07-04-2018, 08:35 | #1 (permalink) |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | J200H Dead Boot Repair successfully completed by eMMC_tool Suite ver. 1.4.9.0 Using the official stock firmware J200HXXU0AQK2_J200HOJV0ARE1_J200HXXU0ARE1_ACR_5.1. 1 Code: eMMC_tool Suite ver. 1.4.9.0 (release date: 12.12.2017) Microsoft Windows 7 (32 bit) build 7601 (6.1.7600.16385) Looking for EasyJTAG box... EasyJTAG API ver. 2022 EasyJTAG Box Serial = 06010014FC294D61 Card Serial = AA34-B7FF EasyJTAG Box Firmware = 1.62 Changelog: 12.12.2017 (ver 1.4.9.0) Fix: Bugs that have been found through your crash report Fix: RandomVerify function Fix: Creation of GPT for Samsung (write by vendor) Fix: Failed to mount large Fat partitions (explorer) Fix: Extraction from contact2.db (explorer) Fix: Error in the "build.prop" parser Fix: CID Parser Add: Support for EasyJtag Plus Box Add: Path for TempDir and InitialDir (option in settings) Add: Unpack Lenovo QSB (utilities) Add: Selecting a PIT file from CSC (write by vendor Samsung) Add: Detect for encrypted dumps from GPG Box Add: Detect for FullDiskEncryption Partition (explorer) Add: LinearVerify of the Partition (read by vendor) Add: Information base about emmc compatibility (thanks to phonemicrodb) Add: Resizing the window (for small screen resolutions) Add: Converting large partitions in SparseImage when reading by vendor (option in settings) Add: Mounting SparseImage (explorer) Add: Automatic backup of the EFS partition for Samsung (read by vendor) Add: Formatting of EFS partition for Samsung on request (write by vendor) Setting frequence to 21 Mhz CMD Pullup Level: 1753 mV CMD Active Level: 2485 mV EMMC Device Information : EMMC CID: 90014A4838473474210169EA84D1920E EMMC CSD: D07F01320F5903FFFFFFFFEF8A400012 EMMC Manufacture Name: SKHYNIX , EMMC NAME: H8G4t , EMMC NAME (HEX): 483847347400 , S/N: 69EA84D1 , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 9/2015 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G4t_69EA84D1_20180704_003351.extcsd EMMC Init completed. Setting frequence to 21 Mhz Error: First select the Pit-file CMD Pullup Level: 1742 mV CMD Active Level: 2495 mV EMMC Device Information : EMMC CID: 90014A4838473474210169EA84D1920E EMMC CSD: D07F01320F5903FFFFFFFFEF8A400012 EMMC Manufacture Name: SKHYNIX , EMMC NAME: H8G4t , EMMC NAME (HEX): 483847347400 , S/N: 69EA84D1 , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 9/2015 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G4t_69EA84D1_20180704_003403.extcsd EMMC Init completed. Opening file: J23G_EUR_OPEN.pit Pit: J23G_EUR_OPEN.pit Entry count: 31 The size of the last section has been updated J200HXXU0AQK2_J200HOJV0ARE1_J200HXXU0ARE1_HOME._ACR.tar The list of files in the firmware: spl.img sboot.bin sboot2.bin param.lfs boot.img recovery.img system.img cache.img hidden.img sprdcp.img sprddsp.img nvitem.bin Setting frequence to 21 Mhz CMD Pullup Level: 1753 mV CMD Active Level: 2495 mV EMMC Device Information : EMMC CID: 90014A4838473474210169EA84D1920E EMMC CSD: D07F01320F5903FFFFFFFFEF8A400012 EMMC Manufacture Name: SKHYNIX , EMMC NAME: H8G4t , EMMC NAME (HEX): 483847347400 , S/N: 69EA84D1 , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 9/2015 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G4t_69EA84D1_20180704_003416.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PIT at address: 000000004400 GPT-partitioning done Unpacking file: spl.img Unpacking file: sboot.bin Unpacking file: sboot2.bin Unpacking file: nvitem.bin Unpacking file: sprddsp.img Unpacking file: sprdcp.img Unpacking file: param.lfs Unpacking file: boot.img Unpacking file: recovery.img Unpacking file: cache.img Unpacking file: system.img Unpacking file: hidden.img Partition name: BOOT Filename: spl.img , Offset: 000000000000 , filesize: 32768 bytes eMMC switching to ROM2 Erasing partition... Writing partition... Done writing partition. Write speed: 285.17 KB/s Partition name: SBOOT Filename: sboot.bin , Offset: 000000400000 , filesize: 1573888 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 506.33 KB/s Partition name: SBOOT2 Filename: sboot2.bin , Offset: 000000600000 , filesize: 1573888 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 500.97 KB/s Partition name: WFIXNV2 Filename: nvitem.bin , Offset: 000000900000 , filesize: 181868 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 509.53 KB/s Partition name: WDSP Filename: sprddsp.img , Offset: 000000C00000 , filesize: 2097152 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 503.40 KB/s Partition name: MODEM Filename: sprdcp.img , Offset: 000001000000 , filesize: 8388608 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 509.47 KB/s Partition name: PARAM Filename: param.lfs , Offset: 000002900000 , filesize: 573440 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 508.15 KB/s Partition name: KERNEL Filename: boot.img , Offset: 000004600000 , filesize: 13796368 