Problem With Classic v3.7.0.20, Unstable while reading the eMMC with 36MHZ after update easy jtag plus box firmware useing v3.7.0.20 cant read emmc by any interfaces at 36mhz and when i downgrade firmware the box is stable in 36mhz , All attempts with the isp 1bit connection and same wires as well as the same chip and board. https://d.top4top.io/p_1778yd3iw1.png https://e.top4top.io/p_1778901962.png https://f.top4top.io/p_1778489bh3.png https://g.top4top.io/p_1778gmplz4.png |
I am waiting for a solution to the problem from the responsible team |
brother i wrote "when i downgrade firmware the box is stable in 36mhz" , did you read it ? |
Just send Report and leave it do not ask here itself to reply for u. wait team will take the notes and will fix in next update. Programming is not like cook a hot water to make immediate Tell your issues and Request solve this as soon as possible. This is the way of approaching a make changes in Software. Hope u will understand. Thank you. |
You use incorrect VIO setting and want to normal work? VIO at most devices is 1,8v |
many devices which did not connect by use before, now work. we most to sacrifice one for the other. use 24 MHz or try to put a resistor of 20-30 ohm in series in the CLK line you can also try to "Disable High Speed timing" at settings |
Thanks Leader, I'll try again. |
