10-25-2021, 09:29 | #1 (permalink) |
No Life Poster Join Date: Nov 2010 Location: RSA-2048 Age: 38
Member: 1444462 Status: Offline Thanks Meter: 1,337 | WORLD 1'ST EXCLUSIVE A127F A12 [Exynos 850] ISP PINOUT FRP RESET and DUMP FILE READ Code: EasyJtag Suite Classic ver.: 3.7.0.20 / wxWidgets 3.1.3-W-U started. OS ver.: Windows 7 (build 7601, Service Pack 1). Admin rights OK Autorun Agent ver:1.0.0.0 Crash Reporting ver:1.4.0.3 EasyJTAG SPI Plugin ver:1.1.1.13 Android ADB API ver:2.0.0.0 FTDI API ver:3.2.4.0 LibUSB API ver:1.2.6.0 Visual C++ Runtime ver:10.0.30319.1 Setting box Pinout ... Box Drivers version: 3.0.0.0 Z3X Card Serial : AA27-78BA , ver: 22 Z3X Card Activation [JTAGPLUS] : ACTIVATED Z3X Card Activation [LG] : NOT ACTIVATED Z3X Card Activation [SAMS] : NOT ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED For more information press F1 to open local help or visit our wiki Found 1 serial devices COM4 USB\VID_1781&PID_AAAC&REV_0100&MI_00 Easy Jtag Plus Control Port (COM4) Selected pinout: GEN2 ISP Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.7.0.20 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: F6F272D292237F2E, ,FW Ver.: 02.53 CMD Pullup Level:2089 mV CMD Active Level:2257 mV Box IO Level:2800 mV CLK Rate:6000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 15010044503644414200E1E0D3E3789B eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 07/2005 Rev.0x0 eMMC NAME: DP6DAB , S/N: 3789607907 eMMC NAME (HEX): 445036444142 EMMC ROM1 (Main User Data) Capacity: 59640 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 404 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: DP6DAB_3789607907_20211024_1937.extcsd Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB Soft (Partitioned) Disk/Image size: 747BFBC sectors 58.2 GiB Disk identifier (GUID): 52444E41-494F-2044-4D4D-43204449534B Logical sector size: 0x200 bytes ,First/Last usable sector: 34,122142686 Partition info successfully found ------ Detected 38 partitions ------ P0 (EFS) [0x400000 0x1400000] Size: 20.0MB P1 (SEC_EFS) [0x1800000 0x1400000] Size: 20.0MB P2 (RESERVED) [0x2c00000 0x400000] Size: 4.0MB P3 (CPEFS) [0x3000000 0x800000] Size: 8.0MB P4 (STEADY) [0x3800000 0x400000] Size: 4.0MB P5 (PARAM) [0x3c00000 0x800000] Size: 8.0MB P6 (BOTA) [0x4400000 0x2400000] Size: 36.0MB P7 (LDFW) [0x6800000 0x800000] Size: 8.0MB P8 (TZSW) [0x7000000 0x180000] Size: 1.500MB P9 (TZAR) [0x7180000 0x680000] Size: 6.500MB P10 (KEYSTORAGE) [0x7800000 0x80000] Size: 512.0KB P11 (NAD_REFER) [0x7880000 0x100000] Size: 1.0MB P12 (UP_PARAM) [0x7980000 0x800000] Size: 8.0MB P13 (MISC) [0x8180000 0x200000] Size: 2.0MB P14 (UH) [0x8380000 0x200000] Size: 2.0MB P15 (UHCFG) [0x8580000 0x400000] Size: 4.0MB P16 (BLCMD) [0x8980000 0x80000] Size: 512.0KB P17 (BOOT) [0x8a00000 0x2c00000] Size: 44.0MB P18 (RECOVERY) [0xb600000 0x3500000] Size: 53.0MB P19 (DTB) [0xeb00000 0x800000] Size: 8.0MB P20 (DTBO) [0xf300000 0x800000] Size: 8.0MB P21 (RADIO) [0xfb00000 