Old 05-04-2021, 08:23   #1 (permalink)
Member: 1199392
Thanks Meter: 91
Post oppo f9 pro hang on logo
all info ok but stuck hang on logo
Setting interface to EasyJtag2/ISP_HiPower
Setting bus width to 1 Bit
HiPower mode is ON
Setting frequence to 36 MHz
CMD Pullup Level: 1804 mV
CMD Active Level: 1851 mV
EMMC Device Information :
EMMC CID: 90014A484347386134A51F99A46D657B
EMMC CSD: D02701328F5903FFFFFFFFEF8A400027
EMMC Manufacture : SKHYNIX , EMMC NAME: HCG8a4 , HEX: 484347386134 , S/N: 1F99A46D , rev. 0xA5
EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 6/2018
EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 563390 , Response: Not Clean
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
Boot Bus Config: 0x02 , width 8bit
H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01
Backup saved: HCG8a4_1F99A46D_20210504_125124.extcsd
EMMC Init completed.
Scanning soft partitions
GPT header is found and is valid
Partition: boot_para, [000000008000 - 000000108000], size: 000000100000 (1.00 MB)
Partition: recovery, [000000108000 - 000004108000], size: 000004000000 (64.0 MB)
Partition: para, [000004108000 - 000004188000], size: 000000080000 (512. KB)
Partition: reserve1, [000004188000 - 000004388000], size: 000000200000 (2.00 MB)
Partition: reserve2, [000004388000 - 000005388000], size: 000001000000 (16.0 MB)
Partition: reserve3, [000005388000 - 000005588000], size: 000000200000 (2.00 MB)
Partition: reserve4, [000005588000 - 000006588000], size: 000001000000 (16.0 MB)
Partition: reserve_exp1, [000006588000 - 000006788000], size: 000000200000 (2.00 MB)
Partition: oppo_custom, [000006788000 - 000006888000], size: 000000100000 (1.00 MB)
Partition: expdb, [000006888000 - 000007C88000], size: 000001400000 (20.0 MB)
Partition: frp, [000007C88000 - 000007D88000], size: 000000100000 (1.00 MB)
Partition: nvcfg, [000007D88000 - 000009D88000], size: 000002000000 (32.0 MB)
Partition: nvdata, [000009D88000 - 00000DD88000], size: 000004000000 (64.0 MB)
Partition: metadata, [00000DD88000 - 00000FD88000], size: 000002000000 (32.0 MB)
Partition: protect1, [00000FD88000 - 000010588000], size: 000000800000 (8.00 MB)
Partition: protect2, [000010588000 - 000011000000], size: 000000A78000 (10.4 MB)
Partition: seccfg, [000011000000 - 000011800000], size: 000000800000 (8.00 MB)
Partition: persist, [000011800000 - 000014800000], size: 000003000000 (48.0 MB)
Partition: sec1, [000014800000 - 000014A00000], size: 000000200000 (2.00 MB)
Partition: proinfo, [000014A00000 - 000014D00000], size: 000000300000 (3.00 MB)
Partition: md1img, [000014D00000 - 00001B100000], size: 000006400000 (100. MB)
Partition: spmfw, [00001B100000 - 00001B200000], size: 000000100000 (1.00 MB)
Partition: scp1, [00001B200000 - 00001B800000], size: 000000600000 (6.00 MB)
Partition: scp2, [00001B800000 - 00001BE00000], size: 000000600000 (6.00 MB)
Partition: sspm_1, [00001BE00000 - 00001BF00000], size: 000000100000 (1.00 MB)
Partition: sspm_2, [00001BF00000 - 00001C000000], size: 000000100000 (1.00 MB)
Partition: cam_vpu1, [00001C000000 - 00001CF00000], size: 000000F00000 (15.0 MB)
Partition: cam_vpu2, [00001CF00000 - 00001DE00000], size: 000000F00000 (15.0 MB)
Partition: cam_vpu3, [00001DE00000 - 00001ED00000], size: 000000F00000 (15.0 MB)
Partition: gz1, [00001ED00000 - 00001FD00000], size: 000001000000 (16.0 MB)
Partition: gz2, [00001FD00000 - 000020D00000], size: 000001000000 (16.0 MB)
Partition: nvram, [000020D00000 - 000024D00000], size: 000004000000 (64.0 MB)
Partition: lk, [000024D00000 - 000025200000], size: 000000500000 (5.00 MB)
Partition: lk2, [000025200000 - 000025700000], size: 000000500000 (5.00 MB)
Partition: boot, [000025700000 - 000027700000], size: 000002000000 (32.0 MB)
Partition: logo, [000027700000 - 000028700000], size: 000001000000 (16.0 MB)
Partition: odmdtbo, [000028700000 - 000029700000], size: 000001000000 (16.0 MB)
Partition: tee1, [000029700000 - 000029C00000], size: 000000500000 (5.00 MB)
Partition: tee2, [000029C00000 - 00002A800000], size: 000000C00000 (12.0 MB)
Partition: odm, [00002A800000 - 00003A800000], size: 000010000000 (256. MB)
Partition: vendor, [00003A800000 - 0000A1800000], size: 000067000000 (1.61 GB)
Partition: system, [0000A1800000 - 0001AE800000], size: 00010D000000 (4.20 GB)
Partition: cache, [0001AE800000 - 0001C9800000], size: 00001B000000 (432. MB)
Partition: userdata, [0001C9800000 - 000E8BCFBE00], size: 000CC24FBE00 (51.0 GB)
Partition: otp, [000E8BCFBE00 - 000E8E7FBE00], size: 000002B00000 (43.0 MB)
Partition: flashinfo, [000E8E7FBE00 - 000E8F7FBE00], size: 000001000000 (16.0 MB)
GPT header successfully parsed
Get firmware version
Manufacturer = OPPO
CPU Abi = arm64-v8a
Android release = 8.1.0
Security Patch = 2019-11-05
Brand = OPPO
Device = CPH1823
Model = CPH1823
Firmware version = CPH1823EX_11_A.20
Firmware date = Sat Oct 26 23:39:42 CST 2019
Old 05-05-2021, 08:31   #2 (permalink)
Member: 2868909
Thanks Meter: 32
Hello mate ,
Does your phone gets directly stuck on oppo logo as soon as power on the device or the boot animation is carried out and then it’s stuck on the logo ?
Btw you can start from safer procedure , firstly try to hard reset (try oppo reset and choose format data ,don’t save data).
Secondly you can try flashing stock rom but mate there’s a catch don’t try to flash it via write by via ISP connection mode as it will disconnect regularly over time yielding a error and finally your flashing will be interrupted and your phone will be gone . You need to take the chip off for flashing this device , or you need to find a good healthy ROM1 back up over 8gb in size with all partition backups like system , vendor etc to flash via isp , which is kinda hard to find .
Please Make back up of your security partitions before proceeding with any operation .
Best Regards .
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.18113 seconds with 7 queries
