Old 11-01-2021, 10:26   #1 (permalink)
ChandruChiyyan's Avatar
Member: 660093
Sonork: 100.1602344
Thanks Meter: 277
Unhappy Oppo A53 After Reset Oppo Qualcomm port only
I tryed oppo a53 phone lock via chip off method after reset oppo qualcomm port only detected not powerd on phone (in that Reset oppo option im getting some lot of ok ok ok ok text so i feel its not normal then i tryed wipe userdata option its' allso came failed again i tryed via EFM rest oppo option its shows done then i put ufs ic to board and checked it's shows only qualcomm port only after that i tryed to write firmware too no use it's there anway to recover this problem ? i checked hardware side it's everything perfect so problem is software side thank's .
EasyJtag Suite Classic ver.: 3.7.0.24 / wxWidgets 3.1.3-W-U started.
OS ver.: Windows 7 (build 7601, Service Pack 1), 64-bit edition. Admin rights FAIL
Autorun Agent ver:1.0.0.0
Crash Reporting ver:1.4.0.3
EasyJTAG SPI Plugin ver:1.1.1.13
Android ADB API ver:2.0.0.0
FTDI API ver:3.2.4.0
LibUSB API ver:1.2.6.0
Visual C++ Runtime ver:10.0.30319.1
Setting box Pinout ...
Box Drivers version: 3.0.0.0
Z3X Card Serial : AA47-2A8F , ver: 22
Z3X Card Activation [JTAGPLUS] : ACTIVATED
Z3X Card Activation [LG] : NOT ACTIVATED
Z3X Card Activation [SAMS] : NOT ACTIVATED
Z3X Card Activation [JTAG] : ACTIVATED
For more information press F1 to open local help or visit our wiki
Found 5 serial devices
COM16 USB\VID_1781&PID_AAAC&REV_0100&MI_00 Easy Jtag Plus Control Port (COM16)
COM1 ACPI\PNP0501 Nuvoton Communications Port (COM1)
COM30 root\rimports RIM Virtual Serial Port v2 (COM30)
COM31 root\rimports RIM Virtual Serial Port v2 (COM31)
COM7 FTDIBUS\COMPORT&VID_0403&PID_6001 USB Serial Port (COM7)
Selected pinout: GEN2 ISP Pinout
Change EasyJTAG Pinout OK
Z3X EasyJtag Software ver. 3.7.0.24
UFS Socket Info.
Serial: 012336CDFC61C8D9EE
Description: EasyJTAG UFS Socket BGA-254 by EasyJTAG 30.01.21
Identify UFS Chip.
UFS Chip Voltage: Low
VCC: 3304mV
VCCQ2: 1901mV
Chip Info:
Manufacturer: SKhynix
ProductName: H9HQ16AECMMDAR
SerialNumber: 0x05655510C3A3
OemID: 01AD
Firmware Version: A.1.1.0
UFS Version: 2.1
Maximum Number of LUs: 32
Number of LUs found: 6
LUN 0:
Block size: 0x1000
Size: 0x1D27000000 / 116,624,000,000B / 116GB
LUN 1 (Boot A):
Block size: 0x1000
Size: 0x800000 / 0,008,000,000B / 8MB
LUN 2 (Boot B):
Block size: 0x1000
LUN 3:
Block size: 0x1000
Size: 0x2000000 / 0,032,000,000B / 32MB
LUN 4:
Block size: 0x1000
Size: 0x84800000 / 2,072,000,000B / 2GB
LUN 5:
Block size: 0x1000
Size: 0x1C000000 / 0,448,000,000B / 448MB
Number of W-LUs found: 1
W-LUN 0xC4 (RPMB):
Block size: 0x100
Size: 0x1000000 / 0,016,000,000B / 16MB
Full size: 0x1DCC800000 / 119,200,000,000B / 119GB
RPMB:
Counter: 18277
Health:
Device life time method A: 0x01 (0%-10% device life time used)
Device life time method B: 0x01 (0%-10% device life time used)
Pre End of Life: 0x01 (Used less then 80% of reserved blocks)
Checking LU0 for partitioning
LUN0 Have 12 partitions
LUN1 Have 2 partitions
LUN2 Have 0 partitions
LUN3 Have 5 partitions
LUN4 Have 43 partitions
LUN5 Have 13 partitions
------ Detected 75 partitions ------
LUN0 (SSD) [0x6000 0x2000] Size: 8.0KB
LUN0 (PERSIST) [0x8000 0x2000000] Size: 32.0MB
LUN0 (MISC) [0x2008000 0x100000] Size: 1.0MB
LUN0 (KEYSTORE) [0x2108000 0x80000] Size: 512.0KB
LUN0 (FRP) [0x2188000 0x80000] Size: 512.0KB
LUN0 (SUPER) [0x2208000 0x200800000] Size: 8.7GB
subpartition (SUPER_metadata) [0x2208000 0x4000] Size: 16.0KB
subpartition (system) [0x2308000 0x123aa4000] Size: 4.556GB
subpartition (product) [0x125e08000 0x4d763000] Size: 1.209GB
subpartition (vendor) [0x173608000 0x42066000] Size: 1.31GB
subpartition (engineering) [0x1b5708000 0x55000] Size: 340.0KB
subpartition (preload_common) [0x1b5808000 0x55000] Size: 340.0KB
subpartition (oppo_product) [0x1b5908000 0xe9ff000] Size: 233.996MB
subpartition (version.20207) [0x1c4308000 0x112000] Size: 1.70MB
subpartition (version.20208) [0x1c4508000 0x112000] Size: 1.70MB
subpartition (version.20221) [0x1c4708000 0x113000] Size: 1.74MB
subpartition (version.20222) [0x1c4908000 0x112000] Size: 1.70MB
subpartition (version.20223) [0x1c4b08000 0x109000] Size: 1.35MB
subpartition (version.20224) [0x1c4d08000 0x112000] Size: 1.70MB
subpartition (version.20225) [0x1c4f08000 0x100000] Size: 1.0MB
subpartition (version.20226) [0x1c5008000 0x100000] Size: 1.0MB
subpartition (version.20227) [0x1c5108000 0x100000] Size: 1.0MB
subpartition (version.20228) [0x1c5208000 0x100000] Size: 1.0MB
subpartition (version.20229) [0x1c5308000 0x100000] Size: 1.0MB
LUN0 (CACHE) [0x202a08000 0x1c000000] Size: 448.0MB
LUN0 (RECOVERY) [0x21ea08000 0x6000000] Size: 96.0MB
LUN0 (VBMETA_SYSTEM) [0x224a08000 0x10000] Size: 64.0KB
LUN0 (VBMETA_VENDOR) [0x224a18000 0x10000] Size: 64.0KB
LUN0 (METADATA) [0x224a28000 0x1000000] Size: 16.0MB
LUN0 (USERDATA) [0x225a28000 0x1b015d3000] Size: 108.20GB
LUN1 (XBL) [0x6000 0x600000] Size: 6.0MB
LUN1 (XBL_CONFIG) [0x606000 0x80000] Size: 512.0KB
