07-15-2019, 16:33 | #693 (permalink) |
Freak Poster Join Date: Nov 2007 Location: Pakistan
Member: 628369 Status: Offline Sonork: 100.1609794 Thanks Meter: 48 | Vivo Y95 pattern frp successfully done with easyjtag Z3X EasyJtag Software ver. 3.5.0.1 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 0C00200394B8F938, ,FW Ver.: 01.63 CMD Pullup Level:2072 mV CMD Active Level:2640 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 90014A484347386134A24D552014A508 eMMC CSD : D02701328F5903FFFFFFFFEF8A400026 eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 10/2018 Rev.0xA2 eMMC NAME: HCG8a4 , S/N: 1297424404 eMMC NAME (HEX): 484347386134 EMMC ROM1 (Main User Data) Capacity: 59640 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 63482 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: HCG8a4_1297424404_20190715_2005.extcsd Done. Running:Reset PIN/PASS/GESTURE Locks Z3X EasyJtag Software ver. 3.5.0.1 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 0C00200394B8F938, ,FW Ver.: 01.63 CMD Pullup Level:2052 mV CMD Active Level:2640 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 90014A484347386134A24D552014A508 eMMC CSD : D02701328F5903FFFFFFFFEF8A400026 eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 10/2018 Rev.0xA2 eMMC NAME: HCG8a4 , S/N: 1297424404 eMMC NAME (HEX): 484347386134 EMMC ROM1 (Main User Data) Capacity: 59640 MB , 0x747C000 pages , 0xE8F800000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is not yet programmed (clear) or NO Error EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Partition table scan: GPT: present Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB Soft (Partitioned) Disk/Image size: 747BFBC sectors 58.2 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 First usable sector: 34 Last usable sector: 122142686 Partition info successfully found ------ Android information ------ Detected LINUX(Android) USERDATA : 0x01B3282000 (51.442GB) Mount EXT4 fs... Unable to mount USER , code : 95 --------------------------------------------- Done. Z3X EasyJtag Software ver. 3.5.0.1 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 0C00200394B8F938, ,FW Ver.: 01.63 CMD Pullup Level:2062 mV CMD Active Level:2640 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 90014A484347386134A24D552014A508 eMMC CSD : D02701328F5903FFFFFFFFEF8A400026 eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 10/2018 Rev.0xA2 eMMC NAME: HCG8a4 , S/N: 1297424404 eMMC NAME (HEX): 484347386134 EMMC ROM1 (Main User Data) Capacity: 59640 MB , 0x747C000 pages , 0xE8F800000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is not yet programmed (clear) or NO Error EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Partition table scan: GPT: present Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB Soft (Partitioned) Disk/Image size: 747BFBC sectors 58.2 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 First usable sector: 34 Last usable sector: 122142686 Partition info successfully found ------ Android information ------ Detected LINUX(Android) CACHE : 0x018B000000 (256.0MB) Erasing... Done. Detected LINUX(Android) USERDATA : 0x01B3282000 (51.442GB) Erasing... Done. --------------------------------------------- Done. Running:Format FRP Partition... Z3X EasyJtag Software ver. 3.5.0.1 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 0C00200394B8F938, ,FW Ver.: 01.63 CMD Pullup Level:2062 mV CMD Active Level:2382 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 90014A484347386134A24D552014A508 eMMC CSD : D02701328F5903FFFFFFFFEF8A400026 eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 10/2018 Rev.0xA2 eMMC NAME: HCG8a4 , S/N: 1297424404 eMMC NAME (HEX): 484347386134 EMMC ROM1 (Main User Data) Capacity: 59640 MB , 0x747C000 pages , 0xE8F800000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is not yet