Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 06-25-2020, 08:27   #1 (permalink)
-=P.F.U=-'s Avatar
Member: 2825953
Thanks Meter: 128
Oppo A5 PBAM00 Screen Lock & FRP Lock Has been Removed by Easy Jtag
EasyJtag Suite Classic ver.: 3.6.2.3 / wxWidgets 3.1.3-W-U started.
OS ver.: Windows 7 (build 7601, Service Pack 1). Admin rights OK
Autorun Agent ver:1.0.0.0
Crash Reporting ver:1.4.0.3
EasyJTAG SPI Plugin ver:1.1.1.11
Android ADB API ver:2.0.0.0
FTDI API ver:3.2.4.0
LibUSB API ver:1.2.6.0
Visual C++ Runtime ver:10.0.30319.1
Setting box Pinout ...
Box Drivers version: 3.0.0.0
Z3X Card Serial : AA27-78BA , ver: 22
Z3X Card Activation [JTAGPLUS] : ACTIVATED
Z3X Card Activation [LG] : NOT ACTIVATED
Z3X Card Activation [SAMS] : NOT ACTIVATED
Z3X Card Activation [JTAG] : ACTIVATED
Found 2 serial devices
COM7 USB\VID_05C6&PID_9008&REV_0000 Qualcomm HS-USB QDLoader 9008 (COM7)
COM32 USB\VID_1781&PID_AAAC&REV_0100&MI_00 Easy Jtag Plus Control Port (COM32)
Selected pinout: GEN2 ISP Pinout
Change EasyJTAG Pinout OK
Z3X EasyJtag Software ver. 3.6.2.3
Loading eMMC GEN2 Firmware... IO: 2800 mV
Box S/N: F6F272D292237F2E, ,FW Ver.: 02.50
CMD Pullup Level:2100 mV
CMD Active Level:2736 mV
Box IO Level:2800 mV
CLK Rate:1000 kHz
Bus Width:1bit,SDR
HiPower mode is off!
---------- eMMC Device Information ----------
eMMC CID : 150100475036424D420196E49BE416CF
eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D
eMMC Manufacturer ID: 0015 , OEM ID: 0100
eMMC Date: 01/2019 Rev.0x1
eMMC NAME: GP6BMB , S/N: 2531564516
eMMC NAME (HEX): 475036424D42
EMMC ROM1 (Main User Data) Capacity: 59640 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB
EMMC RPMB is programmed and written 182521 times
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area)
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: GP6BMB_2531564516_20200622_2246.extcsd
Found valid GPT with protective MBR; using GPT.
Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB
Soft (Partitioned) Disk/Image size: 747BFBC sectors 58.2 GiB
Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20
Logical sector size: 0x200 bytes ,First/Last usable sector: 34,122142686
Partition info successfully found
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x003E800000 (3.750GB)
Short EXT fs info:
Block size: 4.0KB
Inode size: 256
Inodes: 245760
Short Android info:
Build ID: OPM1.171019.026
Release Base ID: 8.1.0
Security Path: 2020-04-05
Architecture ABI: arm64-v8a
Device manufacturer: OPPO
Build Description: msm8953_64-user 8.1.0 OPM1.171019.026 eng.root.20200407.230017 release-keys
Backup saved: BuildProp_20200622_2246.txt
Detected USERDATA USERDATA : 0x0186800000 (52.139GB)
Unable to mount USERDATA , code : 95
Userdata Superblock contents::
A7B6B88D 0826CFC4 AD915A06 909821B0 E19A4AE6 15F21D2B AA3782F7 68B81DEC ..&*Z...!J..+7h.;
BE2A6467 D3DF8BD0 B3FB2F65 088F2C5F 50AEBDB0 BFC1CEDA A2764B75 BC75F44E *dgߋг/e..,_PڢvKuuN;
EC970958 0390D9DA 8F2FBB71 AD7A7319 767DB379 C8BA16A8 E6C9A00B 294947C3 X.../q*zs.v}yȺ.*.)IG;
9D330392 0C5881BD 23760D10 C3CA45FD F33EC1B0 D392A1F7 3289A638 9CC01430 .3..X.#v..E>Ӓ28.0;
BACF8BA0 DD8F5DA2 252A307E A2190CAB 4A1981FE 72A7053E C9D18462 30C9047E ϋ*.]%*0~..J..r.>фb0.~;
A5172F6D 58489A1F 6678788A 55D83A2C B5281DB0 1B308AE6 CA29CC01 56E1B2EE ./mXH.fxxU:,(..0).V;
14FBD0A1 E6E2FF04 CAD25D60 6482BE33 46EEE415 96688B11 1C1F6C45 867F4847 .С.]`d3F.h...lE.HG;
E09386CB F0E35F70 958F79C8 3532B4ED B7747926 06541587 443450C6 8A0137A1 _p.y52ty&.T.D4PƊ.7;
Done.
Checking security ...
CMD Pullup Level:2102 mV
CMD Active Level:2738 mV
CLK Rate:1000 kHz
Bus Width:1bit,SDR
EMMC ROM1 (Main User Data) Capacity: 59640 MB , 0x747C000 pages , 0xE8F800000 bytes
Writing Recovery Command to MISC (33)
Done.
Running:Format FRP Partition...
CMD Pullup Level:2099 mV
CLK Rate:1000 kHz
Bus Width:1bit,SDR
Formatting FRP...
Detected LINUX(Android) CACHE : 0x001F300000 (256.0MB) , formatting...
Done.
Detected LINUX(Android) CONFIG : 0x002F480000 (32.0KB) formatting...
Done.
Detected LINUX(Android) USERDATA : 0x0186800000 (52.139GB) , formatting...
Done.
Done.
Done.
Page generated in 0.23020 seconds with 7 queries
