01-31-2021, 05:06 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: GOOD
Member: 388862 Status: Offline Thanks Meter: 107 | vivo x23 not work????help me!!!! phone is good!!!! Z3X EasyJtag EMMC File Manager v 1.19 at 11/01/2021 Started.. Box API Version: 3403 FS Driver Version: 04012021 SQLite Version: 3.34.0 FSCK Engine Version: 04012021 ESE DB Version: 04012021 System Util Version: 04012021 System: Windows NT 6.2 (Build 9200) / 64 BIT CPU: Intel(R) Core(TM) i5-9400F CPU @ 2.90GHz Total RAM: 7.94 GB System Date: 2021/1/31 12:01:54 Official Site: http://efm.easy-jtag.com/ Telegram Support: https://t.me/z3xefm FRP Apps: Z3X FRP Files Z3X Card Serial: AAXXXX EasyJtag Plus Box Found at: COM4 EasyJtag Plus Box Firmware: 2.53.1 Source: Qualcomm 9008 EMMC/UFS/AUTO Generation: GPT [QC/SAMS/BCM/INTEL/MTK] Box Voltage set to: 2800 mV Scanner Thread Created.. Config: 1011111111101111 Setup HiPower CLK: OFF Disable HS Timing: TRUE Connecting To EasyJtag Plus Box: 2800mV/21MHz/8BIT EasyJtag Plus Box Found! Result: 0/OK EasyJtag Plus S/N: 5B0DF49404C29B41 EasyJtag Plus Box FirmWare: 2.53.1 Box Bus Width = 8 BIT Box Hardware = EasyJtag 2nd Generation Use Qlm 9008 (EDL) Mode.. Please Connect Qlm Device in 9008 (EDL) Mode.. Selected Primary Memory Type: AUTO Waiting For Device.. Found Device: Path: \\?\usb#vid_05c6&pid_9008#5&1e7d8db7&0&6#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Desc: Qualcomm HS-USB QDLoader 9008 HWID: USB\VID_05C6&PID_9008&REV_0000 Name: Qualcomm HS-USB QDLoader 9008 (COM3) Vendor: Qualcomm Incorporated Trying Connect to Device.. Open Port OK Sahara OK, Get Data.. Read Qualcomm CPU Info OK S/N: 0xFB022198 HW ID: 0x000910E100730003 HASH: 0x2C0A52FFBD8DB687B56F6A98D8840F46597A4DDE6D9DC8D0 0039873CE6D74F60 PBL : 0x00000000 DEV HASH: 0x000000861CA2 CPU : SnapDragon 670 [SDM670] Loader Automatically Selected.. Using Qlm Loader: X23.elf Sending Loader.. Loader Size: 729896 bytes Loader CheckSum: 0xED2DC2CD Loader Info: HWID: 0x6004000000730003 SWID: 0x0000000000000003 HASH: 0x2C0A52FFBD8DB687B56F6A98D8840F46597A4DDE6D9DC8D0 0039873CE6D74F60 CERT Cnt: 6 Wait.. Loader Sent, Run FireHose.. Get Memory Type.. [AUTO] Detected Memory: UFS FireHose Config Info: MSM, Memory: UFS, Ver: 1 Ext Info: 0x00002000/0x00100000/0xFFFFFFFF/0x00001000 FireHose Configure OK Get Protocol Type.. Found VIP Programmer Auto Set to Generic FireHose Type.. UFS -> INFO: Calling handler for getstorageinfo UFS -> INFO: Device Total Logical Blocks: 0x1d3f000 UFS -> INFO: Device Block Size in Bytes: 0x1000 UFS -> INFO: Device Total Physical Partitions: 0x6 UFS -> INFO: Device Manufacturer ID: 0x1ce UFS -> INFO: Device Serial Number: 0x4d53554e UFS -> INFO: UFS fInitialized: 0x1 UFS -> INFO: UFS Current LUN Number: = 0x0 UFS -> INFO: UFS Total Active LU: 0x6 UFS -> INFO: UFS wManufacturerID: 0x1ce UFS -> INFO: UFS Boot Partition Enabled: 0x1 UFS -> INFO: UFS Raw Device Capacity: = 0xee64000 UFS -> INFO: UFS Min Block Size: 0x8 UFS -> INFO: UFS Erase Block Size: 0x2000 UFS -> INFO: UFS Allocation Unit Size: 0x1 UFS -> INFO: UFS RPMB ReadWrite Size: = 0x40 UFS -> INFO: UFS Number of Allocation Uint for This LU: 0x74fc UFS -> INFO: UFS Logical Block Size: 0xc UFS -> INFO: UFS Provisioning Type: 0x2 UFS -> INFO: UFS LU Write Protect: 0x0 UFS -> INFO: UFS Boot LUN ID: = 0x0 UFS -> INFO: UFS Memory Type: 0x0 UFS -> INFO: UFS LU Total Blocks: 0x1d3f000 UFS -> INFO: UFS Supported Memory Types: 0x800f UFS -> INFO: UFS dEnhanced1MaxNAllocU: 0x7732 UFS -> INFO: UFS wEnhanced1CapAdjFac: 0x300 UFS -> INFO: UFS dEnhanced2MaxNAllocU: = 0x0 UFS -> INFO: UFS wEnhanced2CapAdjFac: 0x0 UFS -> INFO: UFS dEnhanced3MaxNAllocU: 0x0 UFS -> INFO: UFS wEnhanced3CapAdjFac: 0x0 UFS -> INFO: UFS dEnhanced4MaxNAllocU: 0x0 UFS -> INFO: UFS wEnhanced4CapAdjFac: 0x0 UFS -> INFO: UFS LUN Enable Bitmask: 0x3f UFS -> INFO: UFS Logical Block Count: 0x1d3f000 UFS -> INFO: UFS bConfigDescrLock: 0x0 UFS -> INFO: UFS iManufacturerName String Index: 0x0 UFS -> INFO: UFS iProductName String Index: 0x1 UFS -> INFO: UFS iSerialNumber String Index: 0x2 UFS -> INFO: UFS iOemID String Index: 0x3 UFS -> INFO: UFS Inquiry Command Output: SAMSUNG KM8V7001JM-B810 0800 Reading LUN's Info.. UFS LUN #0 -> 30666752 / 116.98 GB UFS LUN #1 -> 1024 / 4.00 MB UFS LUN #2 -> 1024 / 4.00 MB UFS LUN #3 -> 32768 / 128.00 MB UFS LUN #4 -> 524288 / 2.00 GB UFS LUN #5 -> 16384 / 64.00 MB Memory Type: UFS LUN's Count: 6 Packet Size: 16384 Sector Size: 4096 UFS Vendor: 0x1CE -> SAMSUNG UFS Serial: 0x4D53554E UFS Firm: 0x320 UFS NAME: KM8V7001JM-B810 BOOT OK, FireHose Ready.. Selected Primary Memory Type: UFS Run Main Engine.. Error Reading Sector: 0, Count: 5, Err: 13 Text: 数据无效。 Error While Reading Data. Code: -1 Error While Scan Partitions. Scanner Shutdown.. Scanner Thread Terminated Elapsed: 00:00:10:524 Found 0 Partition(s).. Search Partitions Fail.. Check Qlm Device and Try Again.. |