programmed (clear) or NO Error EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Partition table scan: GPT: present Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB Soft (Partitioned) Disk/Image size: 747BFBC sectors 58.2 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 First usable sector: 34 Last usable sector: 122142686 Partition info successfully found Formatting FRP... Detected LINUX(Android) CACHE : 0x018B000000 (256.0MB) , formatting... Detected LINUX(Android) CONFIG : 0x019D180000 (32.0KB) formatting... Detected LINUX(Android) USERDATA : 0x01B3282000 (51.442GB) , formatting... Done. Done. |
07-28-2019, 05:34 | #694 (permalink) |
Freak Poster Join Date: Jan 2011 Location: viet nam
Member: 1486276 Status: Offline Thanks Meter: 39 | EasyJtag_Release_v3.6.1.9.rar https://drive.google.com/file/d/1wm6...oa0Pm8lwW/view |
08-07-2019, 11:14 | #695 (permalink) |
Freak Poster Join Date: Feb 2011 Location: Aegean Sea
Member: 1520712 Status: Offline Thanks Meter: 19 | i want to learn how can we do recovery from monolithik micro sd card with easy jtag plus is any solution ? a step by step tutorial video or something? i thing that needs a logic analyzer tool and some pinout from cards is very late i know but it will be very helpful for all users easy jtag plus |
08-08-2019, 18:14 | #696 (permalink) |
No Life Poster Join Date: Aug 2017 Location: India
Member: 2746336 Status: Offline Sonork: NULL Thanks Meter: 47 | S7562 hang on logo, no download mode, done with easy jtag plus : 8/5/2019 5:17:41 PM> Setting interface to EasyJtag2/ISP 8/5/2019 5:17:41 PM> Setting bus width to 1 Bit 8/5/2019 5:17:41 PM> Setting frequence to 1 MHz 8/5/2019 5:17:41 PM> CMD Pullup Level: 1821 mV 8/5/2019 5:17:41 PM> CMD Active Level: 1881 mV 8/5/2019 5:17:41 PM> eMMC Init returned = 0 8/5/2019 5:17:41 PM> EMMC Device Information : 8/5/2019 5:17:41 PM> EMMC CID: 1501004A4A53303041039982755E2129 8/5/2019 5:17:41 PM> EMMC CSD: D02701320F5903FFF6DBFFE78A404057 8/5/2019 5:17:41 PM> EMMC Manufacture : SAMSUNG , EMMC NAME: JJS00A , HEX: 4A4A53303041 , S/N: 9982755E , rev. 0x03 8/5/2019 5:17:41 PM> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 2/2014 8/5/2019 5:17:41 PM> EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) 8/5/2019 5:17:41 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 1024 KB (000000100000) 8/5/2019 5:17:41 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 128 KB (000000020000) Counter: 0 , Response: Clean 8/5/2019 5:17:41 PM> EMMC Permanent Write Protection: No 8/5/2019 5:17:41 PM> EMMC Temporary Write Protection: No 8/5/2019 5:17:41 PM> Extended CSD Information : 8/5/2019 5:17:41 PM> Extended CSD rev: 1.5 (MMC 4.41) 8/5/2019 5:17:41 PM> Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot 8/5/2019 5:17:41 PM> Boot Bus Config: 0x00 , width 1bit 8/5/2019 5:17:41 PM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 8/5/2019 5:17:41 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x03 8/5/2019 5:17:41 PM> Device supports partitioning features 8/5/2019 5:17:41 PM> Device can have enhanced technological features in partitions and user data area 8/5/2019 5:17:41 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 8/5/2019 5:17:41 PM> Backup saved: JJS00A_9982755E_20190805_171741.extcsd 8/5/2019 5:17:41 PM> EMMC Init completed. 8/5/2019 5:17:41 PM> 8/5/2019 5:17:42 PM> Scanning soft partitions 8/5/2019 5:17:42 PM> GPT header is not found 8/5/2019 5:17:42 PM> MBR header is found. Analyzing data ... 