oppo f9 pro hang on logo all info ok but stuck hang on logo Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 36 MHz CMD Pullup Level: 1804 mV CMD Active Level: 1851 mV EMMC Device Information : EMMC CID: 90014A484347386134A51F99A46D657B EMMC CSD: D02701328F5903FFFFFFFFEF8A400027 EMMC Manufacture : SKHYNIX , EMMC NAME: HCG8a4 , HEX: 484347386134 , S/N: 1F99A46D , rev. 0xA5 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 6/2018 EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 563390 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x02 , width 8bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: HCG8a4_1F99A46D_20210504_125124.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: boot_para, [000000008000 - 000000108000], size: 000000100000 (1.00 MB) Partition: recovery, [000000108000 - 000004108000], size: 000004000000 (64.0 MB) Partition: para, [000004108000 - 000004188000], size: 000000080000 (512. KB) Partition: reserve1, [000004188000 - 000004388000], size: 000000200000 (2.00 MB) Partition: reserve2, [000004388000 - 000005388000], size: 000001000000 (16.0 MB) Partition: reserve3, [000005388000 - 000005588000], size: 000000200000 (2.00 MB) Partition: reserve4, [000005588000 - 000006588000], size: 000001000000 (16.0 MB) Partition: reserve_exp1, [000006588000 - 000006788000], size: 000000200000 (2.00 MB) Partition: oppo_custom, [000006788000 - 000006888000], size: 000000100000 (1.00 MB) Partition: expdb, [000006888000 - 000007C88000], size: 000001400000 (20.0 MB) Partition: frp, [000007C88000 - 000007D88000], size: 000000100000 (1.00 MB) Partition: nvcfg, [000007D88000 - 000009D88000], size: 000002000000 (32.0 MB) Partition: nvdata, [000009D88000 - 00000DD88000], size: 000004000000 (64.0 MB) Partition: metadata, [00000DD88000 - 00000FD88000], size: 000002000000 (32.0 MB) Partition: protect1, [00000FD88000 - 000010588000], size: 000000800000 (8.00 MB) Partition: protect2, [000010588000 - 000011000000], size: 000000A78000 (10.4 MB) Partition: seccfg, [000011000000 - 000011800000], size: 000000800000 (8.00 MB) Partition: persist, [000011800000 - 000014800000], size: 000003000000 (48.0 MB) Partition: sec1, [000014800000 - 000014A00000], size: 000000200000 (2.00 MB) Partition: proinfo, [000014A00000 - 000014D00000], size: 000000300000 (3.00 MB) Partition: md1img, [000014D00000 - 00001B100000], size: 000006400000 (100. MB) Partition: spmfw, [00001B100000 - 00001B200000], size: 000000100000 (1.00 MB) Partition: scp1, [00001B200000 - 00001B800000], size: 000000600000 (6.00 MB) Partition: scp2, [00001B800000 - 00001BE00000], size: 000000600000 (6.00 MB) Partition: sspm_1, [00001BE00000 - 00001BF00000], size: 000000100000 (1.00 MB) Partition: sspm_2, [00001BF00000 - 00001C000000], size: 000000100000 (1.00 MB) Partition: cam_vpu1, [00001C000000 - 00001CF00000], size: 000000F00000 (15.0 MB) Partition: cam_vpu2, [00001CF00000 - 00001DE00000], size: 000000F00000 (15.0 MB) Partition: cam_vpu3, [00001DE00000 - 00001ED00000], size: 000000F00000 (15.0 MB) Partition: gz1, [00001ED00000 - 00001FD00000], size: 000001000000 (16.0 MB) Partition: gz2, [00001FD00000 - 000020D00000], size: 000001000000 (16.0 MB) Partition: nvram, [000020D00000 - 000024D00000], size: 000004000000 (64.0 MB) Partition: lk, [000024D00000 - 000025200000], size: 000000500000 (5.00 MB) Partition: lk2, [000025200000 - 000025700000], size: 000000500000 (5.00 MB) Partition: boot, [000025700000 - 000027700000], size: 000002000000 (32.0 MB) Partition: logo, [000027700000 - 000028700000], size: 000001000000 (16.0 MB) Partition: odmdtbo, [000028700000 - 000029700000], size: 000001000000 (16.0 MB) Partition: tee1, [000029700000 - 000029C00000], size: 000000500000 (5.00 MB) Partition: tee2, [000029C00000 - 00002A800000], size: 000000C00000 (12.0 MB) Partition: odm, [00002A800000 - 00003A800000], size: 000010000000 (256. MB) Partition: vendor, [00003A800000 - 0000A1800000], size: 000067000000 (1.61 GB) Partition: system, [0000A1800000 - 0001AE800000], size: 00010D000000 (4.20 GB) Partition: cache, [0001AE800000 - 0001C9800000], size: 00001B000000 (432. MB) Partition: userdata, [0001C9800000 - 000E8BCFBE00], size: 000CC24FBE00 (51.0 GB) Partition: otp, [000E8BCFBE00 - 000E8E7FBE00], size: 000002B00000 (43.0 MB) Partition: flashinfo, [000E8E7FBE00 - 000E8F7FBE00], size: 000001000000 (16.0 MB) GPT header successfully parsed Get firmware version Manufacturer = OPPO CPU Abi = arm64-v8a Android release = 8.1.0 Security Patch = 2019-11-05 Brand = OPPO Device = CPH1823 Model = CPH1823 Firmware version = CPH1823EX_11_A.20 Firmware date = Sat Oct 26 23:39:42 CST 2019 |
Hello mate , Does your phone gets directly stuck on oppo logo as soon as power on the device or the boot animation is carried out and then it’s stuck on the logo ? Btw you can start from safer procedure , firstly try to hard reset (try oppo reset and choose format data ,don’t save data). Secondly you can try flashing stock rom but mate there’s a catch don’t try to flash it via write by via ISP connection mode as it will disconnect regularly over time yielding a error and finally your flashing will be interrupted and your phone will be gone . You need to take the chip off for flashing this device , or you need to find a good healthy ROM1 back up over 8gb in size with all partition backups like system , vendor etc to flash via isp , which is kinda hard to find . Please Make back up of your security partitions before proceeding with any operation . Best Regards . |
