09-02-2020, 18:25 | #1 (permalink) |
Freak Poster Join Date: Feb 2015 Location: Egypt
Member: 2346548 Status: Offline Thanks Meter: 36 | problem on Cph1933 ufs chip i have oppo A52020 Cph 1933 i toke chip off and worked on EFM i connected and oppo reset and reset frp got error while resetting frp after that EFM gave many errors while connecting and set hang on first logo and no recovery tried with classic all is ok lun 5 have no partions set now is hang on first logo and no recovery solution? |
09-03-2020, 13:43 | #3 (permalink) |
Member: 2346548 Status: Offline Thanks Meter: 36 | 31.08.2020 22:05:42> Search FRP Partition.. 31.08.2020 22:05:42> Partition #7 - 'FRP' is FRP. 31.08.2020 22:05:42> Erasing Partition. Please Wait.. 31.08.2020 22:05:55> Error Verify Write Sector: 8635, Count: 1 31.08.2020 22:05:55> Error Erasing Data. Break.. 31.08.2020 22:05:55> Error Code: -13 |
09-03-2020, 14:20 | #4 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | try to find unpacked firmware and download latest EFM and write firmware to UFS chip via EFM |
The Following User Says Thank You to layder For This Useful Post: |
09-05-2020, 13:37 | #7 (permalink) |
Member: 2346548 Status: Offline Thanks Meter: 36 | everytime i try to connect with EFM 05.09.2020 14:22:30> 05.09.2020 14:22:32> Z3X Card Serial: 05.09.2020 14:22:32> EasyJtag Plus Box Found at: COM105 05.09.2020 14:22:32> EasyJtag Plus Box Firmware: 2.53.1 05.09.2020 14:22:32> 05.09.2020 14:22:46> Source: EasyJtag Port [UFS] 05.09.2020 14:22:46> Generation: GPT [QC/SAMS/BCM/INTEL/MTK] 05.09.2020 14:22:46> UFS Power Mode: LOW 05.09.2020 14:22:46> Scanner Thread Created.. 05.09.2020 14:22:46> 05.09.2020 14:22:46> Running EasyJtag UFS Mode... 05.09.2020 14:22:46> UFS ISP Mode: OFF 05.09.2020 14:22:46> UFS Safe Mode: ON 05.09.2020 14:22:46> 05.09.2020 14:23:04> Init UFS Engine: 0/OK 05.09.2020 14:23:04> 05.09.2020 14:23:04> EasyJtag Plus S/N: 05.09.2020 14:23:04> EasyJtag Plus Box FirmWare: 2.53 05.09.2020 14:23:04> Box Hardware = EasyJtag 2nd Generation 05.09.2020 14:23:04> 05.09.2020 14:23:04> UFS: Socket Info: 05.09.2020 14:23:04> S/N: 05.09.2020 14:23:04> Desc: EasyJTAG UFS Socket 3 in 1 by MOORC 18.06.20 05.09.2020 14:23:04> Type: MOORK UFS Socket 3 in 1 05.09.2020 14:23:04> ID: 3708 05.09.2020 14:23:04> 05.09.2020 14:23:04> UFS: Voltage Info: 05.09.2020 14:23:04> Mode: LOW 05.09.2020 14:23:04> VCC : 3320 mV, VCCQ2: 1917 mV 05.09.2020 14:23:04> 3v3 : 3360 mV, 1v2: 1215 mV 05.09.2020 14:23:04> 05.09.2020 14:23:04> UFS: Memory Info: 05.09.2020 14:23:04> Connection: UNKNOWN SOCKET TYPE 05.09.2020 14:23:04> Vendor: MICRON 05.09.2020 14:23:04> Name: MT128GASAO4U21 05.09.2020 14:23:04> S/N: 0x0597151301020C081900 05.09.2020 14:23:04> OEM ID: MICRON 05.09.2020 14:23:04> Firm Version: 1.01 05.09.2020 14:23:04> UFS Version: 2.1 05.09.2020 14:23:04> Size: 0x001DCC800000/119.20 GB 05.09.2020 14:23:04> Max