04-20-2019, 21:29 | #1 (permalink) |
No Life Poster Join Date: May 2009 Location: mumbai wadala
Member: 1037372 Status: Offline Thanks Meter: 557 | Oppo realme 2 pattern and frp unlock done with easy jtag plus |
The Following 29 Users Say Thank You to royalnasim For This Useful Post: |
06-26-2019, 09:01 | #7 (permalink) |
No Life Poster Join Date: Oct 2009 Location: Rajasthan INDIA
Member: 1147254 Status: Offline Sonork: 100.1620677 Thanks Meter: 639 | Oppo Realme 2 ( RMX1805 ) Pattern Lock & FRP Remove Succesfully By Easy JTAG Hello Everyone Today In My Shop Come Oppo Realme 2 ( RMX1805 ) With Pattern Lock Than I Do This & Remove Pattern Lock Successfully Via Easy JTAG [CENTER] Before & After Images Read Info & All LOG: LOG: Code: Z3X EasyJtag Software ver. 3.6.0.0 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: XXXXXXXXX, ,FW Ver.: 01.63 CMD Pullup Level:1773 mV CMD Active Level:2495 mV Box IO Level:3300 mV CLK Rate:7000 kHz Bus Width:1bit,SDR HiPower mode is ON! Can't init device, Reason: CMD Timeout Error Done. Z3X EasyJtag Software ver. 3.6.0.0 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0XXXXXXXXXXXXXX, ,FW Ver.: 01.63 CMD Pullup Level:2041 mV CMD Active Level:3011 mV Box IO Level:3300 mV CLK Rate:7000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 150100474436424D42014105077155EE eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 05/2018 Rev.0x1 eMMC NAME: GD6BMB , S/N: XXXXXXXXXXXXXX eMMC NAME (HEX): 474436424D42 EMMC ROM1 (Main User Data) Capacity: 29820 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 27928 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: GD6BMB_XXXXXXXXXXXXXX_20190626_1145.extcsd Partition table scan: GPT: present Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 First usable sector: 34 Last usable sector: 61071326 Partition info successfully found Found Data areas (firmware parts) count is: 64 --------------------------------------------- P0 (OPPODYCNVBK) [0x5000 0xa00000] Size: 10.0MB P1 (OPPOSTANVBK) [0xa05000 0xa00000] Size: 10.0MB P2 (MODEMST1) [0x1405000 0x180000] Size: 1.500MB P3 (MODEMST2) [0x1585000 0x180000] Size: 1.500MB P4 (PERSIST) [0x1705000 0x2000000] Size: 32.0MB P5 (OPPORESERVE1) [0x3705000 0x800000] Size: 8.0MB P6 (OPPORESERVE2) [0x3f05000 0x4000000] Size: 64.0MB P7 (FSC) [0x7f05000 0x400] Size: 1.0KB P8 (SSD) [0x7f06000 0x2000] Size: 8.0KB P9 (SBL1) [0x7f08000 0x80000] Size: 512.0KB P10 (RPM) [0x7f88000 0x80000] Size: 512.0KB P11 (TZ) [0x8008000 0x200000] Size: 2.0MB P12 (DEVCFG) [0x8208000 0x40000] Size: 256.0KB P13 (SBL1BAK) [0x8248000 0x80000] Size: 512.0KB P14 (RPMBAK) [0x82c8000 0x80000] Size: 512.0KB P15 (TZBAK) [0x8348000 0x200000] Size: 2.0MB P16 (DEVCFGBAK) [0x8548000 0x40000] Size: 256.0KB P17 (DSP) [0x8588000 0x1000000] Size: 16.0MB P18 (DDR) [0x9800000 0x8000] Size: 32.0KB P19 (FSG) [0x9808000 0x400000] Size: 4.0MB P20 (SEC) [0x9c08000 0x4000] Size: 16.0KB P21 (ABOOT) [0x9c0c000 0x100000] Size: 1.0MB P22 (ABOOTBAK) [0x9d0c000 0x100000] Size: 1.0MB P23 (MODEM) [0x9e0c000 0x8000000] Size: 128.0MB P24 (DTBO) [0x11e0c000 0x800000] Size: 8.0MB P25 (VBMETA) [0x1260c000 0x10000] Size: 64.0KB P26 (BOOT) [0x1261c000 0x4000000] Size: 64.0MB P27 (RECOVERY) [0x1661c000 0x4000000] Size: 64.0MB P28 (DEVINFO) [0x1a61c000 0x100000] Size: 1.0MB P29 (SPLASH) [0x1a800000 0xb00000] Size: 11.0MB P30 (LOGO) [0x1b300000 0x2000000] Size: 32.0MB P31 (DRIVER) [0x1d300000 0x2000000] Size: 32.0MB P32 (CACHE) [0x1f300000 0x10000000] Size: 256.0MB P33 (MISC) [0x2f300000 