LUN3 (ALIGN_TO_128K_1) [0x6000 0x1a000] Size: 104.0KB
LUN3 (CDT) [0x20000 0x20000] Size: 128.0KB
LUN3 (DDR) [0x40000 0x200000] Size: 2.0MB
LUN3 (ENGINEERING_CDT) [0x240000 0x100000] Size: 1.0MB
LUN3 (OCDT) [0x340000 0x20000] Size: 128.0KB
LUN4 (RPM) [0x6000 0x80000] Size: 512.0KB
LUN4 (TZ) [0x86000 0x400000] Size: 4.0MB
LUN4 (HYP) [0x486000 0x800000] Size: 8.0MB
LUN4 (MODEM) [0xc86000 0xc300000] Size: 195.0MB
LUN4 (BLUETOOTH) [0xcf86000 0x100000] Size: 1.0MB
LUN4 (MDTPSECAPP) [0xd086000 0x400000] Size: 4.0MB
LUN4 (MDTP) [0xd486000 0x2000000] Size: 32.0MB
LUN4 (ABL) [0xf486000 0x100000] Size: 1.0MB
LUN4 (DSP) [0xf586000 0x4000000] Size: 64.0MB
LUN4 (KEYMASTER) [0x13586000 0x80000] Size: 512.0KB
LUN4 (BOOT) [0x13606000 0x6000000] Size: 96.0MB
LUN4 (CMNLIB) [0x19606000 0x80000] Size: 512.0KB
LUN4 (CMNLIB64) [0x19686000 0x80000] Size: 512.0KB
LUN4 (DEVCFG) [0x19706000 0x20000] Size: 128.0KB
LUN4 (QUPFW) [0x19726000 0x14000] Size: 80.0KB
LUN4 (VBMETA) [0x1973a000 0x10000] Size: 64.0KB
LUN4 (DTBO) [0x1974a000 0x1800000] Size: 24.0MB
LUN4 (IMAGEFV) [0x1af4a000 0x400000] Size: 4.0MB
LUN4 (UEFISECAPP) [0x1b34a000 0x200000] Size: 2.0MB
LUN4 (FEATENABLER) [0x1b54a000 0x20000] Size: 128.0KB
LUN4 (DEVINFO) [0x1b56a000 0x1000] Size: 4.0KB
LUN4 (DIP) [0x1b56b000 0x100000] Size: 1.0MB
LUN4 (APDP) [0x1b66b000 0x40000] Size: 256.0KB
LUN4 (APDP_FULL) [0x1b6ab000 0x40000] Size: 256.0KB
LUN4 (SPUNVM) [0x1b6eb000 0x2000000] Size: 32.0MB
LUN4 (SPLASH) [0x1d6eb000 0x20a4000] Size: 32.640MB
LUN4 (LIMITS) [0x1f78f000 0x1000] Size: 4.0KB
LUN4 (TOOLSFV) [0x1f790000 0x100000] Size: 1.0MB
LUN4 (LOGFS) [0x1f890000 0x800000] Size: 8.0MB
LUN4 (CATELOADER) [0x20090000 0x200000] Size: 2.0MB
LUN4 (RAWDUMP) [0x20290000 0x8000000] Size: 128.0MB
LUN4 (LOGDUMP) [0x28290000 0x4000000] Size: 64.0MB
LUN4 (STORSEC) [0x2c290000 0x20000] Size: 128.0KB
LUN4 (MULTIIMGOEM) [0x2c2b0000 0x8000] Size: 32.0KB
LUN4 (MULTIIMGQTI) [0x2c2b8000 0x8000] Size: 32.0KB
LUN4 (UEFIVARSTORE) [0x2c2c0000 0x80000] Size: 512.0KB
LUN4 (SECDATA) [0x2c340000 0x7000] Size: 28.0KB
LUN4 (CATEFV) [0x2c347000 0x80000] Size: 512.0KB
LUN4 (CATECONTENTFV) [0x2c3c7000 0x100000] Size: 1.0MB
LUN4 (OPPO_SEC) [0x2c4c7000 0xa00000] Size: 10.0MB
LUN4 (CUSTOM) [0x2cec7000 0x10000000] Size: 256.0MB
LUN4 (ODM) [0x3cec7000 0x10000000] Size: 256.0MB
LUN4 (PRELOAD) [0x4cec7000 0x30000000] Size: 768.0MB
LUN5 (ALIGN_TO_128K_2) [0x6000 0x1a000] Size: 104.0KB
LUN5 (OPPODYCNVBK) [0x20000 0x1400000] Size: 20.0MB
LUN5 (OPPOSTANVBK) [0x1420000 0x1400000] Size: 20.0MB
LUN5 (MODEMST1) [0x2820000 0x200000] Size: 2.0MB
LUN5 (MODEMST2) [0x2a20000 0x200000] Size: 2.0MB
LUN5 (FSG) [0x2c20000 0x200000] Size: 2.0MB
LUN5 (FSC) [0x2e20000 0x20000] Size: 128.0KB
LUN5 (OPPORESERVE1) [0x2e40000 0x800000] Size: 8.0MB
LUN5 (OPPORESERVE2) [0x3640000 0x8000000] Size: 128.0MB
LUN5 (OPPORESERVE3) [0xb640000 0x4000000] Size: 64.0MB
LUN5 (OPPORESERVE4) [0xf640000 0x2000000] Size: 32.0MB
LUN5 (OPPORESERVE5) [0x11640000 0x4000000] Size: 64.0MB
LUN5 (DRIVER) [0x15640000 0x2000000] Size: 32.0MB
Read SYSTEM from LUN0.
------ Android information ------
Detected LINUX(Android) system : 0x0002308000 (4.556GB)
Short EXT fs info:
Block size: 4.0KB
Inode size: 256
Inodes: 6336
Short Android info:
Build ID: QKQ1.200614.002
Release Base ID: 10
Security Path: 2020-11-05
Architecture ABI: arm64-v8a
Backup saved: BuildProp_20210911_1835.txt
Read USERDATA from LUN0.
Detected USERDATA USERDATA : 0x0225A28000 (108.20GB)
Unable to mount USERDATA , code : 95
Userdata Superblock contents::
00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ................................;
F4ADBE0B 707D6809 E4ACBE0B 9F641D77 A4641D77 8554317D 707D6809 F4ADBE0B *.p}h 䬾.Ÿd.wd.w…T1}p}h *.;
00000000 BCACBE0B 51F91B77 20ADBE0B CD4D2177 A9379301 FEFFFFFF F4ACBE0B .....Q.w *.M!w7“..;
0A7AB274 E5030000 F4ADBE0B 30ADBE0B 09D3AF74 10D3AF74 DF28C7F9 707D6809 .zt...*.0*. ӯt.ӯt(p}h ;
1E405003 98A36809 51F91B77 60ADBE0B 00ADBE0B A9379301 01F91B77 CE15B074 [email protected]h Q.w`*..*.7“...w.t;
Done.
UFS Socket Info.
Identify UFS Chip.
VCC: 3265mV
VCCQ2: 1903mV
Chip Info:
OemID: 01AD
UFS Version: 2.1
LUN 0:
Block size: 0x1000
LUN 1 (Boot A):
Block size: 0x1000
LUN 2 (Boot B):
Block size: 0x1000
LUN 3:
Block size: 0x1000
LUN 4:
Block size: 0x1000
LUN 5:
Block size: 0x1000
W-LUN 0xC4 (RPMB):
Block size: 0x100
RPMB:
Counter: 18277
Health:
OK
OK
OK
Format OPPO MISC on LUN 0.
Writing Recovery Command to MISC
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
Done.
Done.
Wipe userdata :
UFS Socket Info.
Identify UFS Chip.
VCC: 3270mV
VCCQ2: 1903mV
Chip Info:
OemID: 01AD
UFS Version: 2.1
   LUN 0:
      Block size: 0x1000
   LUN 1 (Boot A):
      Block size: 0x1000
   LUN 2 (Boot B):
      Block size: 0x1000
   LUN 3:
      Block size: 0x1000
   LUN 4:
      Block size: 0x1000
   LUN 5:
      Block size: 0x1000
   W-LUN 0xC4 (RPMB):
      Block size: 0x100
RPMB:
 Counter: 18277
Health:
Format USERDATA on LUN 0.
The protective MBR's 0xEE partition is oversized! Auto-repairing.
Found valid GPT with protective MBR; using GPT.
