03-03-2022, 13:58 | #1 (permalink) |
No Life Poster Join Date: Jul 2007 Location: In My Laptop Age: 16
Member: 541117 Status: Offline Sonork: .::100.1586906::. Thanks Meter: 173 | CPH1803 baseband unknonw after Pattern/FRP Code: Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 36 MHz CMD Pullup Level: 1801 mV CMD Active Level: 1851 mV EMMC Device Information : EMMC CID: 90014A484147346132A50E52644D459D EMMC CSD: D02701328F5903FFFFFFFFE78A400017 EMMC Manufacture : SKHYNIX , EMMC NAME: HAG4a2 , HEX: 484147346132 , S/N: 0E52644D , rev. 0xA5 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 4/2018 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 41989 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: HAG4a2_0E52644D_20220303_111933.extcsd EMMC Init completed. Warning: Health report is very BAD Device Life Time Estimation (MLC) [269]: 0x0A 90% - 100% device life time used Device Life Time Estimation (SLC) [268]: 0x01 0% - 10% device life time used Pre EOL information [267]: 0x01 Normal Scanning soft partitions GPT header is found and is valid Partition: oppodycnvbk, [000000005000 - 000000A05000], size: 000000A00000 (10.0 MB) Partition: oppostanvbk, [000000A05000 - 000001405000], size: 000000A00000 (10.0 MB) Partition: modemst1, [000001405000 - 000001585000], size: 000000180000 (1.50 MB) Partition: modemst2, [000001585000 - 000001705000], size: 000000180000 (1.50 MB) Partition: persist, [000001705000 - 000003705000], size: 000002000000 (32.0 MB) Partition: opporeserve1, [000003705000 - 000003F05000], size: 000000800000 (8.00 MB) Partition: opporeserve2, [000003F05000 - 000007F05000], size: 000004000000 (64.0 MB) Partition: reserve_exp1, [000007F05000 - 000008105000], size: 000000200000 (2.00 MB) Partition: reserve_exp2, [000008105000 - 000008305000], size: 000000200000 (2.00 MB) Partition: fsc, [000008305000 - 000008305400], size: 000000000400 (1.00 KB) Partition: ssd, [000008306000 - 000008308000], size: 000000002000 (8.00 KB) Partition: sbl1, [000008308000 - 000008388000], size: 000000080000 (512. KB) Partition: rpm, [000008388000 - 000008408000], size: 000000080000 (512. KB) Partition: tz, [000008408000 - 000008608000], size: 000000200000 (2.00 MB) Partition: devcfg, [000008608000 - 000008648000], size: 000000040000 (256. KB) Partition: sbl1bak, [000008648000 - 0000086C8000], size: 000000080000 (512. KB) Partition: rpmbak, [0000086C8000 - 000008748000], size: 000000080000 (512. KB) Partition: tzbak, [000008748000 - 000008948000], size: 000000200000 (2.00 MB) Partition: devcfgbak, [000008948000 - 000008988000], size: 000000040000 (256. KB) Partition: dsp, [000008988000 - 000009988000], size: 000001000000 (16.0 MB) Partition: DDR, [00000A000000 - 00000A008000], size: 000000008000 (32.0 KB) Partition: fsg, [00000A008000 - 00000A188000], size: 000000180000 (1.50 MB) Partition: sec, [00000A188000 - 00000A18C000], size: 000000004000 (16.0 KB) Partition: aboot, [00000A18C000 - 00000A28C000], size: 000000100000 (1.00 MB) Partition: abootbak, [00000A28C000 - 00000A38C000], size: 000000100000 (1.00 MB) Partition: modem, [00000A38C000 - 00001238C000], size: 000008000000 (128. MB) Partition: dtbo, [00001238C000 - 000012B8C000], size: 000000800000 (8.00 MB) Partition: vbmeta, [000012B8C000 - 000012B9C000], size: 000000010000 (64.0 KB) Partition: boot, [000012B9C000 - 000016B9C000], size: 000004000000 (64.0 MB) Partition: recovery, [000016B9C000 - 00001AB9C000], size: 000004000000 (64.0 MB) Partition: devinfo, [00001AB9C000 - 00001AC9C000], size: 000000100000 (1.00 MB) Partition: splash, [00001B000000 - 00001BB00000], size: 000000B00000 (11.0 MB) Partition: LOGO, [00001BB00000 - 00001DB00000], size: 000002000000 (32.0 MB) Partition: DRIVER, [00001DB00000 - 00001FB00000], size: 000002000000 (32.0 MB) Partition: cache, [00001FB00000 - 00002FB00000], size: 000010000000 (256. MB) Partition: misc, [00002FB00000 - 00002FC00000], size: 000000100000 (1.00 MB) Partition: keystore, [00002FC00000 - 00002FC80000], size: 000000080000 (512. KB) Partition: config, [00002FC80000 - 00002FC88000], size: 000000008000 (32.0 KB) Partition: oem, [00002FC88000 - 00002FD88000], size: 000000100000 (1.00 MB) Partition: limits, [000030000000 - 000030008000], size: 000000008000 (32.0 KB) Partition: mota, [000030800000 - 000030880000], size: 