Please Help I'm Try to read emmcdump then i face this issue Z3X EasyJtag Software ver. 3.7.0.20 Loading eMMC GEN2 Firmware... IO: 3300 mV Box S/N: 85ACDFEAD0FD46F2, ,FW Ver.: 02.53 CMD Pullup Level:2119 mV CMD Active Level:2854 mV Box IO Level:3300 mV CLK Rate:24000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100464536324D4200EBD9D36F2785 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 02/2020 Rev.0x0 eMMC NAME: FE62MB , S/N: 3956921199 eMMC NAME (HEX): 464536324D42 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 95 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: FE62MB_3956921199_20210504_0027.extcsd Caution: invalid main GPT header, but valid a backup header! Warning: Invalid CRC on main header data; loaded backup partition table. EFI Table seems to be corrupted (sizeOfPartitionEntries!=128) sizeOfPartitionEntries = 0 mmc_read_blocks(0x3AB400200 > 0x3AB400000 ), Read address is invalid Warning! Read error 0 ! Misbehavior now likely! Caution! After loading partitions, the CRC doesn't check out! Warning! Main partition table CRC mismatch! Loaded backup Warning! One or more CRCs don't match. You should repair the disk! Invalid partition data! Partition info not found Done. |
whet for the next update |
Hello mate , What’s the state of the phone to which this chip was connected ? There can be two reason either the partition table of the chip is corrupted so it’s kinda difficult to read dump or the chip itself has malfunctioned and it needs to be repaired or replaced . |