8/5/2019 5:17:42 PM> Partition: mmcblk0p0 [000000000200 - 000000005200], size: 000000005000 (20.0 KB) 8/5/2019 5:17:42 PM> Partition: mmcblk0p1 [000000005200 - 00000002AA00], size: 000000025800 (150. KB) 8/5/2019 5:17:42 PM> Partition: mmcblk0p2 [00000002AA00 - 00000142AA00], size: 000001400000 (20.0 MB) 8/5/2019 5:17:42 PM> EBR detected at address: 00000142AA00 8/5/2019 5:17:42 PM> Partition: mmcblk0p3 [000001800000 - 0000018FA000], size: 0000000FA000 8/5/2019 5:17:42 PM> Partition: mmcblk0p4 [0000018FA000 - 0000019F4000], size: 0000000FA000 8/5/2019 5:17:42 PM> Partition: mmcblk0p5 [0000019F4000 - 000001BE8000], size: 0000001F4000 8/5/2019 5:17:42 PM> Partition: mmcblk0p6 [000001BE8000 - 0000027E8000], size: 000000C00000 8/5/2019 5:17:42 PM> Partition: mmcblk0p7 [0000027E8000 - 000002AE8000], size: 000000300000 8/5/2019 5:17:42 PM> Partition: mmcblk0p8 [000002AE8000 - 000002DE8000], size: 000000300000 8/5/2019 5:17:42 PM> Partition: mmcblk0p9 [000002DE8000 - 0000035E8000], size: 000000800000 8/5/2019 5:17:42 PM> Partition: mmcblk0p10 [0000035E8000 - 0000041E8000], size: 000000C00000 8/5/2019 5:17:42 PM> Partition: mmcblk0p11 [0000041E8000 - 0000045E8000], size: 000000400000 8/5/2019 5:17:42 PM> Partition: mmcblk0p12 [0000045E8000 - 0000049E8000], size: 000000400000 8/5/2019 5:17:42 PM> Partition: mmcblk0p13 [0000049E8000 - 000004A68000], size: 000000080000 8/5/2019 5:17:42 PM> Partition: mmcblk0p14 [000004A68000 - 00004FA68000], size: 00004B000000 8/5/2019 5:17:42 PM> Partition: mmcblk0p15 [00004FA68000 - 00006EE68000], size: 00001F400000 8/5/2019 5:17:42 PM> Partition: mmcblk0p16 [00006EE68000 - 00006F068000], size: 000000200000 8/5/2019 5:17:42 PM> Partition: mmcblk0p17 [00006F068000 - 00006FC68000], size: 000000C00000 8/5/2019 5:17:42 PM> Partition: mmcblk0p18 [00006FC68000 - 000071468000], size: 000001800000 8/5/2019 5:17:42 PM> Partition: mmcblk0p19 [000071468000 - 000071868000], size: 000000400000 8/5/2 |
08-09-2019, 14:22 | #698 (permalink) |
No Life Poster Join Date: May 2014 Location: UGANDA
Member: 2185549 Status: Offline Thanks Meter: 535 | SAMSUNG G532F BOOT REPAIR DONE eMMC_tool Suite ver. 1.6.2.0 (release date: 30.06.2019) Microsoft Windows 7 (64 bit) build 7600 (6.1.7600.16385) Looking for EasyJTAG box... EasyJTAG API ver. 3307 EasyJTAG Box Serial = 417A1E88471829FA Card Serial = AAF96E71 EasyJTAG Box Firmware = 2.44 Changelog: 30.06.2019 (ver 1.6.1.0) Fix: Bugs that have been found through your crash report Failed to connect to the server Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 1 MHz CMD Pullup Level: 2806 mV CMD Active Level: 2800 mV EMMC Device Information : EMMC CID: 90014A48384734759201C38364F935E3 EMMC CSD: D02701320F5903FFFFFFFFE78A40002B EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: C38364F9 , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 3/2018 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H8G4u_C38364F9_20190809_143622.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: BOTA0, [000000400000 - 000000800000], size: 000000400000 (4.00 MB) Partition: nvram, [000000800000 - 000001000000], size: 000000800000 (8.00 MB) Partition: lk, [000001000000 - 000001200000], size: 000000200000 (2.00 MB) Partition: BOTA1, [000001200000 - 000001400000], size: 000000200000 (2.00 MB) Partition: secro, [000001400000 - 000001B00000], size: 000000700000 (7.00 MB) Partition: seccfg, [000001B00000 - 000001B80000], size: 000000080000 (512. KB) Partition: efuse, [000001B80000 - 000001C00000], size: 000000080000 (512. KB) Partition: tee1, [000001C00000 - 000002200000], size: 000000600000 (6.00 MB) Partition: BOTA2, [000002200000 - 000002800000], size: 000000600000 (6.00 MB) Partition: EFS, [000002800000 - 000003000000], size: 000000800000 (8.00 MB) Partition: nvdata, [000003000000 - 000005000000], size: 000002000000 (32.0 MB) Partition: PARAM, [000005000000 - 000005800000], size: 000000800000 (8.00 MB) Partition: recovery, [000005800000 - 000006800000], size: 000001000000 (16.0 MB) Partition: boot, [000006800000 - 000007800000], size: 000001000000 (16.0 MB) Partition: md1img, [000007800000 - 000009800000], size: 000002000000 (32.0 MB) Partition: md1dsp, [000009800000 - 000009C00000], size: 