0x3200000] Size: 50.0MB P22 (PERSISTENT) [0x12d00000 0x80000] Size: 512.0KB P23 (VBMETA) [0x12d80000 0x80000] Size: 512.0KB P24 (VBMETA_SYSTEM) [0x12e00000 0x80000] Size: 512.0KB P25 (KEYREFUGE) [0x12e80000 0x1000000] Size: 16.0MB P26 (KEYDATA) [0x13e80000 0x1000000] Size: 16.0MB P27 (METADATA) [0x14e80000 0x2000000] Size: 32.0MB P28 (FMP_SELFTEST) [0x16e80000 0x1000] Size: 4.0KB P29 (RESERVED2) [0x16e81000 0x17f000] Size: 1.496MB P30 (SUPER) [0x17000000 0x152800000] Size: 5.289GB P31 (PRISM) [0x169800000 0x37000000] Size: 880.0MB P32 (OPTICS) [0x1a0800000 0x1800000] Size: 24.0MB P33 (CACHE) [0x1a2000000 0xc800000] Size: 200.0MB P34 (OMR) [0x1ae800000 0x3200000] Size: 50.0MB P35 (CP_DEBUG) [0x1b1a00000 0x500000] Size: 5.0MB P36 (SPU) [0x1b1f00000 0x3200000] Size: 50.0MB P37 (USERDATA) [0x1b5100000 0xcda000000] Size: 51.406GB ------------------------------------ ------ Android information ------ Detected LINUX(Android) SUPER : 0x0017000000 (5.289GB) Unable to mount SYSTEM , code : 95 --------------------------------------------- Detected USERDATA USERDATA : 0x01B5100000 (51.406GB) Unable to mount USERDATA , code : 95 Userdata Superblock contents:: B7002C59 A11716E4 FE6DBBEE D52ACF7A 95F759A6 B531EBE9 DA20F7B3 86EFF17F ·.,Y¡..äþm»îÕ*Ïz•÷Y¦µ1ëéÚ ÷³†ïñ.; C6069DB2 42D613CF F07ED426 F3C1EDB7 ECA19078 BD4FCF7B 131A7DF5 89BA8314 Æ..²BÖ.Ïð~Ô&óÁí·ì¡.x½OÏ{..}õ‰ºƒ.; 4538E8E4 2C6D41CD 02D4C4C3 E8E0FE77 C6CD668A B96287CD 9CC51EBC 96451FCC E8èä,mAÍ.ÔÄÃèàþwÆÍfŠ¹b‡ÍœÅ.¼–E.Ì; DFE9B85B 98A0B296 F233AB44 806B33ED 62BDF34C 951D4790 8399EEF0 E54AAF18 ßé¸[.*²–ò3«D.k3íb½óL•.G.ƒ.îðåJ¯.; 453DB693 40F28B97 E4578242 97BFD6D8 1E9D78E0 27BB2BFE AA0954A2 99E156F5 E=¶“@ò‹—äW‚B—¿ÖØ..xà'»+þª T¢.áVõ; 5FB1A5AE DD9CF7DE C1E2A4D8 9C5B983D 781B1689 6C073429 56D5C201 792C646B _±¥®Ýœ÷ÞÁâ¤Øœ[.=x..‰l.4)VÕÂ.y,dk; 90C8F789 AAE3204D 34724668 8F9421C2 55B8DD2D 80E8EBE1 2CF3AE83 3108AA0A .È÷‰ªã M4rFh.”!ÂU¸Ý-.èëá,ó®ƒ1.ª.; 4FFD9952 74910C88 30AB66FB C5D8D53B 8CF537F1 71BAA247 3DF08C11 BD1AFF5B Oý.Rt‘..0«fûÅØÕ;Œõ7ñqº¢G=ðŒ.½.ÿ[; Done. Checking security ... Running:Format FRP Partition... Z3X EasyJtag Software ver. 3.7.0.20 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: F6F272D292237F2E, ,FW Ver.: 02.53 CMD Pullup Level:2092 mV CMD Active Level:2260 mV Box IO Level:2800 mV CLK Rate:6000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 15010044503644414200E1E0D3E3789B eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 07/2005 Rev.0x0 eMMC NAME: DP6DAB , S/N: 3789607907 eMMC NAME (HEX): 445036444142 EMMC ROM1 (Main User Data) Capacity: 59640 MB , 0x747C000 pages , 0xE8F800000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 404 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB Soft (Partitioned) Disk/Image size: 747BFBC sectors 58.2 GiB Disk identifier (GUID): 52444E41-494F-2044-4D4D-43204449534B Logical sector size: 0x200 bytes ,First/Last usable sector: 34,122142686 Partition info successfully found Formatting FRP... Detected LINUX(Android) PERSISTENT : 