LUNs: 32 05.09.2020 14:23:04> LUNs Cnt: 6 05.09.2020 14:23:04> W-LUNs Cnt: 1 05.09.2020 14:23:04> LUNs ReConfig: Enabled 05.09.2020 14:23:04> 05.09.2020 14:23:04> UFS Health Info: 05.09.2020 14:23:04> UFS Life Time A: 0x01 - 0% - 10% Life Time Used 05.09.2020 14:23:04> UFS Life Time B: 0x01 - 0% - 10% Life Time Used 05.09.2020 14:23:04> UFS Pre-EOL Info: 0x01 - Used Less 80% of Reserved Blocks 05.09.2020 14:23:04> 05.09.2020 14:23:04> UFS: LUNs Info: 05.09.2020 14:23:04> LUN 0 - Size: 30111744 Block(s)/114.87 GB 05.09.2020 14:23:04> LUN 1 (Boot A) - Size: 2048 Block(s)/8.00 MB 05.09.2020 14:23:04> LUN 2 (Boot B) - Size: 2048 Block(s)/8.00 MB 05.09.2020 14:23:04> LUN 3 - Size: 8192 Block(s)/32.00 MB 05.09.2020 14:23:04> LUN 4 - Size: 1048576 Block(s)/4.00 GB 05.09.2020 14:23:04> LUN 5 - Size: 65536 Block(s)/256.00 MB 05.09.2020 14:23:04> W-LUN 0xC4 (REPORT LUNS) - Size: 65536 Block(s)/16.00 MB 05.09.2020 14:23:04> 05.09.2020 14:23:04> UFS Init OK 05.09.2020 14:23:04> Scanning Data From UFS Chip. Please wait.. 05.09.2020 14:23:04> 05.09.2020 14:23:04> Scanning GUID Partition Table from LUN 0 05.09.2020 14:23:04> GUID Partition Table is Found. Max Parts: 32 05.09.2020 14:23:04> GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB 05.09.2020 14:23:04> GPT: SSD [000000006000 - 000000002000] Size: 8.00 KB 05.09.2020 14:23:04> GPT: PERSIST [000000008000 - 000002000000] Size: 32.00 MB 05.09.2020 14:23:04> GPT: MISC [000002008000 - 000000100000] Size: 1.00 MB 05.09.2020 14:23:04> GPT: KEYSTORE [000002108000 - 000000080000] Size: 512.00 KB 05.09.2020 14:23:04> GPT: FRP [000002188000 - 000000080000] Size: 512.00 KB 05.09.2020 14:23:04> GPT: CACHE [000002208000 - 000010000000] Size: 256.00 MB 05.09.2020 14:23:04> GPT: SYSTEM [000012208000 - 00018FC00000] Size: 6.25 GB 05.09.2020 14:23:04> GPT: METADATA [0001A1E08000 - 000001000000] Size: 16.00 MB 05.09.2020 14:23:04> GPT: ODM [0001A2E08000 - 000010000000] Size: 256.00 MB 05.09.2020 14:23:04> GPT: USERDATA [0001B2E08000 - 001B049F3000] Size: 108.07 GB 05.09.2020 14:23:04> GPT: BACKUP_GPT [001CB77FB000 - 000000005000] Size: 20.00 KB 05.09.2020 14:23:04> Reading Table Completed 05.09.2020 14:23:05> Scanning GUID Partition Table from LUN 1 05.09.2020 14:23:05> GUID Partition Table is Found. Max Parts: 32 05.09.2020 14:23:05> GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB 05.09.2020 14:23:05> GPT: XBL [000000006000 - 000000380000] Size: 3.50 MB 05.09.2020 14:23:05> GPT: XBL_CONFIG [000000386000 - 000000020000] Size: 128.00 KB 05.09.2020 14:23:05> GPT: LAST_PARTI [0000003A6000 - 000000455000] Size: 4.33 MB 05.09.2020 14:23:05> GPT: BACKUP_GPT [0000007FB000 - 000000005000] Size: 20.00 KB 05.09.2020 14:23:05> Reading Table Completed 05.09.2020 14:23:05> Scanning GUID Partition Table from LUN 2 05.09.2020 14:23:06> 05.09.2020 14:23:06> Error Reading Sector: 0, Count: 6, Err: -403/ERROR_UFS_CHIP_HWPART_JEDEC_PSREQ 05.09.2020 14:23:06> Try Again #1 05.09.2020 14:23:06> 05.09.2020 14:23:06> Error Reading Sector: 0, Count: 6, Err: -403/ERROR_UFS_CHIP_HWPART_JEDEC_PSREQ 05.09.2020 14:23:06> Try Again #2 05.09.2020 14:23:06> 05.09.2020 14:23:06> Error Reading Sector: 0, Count: 6, Err: -403/ERROR_UFS_CHIP_HWPART_JEDEC_PSREQ 05.09.2020 14:23:06> Try Again #3 05.09.2020 14:23:06> 05.09.2020 14:23:06> Too Many Errors. Stopped. Err: -403/ERROR_UFS_CHIP_HWPART_JEDEC_PSREQ 05.09.2020 14:23:06> Error While Reading. Exit. Code: -403 05.09.2020 14:23:06> 05.09.2020 14:23:06> Error While Scan Partitions. Scanner Shutdown.. 05.09.2020 14:23:06> 05.09.2020 14:23:06> Scanner Thread Terminated 05.09.2020 14:23:06> Elapsed: 00:00:20:015 05.09.2020 14:23:06> Found 0 Partition(s).. 05.09.2020 14:23:06> 05.09.2020 14:23:06> Search Partitions Fail.. 05.09.2020 14:23:06> Check Socket/UFS Chip and Try Again.. 05.09.2020 14:23:06> 05.09.2020 14:23:35> Source: EasyJtag Port [UFS] 05.09.2020 14:23:35> Generation: GPT [QC/SAMS/BCM/INTEL/MTK] 05.09.2020 14:23:35> UFS Power Mode: LOW 05.09.2020 14:23:35> Scanner Thread Created.. |
09-05-2020, 14:04 | #8 (permalink) |
Member: 2346548 Status: Offline Thanks Meter: 36 | 05.09.2020 15:02:19> Running EasyJtag UFS Mode... 05.09.2020 15:02:19> UFS ISP Mode: OFF 05.09.2020 15:02:19> UFS Safe Mode: ON 05.09.2020 15:02:19> 05.09.2020 15:02:33> Init UFS Engine: 0/OK 05.09.2020 15:02:33> 05.09.2020 15:02:34> EasyJtag Plus S/N: 05.09.2020 15:02:34> EasyJtag Plus Box FirmWare: 2.53 05.09.2020 15:02:34> Box Hardware = EasyJtag 2nd Generation 05.09.2020 15:02:34> 05.09.2020 15:02:34> UFS: Socket Info: 05.09.2020 15:02:34> S/N: 05.09.2020 15:02:34> Desc: EasyJTAG UFS Socket 3 in 1 by MOORC 18.06.20 05.09.2020 15:02:34> Type: MOORK UFS Socket 3 in 1 05.09.2020 15:02:34> ID: 3708 05.09.2020 15:02:34> 05.09.2020 15:02:34> UFS: Voltage Info: 05.09.2020 15:02:34> Mode: LOW 05.09.2020 15:02:34> VCC : 3278 mV, VCCQ2: 1918 mV 05.09.2020 15:02:34> 3v3 : 3361 mV, 1v2: 1215 mV 05.09.2020 15:02:34> 05.09.2020 15:02:34> UFS: Memory Info: 05.09.2020 15:02:34> Connection: UNKNOWN SOCKET TYPE 05.09.2020 15:02:34> Vendor: MICRON 05.09.2020 15:02:34> Name: MT128GASAO4U21 05.09.2020 15:02:34> S/N: 0x0597151301020C081900 05.09.2020 15:02:34> OEM ID: MICRON 05.09.2020 15:02:34> Firm Version: 1.01 05.09.2020 15:02:34> UFS Version: 2.1 05.09.2020 15:02:34> Size: 0x001DCC800000/119.20 GB 05.09.2020 15:02:34> Max LUNs: 32 05.09.2020 15:02:34> LUNs Cnt: 6 05.09.2020 15:02:34> W-LUNs Cnt: 1 05.09.2020 15:02:34> LUNs ReConfig: Enabled 05.09.2020 15:02:34> 05.09.2020 15:02:34> UFS Health Info: 05.09.2020 15:02:34> UFS Life Time A: 0x01 - 0% - 10% Life Time Used 05.09.2020 15:02:34> UFS Life Time B: 0x01 - 0% - 10% Life Time Used 05.09.2020 15:02:34> UFS Pre-EOL Info: 0x01 - Used Less 80% of Reserved Blocks 05.09.2020 15:02:34> 05.09.2020 