03-10-2020, 07:06 | #721 (permalink) |
No Life Poster Join Date: Sep 2004 Location: coast Age: 52
Member: 83397 Status: Offline Thanks Meter: 204 | Quote: thank you for the superb logs |
The Following 2 Users Say Thank You to jamohaki For This Useful Post: |
03-13-2020, 07:13 | #722 (permalink) |
Product Supporter Join Date: Jul 2011 Location: ISLAMIC & INDIA WITH MIRACLE T Age: 37
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Realme c1 cph1811 pattern unlock easy jtag REALME C1 CPH1811 PATTERN UNLOCK EASY JTAG INFO OR UNLOCK LOGS Code: Z3X EasyJtag Software ver. 3.6.2.3 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0707031F7AA05FBD, ,FW Ver.: 01.63 CMD Pullup Level:2093 mV CMD Active Level:2547 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D42064277077F85EE eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 08/2018 Rev.0x6 eMMC NAME: QE63MB , S/N: 1115096959 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 83630 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: QE63MB_1115096959_20200312_2201.extcsd Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 1D1F000 sectors 14.6 GiB Soft (Partitioned) Disk/Image size: 1D1EFBC sectors 14.6 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,30535646 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0042800000 (3.352GB) Short EXT fs info: Size: 3.298GB Block size: 4.0KB Inode size: 256 Inodes: 216432 Short Android info: Unable to read prop.plist , code : 2 Backup saved: BuildProp_20200312_2201.txt --------------------------------------------- Detected USERDATA USERDATA : 0x015B800000 (9.129GB) Unable to mount USERDATA , code : 95 Userdata Superblock contents:: F4B54915 9BE56FE5 05B758EA 747E07C1 E1F60180 3AAA29BB 3E5A5720 36A4CD2C ôµI.›åoå.·Xêt~.Ááö..:ª)»>ZW 6¤Í,; AD6A5F8D E7A5D1B6 5E176140 C4BC927B 993F0B8C A52ED75F C15E4C35 DDA92C6E *j_.ç¥Ñ¶^.a@ļ’{.?.Œ¥.×_Á^L5Ý©,n; A55BA401 49163CA8 67996E54 AA8F03A6 35F76CE7 67DBE2CC 7C43E92F 1DFBC463 ¥[¤.I.<¨g.nTª..¦5÷lçgÛâÌ|Cé/.ûÄc; 5952B4E7 C1B08BA8 5D70BC7C 8F30D840 7E5CC19D 5609162F 91C94161 0A0FFE8E YR´çÁ°‹¨]p¼|.0Ø@~\Á.V ./‘ÉAa..þŽ; 970D7C78 131C6037 A13279AE 499D16F4 77549AFE 7B061B59 653FB149 AE35A585 —.|x..`7¡2y®I..ôwTšþ{..Ye?±I®5¥…; 320ED2EB 20B5AD09 5B42983C BD926B35 9F2B4BD6 8B3EE764 FCE35DF9 AD8EF77C 2.Òë µ* [B.<½’k5Ÿ+KÖ‹>çdüã]ù*Ž÷|; 060A7747 BAEAC061 BF26A73A B5F703DC EBEAAEF5 CEB98A10 1CE91128 D263BEB3 ..wGºêÀa¿&§:µ÷.Üëê®õιŠ..é.(Òc¾³; CCE56DC5 D9C0D633 D38093AB 017301BF 178C4891 6470C8A2 74FB5E73 442F3DB7 ÌåmÅÙÀÖ3Ó.“«.s.¿.ŒH‘dpÈ¢tû^sD/=·; Done. Running:Format FRP Partition... Z3X EasyJtag Software ver. 3.6.2.3 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0707031F7AA05FBD, ,FW Ver.: 01.63 CMD Pullup Level:2103 mV CMD Active Level:3042 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D42064277077F85EE eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 08/2018 Rev.0x6 eMMC NAME: QE63MB , S/N: 1115096959 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB , 0x1D1F000 pages , 0x3A3E00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 83630 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 1D1F000 sectors 14.6 GiB Soft (Partitioned) Disk/Image size: 1D1EFBC sectors 14.6 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,30535646 Partition info successfully found Formatting FRP... Detected LINUX(Android) CACHE : 0x001F300000 (256.0MB) , formatting... Done. Detected LINUX(Android) CONFIG : 0x002F480000 (32.0KB) formatting... Done. Detected LINUX(Android) USERDATA : 0x015B800000 (9.129GB) , formatting... Done. Done. Done. |
03-16-2020, 07:42 | #723 (permalink) |
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Oppo a3s pattern unlock easy jtag OPPO A3S PATTERN UNLOCK EASY JTAG INFO OR UNLOCK LOGS Code: Z3X EasyJtag Software ver. 3.6.2.3 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0707031F7AA05FBD, ,FW Ver.: 01.63 CMD Pullup Level:2083 mV CMD Active Level:3104 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D420388C60782251A eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 02/2018 Rev.0x3 eMMC NAME: QE63MB , S/N: 2294679426 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 120380 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: QE63MB_2294679426_20200316_1153.extcsd Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 1D1F000 