06-21-2020, 23:45 | #1 (permalink) |
Freak Poster Join Date: May 2014
Member: 2194348 Status: Offline Thanks Meter: 52 | oppo a5 2020 dead after oppo reset only detected as qualcom OS ver.: Windows 10 (build 18362), 64-bit edition. Admin rights FAIL Autorun Agent ver:1.0.0.0 Crash Reporting ver:1.4.0.3 EasyJTAG SPI Plugin ver:1.1.1.11 Android ADB API ver:2.0.0.0 FTDI API ver:3.2.4.0 LibUSB API ver:1.2.6.0 Visual C++ Runtime ver:10.0.30319.1 Setting box Pinout ... Box Drivers version: 10.0.18362.1, are OK Z3X Card Serial : AA88-DB08 , ver: 22 Z3X Card Activation [JTAGPLUS] : NOT ACTIVATED Z3X Card Activation [LG] : NOT ACTIVATED Z3X Card Activation [SAMS] : NOT ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED Found 2 serial devices COM3 ???? Intel(R) Active Management Technology - SOL (COM3) COM26 USB\VID_0325&PID_0032&REV_0100&MI_00 Périphérique série USB (COM26) Selected pinout: EasyJTAG GEN1 ISP Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.6.2.0 Loading eMMC GEN1 Firmware... IO: 1850 mV Box S/N: 0800A006DD1A858D, ,FW Ver.: 01.63 CMD Pullup Level:1753 mV CMD Active Level:1815 mV Box IO Level:1850 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 90014A68433861503E0342A5AD789626 eMMC CSD : D02700328F5903FFFFFFFFEF8E400042 eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 09/2019 Rev.0x3 eMMC NAME: hC8aP> , S/N: 1118154104 eMMC NAME (HEX): 68433861503E EMMC ROM1 (Main User Data) Capacity: 59640 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 21695 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: hC8aP>_1118154104_20200621_2257.extcsd Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB Soft (Partitioned) Disk/Image size: 747BFBC sectors 58.2 GiB Disk identifier (GUID): 7423EE08-EA2F-639D-8161-E529D06FB73B Logical sector size: 0x200 bytes ,First/Last usable sector: 34,122142686 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x00A0020000 (6.246GB) Short EXT fs info: Size: 6.147GB Block size: 4.0KB Inode size: 256 Inodes: 403200 Short Android info: Unable to read prop.plist , code : 2 Backup saved: BuildProp_20200621_2257.txt --------------------------------------------- Detected USERDATA USERDATA : 0x02A4020000 (47.678GB) Unable to mount USERDATA , code : 95 Userdata Superblock contents:: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................; Done. Z3X EasyJtag Software ver. 3.6.2.0 Loading eMMC GEN1 Firmware... IO: 1850 mV Box S/N: 0800A006DD1A858D, ,FW Ver.: 01.63 CMD Pullup Level:1763 mV CMD Active Level:1825 mV Box IO Level:1850 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 90014A68433861503E0342A5AD789626 eMMC CSD : D02700328F5903FFFFFFFFEF8E400042 eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 09/2019 Rev.0x3 eMMC NAME: hC8aP> , S/N: 1118154104 eMMC NAME (HEX): 68433861503E EMMC ROM1 (Main User Data) Capacity: 59640 MB , 0x747C000 pages , 0xE8F800000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 21695 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Writing Recovery Command to MISC (50) Done. |
The Following 2 Users Say Thank You to beg-one For This Useful Post: |
06-22-2020, 00:19 | #3 (permalink) |
Freak Poster Join Date: Nov 2012 Location: Imus,Cavite
Member: 1844172 Status: Offline Sonork: 100.1620999 Thanks Meter: 49 | Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: hC8aP>_1118154104_20200621_2257.extcsd Write extcsd backup wipe userdata |
The Following User Says Thank You to techscrew For This Useful Post: |
03-02-2021, 07:46 | #7 (permalink) |
Freak Poster Join Date: Feb 2004 Location: Malaysia Age: 38
Member: 55800 Status: Offline Thanks Meter: 9 | 100000% working .luckily i found this .. i would like to know this short will keep there permanent or once its on disconnect it ? Last edited by kit_kit; 03-02-2021 at 07:51. |