Real (Hardware) Disk/Image size: 1D27000 sectors 116.6 GiB
Soft (Partitioned) Disk/Image size: 1D26FF4 sectors 116.6 GiB
Disk identifier (GUID): B5B5E27D-F4DA-46D8-23CF-E2AD0D6B3783
Logical sector size: 0x1000  bytes ,First/Last usable sector: 6,30568442
Partition info successfully found
------ Detected 12 partitions ------
P0 (SSD) [0x6000 0x2000] Size: 8.0KB
P1 (PERSIST) [0x8000 0x2000000] Size: 32.0MB
P2 (MISC) [0x2008000 0x100000] Size: 1.0MB
P3 (KEYSTORE) [0x2108000 0x80000] Size: 512.0KB
P4 (FRP) [0x2188000 0x80000] Size: 512.0KB
P5 (SUPER) [0x2208000 0x200800000] Size: 8.7GB
   sp (SUPER_metadata) [0x2208000 0x4000] Size: 16.0KB
   sp (system) [0x2308000 0x123aa4000] Size: 4.556GB
   sp (product) [0x125e08000 0x4d763000] Size: 1.209GB
   sp (vendor) [0x173608000 0x42066000] Size: 1.31GB
   sp (engineering) [0x1b5708000 0x55000] Size: 340.0KB
   sp (preload_common) [0x1b5808000 0x55000] Size: 340.0KB
   sp (oppo_product) [0x1b5908000 0xe9ff000] Size: 233.996MB
   sp (version.20207) [0x1c4308000 0x112000] Size: 1.70MB
   sp (version.20208) [0x1c4508000 0x112000] Size: 1.70MB
   sp (version.20221) [0x1c4708000 0x113000] Size: 1.74MB
   sp (version.20222) [0x1c4908000 0x112000] Size: 1.70MB
   sp (version.20223) [0x1c4b08000 0x109000] Size: 1.35MB
   sp (version.20224) [0x1c4d08000 0x112000] Size: 1.70MB
   sp (version.20225) [0x1c4f08000 0x100000] Size: 1.0MB
   sp (version.20226) [0x1c5008000 0x100000] Size: 1.0MB
   sp (version.20227) [0x1c5108000 0x100000] Size: 1.0MB
   sp (version.20228) [0x1c5208000 0x100000] Size: 1.0MB
   sp (version.20229) [0x1c5308000 0x100000] Size: 1.0MB
P6 (CACHE) [0x202a08000 0x1c000000] Size: 448.0MB
P7 (RECOVERY) [0x21ea08000 0x6000000] Size: 96.0MB
P8 (VBMETA_SYSTEM) [0x224a08000 0x10000] Size: 64.0KB
P9 (VBMETA_VENDOR) [0x224a18000 0x10000] Size: 64.0KB
P10 (METADATA) [0x224a28000 0x1000000] Size: 16.0MB
P11 (USERDATA) [0x225a28000 0x1b015d3000] Size: 108.20GB
Detected (Android Userdata) USERDATA : 0x0225A28000 (108.20GB)
Erasing...
Failed...
Detected (Android Cache)) CACHE : 0x0202A08000 (448.0MB)
Erasing...
Failed...
OK
Done.
EFM LOG:
Running EasyJtag UFS Mode...
UFS ISP Mode: OFF
UFS Safe Mode: ON
Init UFS Engine: 0/OK
EasyJtag Plus S/N: F3579B4B4211DD77
EasyJtag Plus Box FirmWare: 2.53.2
Box Hardware  = EasyJtag 2nd Generation
UFS: Socket Info:
 S/N: 0x012336CDFC61C8D9EE
 Desc: EasyJTAG UFS Socket BGA-254 by EasyJTAG 30.01.21
 Type: EasyJtag UFS Socket BGA-254
UFS: Voltage Info:
 Mode: LOW
 VCC : 3283 mV, VCCQ2: 1901 mV
 3v3 : 3309 mV, 1v2: 1193 mV
UFS: Memory Info:
 Connection: UNKNOWN SOCKET TYPE
 Vendor: SKhynix
 S/N: 0x05655510C3A3
 OEM ID: 01AD
 Firm Version: A.1.1.0
 UFS Version: 2.1
 Max LUNs: 32
 LUNs Cnt: 6
 W-LUNs Cnt: 1
 LUNs ReConfig: Enabled
UFS RPMB Info:
 RPMB Counter: 18277
UFS Health Info:
UFS Life Time A: 0x01 -> 0% - 10% Life Time Used
UFS Life Time B: 0x01 -> 0% - 10% Life Time Used
UFS Pre-EOL Info: 0x01 -> Used Less 80% of Reserved Blocks
UFS: LUNs Info:
 LUN 0 -> Size: 30568448 Block(s)/116.61 GB
 LUN 1 (Boot A) -> Size: 2048 Block(s)/8.00 MB
 LUN 2 (Boot B) -> Size: 2048 Block(s)/8.00 MB
 LUN 3 -> Size: 8192 Block(s)/32.00 MB
 LUN 4 -> Size: 542720 Block(s)/2.07 GB
 LUN 5 -> Size: 114688 Block(s)/448.00 MB
 W-LUN 0xC4 (RPMB) -> Size: 65536 Block(s)/16.00 MB
UFS Init OK
Scanning Data From UFS Chip. Please wait..
Scanning GUID Partition Table from LUN 0
GUID Partition Table is Found. Max Parts: 32
GPT: GPT   [000000000000 - 000000006000] Size: 24.00 KB
GPT: SSD   [000000006000 - 000000002000] Size: 8.00 KB
GPT: PERSIST   [000000008000 - 000002000000] Size: 32.00 MB
GPT: MISC   [000002008000 - 000000100000] Size: 1.00 MB
GPT: KEYSTORE   [000002108000 - 000000080000] Size: 512.00 KB
GPT: FRP   [000002188000 - 000000080000] Size: 512.00 KB
GPT: SUPER   [000002208000 - 000200800000] Size: 8.01 GB
GPT: CACHE   [000202A08000 - 00001C000000] Size: 448.00 MB
GPT: RECOVERY   [00021EA08000 - 000006000000] Size: 96.00 MB
GPT: VBMETA_SYSTEM   [000224A08000 - 000000010000] Size: 64.00 KB
GPT: VBMETA_VENDOR   [000224A18000 - 000000010000] Size: 64.00 KB
GPT: METADATA   [000224A28000 - 000001000000] Size: 16.00 MB
GPT: USERDATA   [000225A28000 - 001B015D3000] Size: 108.02 GB
GPT: BACKUP_GPT   [001D26FFB000 - 000000005000] Size: 20.00 KB
Reading Table Completed
Scanning GUID Partition Table from LUN 1
GPT: XBL   [000000006000 - 000000600000] Size: 6.00 MB
GPT: XBL_CONFIG   [000000606000 - 000000080000] Size: 512.00 KB
GPT: LAST_PARTI   [000000686000 - 000000175000] Size: 1.46 MB
GPT: BACKUP_GPT   [0000007FB000 - 000000005000] Size: 20.00 KB
Scanning GUID Partition Table from LUN 2
GPT: LAST_PARTI   [000000006000 - 0000007F5000] Size: 7.96 MB
Scanning GUID Partition Table from LUN 3
GPT: ALIGN_TO_128K_1   [000000006000 - 00000001A000] Size: 104.00 KB
GPT: CDT   [000000020000 - 000000020000] Size: 128.00 KB
GPT: DDR   [000000040000 - 000000200000] Size: 2.00 MB
GPT: ENGINEERING_CDT   [000000240000 - 000000100000] Size: 1.00 MB
GPT: OCDT   [000000340000 - 000000020000] Size: 128.00 KB
GPT: LAST_PARTI   [000000360000 - 000001C9B000] Size: 28.61 MB
GPT: BACKUP_GPT   [000001FFB000 - 000000005000] Size: 20.00 KB
Scanning GUID Partition Table from LUN 4
GUID Partition Table is Found. Max Parts: 64
GPT: RPM   [000000006000 - 000000080000] Size: 512.00 KB
GPT: TZ   [000000086000 - 000000400000] Size: 4.00 MB
GPT: HYP   [000000486000 - 000000800000] Size: 8.00 MB
GPT: MODEM   [000000C86000 - 00000C300000] Size: 195.00 MB
GPT: BLUETOOTH   [00000CF86000 - 000000100000] Size: 1.00 MB
GPT: MDTPSECAPP   [00000D086000 - 000000400000] Size: 4.00 MB
GPT: MDTP   [00000D486000 - 000002000000] Size: 32.00 MB