sectors 14.6 GiB Soft (Partitioned) Disk/Image size: 1D1EFBC sectors 14.6 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,30535646 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x003F000000 (3.352GB) Short EXT fs info: Size: 3.298GB Block size: 4.0KB Inode size: 256 Inodes: 216432 Short Android info: Build ID: OPM1.171019.026 Release Base ID: 8.1.0 Security Path: 2019-07-05 Architecture ABI: arm64-v8a Device manufacturer: OPPO Build Description: msm8953_64-user 8.1.0 OPM1.171019.026 eng.root.20190717.054518 release-keys Backup saved: BuildProp_20200316_1153.txt --------------------------------------------- Detected USERDATA USERDATA : 0x0158000000 (9.184GB) Unable to mount USERDATA , code : 95 Userdata Superblock contents:: 1E56A73E ACA60293 4887AC8D C466DC20 1BEFBF3A 652A67E9 6C9BA44D 62A31918 .V§>¬¦.“H‡¬.ÄfÜ .ï¿:e*gél›¤Mb£..; 5971B3F2 EBC30286 ACB7ACDD E44478E8 D800E57A B41837FD 380106E3 B066AA38 Yq³òëÃ.†¬·¬ÝäDxèØ.åz´.7ý8..ã°fª8; A5C9C7FA 23FDA5F0 1C2EB9DD AF8BA529 5C7A42E2 AA609C88 77BA096A D03AAD83 ¥ÉÇú#ý¥ð..¹Ý¯‹¥)\zBâª`œ.wº jÐ:*ƒ; 43BC6585 634053A6 F6C91753 D646FB63 FCF5C947 ECFDAE42 47218097 FD605F52 C¼e…c@S¦öÉ.SÖFûcüõÉGìý®BG!.—ý`_R; 083C0832 CB20690C B161CC54 78E97760 47CBD9BC 321CBA00 6F6E2597 83C93526 .<.2Ë i.±aÌTxéw`GËÙ¼2.º.on%—ƒÉ5&; F4B53644 17AB6F70 54C0383F 266EC532 FAFC9E2F 5B00A36A F03E50D7 EB2F8F89 ôµ6D.«opTÀ8?&nÅ2úüž/[.£jð>P×ë/.‰; 3AFDCD5D 3140E08F 8FE53E78 CEE5299C F807BDCF 04E96B2D 17DCAA0E 430CA940 :ýÍ]1@à..å>xÎå)œø.½Ï.ék-.ܪ.C.©@; BAA11FD8 F8F58278 7ECA2355 3C2F0982 7DD70884 95AF461C 02993DA5 47F0DFFD º¡.Øøõ‚x~Ê#U</ ‚}×.„•¯F...=¥Gðßý; Done. Running:Format FRP Partition... Z3X EasyJtag Software ver. 3.6.2.3 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0707031F7AA05FBD, ,FW Ver.: 01.63 CMD Pullup Level:2083 mV CMD Active Level:3093 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D420388C60782251A eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 02/2018 Rev.0x3 eMMC NAME: QE63MB , S/N: 2294679426 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB , 0x1D1F000 pages , 0x3A3E00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 120380 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 1D1F000 sectors 14.6 GiB Soft (Partitioned) Disk/Image size: 1D1EFBC sectors 14.6 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,30535646 Partition info successfully found Formatting FRP... Detected LINUX(Android) CACHE : 0x001FB00000 (256.0MB) , formatting... Done. Detected LINUX(Android) CONFIG : 0x002FC80000 (32.0KB) formatting... Done. Detected LINUX(Android) USERDATA : 0x0158000000 (9.184GB) , formatting... Done. Done. Done. |
03-20-2020, 14:59 | #725 (permalink) |
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Realme 2 pro rmx1801 pattern unlock easy jtag REALME 2 PRO RMX1801 PATTERN UNLOCK EASY JTAG INFO OR UNLOCK LOGS Code: Z3X EasyJtag Software ver. 3.6.2.3 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0707031F7AA05FBD, ,FW Ver.: 01.63 CMD Pullup Level:2041 mV CMD Active Level:2866 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 150100444836444142025F74C224A5A2 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 10/2018 Rev.0x2 eMMC NAME: DH6DAB , S/N: 1601487396 eMMC NAME (HEX): 444836444142 EMMC ROM1 (Main User Data) Capacity: 59640 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 19302 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: DH6DAB_1601487396_20200320_1758.extcsd Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB Soft (Partitioned) Disk/Image size: 747BFBC sectors 58.2 GiB Disk identifier (GUID): E3048BDF-6E09-4A80-1CB0-70A72E4FD7BB Logical sector size: 0x200 bytes ,First/Last usable sector: 34,122142686 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0041000000 (5.250GB) Short EXT fs info: Size: 5.167GB Block size: 4.0KB Inode size: 256 Inodes: 339360 Short Android info: Unable to read prop.plist , code : 2 Backup saved: BuildProp_20200320_1758.txt --------------------------------------------- Detected USERDATA USERDATA : 0x0201800000 (50.217GB) Unable to mount USERDATA , code : 95 Userdata Superblock contents:: 7A1F08A2 14B333F0 BB684CC3 E95AC216 D96B2A4D 8489AD28 90CB13DB CC0FB9B1 z..¢.³3ð»hLÃéZÂ.Ùk*M„‰*(.Ë.ÛÌ.¹±; 9F9AE415 3BFA4A3C FF9ED4B1 B2958C7F 08C824E4 0C796431 C38C690A 14258DAB Ÿšä.;úJ<ÿžÔ±²•Œ..È$ä.yd1ÃŒi..