Old 11-13-2020, 14:41   #1 (permalink)
Member: 2611378
Problem With Classic v3.7.0.20, Unstable while reading the eMMC with 36MHZ
after update easy jtag plus box firmware useing v3.7.0.20 cant read emmc by any interfaces at 36mhz and when i downgrade firmware the box is stable in 36mhz , All attempts with the isp 1bit connection and same wires as well as the same chip and board.
Old 11-13-2020, 18:47   #2 (permalink)
Member: 2611378
I am waiting for a solution to the problem from the responsible team
Old 11-13-2020, 21:07   #3 (permalink)
hitech care's Avatar
Member: 1834832
Thanks Meter: 1,385
Higher Clock Rate Will Not Work Well With ISP Connection Spsly On 1Bit Connection In Older Devices It May Work But In New Devices It Give Error 18Mhz Is Recommended Speed For ISP U Can Try Higher Clock If Give Error Kindly Reduce Speed If U Want To Work With Higher Clock Better Do Chip OFF N Do Operation Spsly For BGA-254 Hope U Got Ur Answer Now
Old 11-13-2020, 21:22   #4 (permalink)
Member: 2611378
Higher Clock Rate Work Well With ISP Connection Spsly On 1Bit with software old version , this problem only with new update.
brother i wrote "when i downgrade firmware the box is stable in 36mhz" , did you read it ?
Old 11-17-2020, 20:47   #5 (permalink)
Member: 350571
Thanks Meter: 908
its New Version Test Report,
Just send Report and leave it
do not ask here itself to reply for u.
wait team will take the notes and will fix in next update.
Programming is not like cook a hot water to make immediate
Tell your issues and Request solve this as soon as possible.
This is the way of approaching a make changes in Software.
Hope u will understand.
Thank you.
The Following User Says Thank You to sree krishna For This Useful Post:
Old 11-18-2020, 12:13   #6 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,143
You use incorrect VIO setting and want to normal work?
VIO at most devices is 1,8v
The Following 2 Users Say Thank You to layder For This Useful Post:
Old 11-19-2020, 01:04   #7 (permalink)
Member: 2611378
Thank you.
I understand very well what you are saying, but some are not convinced there is a problem, all I ask is that some do the same as my experience and present the result.
Old 11-19-2020, 01:15   #8 (permalink)
Member: 2611378
I tried all of them 1.8v, 2.8v and 3.3v same result, But with an older version of v3.7.0.20, there is no problem.
Old 11-19-2020, 10:26   #9 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,143
you can use older version.
many devices which did not connect by use before, now work.
we most to sacrifice one for the other.
use 24 MHz or try to put a resistor of 20-30 ohm in series in the CLK line
you can also try to "Disable High Speed timing" at settings
Old 11-21-2020, 08:21   #10 (permalink)
Member: 2611378
Thanks Leader, I'll try again.
Page generated in 0.32064 seconds with 7 queries