0x100000] Size: 1.0MB P34 (KEYSTORE) [0x2f400000 0x80000] Size: 512.0KB P35 (CONFIG) [0x2f480000 0x8000] Size: 32.0KB P36 (LOG) [0x2f488000 0x4000000] Size: 64.0MB P37 (OEM) [0x33488000 0x100000] Size: 1.0MB P38 (LIMITS) [0x33800000 0x8000] Size: 32.0KB P39 (MOTA) [0x34000000 0x80000] Size: 512.0KB P40 (DIP) [0x34080000 0x100000] Size: 1.0MB P41 (MDTP) [0x34180000 0x2000000] Size: 32.0MB P42 (SYSCFG) [0x36180000 0x80000] Size: 512.0KB P43 (MCFG) [0x36200000 0x400000] Size: 4.0MB P44 (LKSECAPP) [0x36800000 0x20000] Size: 128.0KB P45 (CMNLIB) [0x36820000 0x100000] Size: 1.0MB P46 (CMNLIB64) [0x36920000 0x100000] Size: 1.0MB P47 (KEYMASTER) [0x36a20000 0x100000] Size: 1.0MB P48 (LKSECAPPBAK) [0x36b20000 0x20000] Size: 128.0KB P49 (CMNLIBBAK) [0x36b40000 0x100000] Size: 1.0MB P50 (CMNLIB64BAK) [0x36c40000 0x100000] Size: 1.0MB P51 (KEYMASTERBAK) [0x36d40000 0x100000] Size: 1.0MB P52 (APDP) [0x37000000 0x40000] Size: 256.0KB P53 (MSADP) [0x37040000 0x40000] Size: 256.0KB P54 (DPO) [0x37080000 0x2000] Size: 8.0KB P55 (LOGDUMP) [0x37082000 0x4000000] Size: 64.0MB P56 (VM-KYSTORE) [0x3b082000 0x100000] Size: 1.0MB P57 (VM-DATA) [0x3b182000 0xa00000] Size: 10.0MB P58 (HYP) [0x3c000000 0x800000] Size: 8.0MB P59 (VM-SYSTEM) [0x3c800000 0x4000000] Size: 64.0MB P60 (VM-LINUX) [0x40800000 0x2000000] Size: 32.0MB P61 (SYSTEM) [0x42800000 0xd6900000] Size: 3.352GB P62 (VENDOR) [0x119100000 0x41f60000] Size: 1.30GB P63 (USERDATA) [0x15b800000 0x5ec3fbe00] Size: 23.690GB ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0042800000 (3.352GB) Build ID: OPM1.171019.026 Release Base ID: 8.1.0 Architecture ABI: arm64-v8a Device manufacturer: OPPO Build Description: S88051AA1-user 8.1.0 OPM1.171019.026 eng.root.20190516.094149 release-keys --------------------------------------------- Detected USERDATA USERDATA : 0x015B800000 (23.690GB) Unable to mount USERDATA , code : 95 Done. Selected eMMC Interface [CENTER] Remove FRP Lock ][/CENTER Thanks & Regards By:All TECH 4 You Last edited by Yashbanswara; 06-26-2019 at 09:09. |
The Following 36 Users Say Thank You to Yashbanswara For This Useful Post: |
06-27-2019, 05:27 | #9 (permalink) |
Freak Poster Join Date: Jun 2011 Location: jahanian punjab pakistan
Member: 1588653 Status: Offline Sonork: imran_Gill Thanks Meter: 83 | Oppo Realme 2 ( RMX1805 ) Pattern Lock & FRP Remove sir pleas share isp pinout |
The Following User Says Thank You to akash48 For This Useful Post: |
06-27-2019, 05:41 | #11 (permalink) |
Member: 1147254 Status: Offline Sonork: 100.1620677 Thanks Meter: 639 | Ask Before Better Search On Google:https://www.google.com/search?q=real...=1360&bih=654# Thanks & Regards By:All TECH 4 You |
The Following 2 Users Say Thank You to Yashbanswara For This Useful Post: |
06-28-2019, 10:20 | #12 (permalink) |
No Life Poster Join Date: Apr 2016 Location: OneTheWay
Member: 2554807 Status: Offline Thanks Meter: 612 | Oppo a5 cph1809 hardreset | pattern | pin lock remove | unbrick with easy jtag OPPO A5 CPH1809 HARDRESET | PATTERN | PIN LOCK REMOVE | UNBRICK WITH EASY JTAG unpack Ofp to XML Write XML Br_Nishan_Raja |
The Following 13 Users Say Thank You to Nishan_Raja For This Useful Post: |
07-03-2019, 05:23 | #14 (permalink) |
Freak Poster Join Date: Jun 2011 Location: kolkata Age: 39
Member: 1596162 Status: Offline Sonork: 100.1616391 Thanks Meter: 146 | Realme rmx1811 user lock done without data lose REALME RMX1811 USER LOCK DONE WITHOUT DATA LOSE |
The Following 10 Users Say Thank You to 4star For This Useful Post: |