GPT: ABL   [00000F486000 - 000000100000] Size: 1.00 MB
GPT: DSP   [00000F586000 - 000004000000] Size: 64.00 MB
GPT: KEYMASTER   [000013586000 - 000000080000] Size: 512.00 KB
GPT: BOOT   [000013606000 - 000006000000] Size: 96.00 MB
GPT: CMNLIB   [000019606000 - 000000080000] Size: 512.00 KB
GPT: CMNLIB64   [000019686000 - 000000080000] Size: 512.00 KB
GPT: DEVCFG   [000019706000 - 000000020000] Size: 128.00 KB
GPT: QUPFW   [000019726000 - 000000014000] Size: 80.00 KB
GPT: VBMETA   [00001973A000 - 000000010000] Size: 64.00 KB
GPT: DTBO   [00001974A000 - 000001800000] Size: 24.00 MB
GPT: IMAGEFV   [00001AF4A000 - 000000400000] Size: 4.00 MB
GPT: UEFISECAPP   [00001B34A000 - 000000200000] Size: 2.00 MB
GPT: FEATENABLER   [00001B54A000 - 000000020000] Size: 128.00 KB
GPT: DEVINFO   [00001B56A000 - 000000001000] Size: 4.00 KB
GPT: DIP   [00001B56B000 - 000000100000] Size: 1.00 MB
GPT: APDP   [00001B66B000 - 000000040000] Size: 256.00 KB
GPT: APDP_FULL   [00001B6AB000 - 000000040000] Size: 256.00 KB
GPT: SPUNVM   [00001B6EB000 - 000002000000] Size: 32.00 MB
GPT: SPLASH   [00001D6EB000 - 0000020A4000] Size: 32.64 MB
GPT: LIMITS   [00001F78F000 - 000000001000] Size: 4.00 KB
GPT: TOOLSFV   [00001F790000 - 000000100000] Size: 1.00 MB
GPT: LOGFS   [00001F890000 - 000000800000] Size: 8.00 MB
GPT: CATELOADER   [000020090000 - 000000200000] Size: 2.00 MB
GPT: RAWDUMP   [000020290000 - 000008000000] Size: 128.00 MB
GPT: LOGDUMP   [000028290000 - 000004000000] Size: 64.00 MB
GPT: STORSEC   [00002C290000 - 000000020000] Size: 128.00 KB
GPT: MULTIIMGOEM   [00002C2B0000 - 000000008000] Size: 32.00 KB
GPT: MULTIIMGQTI   [00002C2B8000 - 000000008000] Size: 32.00 KB
GPT: UEFIVARSTORE   [00002C2C0000 - 000000080000] Size: 512.00 KB
GPT: SECDATA   [00002C340000 - 000000007000] Size: 28.00 KB
GPT: CATEFV   [00002C347000 - 000000080000] Size: 512.00 KB
GPT: CATECONTENTFV   [00002C3C7000 - 000000100000] Size: 1.00 MB
GPT: OPPO_SEC   [00002C4C7000 - 000000A00000] Size: 10.00 MB
GPT: CUSTOM   [00002CEC7000 - 000010000000] Size: 256.00 MB
GPT: ODM   [00003CEC7000 - 000010000000] Size: 256.00 MB
GPT: PRELOAD   [00004CEC7000 - 000030000000] Size: 768.00 MB
GPT: LAST_PARTI   [00007CEC7000 - 000007934000] Size: 121.20 MB
GPT: BACKUP_GPT   [0000847FB000 - 000000005000] Size: 20.00 KB
Scanning GUID Partition Table from LUN 5
GPT: ALIGN_TO_128K_2   [000000006000 - 00000001A000] Size: 104.00 KB
GPT: OPPODYCNVBK   [000000020000 - 000001400000] Size: 20.00 MB
GPT: OPPOSTANVBK   [000001420000 - 000001400000] Size: 20.00 MB
GPT: MODEMST1   [000002820000 - 000000200000] Size: 2.00 MB
GPT: MODEMST2   [000002A20000 - 000000200000] Size: 2.00 MB
GPT: FSG   [000002C20000 - 000000200000] Size: 2.00 MB
GPT: FSC   [000002E20000 - 000000020000] Size: 128.00 KB
GPT: OPPORESERVE1   [000002E40000 - 000000800000] Size: 8.00 MB
GPT: OPPORESERVE2   [000003640000 - 000008000000] Size: 128.00 MB
GPT: OPPORESERVE3   [00000B640000 - 000004000000] Size: 64.00 MB
GPT: OPPORESERVE4   [00000F640000 - 000002000000] Size: 32.00 MB
GPT: OPPORESERVE5   [000011640000 - 000004000000] Size: 64.00 MB
GPT: DRIVER   [000015640000 - 000002000000] Size: 32.00 MB
GPT: LAST_PARTI   [000017640000 - 0000049BB000] Size: 73.73 MB
GPT: BACKUP_GPT   [00001BFFB000 - 000000005000] Size: 20.00 KB
Reading Initial Data. Please Wait..
Partition #3 - [PERSIST] mount as [/mnt/vendor/persist] -> 32.00 MB, Type: EXT4
Partition #12 - [METADATA] mount as [/metadata] -> 16.00 MB, Type: EXT4
Partition #5 - [MODEM] mount as [/MODEM] -> 195.00 MB, Type: FAT16
Partition #6 - [BLUETOOTH] mount as [/BLUETOOTH] -> 1.00 MB, Type: FAT16
Partition #10 - [DSP] mount as [/dev_9] -> 64.00 MB, Type: EXT4
Partition #30 - [LOGFS] mount as [/LOGFS] -> 8.00 MB, Type: FAT12
Partition #42 - [CUSTOM] mount as [/my_custom] -> 256.00 MB, Type: EXT4
Partition #44 - [PRELOAD] mount as [/special_preload] -> 768.00 MB, Type: EXT4
Partition #10 - [OPPORESERVE2] mount as [/mnt/vendor/opporeserve] -> 128.00 MB, Type: EXT4
EmptyCheck:
 EMPTY -> LUN0 -> Part #2 - [SSD]
 EMPTY -> LUN0 -> Part #5 - [KEYSTORE]
 EMPTY -> LUN1 -> Part #4 - [LAST_PARTI]
 EMPTY -> LUN2 -> Part #2 - [LAST_PARTI]
 EMPTY -> LUN3 -> Part #2 - [ALIGN_TO_128K_1]
 EMPTY -> LUN3 -> Part #3 - [CDT]
 EMPTY -> LUN4 -> Part #7 - [MDTPSECAPP]
 EMPTY -> LUN4 -> Part #8 - [MDTP]
 EMPTY -> LUN4 -> Part #23 - [DIP]
 EMPTY -> LUN4 -> Part #25 - [APDP_FULL]
 EMPTY -> LUN4 -> Part #26 - [SPUNVM]
 EMPTY -> LUN4 -> Part #28 - [LIMITS]
 EMPTY -> LUN4 -> Part #29 - [TOOLSFV]
 EMPTY -> LUN4 -> Part #31 - [CATELOADER]
 EMPTY -> LUN4 -> Part #32 - [RAWDUMP]
 EMPTY -> LUN4 -> Part #33 - [LOGDUMP]
 EMPTY -> LUN4 -> Part #35 - [MULTIIMGOEM]
 EMPTY -> LUN4 -> Part #36 - [MULTIIMGQTI]
 EMPTY -> LUN4 -> Part #39 - [CATEFV]
 EMPTY -> LUN4 -> Part #40 - [CATECONTENTFV]
 EMPTY -> LUN4 -> Part #45 - [LAST_PARTI]
 EMPTY -> LUN5 -> Part #2 - [ALIGN_TO_128K_2]
 EMPTY -> LUN5 -> Part #7 - [FSG]
 EMPTY -> LUN5 -> Part #8 - [FSC]
 EMPTY -> LUN5 -> Part #11 - [OPPORESERVE3]
 EMPTY -> LUN5 -> Part #12 - [OPPORESERVE4]
 EMPTY -> LUN5 -> Part #13 - [OPPORESERVE5]
 EMPTY -> LUN5 -> Part #15 - [LAST_PARTI]
EmptyCheck: Done
Warning! Device Blocked by FRP
For Reset FRP Try to Tools Tab
Press Reset FRP Button
Partition: #6 -> LUN0 -> 'FRP'
Scanner Thread Terminated
Elapsed: 00:00:36:558
Found 92 Partition(s)..
Scan Done. Init Main Engine...
Use EasyJtag UFS Device: H9HQ16AECMMDAR
Reader Engine Initialized.. 0/OK
Source: EasyJtag Port [UFS]
Power Mode: LOW
Generation: GPT [QC/SAMS/BCM/INTEL/MTK]
Config: 1011111111101111
Operation Done: [Init Engine], Elapsed: 00:00:00:060
Universal Wipe User Data v1.0
Wiping MISC Partition..
