09-13-2020, 11:15 | #1 (permalink) |
Freak Poster Join Date: Jul 2015
Member: 2425099 Status: Offline Thanks Meter: 26 | a500f after flash dead I tried repair boot With Easy-Jtag and aft but phone no power .is dead please help me solution log Easy-Jtag ---------- eMMC Device Information ---------- eMMC CID : 150100513331334D4200D6DE6A579222 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 09/2015 Rev.0x0 eMMC NAME: Q313MB , S/N: 3604900439 eMMC NAME (HEX): 513331334D42 IC Name: Samsung , KMQ310013M-B419/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 40 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: Q313MB_3604900439_20200911_2054.extcsd Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 1D5A000 sectors 14.7 GiB Soft (Partitioned) Disk/Image size: 1D59FBC sectors 14.7 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,30777310 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x000BFFF000 (2.246GB) Short EXT fs info: Size: 2.246GB Block size: 4.0KB Inode size: 256 Inodes: 147456 Short Android info: Build ID: MMB29M Display Build ID: MMB29M.A500FXXS1CPL2 Release Incremental ID: A500FXXS1CPL2 Release Base ID: 6.0.1 Security Path: 2016-12-01 Device Model: SM-A500F Device Manufacturer: samsung Device Name A: a5ltexx Device Name B: a5lte Device Board Name: MSM8916 Architecture ABI: armeabi-v7a Device manufacturer: samsung Device Platform: msm8916 Product ID: a5lte Build Description: a5ltexx-user 6.0.1 MMB29M A500FXXS1CPL2 release-keys PDA ver.: A500FXXS1CPL2 Hidden ver.: A500FXXS1CPL2 Samsung CPU: MSM8916 Backup saved: BuildProp_20200911_2054.txt --------------------------------------------- Detected USERDATA USERDATA : 0x00B23FF000 (11.889GB) Short EXT fs info: Size: 4.0GB Block size: 4.0KB Inode size: 256 Inodes: 131072 Short userdata info: Unable to read gesture.key , code 2 Done. log atf 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 150100513331334D4200D6DE6A579223 CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Boot Information Revision 1.7 (for MMC v5.0, v5.01) BOOT PARTITION : NOT BOOT ENABLED PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 15758000128 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 4096 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : Q313MB Product Rev : 0.0 Product SN : D6DE6A57 Manufactured : January 1999 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 150100513331334D4200D6DE6A579223.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Start Writing Flash Images... Flash Image: MBR + PGPT Start Writing 0x00000032 Blocks at 0x00000000 Partition Selected: USER AREA Total Elapsed Time 00:00:00 Write Success! Flash Image: PIT Start Writing 0x00000009 Blocks at 0x00000022 Partition Selected: USER AREA Total Elapsed Time 00:00:00 Write Success! Flash Image: SGPT Start Writing 0x00000021 Blocks at 0x01D59FDF Partition Selected: USER AREA Total Elapsed Time 00:00:00 Write Success! Flash Image: aboot.mbn Start Writing 0x00001000 Blocks at 0x000267C0 Partition Selected: USER AREA Total Elapsed Time 00:00:04 Write Success! Flash Image: sbl1.mbn Start Writing 0x00000400 Blocks at 0x00026380 Partition Selected: USER AREA Total Elapsed Time 00:00:01 Write Success! Flash Image: rpm.mbn Start Writing 0x00000400 Blocks at 0x000277C0 Partition Selected: USER AREA Total Elapsed Time 00:00:01 Write Success! Flash Image: tz.mbn Start Writing 0x00000400 Blocks at 0x00027BC0 Partition Selected: USER AREA Total Elapsed Time 00:00:01 Write Success! Flash Image: hyp.mbn Start Writing 0x00000400 Blocks at 0x00027FC0 Partition Selected: USER AREA Total Elapsed Time 00:00:01 Write Success! Flash Image: non-hlos.bin Start Writing 0x00007800 Blocks at 0x00002000 Partition Selected: USER AREA Total Elapsed Time 00:00:26 Write Success! Total Images Written: 6 Process Done! |
The Following User Says Thank You to sadeghz For This Useful Post: |