000000400000 (4.00 MB) Partition: keystore, [000009C00000 - 00000A400000], size: 000000800000 (8.00 MB) Partition: omekeystore, [00000A400000 - 00000A780000], size: 000000380000 (3.50 MB) Partition: proinfo, [00000A780000 - 00000AA00000], size: 000000280000 (2.50 MB) Partition: para, [00000AA00000 - 00000AA80000], size: 000000080000 (512. KB) Partition: PERSISTENT, [00000AA80000 - 00000AB00000], size: 000000080000 (512. KB) Partition: STEADY, [00000AB00000 - 00000AC00000], size: 000000100000 (1.00 MB) Partition: protect1, [00000AC00000 - 00000B400000], size: 000000800000 (8.00 MB) Partition: protect2, [00000B400000 - 00000BC00000], size: 000000800000 (8.00 MB) Partition: RESERVE2, [00000BC00000 - 00000C000000], size: 000000400000 (4.00 MB) Partition: system, [00000C000000 - 0000CC800000], size: 0000C0800000 (3.01 GB) Partition: cache, [0000CC800000 - 0000E5800000], size: 000019000000 (400. MB) Partition: hidden, [0000E5800000 - 0000E9400000], size: 000003C00000 (60.0 MB) Partition: userdata, [0000E9400000 - 0001D1C00000], size: 0000E8800000 (3.63 GB) GPT header successfully parsed Get firmware version Brand = samsung Manufacturer = samsung Device = grandpplte Model = SM-G532F Phone platform = mt6737t CPU Abi = armeabi-v7a Mediatek platform = MT6737T Android release = 6.0.1 Firmware version = MMB29T.G532FXWU1APJ1 Firmware date = Sat Oct 1 18:25:42 KST 2016 Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 1 MHz CMD Pullup Level: 3283 mV CMD Active Level: 2843 mV EMMC Device Information : EMMC CID: 90014A48384734759201C38364F935E3 EMMC CSD: D02701320F5903FFFFFFFFE78A40002B EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: C38364F9 , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 3/2018 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H8G4u_C38364F9_20190809_153546.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: BOTA0, [000000400000 - 000000800000], size: 000000400000 (4.00 MB) Partition: NVRAM, [000000800000 - 000001000000], size: 000000800000 (8.00 MB) Partition: LK, [000001000000 - 000001200000], size: 000000200000 (2.00 MB) Partition: BOTA1, [000001200000 - 000001400000], size: 000000200000 (2.00 MB) Partition: SECRO, [000001400000 - 000001B00000], size: 000000700000 (7.00 MB) Partition: SECCFG, [000001B00000 - 000001B80000], size: 000000080000 (512. KB) Partition: EFUSE, [000001B80000 - 000001C00000], size: 000000080000 (512. KB) Partition: TEE1, [000001C00000 - 000002200000], size: 000000600000 (6.00 MB) Partition: BOTA2, [000002200000 - 000002800000], size: 000000600000 (6.00 MB) Partition: EFS, [000002800000 - 000003000000], size: 000000800000 (8.00 MB) Partition: NVDATA, [000003000000 - 000005000000], size: 000002000000 (32.0 MB) Partition: PARAM, [000005000000 - 000005800000], size: 000000800000 (8.00 MB) Partition: RECOVERY, [000005800000 - 000006800000], size: 000001000000 (16.0 MB) Partition: BOOT, [000006800000 - 000007800000], size: 000001000000 (16.0 MB) Partition: MD1IMG, [000007800000 - 000009800000], size: 000002000000 (32.0 MB) Partition: MD1DSP, [000009800000 - 000009C00000], size: 000000400000 (4.00 MB) Partition: KEYSTORE, [000009C00000 - 00000A400000], size: 000000800000 (8.00 MB) Partition: OMEKEYSTORE, [00000A400000 - 00000A780000], size: 000000380000 (3.50 MB) Partition: PROINFO, [00000A780000 - 00000AA00000], size: 000000280000 (2.50 MB) Partition: PARA, [00000AA00000 - 00000AA80000], size: 000000080000 (512. KB) Partition: PERSISTENT, [00000AA80000 - 00000AB00000], size: 000000080000 (512. KB) Partition: STEADY, [00000AB00000 - 00000AC00000], size: 000000100000 (1.00 MB) Partition: PROTECT1, [00000AC00000 - 00000B400000], size: 000000800000 (8.00 MB) Partition: PROTECT2, [00000B400000 - 00000BC00000], size: 000000800000 (8.00 MB) Partition: RESERVE2, [00000BC00000 - 00000C000000], size: 000000400000 (4.00 