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 509.99 KB/s Partition name: RECOVERY Filename: recovery.img , Offset: 000005600000 , filesize: 14533648 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 510.45 KB/s Partition name: CACHE Filename: cache.img , Offset: 000007000000 , filesize: 42369312 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 16 Done writing partition. Write speed: 510.26 KB/s Partition name: SYSTEM Filename: system.img , Offset: 000013800000 , filesize: 1421073920 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 2270 Done writing partition. Write speed: 508.19 KB/s Partition name: HIDDEN Filename: hidden.img , Offset: 000071400000 , filesize: 27317232 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 61 Done writing partition. Write speed: 505.22 KB/s Critical error: Access violation at address 00E1387E in module 'eMMC_tool.exe'. Read of address 00000004. Send a crash report. Please, wait ... Setting frequence to 21 Mhz CMD Pullup Level: 1742 mV CMD Active Level: 2495 mV EMMC Device Information : EMMC CID: 90014A4838473474210169EA84D1920E EMMC CSD: D07F01320F5903FFFFFFFFEF8A400012 EMMC Manufacture Name: SKHYNIX , EMMC NAME: H8G4t , EMMC NAME (HEX): 483847347400 , S/N: 69EA84D1 , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 9/2015 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G4t_69EA84D1_20180704_020832.extcsd EMMC Init completed. CrashReport sent successfully Setting frequence to 21 Mhz CMD Pullup Level: 1732 mV CMD Active Level: 2485 mV EMMC Device Information : EMMC CID: 90014A4838473474210169EA84D1920E EMMC CSD: D07F01320F5903FFFFFFFFEF8A400012 EMMC Manufacture Name: SKHYNIX , EMMC NAME: H8G4t , EMMC NAME (HEX): 483847347400 , S/N: 69EA84D1 , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 9/2015 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H8G4t_69EA84D1_20180704_020845.extcsd EMMC Init completed. Get firmware version Brand = samsung Manufacturer = samsung Model = SM-J200H Phone platform = sc8830 CPU Abi = armeabi-v7a Android release = 5.1.1 Firmware version = LMY48B.J200HXXU0AQK2 Firmware date = Mon Nov 13 22:32:54 KST 2017
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. |
The Following User Says Thank You to ...:::::NP™:::::... For This Useful Post: |
01-31-2021, 14:47 | #3 (permalink) |
Freak Poster Join Date: Jan 2015 Location: golarchi sindh pakistan
Member: 2335681 Status: Offline Sonork: 100.1668903 Thanks Meter: 23 | Warning: Health report is very BAD Device Life Time Estimation (MLC) [269]: 0x0B Exceeded its maximum estimated device life time Device Life Time Estimation (SLC) [268]: 0x01 0% - 10% device life time used Pre EOL information [267]: 0x03 Urgent Scanning soft partitions GPT header is found and is valid Partition: SBOOT, [000000400000 - 000000600000], size: 000000200000 (2.00 MB) Partition: SBOOT2, [000000600000 - 000000800000], size: 000000200000 (2.00 MB) Partition: wfixnv1, [000000800000 - 000000900000], size: 000000100000 (1.00 MB) Partition: wfixnv2, [000000900000 - 000000A00000], size: 000000100000 (1.00 MB) Partition: tdfixnv1, [000000A00000 - 000000B00000], size: 000000100000 (1.00 MB) Partition: tdfixnv2, [000000B00000 - 000000C00000], size: 000000100000 (1.00 MB) Partition: WDSP, [000000C00000 - 000001000000], size: 000000400000 (4.00 MB) Partition: MODEM, [000001000000 - 000001800000], size: 000000800000 (8.00 MB) Partition: MODEM2, [000001800000 - 000002000000], size: 000000800000 (8.00 MB) Partition: TDDSP, [000002000000 - 000002400000], size: 000000400000 (4.00 MB) Partition: FOTA_SIG, [000002400000 - 000002500000], size: 000000100000 (1.00 MB) Partition: wruntimenv1, [000002500000 - 000002600000], size: 000000100000 (1.00 MB) Partition: wruntimenv2, [000002600000 - 000002700000], size: 000000100000 (1.00 MB) Partition: tdruntimenv1, [000002700000 - 000002800000], size: 000000100000 (1.00 MB) Partition: tdruntimenv2, [000002800000 - 000002900000], size: 000000100000 (1.00 MB) Partition: PARAM, [000002900000 - 000002B00000], size: 000000200000 (2.00 MB) Partition: efs, [000002B00000 - 000003F00000], size: 000001400000 (20.0 MB) Partition: prodnv, [000003F00000 - 000004400000], size: 000000500000 (5.00 MB) Partition: RESERVED2, [000004400000 - 000004600000], size: 000000200000 (2.00 MB) Partition: KERNEL, [000004600000 - 000005600000], size: 000001000000 (16.0 MB) Partition: RECOVERY, [000005600000 - 000006600000], size: 000001000000 (16.0 MB) Partition: PERSISTENT, [000006600000 - 000006700000], size: 000000100000 (1.00 MB) Partition: persdata, [000006700000 - 000007000000], size: 000000900000 (9.00 MB) Partition: CACHE, [000007000000 - 000013800000], size: 00000C800000 (200. MB) Partition: SYSTEM, [000013800000 - 000071400000], size: 00005DC00000 (1.46 GB) Partition: HIDDEN, [000071400000 - 000073200000], size: 000001E00000 (30.0 MB) Partition: userdata, [000073200000 - 0001D1200000], size: 00015E000000 (5.47 GB) GPT header successfully parsed pleas sulition |