%.«; AFCC6B78 A44A6543 8FC728B2 3CDC6362 96C44762 10149727 BB8731AB 07EF2C73 ¯Ìkx¤JeC.Ç(²<Ücb–ÄGb..—'»‡1«.ï,s; 6EDCC001 C42941D9 001A28BB 788E7F64 0D5C0213 00EED537 5F5257C5 DC1FA78E nÜÀ.Ä)AÙ..(»xŽ.d.\...îÕ7_RWÅÜ.§Ž; A6550B8E 17DBB8A7 5181B33C 7021ECE6 2BE26B55 5723A10B 78455930 5B07D180 ¦U.Ž.Û¸§Q.³<p!ìæ+âkUW#¡.xEY0[.Ñ.; 5F6AB38B 44B13836 D0C621AA 6A401B73 741CC2D6 27AE9420 293E5518 877168ED _j³‹D±86ÐÆ!ª[email protected].ÂÖ'®” )>U.‡qhí; 1978A5E9 3E138D46 E191E9CA 2E3D79E7 BC101564 8C22BFFD F2BD9E9B 052218E8 .x¥é>..Fá‘éÊ.=yç¼..dŒ"¿ýò½ž›.".è; BB59147B 5DDA4FD5 1D89F6D1 B14E1995 DCFB81C8 92B6DD91 49B4B329 41D1736F »Y.{]ÚOÕ.‰öѱN.•Üû.È’¶Ý‘I´³)AÑso; Done. Running:Format FRP Partition... Z3X EasyJtag Software ver. 3.6.2.3 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0707031F7AA05FBD, ,FW Ver.: 01.63 CMD Pullup Level:2041 mV CMD Active Level:2877 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 150100444836444142025F74C224A5A2 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 10/2018 Rev.0x2 eMMC NAME: DH6DAB , S/N: 1601487396 eMMC NAME (HEX): 444836444142 EMMC ROM1 (Main User Data) Capacity: 59640 MB , 0x747C000 pages , 0xE8F800000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 19302 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB Soft (Partitioned) Disk/Image size: 747BFBC sectors 58.2 GiB Disk identifier (GUID): E3048BDF-6E09-4A80-1CB0-70A72E4FD7BB Logical sector size: 0x200 bytes ,First/Last usable sector: 34,122142686 Partition info successfully found Formatting FRP... Detected LINUX(Android) FRP : 0x0021383000 (512.0KB) formatting... Done. Detected LINUX(Android) CACHE : 0x0031000000 (256.0MB) , formatting... Done. Detected LINUX(Android) USERDATA : 0x0201800000 (50.217GB) , formatting... Done. Done. Done. forensic anthropology crime |
03-21-2020, 15:54 | #726 (permalink) |
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Oppo a3s pattern unlock no data format media file easy jtag OPPO A3S PATTERN UNLOCK NO DATA FORMAT MEDIA FILE EASY JTAG INFO OR UNLOCK LOGS CLICK>>>> RESET OPPO Code: Z3X EasyJtag Software ver. 3.6.2.3 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0707031F7AA05FBD, ,FW Ver.: 01.63 CMD Pullup Level:2052 mV CMD Active Level:3042 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 90014A484247346132A5C702A8636524 eMMC CSD : D02701328F5903FFFFFFFFE78A400016 eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 06/2018 Rev.0xA5 eMMC NAME: HBG4a2 , S/N: 3338840163 eMMC NAME (HEX): 484247346132 EMMC ROM1 (Main User Data) Capacity: 29820 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 52252 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00002000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: HBG4a2_3338840163_20200321_1931.extcsd Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,61071326 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x003F000000 (3.352GB) Short EXT fs info: Size: 3.298GB Block size: 4.0KB Inode size: 256 Inodes: 216432 Short Android info: Build ID: OPM1.171019.026 Release Base ID: 8.1.0 Security Path: 2020-01-05 Architecture ABI: arm64-v8a Device manufacturer: OPPO Build Description: msm8953_64-user 8.1.0 OPM1.171019.026 eng.root.20191225.101315 release-keys Backup saved: BuildProp_20200321_1931.txt --------------------------------------------- Detected USERDATA USERDATA : 0x0158000000 (23.745GB) Unable to mount USERDATA , code : 95 Userdata Superblock contents:: 7724D89D 3B28A043 47AEA020 7E12E12D C2497D39 76E0D20D A8517811 9D49E4D2 w$Ø.;( CG® ~.á-ÂI}9vàÒ.¨Qx..IäÒ; 58D12DBC FF14A7FE E73EC41E A4CD2694 4A66B7FB B336CAD7 4198962A A79005B9 XÑ-¼ÿ.§þç>Ä.¤Í&”Jf·û³6Ê×A.–*§..¹; C6AA6E36 FC457C1D F78CC2AA E03289A7 B54FCF48 640179EB 5141BC41 33BFE980 ƪn6üE|.÷ŒÂªà2‰§µOÏHd.yëQA¼A3¿é.; E9DBE13D 4132A2FC 4CEAAB17 8C0A1E29 734CF947 C657A152 68F7EA57 99046668 éÛá=A2¢üLê«.Œ..)sLùGÆW¡Rh÷êW..fh; 15865EA1 05000976 1A0295CB 7804C9BB 4ACF69CD 5B901233 04CF391D E9DA8D5C .†^¡.. v..•Ëx.É»JÏiÍ[..3.Ï9.éÚ.\; 1E2DDE85 CAC62807 D3EA73CB 9FFCB06E 9ADAE4AA CF0BBFA4 65A5522F 4FA61264 .-Þ…ÊÆ(.ÓêsËŸü°nšÚäªÏ.¿¤e¥R/O¦.d; 8B75C85D 74CF8584 9E622CBD 82E21D39 3A837AC4 5BB1F372 74D07D0C 0BAA4AA3 ‹uÈ]tÏ…„žb,½‚â.9:ƒzÄ[±órtÐ}..ªJ£; ACDEBA85 33FFA868 FEE0F18F 8AEEFC35 D800A503 70DC4253 A74021FD 7F8B450D ¬Þº…3ÿ¨hþàñ.Šîü5Ø.¥.pÜBS§@!ý.