07-07-2020, 08:18 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Location: PAKISTAN/MULTAN
Member: 242838 Status: Offline Thanks Meter: 83 | OPPO F7 Flashing Problem i tried to flash with ISP connection i am Facing Problem flashing Error I tried Diffrent Version But same Error now i flash it with dump file no Luck Here is Log info eMMC_tool Suite ver. 1.6.3.0 (release date: 23.06.2020) Microsoft Windows 8.1 (64 bit) build 9600 (6.3.9600.18217) Looking for EasyJTAG box... EasyJTAG API ver. 3401 EasyJTAG Box Serial = C095AC153xxxxxxxx Card Serial = AAxxxxxxxx EasyJTAG Box Firmware = 2.5201 Changelog: 23.06.2020 (ver 1.6.3.0) Fix: Bugs that have been found through your crash report Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 24 MHz CMD Pullup Level: 620 mV CMD Active Level: 1441 mV Can't init device. Reason: CMD Timeout Error Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 24 MHz CMD Pullup Level: 1807 mV CMD Active Level: 1862 mV EMMC Device Information : EMMC CID: 90014A484347386134A44838E1601549 EMMC CSD: D02701328F5903FFFFFFFFEF8A400027 EMMC Manufacture : SKHYNIX , EMMC NAME: HCG8a4 , HEX: 484347386134 , S/N: 4838E160 , rev. 0xA4 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 1/2018 EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 129023 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x02 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: HCG8a4_4838E160_20200707_120841.extcsd EMMC Init completed. Get firmware version Firmware info not found Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 24 MHz CMD Pullup Level: 1809 mV CMD Active Level: 1864 mV EMMC Device Information : EMMC CID: 90014A484347386134A44838E1601549 EMMC CSD: D02701328F5903FFFFFFFFEF8A400027 EMMC Manufacture : SKHYNIX , EMMC NAME: HCG8a4 , HEX: 484347386134 , S/N: 4838E160 , rev. 0xA4 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 1/2018 EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 129023 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x02 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: HCG8a4_4838E160_20200707_120908.extcsd EMMC Init completed. Operation: Writing all eMMC Regions... Writing to: ROM2 , start: 0x000000000000 , size: 0x000000400000 Filename: OPPO_F7_CPH1819_emmc_dump_ROM2.bin eMMC switching to ROM2 Writing partition... Done writing partition. Write speed: 1074.38 KB/s Writing to: ROM3 , start: 0x000000000000 , size: 0x000000400000 Filename: OPPO_F7_CPH1819_emmc_dump_ROM3.bin eMMC switching to ROM3 Writing partition... Done writing partition. Write speed: 1069.87 KB/s Writing to: ROM1 , start: 0x000000000000 , size: 0x000040000000 Filename: OPPO_F7_CPH1819_emmc_dump_ROM1_1GB.bin eMMC switching to ROM1 Writing partition... Error writing at address: 000009600000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #1 Error writing at address: 000009600000 , error: -1, CMD Timeout Error ... Retry #2 Error writing at address: 000009600000 , error: -1, CMD Timeout Error ... Retry #3 Too many errors. Writing has been stopped Kindly help me in this matter Thanks In Advacne EASY JTAG PLUS TEAM |
