Old 11-04-2022, 12:08   #751 (permalink)
Member: 2256970
Thanks Meter: 67
vivo y15 pattern and frp done
eMMC CID : 150100525036344D4201BEBCC232B635
eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D
eMMC Manufacturer ID: 0015 , OEM ID: 0100
eMMC Date: 11/2019 Rev.0x1
eMMC NAME: RP64MB , S/N: 3200041522
eMMC NAME (HEX): 525036344D42
EMMC ROM1 (Main User Data) Capacity: 59640 MB , 0x747C000 pages , 0xE8F800000 bytes
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB
EMMC RPMB is programmed and written 463 times
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x02 , width 8bits , Partition config [179]: 0x48.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Found valid GPT with protective MBR; using GPT.
Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB
Soft (Partitioned) Disk/Image size: 747BFBC sectors 58.2 GiB
Disk identifier (GUID): 00000000-0000-0000-0000-000000000000
Logical sector size: 0x200 bytes ,First/Last usable sector: 34,122142686
Partition info successfully found
Formatting FRP...
Detected LINUX(Android) FRP : 0x0005588000 (1.0MB) formatting...
Done.
Detected LINUX(Android) CACHE : 0x016F800000 (256.0MB) , formatting...
Done.
Detected LINUX(Android) USERDATA : 0x017F800000 (52.191GB) , formatting...
Done.
Done.
Done.
Checking security ...
Running:Reset PIN/PASS/GESTURE Locks
Z3X EasyJtag Software ver. 3.8.0.0
Loading eMMC GEN2 Firmware... IO: 2400 mV
Box S/N: EB3969F4129DD4FF, ,FW Ver.: 02.53
CMD Pullup Level:2066 mV
CMD Active Level:2192 mV
Box IO Level:2400 mV
CLK Rate:18000 kHz
Bus Width:1bit,SDR
HiPower mode is off!
---------- eMMC Device Information ----------
------ Android information ------
Mount EXT4 fs...
Unable to mount USER , code : 95
Done.
Old 11-15-2022, 17:25   #752 (permalink)
Member: 3006218
How to remove mdm by jtag please anyone
Old 11-25-2022, 14:41   #753 (permalink)
Member: 4627
Sonork: 57528:debeliamark
Thanks Meter: 1,013
SM-A035G FRP remove.
As in title. This phone is UniSOC T606 based, but no tool for now that boot it correct, so the lovely Z3x JTAG do the job.
Use pinouts from here.
Connect phone PCB to EMMC Tool 2 via ISP.
Use Vendor -> Scan Source -> Actions -> Wipe Data and after this Remove FRP. Disconnect and connect it again - repeat operations until you see at end of log window - FRP not found. The job is done.
Operation: Connect to Z3X EasyJtagPlus
Setting Interface to EasyJtag2/ISP
Setting Frequence to 18 Mhz
Setting BusWidth to 1 Bit
CMD Pullup Level: 75 mV
CMD Active Level: 2000 mV
Setting HS Timing to Enabled
EMMC Device Information :
EMMC CID: 1501004450364442420068D5DC23497D
EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D
Manufacturer: SAMSUNG , NAME: DP6DBB , HEX: 445036444242 , S/N: 68D5DC23 , Rev: 00
Manufacturer ID: 15 , OEM ID: 00 , Device Type: BGA (Discrete embedded) , Date: 4/2022
   EMMC ROM 1 (Main User Data) Capacity: 59640 MB (0x000E8F800000)
   EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (0x000000400000)
   EMMC RPMB Capacity: 16384 KB (0x000001000000) , Counter: 8684 , Response: Not Clean
Extended CSD Information :
Extended CSD rev: 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG]: 0x08 , Boot partition 1 enabled for boot
Boot Bus Config: 0x00 , x1 (sdr) or x4 (ddr) bus width in boot operation mode