‹E.; Done. Z3X EasyJtag Software ver. 3.6.2.3 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0707031F7AA05FBD, ,FW Ver.: 01.63 CMD Pullup Level:2052 mV CMD Active Level:3083 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 90014A484247346132A5C702A8636524 eMMC CSD : D02701328F5903FFFFFFFFE78A400016 eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 06/2018 Rev.0xA5 eMMC NAME: HBG4a2 , S/N: 3338840163 eMMC NAME (HEX): 484247346132 EMMC ROM1 (Main User Data) Capacity: 29820 MB , 0x3A3E000 pages , 0x747C00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 52252 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00002000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Writing Recovery Command to MISC (35) Done. free image uploader |
The Following 3 Users Say Thank You to .::THE ROCK::. For This Useful Post: |
05-25-2020, 00:33 | #728 (permalink) |
Insane Poster Join Date: May 2005 Age: 46
Member: 149217 Status: Offline Thanks Meter: 21 | Problem conection A30s please helpme Z3X EasyJtag Software ver. 3.6.2.3 Loading eMMC GEN1 Firmware... IO: 1800 mV Box S/N: 19014010F2263E6F, ,FW Ver.: 01.63 CMD Pullup Level:1711 mV CMD Active Level:1247 mV Box IO Level:1800 mV CLK Rate:3000 kHz Bus Width:1bit,SDR HiPower mode is off! Can't init device, Reason: CMD Timeout Error Done. Z3X EasyJtag Software ver. 3.6.2.3 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 19014010F2263E6F, ,FW Ver.: 01.63 Warning: CMD Pullup Level (309 mV) too low , check cables etc.! CMD Active Level:1639 mV Box IO Level:2800 mV CLK Rate:1000 kHz Bus Width:1bit,SDR HiPower mode is off! Can't init device, Reason: CMD Timeout Error Done. |
06-01-2020, 13:14 | #729 (permalink) |
No Life Poster Join Date: May 2010 Location: Incredible-India
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | Samsung J2(J200g) Always Goes To Download Mode Successfully Recovered With Easy Jtag Samsung J2(J200g) Always Goes To Download Mode Device Life Time Error Fix Emmc Successfully Reprograme Handset Recovered With Easy Jtag Image. Log Log2 Successfully Alive Handset |
The Following 4 Users Say Thank You to Deepesh Sharma For This Useful Post: |
06-12-2020, 19:11 | #731 (permalink) |
No Life Poster Join Date: Nov 2016 Location: GUJARAT
Member: 2643730 Status: Offline Thanks Meter: 1,115 | Found 2 serial devices COM8 ACPI\PNP0501 Communications Port (COM8) COM24 USB\VID_0325&PID_0032&REV_0100&MI_00 Easy Jtag Control Port (COM24) Selected pinout: EasyJTAG GEN1 ISP Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.6.2.3 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0E004019B192A1BE, ,FW Ver.: 01.63 CMD Pullup Level:2041 mV CMD Active Level:2495 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 13014E51324A3936521006A7C17564E8 eMMC CSD : D07F01320F5913FFFFFFFFEF924000A2 eMMC Manufacturer ID: 0013 , OEM ID: 014E eMMC Date: 06/2017 Rev.0x10 eMMC NAME: Q2J96R , S/N: 111657333 eMMC NAME (HEX): 51324A393652 IC Name: Micron , eMMC_(JY950)MT29TZZZ5D6JKFRL-107/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is not yet programmed (clear) or RPMB General failure EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: Q2J96R_ 111657333_20200612_2332.extcsd Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 1D5A000 sectors 14.7 GiB Soft (Partitioned) Disk/Image size: 1D59FBC sectors 14.7 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,30777310 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x001C000000 (2.750GB) Short EXT fs info: Size: 2.750GB Block size: 4.0KB Inode size: 256 Inodes: 180224 Short Android info: Release Incremental ID: 1480422943 Product ID: A37f Device Name A: A37f Device Model: A37f OPPO ROM Version: V3.0.0i Display Build ID: A37fEX_11_171209 OPPO Region ID A: US OPPO Region ID B: US Build ID: LMY47V Release Base ID: 5.1.1 Security Path: 2017-12-01 Device Manufacturer: OPPO Device Board Name: msm8916 Architecture ABI: arm64-v8a Device manufacturer: OPPO Device Platform: msm8916 Build Description: msm8916_64-user 5.1.1 LMY47V eng.root.20171209.165633 release-keys FRP Partition Path: /dev/block/bootdevice/by-name/config Release Incremental ID: 1480422943 Product ID: A37f Device Name A: A37f Device Model: A37f OPPO ROM Version: V3.0.0i Display Build ID: A37fEX_11_171209 OPPO Region ID A: US OPPO Region ID B: US Backup saved: BuildProp_20200612_2332.txt --------------------------------------------- Detected USERDATA USERDATA : 0x00E2788000 (11.136GB) Short EXT fs info: Size: 11.135GB Block size: 4.0KB Inode size: 256 Inodes: 737280 Short userdata info: Gesture HASH A39A3EE5E6B4B0D3255BFEF95601890AFD80709 Done. CLEAR PIN/GST/PASS EasyJtag Suite Classic ver.: 3.6.2.3 / wxWidgets 3.1.3-W-U started. OS ver.: Windows 7 (build 7601, Service Pack 1), 64-bit edition. Admin rights OK Autorun Agent ver:1.0.0.0 Crash Reporting ver:1.4.0.3 EasyJTAG SPI Plugin ver:1.1.1.11 Android ADB API ver:2.0.0.0 FTDI API ver:3.2.4.0 LibUSB API ver:1.2.6.0 Visual C++ Runtime ver:10.0.30319.1 Setting box Pinout ... Box Drivers version: 3.0.1.0, are OK Z3X Card Serial : AA9A-15A0 , ver: 22 Z3X Card Activation [JTAGPLUS] : NOT ACTIVATED Z3X Card Activation [LG] : NOT ACTIVATED Z3X Card Activation [SAMS] : NOT ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED Found 2 serial devices COM8 ACPI\PNP0501 Communications Port (COM8) COM24 USB\VID_0325&PID_0032&REV_0100&MI_00 Easy Jtag Control Port (COM24) Selected pinout: EasyJTAG GEN1 ISP Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.6.2.3 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0E004019B192A1BE, ,FW Ver.: 01.63 CMD Pullup Level:2041 mV CMD Active Level:2495 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 13014E51324A3936521006A7C17564E8 eMMC CSD : D07F01320F5913FFFFFFFFEF924000A2 eMMC Manufacturer ID: 0013 , OEM ID: 014E eMMC Date: 06/2017 Rev.0x10 eMMC NAME: Q2J96R , S/N: 111657333 eMMC NAME (HEX): 51324A393652 IC Name: Micron , eMMC_(JY950)MT29TZZZ5D6JKFRL-107/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is not yet programmed (clear) or RPMB General failure EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: Q2J96R_ 111657333_20200612_2332.extcsd Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 1D5A000 sectors 14.7 GiB Soft (Partitioned) Disk/Image size: 1D59FBC sectors 14.7 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,30777310 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x001C000000 (2.750GB) Short EXT fs info: Size: 2.750GB Block size: 4.0KB Inode size: 256 Inodes: 180224 Short Android info: Release Incremental ID: 1480422943 Product ID: A37f Device Name A: A37f Device Model: A37f OPPO ROM Version: V3.0.0i Display Build ID: A37fEX_11_171209 OPPO Region ID A: US OPPO Region ID B: US Build ID: LMY47V Release Base ID: 5.1.1 Security Path: 2017-12-01 Device Manufacturer: OPPO Device Board Name: msm8916 Architecture ABI: arm64-v8a Device manufacturer: OPPO Device Platform: msm8916 Build Description: msm8916_64-user 5.1.1 LMY47V eng.root.20171209.165633 release-keys FRP Partition Path: /dev/block/bootdevice/by-name/config Release Incremental ID: 1480422943 Product ID: A37f Device Name A: A37f Device Model: A37f OPPO ROM Version: V3.0.0i Display Build ID: A37fEX_11_171209 OPPO Region ID A: US OPPO Region ID B: US Backup saved: BuildProp_20200612_2332.txt --------------------------------------------- Detected USERDATA USERDATA : 0x00E2788000 (11.136GB) Short EXT fs info: Size: 11.135GB Block size: 4.0KB Inode size: 256 Inodes: 737280 Short userdata info: Gesture HASH A39A3EE5E6B4B0D3255BFEF95601890AFD80709 Done. Running:Reset PIN/PASS/GESTURE Locks Z3X EasyJtag Software ver. 3.6.2.3 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0E004019B192A1BE, ,FW Ver.: 01.63 CMD Pullup Level:2031 mV CMD Active Level:2485 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 13014E51324A3936521006A7C17564E8 eMMC CSD : D07F01320F5913FFFFFFFFEF924000A2 eMMC Manufacturer ID: 0013 , OEM ID: 014E eMMC Date: 06/2017 Rev.0x10 eMMC NAME: Q2J96R , S/N: 111657333 eMMC NAME (HEX): 51324A393652 IC Name: Micron , eMMC_(JY950)MT29TZZZ5D6JKFRL-107/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 15028 MB , 0x1D5A000 pages , 0x3AB400000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is not yet programmed (clear) or RPMB General failure EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 1D5A000 sectors 14.7 GiB Soft (Partitioned) Disk/Image size: 1D59FBC sectors 14.7 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,30777310 Partition info successfully found ------ Android information ------ Detected LINUX(Android) USERDATA : 0x00E2788000 (11.136GB) Mount EXT4 fs... Starting EXT4 