0x0012D00000 (512.0KB) formatting... Done. Detected LINUX(Android) CACHE : 0x01A2000000 (200.0MB) , formatting... Done. Detected LINUX(Android) USERDATA : 0x01B5100000 (51.406GB) , formatting... Done. Done. Done. Z3X EasyJtag EMMC File Manager v 1.18 at 29/06/2020 Started.. Box API Version: 3401 FS Driver Version: 29062020 SQLite Version: 3.32.0 FSCK Engine Version: 29062020 ESE DB Version: 29062020 System Util Version: 29062020 System: Windows NT 6.1 (Build 7601, Service Pack 1) / 32 BIT CPU: Intel(R) Core(TM) i5-3230M CPU @ 2.60GHz Total RAM: 2.89 GB Telegram Support: https://t.me/z3xefm FRP Apps: http://efm.easy-jtag.com/frp/ Z3X Card Serial: AA2778BA EasyJtag Plus Box Found at: COM4 EasyJtag Plus Box Firmware: 2.53.1 Source: EasyJtag Port [EMMC/SD/MMC] Generation: GPT [QC/SAMS/BCM/INTEL/MTK] Box Voltage set to: 2800 mV Scanner Thread Created.. Config: 1011111111101111 Setup HiPower CLK: OFF Connecting To EasyJtag Plus Box: 2800mV/4MHz/1BIT EasyJtag Plus Box Found! Result: 0/OK CMD Pullup Level: 2087 mV CMD Active Level: 2257 mV EasyJtag Plus S/N: F6F272D292237F2E EasyJtag Plus Box FirmWare: 2.53 Box Bus Width = 1 BIT Box Hardware = EasyJtag 2nd Generation Search EMMC Chip... EMMC Chip Found! 0/OK EMMC CID: 15010044503644414200E1E0D3E3789B EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC VENDOR: SAMSUNG EMMC NAME: DP6DAB EMMC SERIAL: E1E0D3E3 EMMC REVISION: 00 EMMC ROM1 Size: 122142720 Block(s)/59640 MB EMMC ROM2/3 Size: 8192 Block(s)/4096 KB EMMC RPMB Size: 32768 Block(s)/16384 KB EMMC RPMB Counter: 404 EMMC RPMB Answer: 0/OK Switch To ROM1 Part: 0/OK EMMC REV: 1.8 (for MMC v5.1) EMMC VER: MMC 5.1 EMMC DEV Life Time: 0x01 -> Normal EMMC MLC Life Time: 0x01 -> 0% - 10% Life Time Used EMMC SLC Life Time: 0x01 -> 0% - 10% Life Time Used EMMC Boot Config: 0x48/0x01/0x01 ExtCSD Automatically Saved.. Scanning Data From EMMC. Please wait.. Scanning GUID Partition Table from ROM1 GUID Partition Table is Found. Max Parts: 128 GPT: GPT [000000000000 - 000000004400] Size: 17.00 KB GPT: EFS [000000400000 - 000001400000] Size: 20.00 MB GPT: SEC_EFS [000001800000 - 000001400000] Size: 20.00 MB GPT: RESERVED [000002C00000 - 000000400000] Size: 4.00 MB GPT: CPEFS [000003000000 - 000000800000] Size: 8.00 MB GPT: STEADY [000003800000 - 000000400000] Size: 4.00 MB GPT: PARAM [000003C00000 - 000000800000] Size: 8.00 MB GPT: BOTA [000004400000 - 000002400000] Size: 36.00 MB GPT: LDFW [000006800000 - 000000800000] Size: 8.00 MB GPT: TZSW [000007000000 - 000000180000] Size: 1.50 MB GPT: TZAR [000007180000 - 000000680000] Size: 6.50 MB GPT: KEYSTORAGE [000007800000 - 000000080000] Size: 512.00 KB GPT: NAD_REFER [000007880000 - 000000100000] Size: 1.00 MB GPT: UP_PARAM [000007980000 - 000000800000] Size: 8.00 MB GPT: MISC [000008180000 - 000000200000] Size: 2.00 MB GPT: UH [000008380000 - 000000200000] Size: 2.00 MB GPT: UHCFG [000008580000 - 000000400000] Size: 4.00 MB GPT: BLCMD [000008980000 - 000000080000] Size: 512.00 KB GPT: BOOT [000008A00000 - 000002C00000] Size: 44.00 MB GPT: RECOVERY [00000B600000 - 000003500000] Size: 53.00 MB GPT: DTB [00000EB00000 - 000000800000] Size: 8.00 MB GPT: DTBO [00000F300000 - 000000800000] Size: 8.00 MB GPT: RADIO [00000FB00000 - 000003200000] Size: 50.00 MB GPT: PERSISTENT [000012D00000 - 000000080000] Size: 512.00 KB GPT: VBMETA [000012D80000 - 000000080000] Size: 512.00 KB GPT: VBMETA_SYSTEM [000012E00000 - 000000080000] Size: 512.00 KB GPT: KEYREFUGE [000012E80000 - 000001000000] Size: 16.00 MB GPT: KEYDATA [000013E80000 - 000001000000] Size: 16.00 MB GPT: METADATA [000014E80000 - 000002000000] Size: 32.00 MB GPT: FMP_SELFTEST [000016E80000 - 000000001000] Size: 4.00 KB GPT: RESERVED2 [000016E81000 - 00000017F000] Size: 1.50 MB GPT: SUPER [000017000000 - 000152800000] Size: 5.29 GB GPT: PRISM [000169800000 - 000037000000] Size: 880.00 MB GPT: OPTICS [0001A0800000 - 000001800000] Size: 24.00 MB GPT: CACHE [0001A2000000 - 00000C800000] Size: 200.00 MB GPT: OMR [0001AE800000 - 000003200000] Size: 50.00 MB GPT: CP_DEBUG [0001B1A00000 - 000000500000] Size: 5.00 MB GPT: SPU [0001B1F00000 - 000003200000] Size: 50.00 MB GPT: USERDATA [0001B5100000 - 000CDA000000] Size: 51.41 GB GPT: BACKUP_GPT [000E8F7FBE00 - 000000004200] Size: 16.50 KB Reading Table Completed Scanning GUID Partition Table from ROM2 GPT Signature Not Found. Break.. Scanning GUID Partition Table from ROM3 GPT Signature Not Found. Break.. Partition #5 mount as [/mnt/vendor/efs] -> 20.00 MB Partition #6 mount as [/efs] -> 20.00 MB Partition #8 mount as [/mnt/vendor/cpefs] -> 8.00 MB Partition #32 mount as [/metadata] -> 32.00 MB Partition #36 mount as [/prism] -> 880.00 MB Partition #37 mount as [/optics] -> 24.00 MB Partition #39 mount as [/omr] -> 50.00 MB Partition #41 mount as [/spu] -> 50.00 MB EmptyCheck: EMPTY -> #6 - [RESERVED] EMPTY -> #9 - [PARAM] EMPTY -> #10 - [BOTA] EMPTY -> #17 - [MISC] EMPTY -> #18 - [UH] EMPTY -> #19 - [UHCFG] EMPTY -> #20 - [BLCMD] EMPTY -> #23 - [DTB] EMPTY -> #26 - [PERSISTENT] EMPTY -> #29 - [KEYREFUGE] EMPTY -> #30 - [KEYDATA] EMPTY -> #33 - [RESERVED2] EMPTY -> #37 - [CACHE] EMPTY -> #41 - [USERDATA] EmptyCheck: Done Samsung S/N = RZ8R9108ENJ Scanner Thread Terminated Elapsed: 00:00:14:682 Found 43 Partition(s).. Scan Done. Init Main Engine... Resetting EasyJtag Box. Wait.. CMD Pullup Level: 2087 mV CMD Active Level: 2255 mV Reader Engine Initialized.. 0/OK Source: EasyJtag Port [EMMC/SD/MMC] Generation: GPT [QC/SAMS/BCM/INTEL/MTK] Bus Mode: 1BIT Operation Done: [Init Engine], Elapsed: 00:00:01:582 Z3X EasyJtag EMMC File Manager v 1.18 at 29/06/2020 Started.. Box API Version: 3401 FS Driver Version: 29062020 SQLite Version: 3.32.0 FSCK Engine Version: 29062020 ESE DB Version: 29062020 System Util Version: 29062020 System: Windows NT 6.1 (Build 7601, Service Pack 1) / 32 BIT CPU: Intel(R) Core(TM) i5-3230M CPU @ 2.60GHz Total RAM: 2.89 GB Telegram Support: https://t.me/z3xefm FRP Apps: http://efm.easy-jtag.com/frp/ Z3X Card