Partition #4 is '/MISC'. Erasing..
Wipe Mode: Oppo/Realme/Vivo Factory Reset Format Data
Wipe 'MISC' Partition Done..
Wiping PARA Partition..
Partition PARA Not Found. Skip..
Done Wiping Data..
Elapsed Time: [00:00:00:210]
Operation Done: [Universal Wipe Data], Elapsed: 00:00:00:220
Write firmware:
05.05.2021 (ver 2.0.1.0)
   Add:   Vendor LG
   Add:   Mediatek Preloader Parser
   Add:   OnePlus Unpacker
   Add:   Xiaomi Custom EDL Authorization
   Add:   Xiaomi Remove Mi Account (only Qualcomm)
Operation: Connect to Z3X EasyJtagPlus
Setting Interface to EasyJtag2/UFS-Socket
Setting IO Levels to Low
Setting Frequence to 66 Mhz
Socket Information :
   Socket Mark: EasyJTAG UFS Socket BGA-254 by EasyJTAG 30.01.21
   Socket Serial: 012336CDFC61C8D9EE
   Socket Type: UFS_SOCKET_BGA_254
UFS Power Information :
   Mode: Low, VCC: 3281 mV, VCCQ2: 1903 mV
UFS Device Information :
   UFS Manufacturer: SKhynix, UFS ProductName: H9HQ16AECMMDAR
   UFS OemID: 01AD, UFS SerialNumber: 0x05655510C3A3
   Maximum Number of LUs: 32, Number of LUs found: 6, Number of WLUs found: 1, LUs Re-configure: Enabled
   RPMB Counter: 18277
   UFS LUN 0 Capacity: 119408 MB (001D27000000)
   UFS LUN 1 (Boot A) Capacity: 8 MB (000000800000)
   UFS LUN 2 (Boot B) Capacity: 8 MB (000000800000)
   UFS LUN 3 Capacity: 32 MB (000002000000)
   UFS LUN 4 Capacity: 2120 MB (000084800000)
   UFS LUN 5 Capacity: 448 MB (00001C000000)
   UFS W-LUN 0xC4 (RPMB) Capacity: 16 MB (000001000000)
Device Life Time Estimation B: 0x01   0% - 10% device life time used
Device Life Time Estimation A: 0x01   0% - 10% device life time used
Pre EOL information: 0x01   Normal (Consumed less then 80% of reserved block)
Do not turn the socket before you press "Close Session" button
Connected successfully
Operation: Scan PartitionTable from Source (Vendor: Binary Read/Write)
Scanning soft partitions from LUN 0
GPT header is found
Partition: PrimaryGPT, [000000000000 - 000000006000], Size: 000000006000 (24.00 KB), Type: GPT
Partition: ssd, [000000006000 - 000000008000], Size: 000000002000 (8.00 KB), Type: Raw
Partition: persist, [000000008000 - 000002008000], Size: 000002000000 (32.00 MB), Type: Linux (/mnt/vendor/persist)
Partition: misc, [000002008000 - 000002108000], Size: 000000100000 (1.00 MB), Type: Raw
Partition: keystore, [000002108000 - 000002188000], Size: 000000080000 (512.00 KB), Type: Blank
Partition: frp, [000002188000 - 000002208000], Size: 000000080000 (512.00 KB), Type: FRP
Partition: super, [000002208000 - 000202A08000], Size: 000200800000 (8.01 GB), Type: Super
          Partition: system, [000002308000 - 000125DAC000], Size: 000123AA4000 (4.56 GB), Type: Linux
          Partition: product, [000125F08000 - 00017366B000], Size: 00004D763000 (1.21 GB), Type: Blank
          Partition: vendor, [0001736C8000 - 0001B572E000], Size: 000042066000 (1.03 GB), Type: Raw
          Partition: engineering, [0001B5848000 - 0001B589D000], Size: 000000055000 (340.00 KB), Type: Raw
          Partition: preload_common, [0001B5908000 - 0001B595D000], Size: 000000055000 (340.00 KB), Type: Raw
          Partition: oppo_product, [0001B59C8000 - 0001C43C7000], Size: 00000E9FF000 (234.00 MB), Type: Raw
          Partition: version.20207, [0001C43C8000 - 0001C44DA000], Size: 000000112000 (1.07 MB), Type: Blank
          Partition: version.20208, [0001C4548000 - 0001C465A000], Size: 000000112000 (1.07 MB), Type: Raw
          Partition: version.20221, [0001C46C8000 - 0001C47DB000], Size: 000000113000 (1.07 MB), Type: Raw
          Partition: version.20222, [0001C4848000 - 0001C495A000], Size: 000000112000 (1.07 MB), Type: Raw
          Partition: version.20223, [0001C49C8000 - 0001C4AD1000], Size: 000000109000 (1.04 MB), Type: Blank
          Partition: version.20224, [0001C4B48000 - 0001C4C5A000], Size: 000000112000 (1.07 MB), Type: Blank
          Partition: version.20225, [0001C4CC8000 - 0001C4DC8000], Size: 000000100000 (1.00 MB), Type: Raw
          Partition: version.20226, [0001C4E48000 - 0001C4F48000], Size: 000000100000 (1.00 MB), Type: Raw
          Partition: version.20227, [0001C4FC8000 - 0001C50C8000], Size: 000000100000 (1.00 MB), Type: Blank
          Partition: version.20228, [0001C5148000 - 0001C5248000], Size: 000000100000 (1.00 MB), Type: Blank
          Partition: version.20229, [0001C52C8000 - 0001C53C8000], Size: 000000100000 (1.00 MB), Type: Raw
Partition: cache, [000202A08000 - 00021EA08000], Size: 00001C000000 (448.00 MB), Type: Raw
Partition: recovery, [00021EA08000 - 000224A08000], Size: 000006000000 (96.00 MB), Type: Boot
Partition: vbmeta_system, [000224A08000 - 000224A18000], Size: 000000010000 (64.00 KB), Type: Raw
Partition: vbmeta_vendor, [000224A18000 - 000224A28000], Size: 000000010000 (64.00 KB), Type: Raw
Partition: metadata, [000224A28000 - 000225A28000], Size: 000001000000 (16.00 MB), Type: Linux (/metadata)
Partition: userdata, [000225A28000 - 001D26FFB000], Size: 001B015D3000 (108.02 GB), Type: Raw
Partition: BackupGPT, [001D26FFB000 - 001D27000000], Size: 000000005000 (20.00 KB), Type: BackupGPT
GPT header successfully parsed
Scanning soft partitions from LUN 1 (Boot A)
GPT header is found
Partition: xbl, [000000006000 - 000000606000], Size: 000000600000 (6.00 MB), Type: Raw
Partition: xbl_config, [000000606000 - 000000686000], Size: 000000080000 (512.00 KB), Type: Raw
Partition: last_parti, [000000686000 - 0000007FB000], Size: 000000175000 (1.46 MB), Type: Blank
Partition: BackupGPT, [0000007FB000 - 000000800000], Size: 000000005000 (20.00 KB), Type: BackupGPT
Scanning soft partitions from LUN 2 (Boot B)
GPT header is found
Partition: last_parti, [000000006000 - 0000007FB000], Size: 0000007F5000 (7.96 MB), Type: Blank
Scanning soft partitions from LUN 3
GPT header is found
Partition: ALIGN_TO_128K_1, [000000006000 - 000000020000], Size: 00000001A000 (104.00 KB), Type: Blank
Partition: cdt, [000000020000 - 000000040000], Size: 000000020000 (128.00 KB), Type: Raw
Partition: ddr, [000000040000 - 000000240000], Size: 000000200000 (2.00 MB), Type: Raw
Partition: engineering_cdt, [000000240000 - 000000340000], Size: 000000100000 (1.00 MB), Type: Raw
