05-11-2019, 09:40 | #1 (permalink) |
No Life Poster Join Date: Dec 2007 Location: tamilnadu,india
Member: 660093 Status: Offline Sonork: 100.1602344 Thanks Meter: 277 | oppo A5 CPH1809 After format hang on oppo logo here is the log: Code: EasyJtag Suite Classic ver.: 3.5.0.1 / wxWidgets 3.1.0-W-U started. OS ver.: Windows 7 (build 7601, Service Pack 1). Admin rights OK Android Explorer ver:1.0.0.13 Autorun Agent ver:1.0.0.0 Crash Reporting ver:1.4.0.3 eMMC Odin ver:1.0.0.6 QUALCOMM Direct ver:1.0.6671.7138 Android ADB API ver:2.0.0.0 FTDI API ver:3.2.4.0 LibUSB API ver:1.2.6.0 Visual C++ Runtime ver:10.0.30319.1 Setting box Pinout ... Box Drivers version: 3.0.0.0 Z3X Card Serial : AAAD-5A0B , ver: 22 Z3X Card Activation [JTAGPLUS] : ACTIVATED Z3X Card Activation [LG] : NOT ACTIVATED Z3X Card Activation [SAMS] : NOT ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED Found 5 serial devices COM1 ACPI\PNP0501 Communications Port (COM1) COM18 USB\VID_05C6&PID_9008&REV_0000 Qualcomm HS-USB QDLoader 9008 (COM18) COM5 USB\VID_1781&PID_AAAC&REV_0100&MI_00 Easy Jtag Plus Control Port (COM5) COM69 root\rimports RIM Virtual Serial Port v2 (COM69) COM70 root\rimports RIM Virtual Serial Port v2 (COM70) Selected pinout: GEN2 High Speed Pinout Change EasyJTAG Pinout OK Setting box Pinout ... Selected pinout: GEN2 ISP Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.5.0.1 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: ACE6B20973890DCB, ,FW Ver.: 02.38 CMD Pullup Level:2086 mV CMD Active Level:2720 mV Box IO Level:2800 mV CLK Rate:24000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 15010052483634414205AB669BC7C54B eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 12/2018 Rev.0x5 eMMC NAME: RH64AB , S/N: 2875628487 eMMC NAME (HEX): 524836344142 EMMC ROM1 (Main User Data) Capacity: 59640 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 893 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: RH64AB_2875628487_20190511_1240.extcsd Partition table scan: GPT: present Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB Soft (Partitioned) Disk/Image size: 747BFBC sectors 58.2 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 First usable sector: 34 Last usable sector: 122142686 Partition info successfully found Found Data areas (firmware parts) count is: 64 --------------------------------------------- P0 (OPPODYCNVBK) [0x5000 0xa00000] Size: 10.0MB P1 (OPPOSTANVBK) [0xa05000 0xa00000] Size: 10.0MB P2 (MODEMST1) [0x1405000 0x180000] Size: 1.500MB P3 (MODEMST2) [0x1585000 0x180000] Size: 1.500MB P4 (PERSIST) [0x1705000 0x2000000] Size: 32.0MB P5 (OPPORESERVE1) [0x3705000 0x800000] Size: 8.0MB P6 (OPPORESERVE2) [0x3f05000 0x4000000] Size: 64.0MB P7 (FSC) [0x7f05000 0x400] Size: 1.0KB P8 (SSD) [0x7f06000 0x2000] Size: 8.0KB P9 (SBL1) [0x7f08000 0x80000] Size: 512.0KB P10 (RPM) [0x7f88000 0x80000] Size: 512.0KB P11 (TZ) [0x8008000 0x200000] Size: 2.0MB P12 (DEVCFG) [0x8208000 0x40000] Size: 256.0KB P13 (SBL1BAK) [0x8248000 0x80000] Size: 512.0KB P14 (RPMBAK) [0x82c8000 0x80000] Size: 512.0KB P15 (TZBAK) [0x8348000 0x200000] Size: 2.0MB P16 (DEVCFGBAK) [0x8548000 0x40000] Size: 256.0KB P17 (DSP) [0x8588000 0x1000000] Size: 16.0MB P18 (DDR) [0x9800000 0x8000] Size: 32.0KB P19 (FSG) [0x9808000 0x400000] Size: 4.0MB P20 (SEC) [0x9c08000 0x4000] Size: 16.0KB P21 (ABOOT) [0x9c0c000 0x100000] Size: 