000000080000 (512. KB) Partition: dip, [000030880000 - 000030980000], size: 000000100000 (1.00 MB) Partition: mdtp, [000030980000 - 000032980000], size: 000002000000 (32.0 MB) Partition: syscfg, [000032980000 - 000032A00000], size: 000000080000 (512. KB) Partition: mcfg, [000032A00000 - 000032E00000], size: 000000400000 (4.00 MB) Partition: lksecapp, [000033000000 - 000033020000], size: 000000020000 (128. KB) Partition: cmnlib, [000033020000 - 000033120000], size: 000000100000 (1.00 MB) Partition: cmnlib64, [000033120000 - 000033220000], size: 000000100000 (1.00 MB) Partition: keymaster, [000033220000 - 000033320000], size: 000000100000 (1.00 MB) Partition: lksecappbak, [000033320000 - 000033340000], size: 000000020000 (128. KB) Partition: cmnlibbak, [000033340000 - 000033440000], size: 000000100000 (1.00 MB) Partition: cmnlib64bak, [000033440000 - 000033540000], size: 000000100000 (1.00 MB) Partition: keymasterbak, [000033540000 - 000033640000], size: 000000100000 (1.00 MB) Partition: apdp, [000033800000 - 000033840000], size: 000000040000 (256. KB) Partition: msadp, [000033840000 - 000033880000], size: 000000040000 (256. KB) Partition: dpo, [000033880000 - 000033882000], size: 000000002000 (8.00 KB) Partition: logdump, [000033882000 - 000037882000], size: 000004000000 (64.0 MB) Partition: vm-kystore, [000037882000 - 000037982000], size: 000000100000 (1.00 MB) Partition: vm-data, [000037982000 - 000038382000], size: 000000A00000 (10.0 MB) Partition: hyp, [000038800000 - 000039000000], size: 000000800000 (8.00 MB) Partition: vm-system, [000039000000 - 00003D000000], size: 000004000000 (64.0 MB) Partition: vm-linux, [00003D000000 - 00003F000000], size: 000002000000 (32.0 MB) Partition: system, [00003F000000 - 000115900000], size: 0000D6900000 (3.35 GB) Partition: vendor, [000115900000 - 000157860000], size: 000041F60000 (1.03 GB) Partition: userdata, [000158000000 - 0003AB3FBE00], size: 0002533FBE00 (9.30 GB) GPT header successfully parsed Get firmware version Manufacturer = OPPO CPU Abi = arm64-v8a Android release = 8.1.0 Security Patch = 2020-05-05 Brand = OPPO Device = CPH1803 Model = CPH1803 Firmware version = CPH1803EX_11_A.28 Firmware date = Fri May 15 20:10:06 CST 2020 After flash Oppo A3s CPH1803 fix baseband and IMEI EMMC_QE63MB_ROM1.rar.zip still unknown baseband Code: Operation: Write by vendor (Qualcomm/HiSilicon/Omap) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Writing BackupGPT at address: 0003AB3FBE00 GPT-partitioning done Partition name: oppodycnvbk Filename: dynamic_nvbk.bin , Offset: 000000005000 , filesize: 10485760 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2798.94 KB/s Partition name: oppostanvbk Filename: static_nvbk.bin , Offset: 000000A05000 , filesize: 10485760 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 3533.42 KB/s Partition name: persist Filename: persist.img , Offset: 000001705000 , filesize: 5132700 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 32 Done writing partition. Write speed: 3194.92 KB/s Partition name: opporeserve1 Filename: emmc_fw.bin , Offset: 000003705000 , filesize: 4194304 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 3627.65 KB/s Partition name: opporeserve2 Filename: opporeserve2.img , Offset: 000003F05000 , filesize: 5300372 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 10 Done writing partition. Write speed: 3445.93 KB/s Partition name: sbl1 Filename: sbl1.mbn , Offset: 000008308000 , filesize: 452656 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 3066.77 KB/s Partition name: rpm Filename: rpm.mbn , Offset: 000008388000 , filesize: 174884 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2146.24 KB/s Partition name: tz Filename: tz.mbn , Offset: 000008408000 , filesize: 1535872 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 3720.25 KB/s Partition name: devcfg Filename: devcfg.mbn , Offset: 000008608000 , filesize: 40220 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 545.82 KB/s Partition name: sbl1bak Filename: sbl1.mbn , Offset: 000008648000 , filesize: 452656 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2932.92 KB/s Partition name: rpmbak Filename: rpm.mbn , Offset: 0000086C8000 , filesize: 174884 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2153.85 KB/s Partition