journal... Removing 2: /data/system/locksettings.db ... Removing 2: /data/system/locksettings.db-wal ... Removing 2: /data/system/locksettings.db-shm ... Removing 1: /data/system/gesture.key ... Removing 1: /data/system/password.key ... Shutting down EXT4... --------------------------------------------- Done. FRP REMOVED EasyJtag Suite Classic ver.: 3.6.2.3 / wxWidgets 3.1.3-W-U started. OS ver.: Windows 7 (build 7601, Service Pack 1), 64-bit edition. Admin rights OK Autorun Agent ver:1.0.0.0 Crash Reporting ver:1.4.0.3 EasyJTAG SPI Plugin ver:1.1.1.11 Android ADB API ver:2.0.0.0 FTDI API ver:3.2.4.0 LibUSB API ver:1.2.6.0 Visual C++ Runtime ver:10.0.30319.1 Setting box Pinout ... Box Drivers version: 3.0.1.0, are OK Z3X Card Serial : AA9A-15A0 , ver: 22 Z3X Card Activation [JTAGPLUS] : NOT ACTIVATED Z3X Card Activation [LG] : NOT ACTIVATED Z3X Card Activation [SAMS] : NOT ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED Found 2 serial devices COM8 ACPI\PNP0501 Communications Port (COM8) COM24 USB\VID_0325&PID_0032&REV_0100&MI_00 Easy Jtag Control Port (COM24) Selected pinout: EasyJTAG GEN1 ISP Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.6.2.3 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0E004019B192A1BE, ,FW Ver.: 01.63 CMD Pullup Level:2041 mV CMD Active Level:2495 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 13014E51324A3936521006A7C17564E8 eMMC CSD : D07F01320F5913FFFFFFFFEF924000A2 eMMC Manufacturer ID: 0013 , OEM ID: 014E eMMC Date: 06/2017 Rev.0x10 eMMC NAME: Q2J96R , S/N: 111657333 eMMC NAME (HEX): 51324A393652 IC Name: Micron , eMMC_(JY950)MT29TZZZ5D6JKFRL-107/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is not yet programmed (clear) or RPMB General failure EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: Q2J96R_ 111657333_20200612_2332.extcsd Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 1D5A000 sectors 14.7 GiB Soft (Partitioned) Disk/Image size: 1D59FBC sectors 14.7 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,30777310 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x001C000000 (2.750GB) Short EXT fs info: Size: 2.750GB Block size: 4.0KB Inode size: 256 Inodes: 180224 Short Android info: Release Incremental ID: 1480422943 Product ID: A37f Device Name A: A37f Device Model: A37f OPPO ROM Version: V3.0.0i Display Build ID: A37fEX_11_171209 OPPO Region ID A: US OPPO Region ID B: US Build ID: LMY47V Release Base ID: 5.1.1 Security Path: 2017-12-01 Device Manufacturer: OPPO Device Board Name: msm8916 Architecture ABI: arm64-v8a Device manufacturer: OPPO Device Platform: msm8916 Build Description: msm8916_64-user 5.1.1 LMY47V eng.root.20171209.165633 release-keys FRP Partition Path: /dev/block/bootdevice/by-name/config Release Incremental ID: 1480422943 Product ID: A37f Device Name A: A37f Device Model: A37f OPPO ROM Version: V3.0.0i Display Build ID: A37fEX_11_171209 OPPO Region ID A: US OPPO Region ID B: US Backup saved: BuildProp_20200612_2332.txt --------------------------------------------- Detected USERDATA USERDATA : 0x00E2788000 (11.136GB) Short EXT fs info: Size: 11.135GB Block size: 4.0KB Inode size: 256 Inodes: 737280 Short userdata info: Gesture HASH A39A3EE5E6B4B0D3255BFEF95601890AFD80709 Done. Running:Reset PIN/PASS/GESTURE Locks Z3X EasyJtag Software ver. 3.6.2.3 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0E004019B192A1BE, ,FW Ver.: 01.63 CMD Pullup Level:2031 mV CMD Active Level:2485 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 13014E51324A3936521006A7C17564E8 eMMC CSD : D07F01320F5913FFFFFFFFEF924000A2 eMMC Manufacturer ID: 0013 , OEM ID: 014E eMMC Date: 06/2017 Rev.0x10 eMMC NAME: Q2J96R , S/N: 111657333 eMMC NAME (HEX): 51324A393652 IC Name: Micron , eMMC_(JY950)MT29TZZZ5D6JKFRL-107/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 15028 MB , 0x1D5A000 pages , 0x3AB400000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is not yet programmed (clear) or RPMB General failure EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 1D5A000 sectors 14.7 GiB Soft (Partitioned) Disk/Image size: 1D59FBC sectors 14.7 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,30777310 Partition info successfully found ------ Android information ------ Detected LINUX(Android) USERDATA : 0x00E2788000 (11.136GB) Mount