Serial: AA2778BA EasyJtag Plus Box Found at: COM4 EasyJtag Plus Box Firmware: 2.53.1 Source: EasyJtag Port [EMMC/SD/MMC] Generation: GPT [QC/SAMS/BCM/INTEL/MTK] Box Voltage set to: 2800 mV Scanner Thread Created.. Config: 1011111111101111 Setup HiPower CLK: OFF Connecting To EasyJtag Plus Box: 2800mV/4MHz/1BIT EasyJtag Plus Box Found! Result: 0/OK CMD Pullup Level: 2087 mV CMD Active Level: 2257 mV EasyJtag Plus S/N: F6F272D292237F2E EasyJtag Plus Box FirmWare: 2.53 Box Bus Width = 1 BIT Box Hardware = EasyJtag 2nd Generation Search EMMC Chip... EMMC Chip Found! 0/OK EMMC CID: 15010044503644414200E1E0D3E3789B EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC VENDOR: SAMSUNG EMMC NAME: DP6DAB EMMC SERIAL: E1E0D3E3 EMMC REVISION: 00 EMMC ROM1 Size: 122142720 Block(s)/59640 MB EMMC ROM2/3 Size: 8192 Block(s)/4096 KB EMMC RPMB Size: 32768 Block(s)/16384 KB EMMC RPMB Counter: 404 EMMC RPMB Answer: 0/OK Switch To ROM1 Part: 0/OK EMMC REV: 1.8 (for MMC v5.1) EMMC VER: MMC 5.1 EMMC DEV Life Time: 0x01 -> Normal EMMC MLC Life Time: 0x01 -> 0% - 10% Life Time Used EMMC SLC Life Time: 0x01 -> 0% - 10% Life Time Used EMMC Boot Config: 0x48/0x01/0x01 ExtCSD Automatically Saved.. Scanning Data From EMMC. Please wait.. Scanning GUID Partition Table from ROM1 GUID Partition Table is Found. Max Parts: 128 GPT: GPT [000000000000 - 000000004400] Size: 17.00 KB GPT: EFS [000000400000 - 000001400000] Size: 20.00 MB GPT: SEC_EFS [000001800000 - 000001400000] Size: 20.00 MB GPT: RESERVED [000002C00000 - 000000400000] Size: 4.00 MB GPT: CPEFS [000003000000 - 000000800000] Size: 8.00 MB GPT: STEADY [000003800000 - 000000400000] Size: 4.00 MB GPT: PARAM [000003C00000 - 000000800000] Size: 8.00 MB GPT: BOTA [000004400000 - 000002400000] Size: 36.00 MB GPT: LDFW [000006800000 - 000000800000] Size: 8.00 MB GPT: TZSW [000007000000 - 000000180000] Size: 1.50 MB GPT: TZAR [000007180000 - 000000680000] Size: 6.50 MB GPT: KEYSTORAGE [000007800000 - 000000080000] Size: 512.00 KB GPT: NAD_REFER [000007880000 - 000000100000] Size: 1.00 MB GPT: UP_PARAM [000007980000 - 000000800000] Size: 8.00 MB GPT: MISC [000008180000 - 000000200000] Size: 2.00 MB GPT: UH [000008380000 - 000000200000] Size: 2.00 MB GPT: UHCFG [000008580000 - 000000400000] Size: 4.00 MB GPT: BLCMD [000008980000 - 000000080000] Size: 512.00 KB GPT: BOOT [000008A00000 - 000002C00000] Size: 44.00 MB GPT: RECOVERY [00000B600000 - 000003500000] Size: 53.00 MB GPT: DTB [00000EB00000 - 000000800000] Size: 8.00 MB GPT: DTBO [00000F300000 - 000000800000] Size: 8.00 MB GPT: RADIO [00000FB00000 - 000003200000] Size: 50.00 MB GPT: PERSISTENT [000012D00000 - 000000080000] Size: 512.00 KB GPT: VBMETA [000012D80000 - 000000080000] Size: 512.00 KB GPT: VBMETA_SYSTEM [000012E00000 - 000000080000] Size: 512.00 KB GPT: KEYREFUGE [000012E80000 - 000001000000] Size: 16.00 MB GPT: KEYDATA [000013E80000 - 000001000000] Size: 16.00 MB GPT: METADATA [000014E80000 - 000002000000] Size: 32.00 MB GPT: FMP_SELFTEST [000016E80000 - 000000001000] Size: 4.00 KB GPT: RESERVED2 [000016E81000 - 00000017F000] Size: 1.50 MB GPT: SUPER [000017000000 - 000152800000] Size: 5.29 GB GPT: PRISM [000169800000 - 000037000000] Size: 880.00 MB GPT: OPTICS [0001A0800000 - 000001800000] Size: 24.00 MB GPT: CACHE [0001A2000000 - 00000C800000] Size: 200.00 MB GPT: OMR [0001AE800000 - 000003200000] Size: 50.00 MB GPT: CP_DEBUG [0001B1A00000 - 000000500000] Size: 5.00 MB GPT: SPU [0001B1F00000 - 000003200000] Size: 50.00 MB GPT: USERDATA [0001B5100000 - 000CDA000000] Size: 51.41 GB GPT: BACKUP_GPT [000E8F7FBE00 - 000000004200] Size: 16.50 KB Reading Table Completed Scanning GUID Partition Table from ROM2 GPT Signature Not Found. Break.. Scanning GUID Partition Table from ROM3 GPT Signature Not Found. Break.. Partition #5 mount as [/mnt/vendor/efs] -> 20.00 MB Partition #6 mount as [/efs] -> 20.00 MB Partition #8 mount as [/mnt/vendor/cpefs] -> 8.00 MB Partition #32 mount as [/metadata] -> 32.00 MB Partition #36 mount as [/prism] -> 880.00 MB Partition #37 mount as [/optics] -> 24.00 MB Partition #39 mount as [/omr] -> 50.00 MB Partition #41 mount as [/spu] -> 50.00 MB EmptyCheck: EMPTY -> #6 - [RESERVED] EMPTY -> #9 - [PARAM] EMPTY -> #10 - [BOTA] EMPTY -> #17 - [MISC] EMPTY -> #18 - [UH] EMPTY -> #19 - [UHCFG] EMPTY -> #20 - [BLCMD] EMPTY -> #23 - [DTB] EMPTY -> #26 - [PERSISTENT] EMPTY -> #29 - [KEYREFUGE] EMPTY -> #30 - [KEYDATA] EMPTY -> #33 - [RESERVED2] EMPTY -> #37 - [CACHE] EMPTY -> #41 - [USERDATA] EmptyCheck: Done Samsung S/N = RZ8R9108ENJ Scanner Thread Terminated Elapsed: 00:00:14:682 Found 43 Partition(s).. Scan Done. Init Main Engine... Resetting EasyJtag Box. Wait.. CMD Pullup Level: 2087 mV CMD Active Level: 2255 mV Reader Engine Initialized.. 0/OK Source: EasyJtag Port [EMMC/SD/MMC] Generation: GPT [QC/SAMS/BCM/INTEL/MTK] Bus Mode: 1BIT Operation Done: [Init Engine], Elapsed: 00:00:01:582 Reset Google FRP v1.0 Search FRP Partition.. Partition FRP Not Found. Break.. Elapsed Time: [00:00:00:255] Operation Done: [RESET FRP], Elapsed: 00:00:00:278 Code: eMMC_tool Suite ver. 1.6.6.0 (release date: 05.05.2021) Microsoft Windows 7 (32 bit) build 7601 (6.1.7600.16385) Looking for EasyJTAG box... EasyJTAG API ver. 3403 EasyJTAG Box Serial = F6F272D292237F2E Card Serial = AA2778BA EasyJTAG Box Firmware = 2.5301 Changelog: 05.05.2021 (ver 1.6.6.0) Add: New keys for Oppo unpack Fix: Bugs that have been found through your crash report 05.05.2021 (ver 2.0.1.0) Add: Vendor LG Add: Mediatek Preloader Parser Add: OnePlus Unpacker Add: Xiaomi Custom EDL Authorization Add: Xiaomi Remove Mi Account (only Qualcomm) Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 24 MHz CMD Pullup Level: 2081 mV CMD Active Level: 2255 mV EMMC Device Information : EMMC CID: 15010044503644414200E1E0D3E3789B EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: DP6DAB , HEX: 445036444142 , S/N: E1E0D3E3 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 7/2021 EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 404 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: DP6DAB_E1E0D3E3_20211024_194219.extcsd EMMC Init completed. Operation: Reading from eMMC... Reading from: ROM1 , start: 0x000000000000 , size: 0x000080000000 Output file: C:\Program Files\Z3X\EASYJTAGPLUS\A127F DUMP\EMMC_NONAME_ROM1_000000000000_000080000000.bin eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2839.96 Kb/s All done time: [00:12:18:809] Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 24 MHz CMD Pullup Level: 2086 mV CMD Active Level: 2255 mV EMMC Device Information : EMMC CID: 15010044503644414200E1E0D3E3789B EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: DP6DAB , HEX: 445036444142 , S/N: E1E0D3E3 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 7/2021 EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 404 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: DP6DAB_E1E0D3E3_20211024_195619.extcsd EMMC Init completed. Operation: Reading from eMMC... Reading from: ROM2 , start: 0x000000000000 , size: 0x000000400000 Output file: C:\Program Files\Z3X\EASYJTAGPLUS\A127F DUMP\EMMC_DP6DAB_ROM2_000000000000_000000400000.bin eMMC switching to ROM2 Reading partition... Done reading partition. Read speed: 2198.99 Kb/s All done time: [00:00:02:104] Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 24 MHz CMD Pullup Level: 2086 mV CMD Active Level: 2257 mV EMMC Device Information : EMMC CID: 15010044503644414200E1E0D3E3789B EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: DP6DAB , HEX: 445036444142 , S/N: E1E0D3E3 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 7/2021 EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 404 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: DP6DAB_E1E0D3E3_20211024_195639.extcsd EMMC Init completed. Operation: Reading from eMMC... Reading from: ROM3 , start: 0x000000000000 , size: 0x000000400000 Output file: C:\Program Files\Z3X\EASYJTAGPLUS\A127F DUMP\EMMC_DP6DAB_ROM3_000000000000_000000400000.bin eMMC switching to ROM3 Reading partition... Done reading partition. Read speed: 2211.76 Kb/s All done time: [00:00:02:156] |
The Following 25 Users Say Thank You to ..::GMSR::.. For This Useful Post: |
12-28-2021, 06:39 | #8 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Anwar Telecom .DHAKA Age: 38
Member: 896667 Status: Offline Sonork: 100.1586139 Thanks Meter: 1,596 | Isp Pinout Working 100% Tested Thanks Bro (..::GMSR::..) |
The Following 2 Users Say Thank You to dvd_anwar For This Useful Post: |
01-08-2022, 06:03 | #11 (permalink) |
No Life Poster Join Date: Sep 2004 Location: coast Age: 53
Member: 83397 Status: Offline Thanks Meter: 204 | |
02-01-2022, 07:26 | #14 (permalink) |
Junior Member Join Date: Jul 2009 Location: South Africa
Member: 1086614 Status: Offline Sonork: adfafaf Thanks Meter: 4 | what addapter did you use for isp connection (1 bit rev 2.1 or socket ? |
The Following 2 Users Say Thank You to yasirjan For This Useful Post: |