Partition: ocdt, [000000340000 - 000000360000], Size: 000000020000 (128.00 KB), Type: Raw
Partition: last_parti, [000000360000 - 000001FFB000], Size: 000001C9B000 (28.61 MB), Type: Raw
Partition: BackupGPT, [000001FFB000 - 000002000000], Size: 000000005000 (20.00 KB), Type: BackupGPT
Scanning soft partitions from LUN 4
GPT header is found
Partition: rpm, [000000006000 - 000000086000], Size: 000000080000 (512.00 KB), Type: Raw
Partition: tz, [000000086000 - 000000486000], Size: 000000400000 (4.00 MB), Type: Raw
Partition: hyp, [000000486000 - 000000C86000], Size: 000000800000 (8.00 MB), Type: Raw
Partition: modem, [000000C86000 - 00000CF86000], Size: 00000C300000 (195.00 MB), Type: Fat16
Partition: bluetooth, [00000CF86000 - 00000D086000], Size: 000000100000 (1.00 MB), Type: Fat16
Partition: mdtpsecapp, [00000D086000 - 00000D486000], Size: 000000400000 (4.00 MB), Type: Blank
Partition: mdtp, [00000D486000 - 00000F486000], Size: 000002000000 (32.00 MB), Type: Blank
Partition: abl, [00000F486000 - 00000F586000], Size: 000000100000 (1.00 MB), Type: Raw
Partition: dsp, [00000F586000 - 000013586000], Size: 000004000000 (64.00 MB), Type: Linux
Partition: keymaster, [000013586000 - 000013606000], Size: 000000080000 (512.00 KB), Type: Raw
Partition: boot, [000013606000 - 000019606000], Size: 000006000000 (96.00 MB), Type: Boot
Partition: cmnlib, [000019606000 - 000019686000], Size: 000000080000 (512.00 KB), Type: Raw
Partition: cmnlib64, [000019686000 - 000019706000], Size: 000000080000 (512.00 KB), Type: Raw
Partition: devcfg, [000019706000 - 000019726000], Size: 000000020000 (128.00 KB), Type: Raw
Partition: qupfw, [000019726000 - 00001973A000], Size: 000000014000 (80.00 KB), Type: Raw
Partition: vbmeta, [00001973A000 - 00001974A000], Size: 000000010000 (64.00 KB), Type: Raw
Partition: dtbo, [00001974A000 - 00001AF4A000], Size: 000001800000 (24.00 MB), Type: Raw
Partition: imagefv, [00001AF4A000 - 00001B34A000], Size: 000000400000 (4.00 MB), Type: Raw
Partition: uefisecapp, [00001B34A000 - 00001B54A000], Size: 000000200000 (2.00 MB), Type: Raw
Partition: featenabler, [00001B54A000 - 00001B56A000], Size: 000000020000 (128.00 KB), Type: Raw
Partition: devinfo, [00001B56A000 - 00001B56B000], Size: 000000001000 (4.00 KB), Type: Raw
Partition: dip, [00001B56B000 - 00001B66B000], Size: 000000100000 (1.00 MB), Type: Blank
Partition: apdp, [00001B66B000 - 00001B6AB000], Size: 000000040000 (256.00 KB), Type: Raw
Partition: apdp_full, [00001B6AB000 - 00001B6EB000], Size: 000000040000 (256.00 KB), Type: Blank
Partition: spunvm, [00001B6EB000 - 00001D6EB000], Size: 000002000000 (32.00 MB), Type: Blank
Partition: splash, [00001D6EB000 - 00001F78F000], Size: 0000020A4000 (32.64 MB), Type: Raw
Partition: limits, [00001F78F000 - 00001F790000], Size: 000000001000 (4.00 KB), Type: Blank
Partition: toolsfv, [00001F790000 - 00001F890000], Size: 000000100000 (1.00 MB), Type: Blank
Partition: logfs, [00001F890000 - 000020090000], Size: 000000800000 (8.00 MB), Type: Fat12
Partition: cateloader, [000020090000 - 000020290000], Size: 000000200000 (2.00 MB), Type: Blank
Partition: rawdump, [000020290000 - 000028290000], Size: 000008000000 (128.00 MB), Type: Blank
Partition: logdump, [000028290000 - 00002C290000], Size: 000004000000 (64.00 MB), Type: Blank
Partition: storsec, [00002C290000 - 00002C2B0000], Size: 000000020000 (128.00 KB), Type: Raw
Partition: multiimgoem, [00002C2B0000 - 00002C2B8000], Size: 000000008000 (32.00 KB), Type: Raw
Partition: multiimgqti, [00002C2B8000 - 00002C2C0000], Size: 000000008000 (32.00 KB), Type: Raw
Partition: uefivarstore, [00002C2C0000 - 00002C340000], Size: 000000080000 (512.00 KB), Type: Raw
Partition: secdata, [00002C340000 - 00002C347000], Size: 000000007000 (28.00 KB), Type: Raw
Partition: catefv, [00002C347000 - 00002C3C7000], Size: 000000080000 (512.00 KB), Type: Blank
Partition: catecontentfv, [00002C3C7000 - 00002C4C7000], Size: 000000100000 (1.00 MB), Type: Blank
Partition: oppo_sec, [00002C4C7000 - 00002CEC7000], Size: 000000A00000 (10.00 MB), Type: Raw
Partition: custom, [00002CEC7000 - 00003CEC7000], Size: 000010000000 (256.00 MB), Type: Linux (/my_custom)
Partition: odm, [00003CEC7000 - 00004CEC7000], Size: 000010000000 (256.00 MB), Type: Raw
Partition: preload, [00004CEC7000 - 00007CEC7000], Size: 000030000000 (768.00 MB), Type: Linux (/special_preload)
Partition: last_parti, [00007CEC7000 - 0000847FB000], Size: 000007934000 (121.20 MB), Type: Blank
Partition: BackupGPT, [0000847FB000 - 000084800000], Size: 000000005000 (20.00 KB), Type: BackupGPT
Scanning soft partitions from LUN 5
GPT header is found
Partition: ALIGN_TO_128K_2, [000000006000 - 000000020000], Size: 00000001A000 (104.00 KB), Type: Raw
Partition: oppodycnvbk, [000000020000 - 000001420000], Size: 000001400000 (20.00 MB), Type: Raw
Partition: oppostanvbk, [000001420000 - 000002820000], Size: 000001400000 (20.00 MB), Type: Raw
Partition: modemst1, [000002820000 - 000002A20000], Size: 000000200000 (2.00 MB), Type: Raw
Partition: modemst2, [000002A20000 - 000002C20000], Size: 000000200000 (2.00 MB), Type: Raw
Partition: fsg, [000002C20000 - 000002E20000], Size: 000000200000 (2.00 MB), Type: Blank
Partition: fsc, [000002E20000 - 000002E40000], Size: 000000020000 (128.00 KB), Type: Raw
Partition: opporeserve1, [000002E40000 - 000003640000], Size: 000000800000 (8.00 MB), Type: Raw
Partition: opporeserve2, [000003640000 - 00000B640000], Size: 000008000000 (128.00 MB), Type: Linux (/mnt/vendor/opporeserve)
Partition: opporeserve3, [00000B640000 - 00000F640000], Size: 000004000000 (64.00 MB), Type: Blank
Partition: opporeserve4, [00000F640000 - 000011640000], Size: 000002000000 (32.00 MB), Type: Blank
Partition: opporeserve5, [000011640000 - 000015640000], Size: 000004000000 (64.00 MB), Type: Blank
Partition: DRIVER, [000015640000 - 000017640000], Size: 000002000000 (32.00 MB), Type: Raw
Partition: last_parti, [000017640000 - 00001BFFB000], Size: 0000049BB000 (73.73 MB), Type: Blank
Partition: BackupGPT, [00001BFFB000 - 00001C000000], Size: 000000005000 (20.00 KB), Type: BackupGPT
Operation: Opening Firmware (Qualcomm)
Firmware: D:\MU\E\Android flash file\OPPO\A53 (CPH2127)\Unpack\
Rom: LUN 0, File: rawprogram0_ufs.xml