name: tzbak Filename: tz.mbn , Offset: 000008748000 , filesize: 1535872 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 3722.34 KB/s Partition name: devcfgbak Filename: devcfg.mbn , Offset: 000008948000 , filesize: 40220 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 709.99 KB/s Partition name: dsp Filename: adspso.bin , Offset: 000008988000 , filesize: 16777216 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 3785.42 KB/s Partition name: aboot Filename: emmc_appsboot.mbn , Offset: 00000A18C000 , filesize: 743184 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1953.95 KB/s Partition name: abootbak Filename: emmc_appsboot.mbn , Offset: 00000A28C000 , filesize: 743184 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 3721.18 KB/s Partition name: modem Filename: NON-HLOS.bin , Offset: 00000A38C000 , filesize: 134217728 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 3974.90 KB/s Partition name: dtbo Filename: dtbo.img , Offset: 00001238C000 , filesize: 8388608 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 3342.57 KB/s Partition name: vbmeta Filename: vbmeta.img , Offset: 000012B8C000 , filesize: 4096 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 251.65 KB/s Partition name: boot Filename: boot.img , Offset: 000012B9C000 , filesize: 67108864 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 3950.86 KB/s Partition name: recovery Filename: recovery.img , Offset: 000016B9C000 , filesize: 67108864 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 3908.31 KB/s Partition name: LOGO Filename: logo.bin , Offset: 00001BB00000 , filesize: 878592 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 3445.16 KB/s Partition name: DRIVER Filename: DRIVER.ISO , Offset: 00001DB00000 , filesize: 23795712 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 3708.77 KB/s Partition name: cache Filename: cache.img , Offset: 00001FB00000 , filesize: 6398160 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 15 Done writing partition. Write speed: 3068.64 KB/s Partition name: mdtp Filename: mdtp.img , Offset: 000030980000 , filesize: 17808306 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 3837.54 KB/s Partition name: lksecapp Filename: lksecapp.mbn , Offset: 000033000000 , filesize: 57352 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2388.46 KB/s Partition name: cmnlib Filename: cmnlib_30.mbn , Offset: 000033020000 , filesize: 213856 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 3074.42 KB/s Partition name: cmnlib64 Filename: cmnlib64_30.mbn , Offset: 000033120000 , filesize: 269088 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1375.48 KB/s Partition name: keymaster Filename: keymaster64.mbn , Offset: 000033220000 , filesize: 271480 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1985.86 KB/s Partition name: lksecappbak Filename: lksecapp.mbn , Offset: 000033320000 , filesize: 57352 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1158.27 KB/s Partition name: cmnlibbak Filename: cmnlib_30.mbn , Offset: 000033340000 , filesize: 213856 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2667.30 KB/s Partition name: cmnlib64bak Filename: cmnlib64_30.mbn , Offset: 000033440000 , filesize: 269088 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2892.66 KB/s Partition name: keymasterbak Filename: keymaster64.mbn , Offset: 000033540000 , filesize: 271480 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 3277.32 KB/s Partition name: apdp Filename: dpAP.mbn , Offset: 000033800000 , filesize: 13248 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 353.41 KB/s Partition name: system Filename: system.img , Offset: 00003F000000 , filesize: 2977559784 bytes eMMC switching to ROM1 Erasing partition... Error erasing at address: 0000499C0000 , error: -1, CMD Timeout Error ... Retry #1 Error erasing at address: 000052780000 , error: -1, CMD Timeout Error ... Retry #1 Error erasing at address: 000062460000 , error: -1, CMD Timeout Error ... Retry #1 Error erasing at address: 000079060000 , error: -1, CMD Timeout Error ... Retry #1 Error erasing at address: 000097440000 , error: -1, CMD Timeout Error ... Retry #1 Error erasing at address: 000098BE0000 , error: -1, CMD Timeout Error ... Retry #1 Error erasing at address: 0000BFD80000 , error: -1, CMD