MB) Partition: SYSTEM, [00000C000000 - 0000CC800000], size: 0000C0800000 (3.01 GB) Partition: CACHE, [0000CC800000 - 0000E5800000], size: 000019000000 (400. MB) Partition: HIDDEN, [0000E5800000 - 0000E9400000], size: 000003C00000 (60.0 MB) Partition: USERDATA, [0000E9400000 - 0001D1FFBE00], size: 0000E8BFBE00 (3.64 GB) GPT header successfully parsed Get firmware version Firmware info not found Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 1 MHz CMD Pullup Level: 3284 mV CMD Active Level: 2844 mV EMMC Device Information : EMMC CID: 90014A48384734759201C38364F935E3 EMMC CSD: D02701320F5903FFFFFFFFE78A40002B EMMC Manufacture : SKHYNIX , EMMC NAME: H8G4u , HEX: 483847347500 , S/N: C38364F9 , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 3/2018 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H8G4u_C38364F9_20190809_153604.extcsd EMMC Init completed. Operation: Writing all eMMC Regions... Operation: Writing BootConfig ... Reg: 179 Value: 0x48 Reg: 177 Value: 0x00 Reg: 162 Value: 0x01 Done Writing to: ROM2 , start: 0x000000000000 , size: 0x000000400000 Filename: EMMC_QN16BB_ROM2_000000000000_000000400000.bin eMMC switching to ROM2 Writing partition... Done writing partition. Write speed: 59.72 KB/s Writing to: ROM3 , start: 0x000000000000 , size: 0x000000400000 Filename: EMMC_QN16BB_ROM3_000000000000_000000400000.bin eMMC switching to ROM3 Writing partition... Done writing partition. Write speed: 59.82 KB/s Writing to: ROM1 , start: 0x000000000000 , size: 0x00000C000000 Filename: EMMC_QN16BB_ROM1_000000000000_00000C000000.bin eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 119.75 KB/s All done time: [00:29:41:413] |
The Following User Says Thank You to ferouz kassim For This Useful Post: |
10-02-2019, 07:17 | #699 (permalink) |
No Life Poster Join Date: Sep 2013 Location: Kotla Arab Ali Khan(PAK)
Member: 2016954 Status: Offline Thanks Meter: 345 | G532F Boot Repair done Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Writing BackupGPT at address: 0001D1FFBE00 Writing PIT at address: 000000004400 GPT-partitioning done Unpacking file: preloader.img Unpacking file: lk.bin Unpacking file: efuse.img Unpacking file: trustzone.bin Unpacking file: param.bin Partition name: BOOTLOADER Filename: preloader.img , Offset: 000000000000 , filesize: 170240 bytes eMMC switching to ROM2 Erasing partition... Writing partition... Done writing partition. Write speed: 174.32 KB/s Partition name: LK Filename: lk.bin , Offset: 000001000000 , filesize: 590336 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 293.56 KB/s Partition name: EFUSE Filename: efuse.img , Offset: 000001B80000 , filesize: 768 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 12.09 KB/s Partition name: TEE1 Filename: trustzone.bin , Offset: 000001C00000 , filesize: 324352 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 446.22 KB/s Partition name: PARAM Filename: param.bin , Offset: 000005000000 , filesize: 747520 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 482.80 KB/s Check BootConfig for the selected vendor All done time: [00:00:34:710] |
The Following User Says Thank You to GsmKotla For This Useful Post: |
10-04-2019, 15:55 | #700 (permalink) |
No Life Poster Join Date: Jan 2004 Location: india
Member: 50772 Status: Offline Sonork: 100.1590990 Thanks Meter: 318 | VIVO V15PRO DONE.... ---------------------------- Z3X EasyJtag Software ver. 3.6.1.15 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: F5B89C5F8960E68F, ,FW Ver.: 02.48 CMD Pullup Level:1939 mV CMD Active Level:2742 mV Box IO Level:2800 mV CLK Rate:6000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 150100335636434D420298C2CC161601 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 01/2019 Rev.0x2 eMMC NAME: 3V6CMB , S/N: 2562903062 eMMC NAME (HEX): 335636434D42 EMMC ROM1 (Main User Data) Capacity: 119276 