The file size for the partition "userdata" is larger than the size of the partition. Skipped
Rom: LUN 1 (Boot A), File: rawprogram1_ufs.xml
Rom: LUN 2 (Boot B), File: rawprogram2_ufs.xml
Rom: LUN 3, File: rawprogram3_ufs.xml
Rom: LUN 4, File: rawprogram4_ufs.xml
Rom: LUN 5, File: rawprogram5_ufs.xml
If the "rawprogram" files are selected incorrectly - you can select them manually
Double-click on ROM file, change the file type to "Firmware files" and select the correct rawprogram
Opening firmware completed
Operation: Writing by Vendor (Qualcomm)
Write/Erase check: Disabled
Writing: LUN 0, Partition: PrimaryGPT, Offset: 0x000000000000, Size: 0x000000006000 (24.00 KB)
Writing file: gpt_main0_ufs.bin, Offset: 0x000000000000, Size: 0x000000006000 (24.00 KB)
Done writing partition  (Write speed: 98.36 Kb/s)
Writing: LUN 0, Partition: persist, Offset: 0x000000008000, Size: 0x000002000000 (32.00 MB)
Writing file: persist.img, Offset: 0x000000000000, Size: 0x000002000000 (32.00 MB)
Done writing partition  (Write speed: 2582.29 Kb/s)
Writing: LUN 0, Partition: super, Offset: 0x000002208000, Size: 0x000200800000 (8.01 GB)
Writing file: super.img, Offset: 0x000000000000, Size: 0x000200800000 (8.01 GB)
Sparse image found v.1.0  Total chunks: 444
Done writing partition  (Write speed: 6038.34 Kb/s)
Writing: LUN 0, Partition: cache, Offset: 0x000202A08000, Size: 0x00001C000000 (448.00 MB)
Writing file: cache.img, Offset: 0x000000000000, Size: 0x00001C000000 (448.00 MB)
Sparse image found v.1.0  Total chunks: 14
Done writing partition  (Write speed: 524565.55 Kb/s)
Writing: LUN 0, Partition: recovery, Offset: 0x00021EA08000, Size: 0x000006000000 (96.00 MB)
Writing file: recovery.img, Offset: 0x000000000000, Size: 0x000006000000 (96.00 MB)
Done writing partition  (Write speed: 5317.80 Kb/s)
Writing: LUN 0, Partition: vbmeta_system, Offset: 0x000224A08000, Size: 0x000000010000 (64.00 KB)
Writing file: vbmeta_system.img, Offset: 0x000000000000, Size: 0x000000002000 (8.00 KB)
Done writing partition  (Write speed: 48.66 Kb/s)
Writing: LUN 0, Partition: vbmeta_vendor, Offset: 0x000224A18000, Size: 0x000000010000 (64.00 KB)
Writing file: vbmeta_vendor.img, Offset: 0x000000000000, Size: 0x000000001000 (4.00 KB)
Done writing partition  (Write speed: 25.91 Kb/s)
Writing: LUN 0, Partition: metadata, Offset: 0x000224A28000, Size: 0x000001000000 (16.00 MB)
Writing file: metadata.img, Offset: 0x000000000000, Size: 0x000001000000 (16.00 MB)
Done writing partition  (Write speed: 55560.32 Kb/s)
Writing: LUN 1 (Boot A), Partition: PrimaryGPT, Offset: 0x000000000000, Size: 0x000000006000 (24.00 KB)
Writing file: gpt_main1_ufs.bin, Offset: 0x000000000000, Size: 0x000000006000 (24.00 KB)
Done writing partition  (Write speed: 46.74 Kb/s)
Writing: LUN 1 (Boot A), Partition: xbl, Offset: 0x000000006000, Size: 0x000000600000 (6.00 MB)
Writing file: xbl.elf, Offset: 0x000000000000, Size: 0x00000035643D (3.34 MB)
Done writing partition  (Write speed: 1601.09 Kb/s)
Writing: LUN 1 (Boot A), Partition: xbl_config, Offset: 0x000000606000, Size: 0x000000080000 (512.00 KB)
Writing file: xbl_config.elf, Offset: 0x000000000000, Size: 0x00000000A83C (42.06 KB)
Done writing partition  (Write speed: 77.31 Kb/s)
Writing: LUN 2 (Boot B), Partition: PrimaryGPT, Offset: 0x000000000000, Size: 0x000000006000 (24.00 KB)
Writing file: gpt_main2_ufs.bin, Offset: 0x000000000000, Size: 0x000000006000 (24.00 KB)
Done writing partition  (Write speed: 91.03 Kb/s)
Writing: LUN 3, Partition: PrimaryGPT, Offset: 0x000000000000, Size: 0x000000006000 (24.00 KB)
Writing file: gpt_main3_ufs.bin, Offset: 0x000000000000, Size: 0x000000006000 (24.00 KB)
Done writing partition  (Write speed: 94.63 Kb/s)
Writing: LUN 3, Partition: engineering_cdt, Offset: 0x000000240000, Size: 0x000000100000 (1.00 MB)
Writing file: cdt_engineering_release.img, Offset: 0x000000000000, Size: 0x000000100000 (1.00 MB)
Done writing partition  (Write speed: 1754.27 Kb/s)
Writing: LUN 4, Partition: PrimaryGPT, Offset: 0x000000000000, Size: 0x000000006000 (24.00 KB)
Writing file: gpt_main4_ufs.bin, Offset: 0x000000000000, Size: 0x000000006000 (24.00 KB)
Done writing partition  (Write speed: 102.99 Kb/s)
Writing: LUN 4, Partition: rpm, Offset: 0x000000006000, Size: 0x000000080000 (512.00 KB)
Writing file: rpm.mbn, Offset: 0x000000000000, Size: 0x000000036FF0 (219.98 KB)
Done writing partition  (Write speed: 428.61 Kb/s)
Writing: LUN 4, Partition: tz, Offset: 0x000000086000, Size: 0x000000400000 (4.00 MB)
Writing file: tz.mbn, Offset: 0x000000000000, Size: 0x00000031D070 (3.11 MB)
Done writing partition  (Write speed: 1952.17 Kb/s)
Writing: LUN 4, Partition: hyp, Offset: 0x000000486000, Size: 0x000000800000 (8.00 MB)
Writing file: hyp.mbn, Offset: 0x000000000000, Size: 0x00000005C908 (370.26 KB)
Done writing partition  (Write speed: 1110.14 Kb/s)
Writing: LUN 4, Partition: modem, Offset: 0x000000C86000, Size: 0x00000C300000 (195.00 MB)
Writing file: NON-HLOS_ufs.bin, Offset: 0x000000000000, Size: 0x00000994F000 (153.31 MB)
Done writing partition  (Write speed: 5295.66 Kb/s)
Writing: LUN 4, Partition: bluetooth, Offset: 0x00000CF86000, Size: 0x000000100000 (1.00 MB)
Writing file: BTFM_ufs.bin, Offset: 0x000000000000, Size: 0x0000000E7000 (924.00 KB)
Done writing partition  (Write speed: 2551.45 Kb/s)
Writing: LUN 4, Partition: abl, Offset: 0x00000F486000, Size: 0x000000100000 (1.00 MB)
Writing file: abl.elf, Offset: 0x000000000000, Size: 0x000000035000 (212.00 KB)
Done writing partition  (Write speed: 951.90 Kb/s)
Writing: LUN 4, Partition: dsp, Offset: 0x00000F586000, Size: 0x000004000000 (64.00 MB)
Writing file: dspso.bin, Offset: 0x000000000000, Size: 0x000002000000 (32.00 MB)
Done writing partition  (Write speed: 5231.96 Kb/s)
Writing: LUN 4, Partition: keymaster, Offset: 0x000013586000, Size: 0x000000080000 (512.00 KB)
Writing file: km4.mbn, Offset: 0x000000000000, Size: 0x00000003920A (228.51 KB)
Done writing partition  (Write speed: 728.24 Kb/s)
Writing: LUN 4, Partition: boot, Offset: 0x000013606000, Size: 0x000006000000 (96.00 MB)
Writing file: boot.img, Offset: 0x000000000000, Size: 0x000006000000 (96.00 MB)
Done writing partition  (Write speed: 5332.89 Kb/s)
