Realme 5 Pro RMX 1971 PIN - FRP UNLOCK WITH EASYJTAGPLUS Realme 5 PRO RMX 1971 PIN - FRP UNLOCK WITH EASYJTAGPLUS https://i.postimg.cc/fbz6zmR5/screenshot-17.png BR_FiXMOBILESOLUTION |
whitout Jtag its possible make factory reset and frp? |
This was my post. https://forum.gsmhosting.com/vbb/14304640-post121.html but my easybjtag box v1 has been BURN ,Now I am wandering every now and then For Buy Z3X Easy-Jtag Plus Full Upgrade Set In INDIA because In INDIA every Reseller on Sell Z3X Easy-Jtag Plus Full Set not sell Z3X Easy-Jtag Plus Full Upgrade Set at this time I have no more money All info give in this threat https://forum.gsmhosting.com/vbb/14304640-post121.html Thanks & Regards By:AllTECH 4 You |
thank u good post i agry with you same situation me no use v1 box.. cant find india easy jtag plus lite kit or put old card upgrade kit but no india any have upgrade lite kit |
OPPO A1k CPH1923 Pattern Unlock By Easy Jtag Plus OPPO A1k CPH1923 Pattern Unlock By Easy Jtag Plus Code: EasyJtag Plus Box FirmWare: 2.53 Code: Resetting EasyJtag Box. Wait.. Br FactoryFilePak |
OPPO A3S CPH1853 Pattern Pin Password Unlock (Remove Screen Lock) by Easy Jtag Plus OPPO A3S CPH1853 Pattern Pin Password Unlock (Remove Screen Lock) by Easy Jtag Plus Box Br FactoryFilePak |
OPPO A1K CPH1923 Pattern Pin Password Unlock (Remove Screen Lock) by Easy Jtag Plus OPPO A1K CPH1923 Pattern Pin Password Unlock (Remove Screen Lock) by Easy Jtag Plus Box Br FactoryFilePak |
Thanks For You Brother |
OPPO CPH2067 UNLOCK DONE WHATSAPP:+2250768149592 https://i.postimg.cc/DZ7BBMKZ/IMG-20210323-005440.jpg https://i.postimg.cc/Tw8cp29B/HUM.png https://i.postimg.cc/nhk2StnD/IMG-20210323-010156.jpg |
OPPO RENO PASSWORD REMOVE DONE,CPH1917 ISP Pinout SDM710 https://i.postimg.cc/qM2p2Pk5/IMG-20210324-013508.jpg https://i.postimg.cc/HnVCJN6B/2021-03-24-023121.png https://i.postimg.cc/ydJHx5Qn/IMG-20210324-014328.jpg https://i.postimg.cc/R0DkkdSt/IMG-20210324-014854.jpg |
OPPO A9 2020 UNLOCK DONE Whtasapp +225076814959 https://i.postimg.cc/rmQpCJJV/OK1.png https://i.postimg.cc/gjxGyPjs/OK2.jpg https://i.postimg.cc/cLyd32S7/OK3.jpg |
Oppo A3S Pattern Unlock done Checking security ... Z3X EasyJtag Software ver. 3.7.0.20 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: , ,FW Ver.: 02.53 CMD Pullup Level:2073 mV CMD Active Level:2322 mV Box IO Level:2800 mV CLK Rate:1000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D4204E4BEAA412611 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 02/2019 Rev.0x4 eMMC NAME: QE63MB , S/N: 3837700673 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB , 0x1D1F000 pages , 0x3A3E00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 174754 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Writing Recovery Command to MISC (33) Done. |
Realme C3 RMX2020 pattern lock Removed By Great MRT Without Tp one click 100% Done Disconnect Mobile... re-input Mobile Battery... then connect usb to computer.... Make Sure your Mobie have power... >>> Searching Mobile Com Port... Get Mobile Port: COM30 >>> Driver Identifying name: MediaTek USB Port >>> Get Mobile Aleady... CPU_NAME: MT6768 >>> Reading Mobile Hardware info...Success HW_Inf: 8A00 SW_Inf: CA00 >>> Searching Mobile Com Port... Get Mobile Port: COM78 >>> Driver Identifying name: OPPO PreLoader USB VCOM (Android) >>> try into Meta Mode...success Reading Mobile Base Info... CPU_TYPE:mt6768 Bulid_Time:Sat Apr 11 00:06:59 CST 2020 Base_Ver:RMX2020_11_A.21_200410_b5a6ed2f Soft_Ver:RMX2020_11_A.21 factory reseting... rebooting... after software done,mobile will power on and hand on logo maybe 30 min after mobile will auto into recovery;please make wipe in it then mobile working all is done!!! |
Oppo A3s Password Reset Done Checking security ... Z3X EasyJtag Software ver. 3.7.0.20 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: , ,FW Ver.: 02.53 CMD Pullup Level:2094 mV CMD Active Level:2358 mV Box IO Level:2800 mV CLK Rate:1000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D420385A668F62533 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 02/2018 Rev.0x3 eMMC NAME: QE63MB , S/N: 2242275574 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB , 0x1D1F000 pages , 0x3A3E00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 68957 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Writing Recovery Command to MISC (35) Done. |
thank you bro my realme c2 was unlock with ufi |
