Old 01-21-2023, 07:42   #1 (permalink)
4G Telecom's Avatar
Member: 2421242
Sonork: 100.1614558
Thanks Meter: 700
Strange Problem KMDP60018M
strange problem occurred
i updated the FFU 64 gb eMMC
After Update ffu showing 32 gb
Now what can happen that the same situation comes again
Before update firmware
Looking for EasyJTAG box...
 EasyJTAG API ver. 3403
 Setting IO Levels to 1.8V
 Setting frequence to 36 MHz
 EasyJTAG Box Serial = A974901B7FD37CCE
 EasyJTAG Box Firmware = 2.5302
 Setting interface to EasyJtag2/ISP_HiPower
 Setting bus width to 1 Bit
 HiPower mode is ON
 CMD Pullup Level: 1802 mV
 CMD Active Level: 1854 mV
 eMMC Init returned = 0
 EMMC Device Information :
 EMMC CID: 150100445036384D4202E3C290FAC89B
 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D
 EMMC Manufacture : SAMSUNG , EMMC NAME: DP68MB , HEX: 445036384D42 , S/N: E3C290FA , rev. 0x02
 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 12/2021
 EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000)
 EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
 EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 0 , Response: Clean
 EMMC Permanent Write Protection: No
 EMMC Temporary Write Protection: No
 Extended CSD Information :
 Extended CSD rev: 1.8 (MMC 5.1)
 Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1)
 Boot Bus Config: 0x00 , width 1bit
 H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
 Supported partition features [PARTITIONING_SUPPORT]: 0x07
 Device supports partitioning features
 Device can have enhanced technological features in partitions and user data area
 Device can have extended partitions attribute
 Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
 Backup saved: DP68MB_E3C290FA_20230120_164536.extcsd
 EMMC Init completed.
after update firmware logs.....
 HiPower mode is ON
 EMMC CSD: 902701320F5903FFF6DB7FE08A40403B
 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000)
 Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot
 H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled
 Backup saved: DP68MB_E3C290FA_20230120_170845.extcsd
Any solution?
Z3x Team
Old 01-22-2023, 11:53   #2 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
use another firmware
some different flash IC can have some firmware
and some flash IC can have different firmware
Page generated in 0.14285 seconds with 9 queries