H/W Reset Function [RST_N_FUNCTION]: 0x00 , RST_n signal is temporarily disabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition settings [PARTITION_SETTING_COMPLETED]: 0x00
EMMC Init completed
Extcsd backup saved: DP6DBB_68D5DC23_20221125_151144.extcsd  (old backup)
Connected successfully
Operation: Scan PartitionTable from Source (Vendor: Binary Read/Write)
Scanning soft partitions from ROM2
GPT header is not found
Scanning soft partitions from ROM3
Scanning soft partitions from ROM1
GPT header is found
Partition: PrimaryGPT, [000000000000 - 000000004400], Size: 000000004400 (17,00 KB), Type: GPT
Partition: prodnv, [000000100000 - 000000B00000], Size: 000000A00000 (10,00 MB), Type: Linux (/mnt/vendor)
Partition: miscdata, [000000B00000 - 000000C00000], Size: 000000100000 (1,00 MB), Type: Raw
Partition: l_fixnv1, [000000C00000 - 000000E00000], Size: 000000200000 (2,00 MB), Type: Raw
Partition: l_fixnv2, [000000E00000 - 000001000000], Size: 000000200000 (2,00 MB), Type: Raw
Partition: l_deltanv, [000001000000 - 000001100000], Size: 000000100000 (1,00 MB), Type: Raw
Partition: l_runtimenv1, [000001100000 - 000001300000], Size: 000000200000 (2,00 MB), Type: Raw
Partition: l_runtimenv2, [000001300000 - 000001500000], Size: 000000200000 (2,00 MB), Type: Raw
Partition: misc, [000001500000 - 000001600000], Size: 000000100000 (1,00 MB), Type: Blank
Partition: param, [000001600000 - 000002000000], Size: 000000A00000 (10,00 MB), Type: Raw
Partition: vendor_efs, [000002000000 - 000003000000], Size: 000001000000 (16,00 MB), Type: Linux (/mnt/vendor/efs)
Partition: sec_efs, [000003000000 - 000004000000], Size: 000001000000 (16,00 MB), Type: Linux (/efs)
Partition: persist, [000004000000 - 000004800000], Size: 000000800000 (8,00 MB), Type: Blank
Partition: steady, [000004800000 - 000004C00000], Size: 000000400000 (4,00 MB), Type: Raw
Partition: persistent, [000004C00000 - 000004D00000], Size: 000000100000 (1,00 MB), Type: Blank
Partition: pad, [000004D00000 - 000005000000], Size: 000000300000 (3,00 MB), Type: Blank
Partition: trustos, [000005000000 - 000005600000], Size: 000000600000 (6,00 MB), Type: Raw
Partition: trustos_bak, [000005600000 - 000005C00000], Size: 000000600000 (6,00 MB), Type: Raw
Partition: sml, [000005C00000 - 000005D00000], Size: 000000100000 (1,00 MB), Type: Raw
Partition: sml_bak, [000005D00000 - 000005E00000], Size: 000000100000 (1,00 MB), Type: Raw
Partition: pm_sys, [000005E00000 - 000006000000], Size: 000000200000 (2,00 MB), Type: Raw
Partition: teecfg, [000006000000 - 000006100000], Size: 000000100000 (1,00 MB), Type: Raw
Partition: teecfg_bak, [000006100000 - 000006200000], Size: 000000100000 (1,00 MB), Type: Raw
Partition: tzar, [000006200000 - 000006600000], Size: 000000400000 (4,00 MB), Type: Blank
Partition: uboot, [000006600000 - 000006B00000], Size: 000000500000 (5,00 MB), Type: Raw
Partition: uboot_bak, [000006B00000 - 000006C00000], Size: 000000100000 (1,00 MB), Type: Blank
Partition: vbmeta, [000006C00000 - 000006D00000], Size: 000000100000 (1,00 MB), Type: Raw
Partition: vbmeta_bak, [000006D00000 - 000006E00000], Size: 000000100000 (1,00 MB), Type: Raw
Partition: btd, [000006E00000 - 000007000000], Size: 000000200000 (2,00 MB), Type: Raw
Partition: uboot_log, [000007000000 - 000008000000], Size: 000001000000 (16,00 MB), Type: Raw
Partition: logo, [000008000000 - 000008600000], Size: 000000600000 (6,00 MB), Type: Raw
Partition: fbootlogo, [000008600000 - 000008A00000], Size: 000000400000 (4,00 MB), Type: Raw
Partition: bota, [000008A00000 - 000009B00000], Size: 000001100000 (17,00 MB), Type: Raw
Partition: debug, [000009B00000 - 00000A500000], Size: 000000A00000 (10,00 MB), Type: Raw
Partition: gnssmodem, [00000A500000 - 00000A600000], Size: 000000100000 (1,00 MB), Type: Raw
Partition: wcnmodem, [00000A600000 - 00000B000000], Size: 000000A00000 (10,00 MB), Type: Raw
Partition: l_gdsp, [00000B000000 - 00000BA00000], Size: 000000A00000 (10,00 MB), Type: Raw
Partition: l_ldsp, [00000BA00000 - 00000CE00000], Size: 000001400000 (20,00 MB), Type: Raw
Partition: l_modem, [00000CE00000 - 00000EC00000], Size: 000001E00000 (30,00 MB), Type: Raw
Partition: boot, [00000EC00000 - 000012C00000], Size: 000004000000 (64,00 MB), Type: Boot
Partition: recovery, [000012C00000 - 000016C00000], Size: 000004000000 (64,00 MB), Type: Boot
Partition: dtbo, [000016C00000 - 000017400000], Size: 000000800000 (8,00 MB), Type: Raw
Partition: socko, [000017400000 - 00001BF00000], Size: 000004B00000 (75,00 MB), Type: Linux (/socko)
Partition: odmko, [00001BF00000 - 00001D700000], Size: 000001800000 (24,00 MB), Type: Linux (/odmko)
Partition: metadata, [00001D700000 - 00001E700000], Size: 000001000000 (16,00 MB), Type: Linux (/metadata)
Partition: vbmeta_system, [00001E700000 - 00001E800000], Size: 000000100000 (1,00 MB), Type: Raw
Partition: vbmeta_vendor, [00001E800000 - 00001E900000], Size: 000000100000 (1,00 MB), Type: Raw
Partition: pad2, [00001E900000 - 00001F000000], Size: 000000700000 (7,00 MB), Type: Blank
Partition: super, [00001F000000 - 00019F000000], Size: 000180000000 (6,00 GB), Type: Super
          Partition: system, [00001F100000 - 0000F37B0000], Size: 0000D46B0000 (3,32 GB), Type: Linux
          Partition: system_ext, [0000F3800000 - 0000FB06C000], Size: 00000786C000 (120,42 MB), Type: Linux
          Partition: vendor, [0000FB100000 - 00012B87F000], Size: 00003077F000 (775,50 MB), Type: Linux
          Partition: product, [00012B900000 - 00016DABF000], Size: 0000421BF000 (1,03 GB), Type: Linux
Partition: prism, [00019F000000 - 0001CC800000], Size: 00002D800000 (728,00 MB), Type: Linux (/prism)
Partition: optics, [0001CC800000 - 0001CE800000], Size: 000002000000 (32,00 MB), Type: Linux (/optics)
Partition: cache, [0001CE800000 - 0001E2000000], Size: 000013800000 (312,00 MB), Type: Linux (/cache)
Partition: omr, [0001E2000000 - 0001E5200000], Size: 000003200000 (50,00 MB), Type: Linux (/omr)
Partition: sysdumpdb, [0001E5200000 - 0001E5C00000], Size: 000000A00000 (10,00 MB), Type: Raw
Partition: l_agdsp, [0001E5C00000 - 0001E6200000], Size: 000000600000 (6,00 MB), Type: Raw
Partition: userdata, [0001E6200000 - 000E8F7FB000], Size: 000CA95FB000 (50,65 GB), Type: Raw
Partition: BackupGPT, [000E8F7FBE00 - 000E8F800000], Size: 000000004200 (16,50 KB), Type: BackupGPT
GPT header successfully parsed
Operation: Wipe Data (Universal Factory Reset)
Writing: ROM1, Partition: misc, Offset: 0x000001500000, Size: 0x000000100000 (1,00 MB)
Erasing partition...
Writing data...
Done writing partition
All done
Operation: Remove FRP
FRP not found
Disconnected
BR, DebeliaMark, BG
Old 12-06-2022, 21:41   #754 (permalink)
Member: 3026822
Thanks Meter: 2
Do we need to 1st buy box or can we use like z3x samsung box to beta test?
Page generated in 0.15350 seconds with 9 queries