Timeout Error ... Retry #1 Error erasing at address: 0000C95C0000 , error: -1, CMD Timeout Error ... Retry #1 Writing partition... Sparse image found v.1.0 Total chunks: 3857 Error writing at address: 000048811000 , error: -1, CMD Timeout Error ... Retry #1 Error writing at address: 000064D86000 , error: -1, CMD Timeout Error ... Retry #1 Error writing at address: 000095DA6000 , error: -1, CMD Timeout Error ... Retry #1 Error writing at address: 0000AB8A2000 , error: -1, CMD Timeout Error ... Retry #1 Error writing at address: 0000BB48A000 , error: -1, CMD Timeout Error ... Retry #1 Error writing at address: 0000DF817000 , error: -1, CMD Timeout Error ... Retry #1 Error writing at address: 0000F8997000 , error: -1, CMD Timeout Error ... Retry #1 Error writing at address: 00010C88C000 , error: -1, CMD Timeout Error ... Retry #1 Done writing partition. Write speed: 3595.59 KB/s Partition name: vendor Filename: vendor.img , Offset: 000115900000 , filesize: 980781056 bytes eMMC switching to ROM1 Erasing partition... Error erasing at address: 00011B860000 , error: -1, CMD Timeout Error ... Retry #1 Error erasing at address: 00012F280000 , error: -1, CMD Timeout Error ... Retry #1 Error erasing at address: 00013ACE0000 , error: -1, CMD Timeout Error ... Retry #1 Writing partition... Sparse image found v.1.0 Total chunks: 2899 Error writing at address: 00011BFA9000 , error: -1, CMD Timeout Error ... Retry #1 Error writing at address: 000145895000 , error: -1, CMD Timeout Error ... Retry #1 Error writing at address: 00014D5F7000 , error: -1, CMD Timeout Error ... Retry #1 Error writing at address: 000150C5F000 , error: -1, CMD Timeout Error ... Retry #1 Done writing partition. Write speed: 3251.22 KB/s Partition name: userdata Filename: userdata.img , Offset: 000158000000 , filesize: 2249422708 bytes eMMC switching to ROM1 Erasing partition... Error erasing at address: 00017A820000 , error: -1, CMD Timeout Error ... Retry #1 Error erasing at address: 0001814A0000 , error: -1, CMD Timeout Error ... Retry #1 Error erasing at address: 0001AB120000 , error: -1, CMD Timeout Error ... Retry #1 Error erasing at address: 0001BF320000 , error: -1, CMD Timeout Error ... Retry #1 Error erasing at address: 0001C8D20000 , error: -1, CMD Timeout Error ... Retry #1 Error erasing at address: 0001CD320000 , error: -1, CMD Timeout Error ... Retry #1 Error erasing at address: 0001E0D40000 , error: -1, CMD Timeout Error ... Retry #1 Error erasing at address: 0001F90E0000 , error: -1, CMD Timeout Error ... Retry #1 Error erasing at address: 0001FE160000 , error: -1, CMD Timeout Error ... Retry #1 Error erasing at address: 0002040C0000 , error: -1, CMD Timeout Error ... Retry #1 Error erasing at address: 0002224A0000 , error: -1, CMD Timeout Error ... Retry #1 Error erasing at address: 00024D0E0000 , error: -1, CMD Timeout Error ... Retry #1 Error erasing at address: 000257480000 , error: -1, CMD Timeout Error ... Retry #1 Error erasing at address: 000267CC0000 , error: -1, CMD Timeout Error ... Retry #1 Error erasing at address: 00027A480000 , error: -1, CMD Timeout Error ... Retry #1 Error erasing at address: 000284BA0000 , error: -1, CMD Timeout Error ... Retry #1 Error erasing at address: 0002BFE60000 , error: -1, CMD Timeout Error ... Retry #1 Error erasing at address: 0002C57A0000 , error: -1, CMD Timeout Error ... Retry #1 Error erasing at address: 0002FDB20000 , error: -1, CMD Timeout Error ... Retry #1 Error erasing at address: 000305E60000 , error: -1, CMD Timeout Error ... Retry #1 Error erasing at address: 00035FDC0000 , error: -1, CMD Timeout Error ... Retry #1 Writing partition... Sparse image found v.1.0 Total chunks: 498 Error writing at address: 00017AC9D000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #1 Error writing at address: 00017C15E000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #1 Error writing at address: 00017C713000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #1 Error writing at address: 0001A9622000 , error: -1, CMD Timeout Error ... Retry #1 Error writing at address: 0001ACE2D000 , error: -1, CMD Timeout Error ... Retry #1 Error writing at address: 000231723000 , error: -1, CMD Timeout Error ... Retry #1 Done writing partition. Write speed: 3838.84 KB/s All done time: [00:36:09:309] |
