08-13-2019, 07:48 | #82 (permalink) |
No Life Poster Join Date: Aug 2012 Location: Bali-Indonesia
Member: 1800628 Status: Offline Thanks Meter: 940 | OPPO A3S remove pass code done Z3X EasyJtag Software ver. 3.6.1.2 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 0F01300C22E581EB, ,FW Ver.: 01.63 CMD Pullup Level:1990 mV CMD Active Level:2588 mV Box IO Level:2800 mV CLK Rate:14000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D420663F768F0B52A eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 11/2018 Rev.0x6 eMMC NAME: QE63MB , S/N: 1677158640 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 67468 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: QE63MB_1677158640_20190813_1323.extcsd Done. Z3X EasyJtag Software ver. 3.6.1.2 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 0F01300C22E581EB, ,FW Ver.: 01.63 CMD Pullup Level:1990 mV CMD Active Level:2588 mV Box IO Level:2800 mV CLK Rate:14000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D420663F768F0B52A eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 11/2018 Rev.0x6 eMMC NAME: QE63MB , S/N: 1677158640 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB , 0x1D1F000 pages , 0x3A3E00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 67468 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Partition table scan: GPT: present Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 1D1F000 sectors 14.6 GiB Soft (Partitioned) Disk/Image size: 1D1EFBC sectors 14.6 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 First usable sector: 34 Last usable sector: 30535646 Partition info successfully found ------ Android information ------ Detected LINUX(Android) CACHE : 0x001F300000 (256.0MB) Erasing... Done. Detected LINUX(Android) USERDATA : 0x015B800000 (9.129GB) Erasing... Done. --------------------------------------------- Done. Running:Format FRP Partition... Z3X EasyJtag Software ver. 3.6.1.2 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 0F01300C22E581EB, ,FW Ver.: 01.63 CMD Pullup Level:1990 mV CMD Active Level:2578 mV Box IO Level:2800 mV CLK Rate:14000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D420663F768F0B52A eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 11/2018 Rev.0x6 eMMC NAME: QE63MB , S/N: 1677158640 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB , 0x1D1F000 pages , 0x3A3E00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 67468 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Partition table scan: GPT: present Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 1D1F000 sectors 14.6 GiB Soft (Partitioned) Disk/Image size: 1D1EFBC sectors 14.6 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 First usable sector: 34 Last usable sector: 30535646 Partition info successfully found Formatting FRP... Detected LINUX(Android) CACHE : 0x001F300000 (256.0MB) , formatting... Done. Detected LINUX(Android) CONFIG : 0x002F480000 (32.0KB) formatting... Done. Detected LINUX(Android) USERDATA : 0x015B800000 (9.129GB) , formatting... Done. Done. Done. Z3X EasyJtag Software ver. 3.6.1.2 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 0F01300C22E581EB, ,FW Ver.: 01.63 CMD Pullup Level:1990 mV CMD Active Level:2578 mV Box IO Level:2800 mV CLK Rate:14000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D420663F768F0B52A eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 11/2018 Rev.0x6 eMMC NAME: QE63MB , S/N: 1677158640 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 67468 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: QE63MB_1677158640_20190813_1323.extcsd Done. |
The Following 3 Users Say Thank You to Deni's For This Useful Post: |
08-18-2019, 12:14 | #86 (permalink) |
Junior Member Join Date: Jun 2016 Location: INDIA
Member: 2582195 Status: Offline Thanks Meter: 3 | real me 2 unlock done http://i68.tinypic.com/2e1zk42.jpg POWER OF JTAG PLUS Last edited by naveenagg18; 08-18-2019 at 12:22. |
08-18-2019, 15:17 | #87 (permalink) | |
No Life Poster Join Date: Nov 2005 Location: Morocco-Khenifra
Member: 198621 Status: Offline Sonork: 100.1591649 Thanks Meter: 1,083 | thank you here's log: Quote:
08-19-2019, 02:08 | #88 (permalink) |
Freak Poster Join Date: Sep 2012 Location: KSA
Member: 1813906 Status: Offline Sonork: 100.1618216 Thanks Meter: 33 | Oppo A3s CPH1853 remove lock screen and frp just one click Oppo reset Selected pinout: GEN2 ISP Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.6.1.14 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: F0491474C976AB1B, ,FW Ver.: 02.48 CMD Pullup Level:2075 mV CMD Active Level:2716 mV Box IO Level:2800 mV CLK Rate:24000 kHz Bus Width:1bit,SDR HiPower mode is ON! Checking security ... Selected pinout: GEN2 ISP Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.6.1.14 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: F0491474C976AB1B, ,FW Ver.: 02.48 CMD Pullup Level:2073 mV CMD Active Level:2716 mV Box IO Level:2800 mV CLK Rate:24000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D4204E51AAAA826AD eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 02/2019 Rev.0x4 eMMC NAME: QE63MB , S/N: 3843730088 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 13074 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: QE63MB_3843730088_20190818_1743.extcsd Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0042800000 (3.352GB) Build ID: OPM1.171019.026 Release Base ID: 8.1.0 Architecture ABI: arm64-v8a Device manufacturer: OPPO Build Description: S88051AA1-user 8.1.0 OPM1.171019.026 eng.root.20190624.211613 release-keys --------------------------------------------- Detected USERDATA USERDATA : 0x015B800000 (9.129GB) Unable to mount USERDATA , code : 95 Done. Checking security ... Z3X EasyJtag Software ver. 3.6.1.14 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: F0491474C976AB1B, ,FW Ver.: 02.48 CMD Pullup Level:2073 mV CMD Active Level:2714 mV Box IO Level:2800 mV CLK Rate:24000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D4204E51AAAA826AD eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 02/2019 Rev.0x4 eMMC NAME: QE63MB , S/N: 3843730088 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB , 0x1D1F000 pages , 0x3A3E00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 13074 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Writing Recovery Command to MISC (33) Done. |
08-21-2019, 06:38 | #89 (permalink) |
Registered User Join Date: Jul 2012
Member: 1784151 Status: Offline Sonork: 0 Thanks Meter: 75 | I have Easy-JTAG and not used anymore bcoz i dont know this update. Wow, amazing,, just use Z3X Box... will use both product again together. Thanks to Easy-JTAG team for this awesome news |
