMETA) [0x12b8c000 0x10000] Size: 64.0KB P28 (BOOT) [0x12b9c000 0x4000000] Size: 64.0MB P29 (RECOVERY) [0x16b9c000 0x4000000] Size: 64.0MB P30 (DEVINFO) [0x1ab9c000 0x100000] Size: 1.0MB P31 (SPLASH) [0x1b000000 0xb00000] Size: 11.0MB P32 (LOGO) [0x1bb00000 0x2000000] Size: 32.0MB P33 (DRIVER) [0x1db00000 0x2000000] Size: 32.0MB P34 (CACHE) [0x1fb00000 0x10000000] Size: 256.0MB P35 (MISC) [0x2fb00000 0x100000] Size: 1.0MB P36 (KEYSTORE) [0x2fc00000 0x80000] Size: 512.0KB P37 (CONFIG) [0x2fc80000 0x8000] Size: 32.0KB P38 (OEM) [0x2fc88000 0x100000] Size: 1.0MB P39 (LIMITS) [0x30000000 0x8000] Size: 32.0KB P40 (MOTA) [0x30800000 0x80000] Size: 512.0KB P41 (DIP) [0x30880000 0x100000] Size: 1.0MB P42 (MDTP) [0x30980000 0x2000000] Size: 32.0MB P43 (SYSCFG) [0x32980000 0x80000] Size: 512.0KB P44 (MCFG) [0x32a00000 0x400000] Size: 4.0MB P45 (LKSECAPP) [0x33000000 0x20000] Size: 128.0KB P46 (CMNLIB) [0x33020000 0x100000] Size: 1.0MB P47 (CMNLIB64) [0x33120000 0x100000] Size: 1.0MB P48 (KEYMASTER) [0x33220000 0x100000] Size: 1.0MB P49 (LKSECAPPBAK) [0x33320000 0x20000] Size: 128.0KB P50 (CMNLIBBAK) [0x33340000 0x100000] Size: 1.0MB P51 (CMNLIB64BAK) [0x33440000 0x100000] Size: 1.0MB P52 (KEYMASTERBAK) [0x33540000 0x100000] Size: 1.0MB P53 (APDP) [0x33800000 0x40000] Size: 256.0KB P54 (MSADP) [0x33840000 0x40000] Size: 256.0KB P55 (DPO) [0x33880000 0x2000] Size: 8.0KB P56 (LOGDUMP) [0x33882000 0x4000000] Size: 64.0MB P57 (VM-KYSTORE) [0x37882000 0x100000] Size: 1.0MB P58 (VM-DATA) [0x37982000 0xa00000] Size: 10.0MB P59 (HYP) [0x38800000 0x800000] Size: 8.0MB P60 (VM-SYSTEM) [0x39000000 0x4000000] Size: 64.0MB P61 (VM-LINUX) [0x3d000000 0x2000000] Size: 32.0MB P62 (SYSTEM) [0x3f000000 0xd6900000] Size: 3.352GB P63 (VENDOR) [0x115900000 0x41f60000] Size: 1.30GB P64 (USERDATA) [0x158000000 0x24bdfbe00] Size: 9.184GB ------------------------------------ ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x003F000000 (3.352GB) Build ID: OPM1.171019.026 Release Base ID: 8.1.0 Architecture ABI: arm64-v8a Device manufacturer: OPPO Build Description: msm8953_64-user 8.1.0 OPM1.171019.026 eng.root.20190323.213841 release-keys --------------------------------------------- Detected USERDATA USERDATA : 0x0158000000 (9.184GB) Unable to mount USERDATA , code : 95 Done. Selected eMMC Interface Z3X EasyJtag Software ver. 3.6.1.9 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 16160C0455030F93, ,FW Ver.: 01.63 CMD Pullup Level:1990 mV CMD Active Level:2588 mV Box IO Level:2800 mV CLK Rate:14000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D42035C28D80845CC eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 04/2018 Rev.0x3 eMMC NAME: QE63MB , S/N: 1546180616 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB , 0x1D1F000 pages , 0x3A3E00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 65702 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Writing Recovery Command to MISC (35) Done. |