Writing: LUN 4, Partition: devcfg, Offset: 0x000019706000, Size: 0x000000020000 (128.00 KB)
Writing file: devcfg.mbn, Offset: 0x000000000000, Size: 0x00000000A7C0 (41.94 KB)
Done writing partition  (Write speed: 143.14 Kb/s)
Writing: LUN 4, Partition: qupfw, Offset: 0x000019726000, Size: 0x000000014000 (80.00 KB)
Writing file: qupv3fw.elf, Offset: 0x000000000000, Size: 0x00000000D211 (52.52 KB)
Done writing partition  (Write speed: 199.77 Kb/s)
Writing: LUN 4, Partition: vbmeta, Offset: 0x00001973A000, Size: 0x000000010000 (64.00 KB)
Writing file: vbmeta.img, Offset: 0x000000000000, Size: 0x000000002000 (8.00 KB)
Done writing partition  (Write speed: 52.15 Kb/s)
Writing: LUN 4, Partition: dtbo, Offset: 0x00001974A000, Size: 0x000001800000 (24.00 MB)
Writing file: dtbo.img, Offset: 0x000000000000, Size: 0x000001800000 (24.00 MB)
Done writing partition  (Write speed: 5267.62 Kb/s)
Writing: LUN 4, Partition: imagefv, Offset: 0x00001AF4A000, Size: 0x000000400000 (4.00 MB)
Writing file: imagefv.elf, Offset: 0x000000000000, Size: 0x00000000D000 (52.00 KB)
Done writing partition  (Write speed: 320.12 Kb/s)
Writing: LUN 4, Partition: uefisecapp, Offset: 0x00001B34A000, Size: 0x000000200000 (2.00 MB)
Writing file: uefi_sec.mbn, Offset: 0x000000000000, Size: 0x00000001E56D (121.36 KB)
Done writing partition  (Write speed: 387.48 Kb/s)
Writing: LUN 4, Partition: featenabler, Offset: 0x00001B54A000, Size: 0x000000020000 (128.00 KB)
Writing file: featenabler.mbn, Offset: 0x000000000000, Size: 0x0000000150D3 (84.21 KB)
Done writing partition  (Write speed: 286.58 Kb/s)
Writing: LUN 4, Partition: apdp, Offset: 0x00001B66B000, Size: 0x000000040000 (256.00 KB)
Writing file: dpAP.mbn, Offset: 0x000000000000, Size: 0x0000000034C4 (13.19 KB)
Done writing partition  (Write speed: 43.55 Kb/s)
Writing: LUN 4, Partition: splash, Offset: 0x00001D6EB000, Size: 0x0000020A4000 (32.64 MB)
Writing file: splash.img, Offset: 0x000000000000, Size: 0x0000003699B8 (3.41 MB)
Done writing partition  (Write speed: 3825.92 Kb/s)
Writing: LUN 4, Partition: logfs, Offset: 0x00001F890000, Size: 0x000000800000 (8.00 MB)
Writing file: logfs_ufs_8mb.bin, Offset: 0x000000000000, Size: 0x000000004000 (16.00 KB)
Done writing partition  (Write speed: 112.04 Kb/s)
Writing: LUN 4, Partition: storsec, Offset: 0x00002C290000, Size: 0x000000020000 (128.00 KB)
Writing file: storsec.mbn, Offset: 0x000000000000, Size: 0x00000000501A (20.03 KB)
Done writing partition  (Write speed: 65.88 Kb/s)
Writing: LUN 4, Partition: oppo_sec, Offset: 0x00002C4C7000, Size: 0x000000A00000 (10.00 MB)
Writing file: oppo_sec.mbn, Offset: 0x000000000000, Size: 0x00000001D9BF (118.44 KB)
Done writing partition  (Write speed: 366.52 Kb/s)
Writing: LUN 4, Partition: custom, Offset: 0x00002CEC7000, Size: 0x000010000000 (256.00 MB)
Writing file: custom.img, Offset: 0x000000000000, Size: 0x000010000000 (256.00 MB)
Sparse image found v.1.0  Total chunks: 13
Done writing partition  (Write speed: 139866.15 Kb/s)
Writing: LUN 4, Partition: odm, Offset: 0x00003CEC7000, Size: 0x000010000000 (256.00 MB)
Done writing partition  (Write speed: 3173.60 Kb/s)
Writing: LUN 4, Partition: preload, Offset: 0x00004CEC7000, Size: 0x000030000000 (768.00 MB)
Writing file: preload.special.img, Offset: 0x000000000000, Size: 0x000030000000 (768.00 MB)
Done writing partition  (Write speed: 5334.27 Kb/s)
Writing: LUN 5, Partition: PrimaryGPT, Offset: 0x000000000000, Size: 0x000000006000 (24.00 KB)
Writing file: gpt_main5_ufs.bin, Offset: 0x000000000000, Size: 0x000000006000 (24.00 KB)
Done writing partition  (Write speed: 87.88 Kb/s)
Writing: LUN 5, Partition: opporeserve1, Offset: 0x000002E40000, Size: 0x000000800000 (8.00 MB)
Writing file: emmc_fw.bin, Offset: 0x000000000000, Size: 0x000000400000 (4.00 MB)
Done writing partition  (Write speed: 2403.14 Kb/s)
Writing: LUN 5, Partition: opporeserve2, Offset: 0x000003640000, Size: 0x000008000000 (128.00 MB)
Writing file: opporeserve2.img, Offset: 0x000000000000, Size: 0x000008000000 (128.00 MB)
Done writing partition  (Write speed: 284122.88 Kb/s)
Writing: LUN 5, Partition: DRIVER, Offset: 0x000015640000, Size: 0x000002000000 (32.00 MB)
Writing file: DRIVER.ISO, Offset: 0x000000000000, Size: 0x0000016B1800 (22.69 MB)
Done writing partition  (Write speed: 3657.79 Kb/s)
All done
Old 11-02-2021, 12:10   #2 (permalink)
nagesss's Avatar
Member: 2306223
Sonork: 1660968:1234
Thanks Meter: 102
Wipe userdata :
UFS Socket Info.
Identify UFS Chip.
VCC: 3270mV
VCCQ2: 1903mV
Chip Info:
OemID: 01AD
UFS Version: 2.1
   LUN 0:
      Block size: 0x1000
   LUN 1 (Boot A):
      Block size: 0x1000
   LUN 2 (Boot B):
      Block size: 0x1000
   LUN 3:
      Block size: 0x1000
   LUN 4:
      Block size: 0x1000
   LUN 5:
      Block size: 0x1000
   W-LUN 0xC4 (RPMB):
      Block size: 0x100
RPMB:
 Counter: 18277
Health:
Erasing...
Failed...
Erasing...
Failed...
OK
Done.
EFM LOG:
UFS ISP Mode: OFF
UFS Safe Mode: ON
UFS: Socket Info:
UFS: Voltage Info:
 Mode: LOW
UFS: Memory Info:
 Vendor: SKhynix
 S/N: 0x05655510C3A3
 OEM ID: 01AD
 UFS Version: 2.1
 Max LUNs: 32
 LUNs Cnt: 6
 W-LUNs Cnt: 1
UFS RPMB Info:
 RPMB Counter: 18277
UFS Health Info:
UFS: LUNs Info:
UFS Init OK
EmptyCheck:
EmptyCheck: Done
Power Mode: LOW
Done Wiping Data..
Write firmware:
   Add:   Vendor LG
   RPMB Counter: 18277
GPT header is found
GPT header is found
GPT header is found
GPT header is found
GPT header is found
GPT header is found
All done
Try writing full old firmwa?es .
Sent from my SM-A305F using Tapatalk
Old 11-02-2021, 13:39   #3 (permalink)
Member: 660093
Sonork: 100.1602344
Thanks Meter: 277
I tyed Same version inside phone (CPH2127PU_11_A.57_201120)
Old 11-09-2021, 07:39   #4 (permalink)
Member: 660093
Sonork: 100.1602344
Thanks Meter: 277
which Higher Version solve this problem ?
Old 11-09-2021, 13:43   #5 (permalink)
nagesss's Avatar
Member: 2306223
Thanks Meter: 102
Try writing old firmwares.
Old 11-11-2021, 11:17   #6 (permalink)
Member: 2749644
Sonork: 100.1678692
Thanks Meter: 45
Itseems your Storage part is OK.....but RAM is Damaged
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.34744 seconds with 7 queries