EXT4 fs... Starting EXT4 journal... Removing 2: /data/system/locksettings.db ... Removing 2: /data/system/locksettings.db-wal ... Removing 2: /data/system/locksettings.db-shm ... Removing 1: /data/system/gesture.key ... Removing 1: /data/system/password.key ... Shutting down EXT4... --------------------------------------------- Done. Running:Format FRP Partition... Z3X EasyJtag Software ver. 3.6.2.3 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0E004019B192A1BE, ,FW Ver.: 01.63 CMD Pullup Level:2041 mV CMD Active Level:2495 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 13014E51324A3936521006A7C17564E8 eMMC CSD : D07F01320F5913FFFFFFFFEF924000A2 eMMC Manufacturer ID: 0013 , OEM ID: 014E eMMC Date: 06/2017 Rev.0x10 eMMC NAME: Q2J96R , S/N: 111657333 eMMC NAME (HEX): 51324A393652 IC Name: Micron , eMMC_(JY950)MT29TZZZ5D6JKFRL-107/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 15028 MB , 0x1D5A000 pages , 0x3AB400000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is not yet programmed (clear) or RPMB General failure EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 1D5A000 sectors 14.7 GiB Soft (Partitioned) Disk/Image size: 1D59FBC sectors 14.7 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,30777310 Partition info successfully found Formatting FRP... Detected LINUX(Android) CACHE : 0x00D0000000 (128.0MB) , formatting... Done. Detected LINUX(Android) CONFIG : 0x00DA180000 (32.0KB) formatting... Done. Detected LINUX(Android) USERDATA : 0x00E2788000 (11.136GB) , formatting... Done. Done. Done. |
08-28-2020, 09:34 | #733 (permalink) |
No Life Poster Join Date: May 2014 Location: UGANDA
Member: 2185549 Status: Offline Thanks Meter: 535 | samsung t560nu dead boot repiar done with writing dump and then flashing bl ap csc wihtout system eMMC_tool Suite ver. 1.6.3.0 (release date: 23.06.2020) Microsoft Windows 10 (64 bit) build 18362 (10.0.18362.959) Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 1 MHz CMD Pullup Level: 2662 mV CMD Active Level: 2316 mV EMMC Device Information : EMMC CID: 1101003430303037330027A2A65714D3 EMMC CSD: D07E00320F5903FFFFFFFFE78A4000D1 EMMC Manufacture : TOSHIBA , EMMC NAME: 400073 , HEX: 343030303733 , S/N: 27A2A657 , rev. 0x00 EMMC Manufacture ID: 0x11 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 1/2017 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 2589 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: 400073_27A2A657_20200828_104113.extcsd EMMC Init completed. Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 1 MHz CMD Pullup Level: 2664 mV CMD Active Level: 2320 mV EMMC Device Information : EMMC CID: 1101003430303037330027A2A65714D3 EMMC CSD: D07E00320F5903FFFFFFFFE78A4000D1 EMMC Manufacture : TOSHIBA , EMMC NAME: 400073 , HEX: 343030303733 , S/N: 27A2A657 , rev. 0x00 EMMC Manufacture ID: 0x11 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 1/2017 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 2589 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: 400073_27A2A657_20200828_104505.extcsd EMMC Init completed. Opening file: CSC_BNN_T560NUBNN1CRG1_CL14081424_QB19124359_REV00 _user_low_ship_MULTI_CERT.tar.md5 Unpacking PIT from CSC Pit: GTELWIFI_USA_OPEN.pit Entry count: 32 The size of the last section has been updated BL_T560NUUEU1CRG1_CL14081424_QB19124359_REV00_user _low_ship_MULTI_CERT.tar.md5 The list of files in the firmware: aboot.mbn sbl1.mbn rpm.mbn tz.mbn hyp.mbn non-hlos.bin sec.dat AP_T560NUUEU1CRG1_CL14081424_QB19124359_REV00_user _low_ship_MULTI_CERT_meta.tar.md5 The list of files in the firmware: boot.img recovery.img system.img.ext4 persist.img.ext4 modem.bin userdata.img.ext4 meta-data/ meta-data/fota.zip Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 1 MHz CMD Pullup Level: 2664 mV CMD Active Level: 2319 mV EMMC Device Information : EMMC CID: 1101003430303037330027A2A65714D3 EMMC CSD: D07E00320F5903FFFFFFFFE78A4000D1 EMMC Manufacture : TOSHIBA , EMMC NAME: 400073 , HEX: 343030303733 , S/N: 27A2A657 , rev. 0x00 EMMC Manufacture ID: 0x11 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 1/2017 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 2589 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: 400073_27A2A657_20200828_104535.