Old 05-03-2021, 20:29   #1 (permalink)
Crazy Poster
Member: 2714896
Please Help I'm Try to read emmcdump then i face this issue
Z3X EasyJtag Software ver. 3.7.0.20
Loading eMMC GEN2 Firmware... IO: 3300 mV
Box S/N: 85ACDFEAD0FD46F2, ,FW Ver.: 02.53
CMD Pullup Level:2119 mV
CMD Active Level:2854 mV
Box IO Level:3300 mV
CLK Rate:24000 kHz
Bus Width:1bit,SDR
HiPower mode is off!
---------- eMMC Device Information ----------
eMMC CID : 150100464536324D4200EBD9D36F2785
eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D
eMMC Manufacturer ID: 0015 , OEM ID: 0100
eMMC Date: 02/2020 Rev.0x0
eMMC NAME: FE62MB , S/N: 3956921199
eMMC NAME (HEX): 464536324D42
EMMC ROM1 (Main User Data) Capacity: 15028 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB
EMMC RPMB is programmed and written 95 times
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area)
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: FE62MB_3956921199_20210504_0027.extcsd
Caution: invalid main GPT header, but valid a backup header!
Warning: Invalid CRC on main header data; loaded backup partition table.
EFI Table seems to be corrupted (sizeOfPartitionEntries!=128) sizeOfPartitionEntries = 0
mmc_read_blocks(0x3AB400200 > 0x3AB400000 ), Read address is invalid
Warning! Read error 0 ! Misbehavior now likely!
Caution! After loading partitions, the CRC doesn't check out!
Warning! Main partition table CRC mismatch! Loaded backup
Warning! One or more CRCs don't match. You should repair the disk!
Invalid partition data!
Partition info not found
Done.
Old 05-03-2021, 20:56   #2 (permalink)
Member: 2094935
Thanks Meter: 13
whet for the next update
Old 05-05-2021, 08:40   #3 (permalink)
Member: 2868909
Thanks Meter: 32
Hello mate ,
What’s the state of the phone to which this chip was connected ?
There can be two reason either the partition table of the chip is corrupted so it’s kinda difficult to read dump or the chip itself has malfunctioned and it needs to be repaired or replaced .
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.13551 seconds with 7 queries