15:02:34> UFS: LUNs Info: 05.09.2020 15:02:34> LUN 0 - Size: 30111744 Block(s)/114.87 GB 05.09.2020 15:02:34> LUN 1 (Boot A) - Size: 2048 Block(s)/8.00 MB 05.09.2020 15:02:34> LUN 2 (Boot B) - Size: 2048 Block(s)/8.00 MB 05.09.2020 15:02:34> LUN 3 - Size: 8192 Block(s)/32.00 MB 05.09.2020 15:02:34> LUN 4 - Size: 1048576 Block(s)/4.00 GB 05.09.2020 15:02:34> LUN 5 - Size: 65536 Block(s)/256.00 MB 05.09.2020 15:02:34> W-LUN 0xC4 (REPORT LUNS) - Size: 65536 Block(s)/16.00 MB 05.09.2020 15:02:34> 05.09.2020 15:02:34> UFS Init OK 05.09.2020 15:02:34> Scanning Data From UFS Chip. Please wait.. 05.09.2020 15:02:34> 05.09.2020 15:02:34> Scanning GUID Partition Table from LUN 0 05.09.2020 15:02:34> GUID Partition Table is Found. Max Parts: 32 05.09.2020 15:02:34> GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB 05.09.2020 15:02:34> GPT: SSD [000000006000 - 000000002000] Size: 8.00 KB 05.09.2020 15:02:34> GPT: PERSIST [000000008000 - 000002000000] Size: 32.00 MB 05.09.2020 15:02:34> GPT: MISC [000002008000 - 000000100000] Size: 1.00 MB 05.09.2020 15:02:34> GPT: KEYSTORE [000002108000 - 000000080000] Size: 512.00 KB 05.09.2020 15:02:34> GPT: FRP [000002188000 - 000000080000] Size: 512.00 KB 05.09.2020 15:02:34> GPT: CACHE [000002208000 - 000010000000] Size: 256.00 MB 05.09.2020 15:02:34> GPT: SYSTEM [000012208000 - 00018FC00000] Size: 6.25 GB 05.09.2020 15:02:34> GPT: METADATA [0001A1E08000 - 000001000000] Size: 16.00 MB 05.09.2020 15:02:34> GPT: ODM [0001A2E08000 - 000010000000] Size: 256.00 MB 05.09.2020 15:02:34> GPT: USERDATA [0001B2E08000 - 001B049F3000] Size: 108.07 GB 05.09.2020 15:02:34> GPT: BACKUP_GPT [001CB77FB000 - 000000005000] Size: 20.00 KB 05.09.2020 15:02:34> Reading Table Completed 05.09.2020 15:02:34> Scanning GUID Partition Table from LUN 1 05.09.2020 15:02:34> GUID Partition Table is Found. Max Parts: 32 05.09.2020 15:02:34> GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB 05.09.2020 15:02:34> GPT: XBL [000000006000 - 000000380000] Size: 3.50 MB 05.09.2020 15:02:34> GPT: XBL_CONFIG [000000386000 - 000000020000] Size: 128.00 KB 05.09.2020 15:02:34> GPT: LAST_PARTI [0000003A6000 - 000000455000] Size: 4.33 MB 05.09.2020 15:02:34> GPT: BACKUP_GPT [0000007FB000 - 000000005000] Size: 20.00 KB 05.09.2020 15:02:34> Reading Table Completed 05.09.2020 15:02:34> Scanning GUID Partition Table from LUN 2 05.09.2020 15:02:35> GUID Partition Table is Found. Max Parts: 32 05.09.2020 15:02:35> GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB 05.09.2020 15:02:35> GPT: XBLBAK [000000006000 - 000000380000] Size: 3.50 MB 05.09.2020 15:02:35> GPT: XBL_CONFIGBAK [000000386000 - 000000020000] Size: 128.00 KB 05.09.2020 15:02:35> GPT: LAST_PARTI [0000003A6000 - 000000455000] Size: 4.33 MB 05.09.2020 15:02:35> GPT: BACKUP_GPT [0000007FB000 - 000000005000] Size: 20.00 KB 05.09.2020 15:02:35> Reading Table Completed 05.09.2020 15:02:35> Scanning