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 1624 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: 3V6CMB_2562903062_20191004_2005.extcsd Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: E8F6000 sectors 116.5 GiB Soft (Partitioned) Disk/Image size: E8F5FBC sectors 116.5 GiB Disk identifier (GUID): 19BCD2FB-7DB9-3260-1CA8-A8C28D0CACA8 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,244277214 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0042200000 (5.0GB) Unable to read prop.plist , code : 2 --------------------------------------------- Detected USERDATA USERDATA : 0x01E2200000 (108.946GB) Unable to mount USERDATA , code : 95 Done. Checking security ... Z3X EasyJtag Software ver. 3.6.1.15 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: F5B89C5F8960E68F, ,FW Ver.: 02.48 CMD Pullup Level:1940 mV CMD Active Level:2742 mV Box IO Level:2800 mV CLK Rate:6000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 150100335636434D420298C2CC161601 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 01/2019 Rev.0x2 eMMC NAME: 3V6CMB , S/N: 2562903062 eMMC NAME (HEX): 335636434D42 EMMC ROM1 (Main User Data) Capacity: 119276 MB , 0xE8F6000 pages , 0x1D1EC00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 1624 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: E8F6000 sectors 116.5 GiB Soft (Partitioned) Disk/Image size: E8F5FBC sectors 116.5 GiB Disk identifier (GUID): 19BCD2FB-7DB9-3260-1CA8-A8C28D0CACA8 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,244277214 Partition info successfully found ------ Android information ------ Detected (Android Userdata) USERDATA : 0x01E2200000 (108.946GB) Erasing... Done. Detected (Android Cache)) CACHE : 0x01D2200000 (256.0MB) Erasing... Done. --------------------------------------------- Done. Checking security ... Running:Format FRP Partition... Z3X EasyJtag Software ver. 3.6.1.15 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: F5B89C5F8960E68F, ,FW Ver.: 02.48 CMD Pullup Level:1940 mV CMD Active Level:2744 mV Box IO Level:2800 mV CLK Rate:6000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 150100335636434D420298C2CC161601 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 01/2019 Rev.0x2 eMMC NAME: 3V6CMB , S/N: 2562903062 eMMC NAME (HEX): 335636434D42 EMMC ROM1 (Main User Data) Capacity: 119276 MB , 0xE8F6000 pages , 0x1D1EC00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 1624 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: E8F6000 sectors 116.5 GiB Soft (Partitioned) Disk/Image size: E8F5FBC sectors 116.5 GiB Disk identifier (GUID): 19BCD2FB-7DB9-3260-1CA8-A8C28D0CACA8 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,244277214 Partition info successfully found Formatting FRP... Detected LINUX(Android) FRP : 0x0027DD0000 (512.0KB) formatting... Done. Detected LINUX(Android) CACHE : 0x01D2200000 (256.0MB) , formatting... Done. Detected LINUX(Android) USERDATA : 0x01E2200000 (108.946GB) , formatting... Done. Done. Done. |
12-19-2019, 15:42 | #701 (permalink) |
Product Supporter Join Date: Jul 2011 Location: ISLAMIC & INDIA WITH MIRACLE T Age: 37
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Vivo y53 pattern reset isp (usb not work) essy jtag |
The Following 2 Users Say Thank You to .::THE ROCK::. For This Useful Post: |
01-03-2020, 11:30 | #702 (permalink) |
No Life Poster Join Date: Jun 2008 Location: Punjabi University India
Member: 788946 Status: Offline Sonork: 100.1682685 Thanks Meter: 502 | Realme 2 pattern unlock done Thanks Easy jtag team |
The Following User Says Thank You to sr8787 For This Useful Post: |
01-05-2020, 12:36 | #703 (permalink) |
No Life Poster Join Date: May 2009 Location: Bangladesh Age: 30
Member: 1034743 Status: Offline Sonork: 100.1619212 Thanks Meter: 193 | Code: Found 1 serial devices COM6 USB\VID_0325&PID_0032&REV_0100&MI_00 Easy Jtag Control Port (COM6) Selected pinout: EasyJTAG GEN1 ISP Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.6.1.15 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 0EFF901ADE07A5AB, ,FW Ver.: 01.63 CMD Pullup Level:2000 mV CMD Active Level:2351 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D4204B26C689B26F2 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 02/2019 Rev.0x4 eMMC NAME: QE63MB , S/N: 2993449115 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 99504 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: QE63MB_2993449115_20200105_1727.extcsd Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 1D1F000 sectors 14.6 GiB Soft (Partitioned) Disk/Image size: 1D1EFBC sectors 14.6 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,30535646 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0042800000 (3.352GB) Build ID: OPM1.171019.026 Release Base ID: 8.1.0 Architecture ABI: arm64-v8a Device manufacturer: OPPO Build Description: S88051AA1-user 8.1.0 OPM1.171019.026 eng.root.20191120.003654 release-keys --------------------------------------------- Detected USERDATA USERDATA : 0x015B800000 (9.129GB) Unable to mount USERDATA , code : 95 Done. Z3X EasyJtag Software ver. 3.6.1.15 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 0EFF901ADE07A5AB, ,FW Ver.: 01.63 CMD Pullup Level:2021 mV CMD Active Level:2567 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D4204B26C689B26F2 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 02/2019 Rev.0x4 eMMC NAME: QE63MB , S/N: 2993449115 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB , 0x1D1F000 pages , 0x3A3E00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 99504 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Writing Recovery Command to MISC (33) Done. |
01-09-2020, 06:56 | #704 (permalink) |
Freak Poster Join Date: Feb 2004 Location: BY Age: 49
Member: 52495 Status: Offline Thanks Meter: 25 | Redmi Note 6 Pro (tulip) miui11 FRP done Code: 09.01.2020 8:39:23> Firehose Info: 09.01.2020 8:39:23> HW_ID: 0x3006000000000000 09.01.2020 8:39:23> HASH: 0xA7B8B82545A98ECA23D6E9105FB464568D1B5828264903441BDEF0CD57E3C370 09.01.2020 8:39:23> SBL_SW: 0x0000000400000003 09.01.2020 8:39:23> MSM: SDM660 09.01.2020 8:39:23> 09.01.2020 8:39:23> The selected firehose may not be compatible with this device. 09.01.2020 8:39:23> It may damage your device. 09.01.2020 8:39:23> 09.01.2020 8:39:27> Sending FlashLoader. Please, wait ... 09.01.2020 8:39:28> FlashLoader was successfully uploaded to the device. 09.01.2020 8:39:28> Connect to FlashLoader ... 09.01.2020 8:39:33> 09.01.2020 8:39:33> EMMC NAME: S0J9D8 S/N: 08E4F61E 09.01.2020 8:39:33> EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000) 09.01.2020 8:39:33> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 09.01.2020 8:39:33> 09.01.2020 8:39:33> Connection with FlashLoader was successful 09.01.2020 8:39:35> Searching GPT ... 09.01.2020 8:39:35> GPT header is found and is valid 09.01.2020 8:39:35> 09.01.2020 8:39:35> GPT header successfully parsed 09.01.2020 8:39:35> 09.01.2020 8:39:35> FRP signature found (partname: frp) 09.01.2020 8:39:35> Erasing FRP partition ... 09.01.2020 8:39:35> 09.01.2020 8:39:35> If the device does not load for a long time - try wiping the data in the recovery 09.01.2020 8:39:35> All done |
The Following User Says Thank You to slav-on For This Useful Post: |
02-03-2020, 06:56 | #705 (permalink) |
No Life Poster Join Date: May 2010 Location: Incredible-India
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,293 | Redmi Note 4 Dead Shorting Over Tempure By Other Technician Replace Pmi Reboll Cpu+Emmc Reprogram By Easy-Jtag Handset Successfully Recover Done Image Emmc Reprogram Full Info Handset Recover Done |
The Following 3 Users Say Thank You to Deepesh Sharma For This Useful Post: |