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Writing BackupGPT at address: 0003AB3FBE00 Writing PIT at address: 000000004400 GPT-partitioning done Unpacking file: non-hlos.bin Unpacking file: modem.bin Unpacking file: sbl1.mbn Unpacking file: aboot.mbn Unpacking file: rpm.mbn Unpacking file: tz.mbn Unpacking file: hyp.mbn Unpacking file: sec.dat Unpacking file: boot.img Unpacking file: recovery.img Unpacking file: persist.img.ext4 Partition name: APNHLOS Filename: non-hlos.bin , Offset: 000000400000 , filesize: 12502784 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 115.74 KB/s Partition name: MODEM Filename: modem.bin , Offset: 000001300000 , filesize: 14354176 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 117.12 KB/s Partition name: SBL1 Filename: sbl1.mbn , Offset: 000004C70000 , filesize: 285428 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 115.35 KB/s Partition name: ABOOT Filename: aboot.mbn , Offset: 000004CF8000 , filesize: 1351464 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 116.61 KB/s Partition name: RPM Filename: rpm.mbn , Offset: 000004EF8000 , filesize: 188308 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 114.58 KB/s Partition name: QSEE Filename: tz.mbn , Offset: 000004F78000 , filesize: 512572 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 116.20 KB/s Partition name: QHEE Filename: hyp.mbn , Offset: 000004FF8000 , filesize: 90368 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 111.39 KB/s Partition name: SEC Filename: sec.dat , Offset: 000005378000 , filesize: 684 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 19.10 KB/s Partition name: BOOT Filename: boot.img , Offset: 000007C00000 , filesize: 12583184 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 117.01 KB/s Partition name: RECOVERY Filename: recovery.img , Offset: 000008900000 , filesize: 13965584 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 116.51 KB/s Partition name: PERSIST Filename: persist.img.ext4 , Offset: 00000AE00000 , filesize: 4350076 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 8 Done writing partition. Write speed: 116.41 KB/s Partition CACHE : formatting as EXT4. Please wait ... Formatting completed Partition HIDDEN : formatting as EXT4. Please wait ... Formatting completed Partition USERDATA : formatting as EXT4. Please wait ... Formatting completed Check BootConfig for the selected vendor All done time: [00:10:46:502] |
09-15-2020, 14:11 | #734 (permalink) |
Member: 2185549 Status: Offline Thanks Meter: 535 | samsung frp t385l android 9 bypass failed no browser frp fix done Setting interface to EasyJtag2/E-Socket Setting bus width to 1 Bit Setting frequence to 1 MHz EMMC Device Information : EMMC CID: 150100424A54443452003D35439FA53F EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: BJTD4R , HEX: 424A54443452 , S/N: 3D35439F , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 10/2018 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 3369 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: BJTD4R_3D35439F_20200915_160910.extcsd EMMC Init completed. Get firmware version Brand = samsung Manufacturer = samsung Device = gta2sltelgt Model = SM-T385L CPU Abi = armeabi-v7a Android release = 9 Security Patch = 2019-09-01 Firmware version = PPR1.180610.011.T385LKLU1CSK2 Firmware date = Fri Nov 8 23:42:28 KST 2019 Setting interface to EasyJtag2/E-Socket Setting bus width to 1 Bit Setting frequence to 1 MHz EMMC Device Information : EMMC CID: 150100424A54443452003D35439FA53F EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: BJTD4R , HEX: 424A54443452 , S/N: 3D35439F , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 10/2018 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 3369 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: BJTD4R_3D35439F_20200915_161008.extcsd EMMC Init completed. Operation: Remove FRP Searching GPT ... GPT header is found and is valid FRP signature found (partname: persistent) Erasing FRP partition ... Done erasing partition. All done |
09-28-2020, 10:02 | #735 (permalink) |
Freak Poster Join Date: Apr 2014 Location: kaduna state,Nigeria Age: 32
Member: 2165294 Status: Offline Thanks Meter: 59 | First ufs 2.1 goes successfully Alhamdulillah!!!! Reno 3 done offline |
The Following User Says Thank You to Ahmadaim1 For This Useful Post: |