1.0MB P22 (ABOOTBAK) [0x9d0c000 0x100000] Size: 1.0MB P23 (MODEM) [0x9e0c000 0x8000000] Size: 128.0MB P24 (DTBO) [0x11e0c000 0x800000] Size: 8.0MB P25 (VBMETA) [0x1260c000 0x10000] Size: 64.0KB P26 (BOOT) [0x1261c000 0x4000000] Size: 64.0MB P27 (RECOVERY) [0x1661c000 0x4000000] Size: 64.0MB P28 (DEVINFO) [0x1a61c000 0x100000] Size: 1.0MB P29 (SPLASH) [0x1a800000 0xb00000] Size: 11.0MB P30 (LOGO) [0x1b300000 0x2000000] Size: 32.0MB P31 (DRIVER) [0x1d300000 0x2000000] Size: 32.0MB P32 (CACHE) [0x1f300000 0x10000000] Size: 256.0MB P33 (MISC) [0x2f300000 0x100000] Size: 1.0MB P34 (KEYSTORE) [0x2f400000 0x80000] Size: 512.0KB P35 (CONFIG) [0x2f480000 0x8000] Size: 32.0KB P36 (LOG) [0x2f488000 0x4000000] Size: 64.0MB P37 (OEM) [0x33488000 0x100000] Size: 1.0MB P38 (LIMITS) [0x33800000 0x8000] Size: 32.0KB P39 (MOTA) [0x34000000 0x80000] Size: 512.0KB P40 (DIP) [0x34080000 0x100000] Size: 1.0MB P41 (MDTP) [0x34180000 0x2000000] Size: 32.0MB P42 (SYSCFG) [0x36180000 0x80000] Size: 512.0KB P43 (MCFG) [0x36200000 0x400000] Size: 4.0MB P44 (LKSECAPP) [0x36800000 0x20000] Size: 128.0KB P45 (CMNLIB) [0x36820000 0x100000] Size: 1.0MB P46 (CMNLIB64) [0x36920000 0x100000] Size: 1.0MB P47 (KEYMASTER) [0x36a20000 0x100000] Size: 1.0MB P48 (LKSECAPPBAK) [0x36b20000 0x20000] Size: 128.0KB P49 (CMNLIBBAK) [0x36b40000 0x100000] Size: 1.0MB P50 (CMNLIB64BAK) [0x36c40000 0x100000] Size: 1.0MB P51 (KEYMASTERBAK) [0x36d40000 0x100000] Size: 1.0MB P52 (APDP) [0x37000000 0x40000] Size: 256.0KB P53 (MSADP) [0x37040000 0x40000] Size: 256.0KB P54 (DPO) [0x37080000 0x2000] Size: 8.0KB P55 (LOGDUMP) [0x37082000 0x4000000] Size: 64.0MB P56 (VM-KYSTORE) [0x3b082000 0x100000] Size: 1.0MB P57 (VM-DATA) [0x3b182000 0xa00000] Size: 10.0MB P58 (HYP) [0x3c000000 0x800000] Size: 8.0MB P59 (VM-SYSTEM) [0x3c800000 0x4000000] Size: 64.0MB P60 (VM-LINUX) [0x40800000 0x2000000] Size: 32.0MB P61 (SYSTEM) [0x42800000 0xd6900000] Size: 3.352GB P62 (VENDOR) [0x119100000 0x41f60000] Size: 1.30GB P63 (USERDATA) [0x15b800000 0xd33ffbe00] Size: 52.811GB ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0042800000 (3.352GB) Build ID: OPM1.171019.026 Release Base ID: 8.1.0 Architecture ABI: arm64-v8a Device manufacturer: OPPO Build Description: S88051AA1-user 8.1.0 OPM1.171019.026 eng.root.20190315.232714 release-keys --------------------------------------------- Detected USERDATA USERDATA : 0x015B800000 (52.811GB) Unable to mount USERDATA , code : 95 Done. Selected eMMC Interface Checking security ... Z3X EasyJtag Software ver. 3.5.0.1 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: ACE6B20973890DCB, ,FW Ver.: 02.38 CMD Pullup Level:2088 mV CMD Active Level:2719 mV Box IO Level:2800 mV CLK Rate:24000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 15010052483634414205AB669BC7C54B eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 12/2018 Rev.0x5 eMMC NAME: RH64AB , S/N: 2875628487 eMMC NAME (HEX): 524836344142 EMMC ROM1 (Main User Data) Capacity: 59640 MB , 0x747C000 pages , 0xE8F800000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 893 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Partition table scan: GPT: present Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB Soft (Partitioned) Disk/Image size: 747BFBC sectors 58.2 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 First usable sector: 34 Last usable sector: 