GUID Partition Table from LUN 3 05.09.2020 15:02:35> GUID Partition Table is Found. Max Parts: 32 05.09.2020 15:02:35> GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB 05.09.2020 15:02:35> GPT: ALIGN_TO_128K_1 [000000006000 - 00000001A000] Size: 104.00 KB 05.09.2020 15:02:35> GPT: CDT [000000020000 - 000000020000] Size: 128.00 KB 05.09.2020 15:02:35> GPT: DDR [000000040000 - 000000100000] Size: 1.00 MB 05.09.2020 15:02:35> GPT: LAST_PARTI [000000140000 - 000001EBB000] Size: 30.73 MB 05.09.2020 15:02:35> GPT: BACKUP_GPT [000001FFB000 - 000000005000] Size: 20.00 KB 05.09.2020 15:02:35> Reading Table Completed 05.09.2020 15:02:35> Scanning GUID Partition Table from LUN 4 05.09.2020 15:02:35> 05.09.2020 15:02:35> Error Reading Sector: 0, Count: 6, Err: -403/ERROR_UFS_CHIP_HWPART_JEDEC_PSREQ 05.09.2020 15:02:35> Try Again #1 05.09.2020 15:02:35> 05.09.2020 15:02:35> Error Reading Sector: 0, Count: 6, Err: -403/ERROR_UFS_CHIP_HWPART_JEDEC_PSREQ 05.09.2020 15:02:35> Try Again #2 05.09.2020 15:02:36> 05.09.2020 15:02:36> Error Reading Sector: 0, Count: 6, Err: -403/ERROR_UFS_CHIP_HWPART_JEDEC_PSREQ 05.09.2020 15:02:36> Try Again #3 05.09.2020 15:02:36> 05.09.2020 15:02:36> Too Many Errors. Stopped. Err: -403/ERROR_UFS_CHIP_HWPART_JEDEC_PSREQ 05.09.2020 15:02:36> Error While Reading. Exit. Code: -403 05.09.2020 15:02:36> 05.09.2020 15:02:36> Error While Scan Partitions. Scanner Shutdown.. 05.09.2020 15:02:36> 05.09.2020 15:02:36> Scanner Thread Terminated 05.09.2020 15:02:36> Elapsed: 00:00:16:840 05.09.2020 15:02:36> Found 0 Partition(s).. 05.09.2020 15:02:36> 05.09.2020 15:02:36> Search Partitions Fail.. 05.09.2020 15:02:36> Check Socket/UFS Chip and Try Again.. 05.09.2020 15:02:36> |
09-05-2020, 14:17 | #9 (permalink) |
Member: 2346548 Status: Offline Thanks Meter: 36 | thats chip info from classic suite Identify UFS Chip. UFS Chip Voltage: Low VCC: 3278mV VCCQ2: 1920mV Chip Info: Manufacturer: MICRON ProductName: MT128GASAO4U21 SerialNumber: 0x0597151301020C081900 OemID: MICRON Firmware Version: 1.01 UFS Version: 2.1 Maximum Number of LUs: 32 Number of LUs found: 6 LUN 0: Block size: 0x1000 Size: 0x1CB7800000 / 114,888,000,000B / 114GB LUN 1 (Boot A): Block size: 0x1000 Size: 0x800000 / 0,008,000,000B / 8MB LUN 2 (Boot B): Block size: 0x1000 Size: 0x800000 / 0,008,000,000B / 8MB LUN 3: Block size: 0x1000 Size: 0x2000000 / 0,032,000,000B / 32MB LUN 4: Block size: 0x1000 Size: 0x100000000 / 4,000,000,000B / 4GB LUN 5: Block size: 0x1000 Size: 0x10000000 / 0,256,000,000B / 256MB Number of W-LUs found: 1 W-LUN 0xC4 (REPORT LUNS): Block size: 0x100 Size: 0x1000000 / 0,016,000,000B / 16MB Full size: 0x1DCC800000 / 119,200,000,000B / 119GB Health: Device life time method A: 0x01 (0%-10% device life time used) Device life time method B: 0x01 (0%-10% device life time used) Pre End of Life: 0x01 (Used less then 80% of reserved blocks) