Old 12-18-2018, 11:04   #31 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Thanks Meter: 497
Originally Posted by duythangvn View Post
put all the info then write. dont use fix button, that make damage boot.
Sir Now Please Check My Steps
Now Okay?
And Thank You So Much For Help
I Will Post Result After Resoldered NAND On Board
The Following 7 Users Say Thank You to shoaibrao For This Useful Post:
Old 12-18-2018, 20:19   #32 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Thanks Meter: 497
iphone 6 error 4013 fix nand cant active because MAC addr different
Sir Have You Solved Activation Problem ?
Old 12-19-2018, 03:28   #33 (permalink)
Member: 818380
Thanks Meter: 56
it all okay, test okay with iphone 5s, ipad 2, ipad 3.
Old 12-19-2018, 07:59   #34 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Thanks Meter: 497
Sir Please Share Procedure
I Also Have Fone Stuck On Activation
Thanks Anticipation
Old 12-19-2018, 09:19   #35 (permalink)
Member: 818380
Thanks Meter: 56
Thanks Anticipation
It looks like you are using the old version. try with this version and report
Nextcloud
Old 12-19-2018, 09:25   #36 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Thanks Meter: 497
Nextcloud
Thanks For New Setup Exe Link
But My Question Is
I Have A Fone In Hands
Which Is Stuck On Activation
" iPhone could not be activated because the activation server cannot be reached "
What Is Solution For This Error
Old 12-19-2018, 09:33   #37 (permalink)
Member: 818380
Thanks Meter: 56
But My Question Is
phone board is original or not. with ios 11 and newer apple check activation with s/n,mac,s/n cpu(iphone 6 and newer board id have 17 number). iphone 6 and newer devices some hw damage make activation error.
The Following User Says Thank You to duythangvn For This Useful Post:
Old 02-14-2019, 23:43   #38 (permalink)
Member: 389266
Thanks Meter: 17
sir now please check my steps
now okay?
And thank you so much for help
i will post result after resoldered nand on board
thanks very good work
100% test
luck
The Following 2 Users Say Thank You to engendro For This Useful Post:
Old 05-26-2019, 15:16   #39 (permalink)
Member: 391748
Thanks Meter: 3
please post more success result of iphone error in restore, i have emmcsocket and planning to buy nand socket instead of navipro.
thanks!
Old 06-16-2019, 00:26   #40 (permalink)
Member: 145109
Sonork: 100.97977
Thanks Meter: 13
Working 100% following the steps above!!!
Old 04-10-2020, 19:46   #41 (permalink)
Member: 2950176
k9gag08u0e
I can't program this memory with an easy jtag as well as can recommend a soft compatibility version and they are loaded all over the shelf thanks
Old 12-25-2020, 07:09   #42 (permalink)
Crazy Poster
Member: 2025909
Sonork: csandaruwan
Thanks Meter: 10
iphone 6 4013 error
Is it possible to troubleshoot the 4013 error iphone 6 ?
Old 09-21-2021, 17:28   #43 (permalink)
Member: 1520712
Thanks Meter: 19
Hello team we will wayting yet the pinouts for the nand mico sd card monolith .
You says that you are provide some famous pinout at the next release but yet nothing.
Please support this section!!!
Old 10-12-2021, 09:29   #44 (permalink)
Member: 1434277
me mobile power music flash file givme
Old 10-12-2021, 09:32   #45 (permalink)
Member: 1434277
https://www.google.com.pk/search?q=m...xsrf=AOaemvJI2]
Page generated in 0.22815 seconds with 8 queries
