07-04-2019, 09:04
#20 (permalink)
Member: 953334
Sonork: 100.1614005 Thanks Meter: 15,424 | OPPO A3s F.R.p & Pattern Done Stuck In Qlcm Mode Done OPPO A3s F.R.p & Pattern Done Stuck In Qlcm Mode Done
Special Thanks To My bro Mukesh Jha Jadeja ..::CHAIN::.. Who had helped me To Recover from Qlcm Mode Love You Bro You Are Great Quote:
Running:Reset PIN/PASS/GESTURE Locks
Z3X EasyJtag Software ver. 3.6.1.4
Loading eMMC GEN1 Firmware... IO: 1800 mV
Box S/N: 1818041DBF5EF1D5, ,FW Ver.: 01.63
CMD Pullup Level:1722 mV
CMD Active Level:1825 mV
Box IO Level:1800 mV
CLK Rate:14000 kHz
Bus Width:1bit,SDR
HiPower mode is off!
---------- eMMC Device Information ----------
eMMC CID : 90014A68423861503E03C7D06AB2C5CC
eMMC CSD : D02700328F5903FFFFFFFFEF8E400042
eMMC Manufacturer ID: 0090 , OEM ID: 014A
eMMC Date: 12/2018 Rev.0x3
eMMC NAME: hB8aP> , S/N: 3352324786
eMMC NAME (HEX): 68423861503E
EMMC ROM1 (Main User Data) Capacity: 29820 MB , 0x3A3E000 pages , 0x747C00000 bytes
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB
EMMC RPMB is programmed and written 31274 times
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area)
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Partition info successfully found
------ Android information ------
Detected LINUX(Android) USERDATA : 0x0158000000 (23.745GB)
Mount EXT4 fs...
Unable to mount USER , code : 95
Done.
| Quote:
Running:Format FRP Partition...
CMD Pullup Level:1732 mV
CMD Active Level:1835 mV
CLK Rate:14000 kHz
Bus Width:1bit,SDR
Formatting FRP...
Detected LINUX(Android) CACHE : 0x001FB00000 (256.0MB) , formatting...
Done.
Detected LINUX(Android) CONFIG : 0x002FC80000 (32.0KB) formatting...
Done.
Detected LINUX(Android) USERDATA : 0x0158000000 (23.745GB) , formatting...
Done.
Done.
Done.