122142686 Partition info successfully found ------ Android information ------ Detected LINUX(Android) CACHE : 0x001F300000 (256.0MB) Read EXT fs info Read EXT fs info Created filesystem with parameters: Size: 268435456 Block size: 4096 Blocks per group: 32768 Inodes per group: 8192 Inode size: 256 Inodes: 16384 Label: Formatting EXT fs... Returned 28... Read EXT fs info NEW Created filesystem with parameters: Size: 268435456 Block size: 1024 Blocks per group: 32768 Inodes per group: 2048 Inode size: 256 Inodes: 16384 Label: Done. Detected LINUX(Android) USERDATA : 0x015B800000 (52.811GB) Read EXT fs info Read EXT fs info Created filesystem with parameters: Size: 268435456 Block size: 1024 Blocks per group: 32768 Inodes per group: 2048 Inode size: 256 Inodes: 16384 Label: Formatting EXT fs... Returned 28... Read EXT fs info NEW Created filesystem with parameters: Size: 268435456 Block size: 1024 Blocks per group: 32768 Inodes per group: 2048 Inode size: 256 Inodes: 16384 Label: Done. --------------------------------------------- Done. Checking security ... Running:Format FRP Partition... Z3X EasyJtag Software ver. 3.5.0.1 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: ACE6B20973890DCB, ,FW Ver.: 02.38 CMD Pullup Level:2086 mV CMD Active Level:2719 mV Box IO Level:2800 mV CLK Rate:24000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 15010052483634414205AB669BC7C54B eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 12/2018 Rev.0x5 eMMC NAME: RH64AB , S/N: 2875628487 eMMC NAME (HEX): 524836344142 EMMC ROM1 (Main User Data) Capacity: 59640 MB , 0x747C000 pages , 0xE8F800000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 893 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Partition table scan: GPT: present Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB Soft (Partitioned) Disk/Image size: 747BFBC sectors 58.2 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 First usable sector: 34 Last usable sector: 122142686 Partition info successfully found Formatting FRP... Detected LINUX(Android) CACHE : 0x001F300000 (256.0MB) , formatting... Detected LINUX(Android) CONFIG : 0x002F480000 (32.0KB) formatting... Detected LINUX(Android) USERDATA : 0x015B800000 (52.811GB) , formatting... Done. Done. |
05-21-2019, 10:59 | #2 (permalink) |
Insane Poster Join Date: May 2016 Location: berhampur, odisha ,india Age: 33
Member: 2571396 Status: Offline Thanks Meter: 51 | dont format userdata just flash userdata , dont format userdata just flash userdata , bcz when u format set gone hang on logo , always try userdata flash dont format ,, aetool emmc provide ,,format userdata ,,, when u format they ware flashing userdata , i think its batter ,, nice job for aetool |
05-23-2019, 11:03 | #3 (permalink) | |
No Life Poster Join Date: May 2006 Location: Gojra
Member: 279362 Status: Offline Sonork: 100.1594141 Thanks Meter: 500 | Quote:
10-31-2019, 11:31 | #8 (permalink) |
Crazy Poster Join Date: Jul 2009 Location: bangladesh naogaon Age: 43
Member: 1071534 Status: Offline Thanks Meter: 9 | oppo a5 pin pascode frp after unlock easy jtag plus phone hang on logo. oppo a5 pin & frp unlock . by easy jtag plus ... unlock dun , but phone hang on logo. 2nd i try recovery mode and wipe user data.. thanks allah' phone 100% run.ok |
The Following User Says Thank You to shamimnaogaon For This Useful Post: |
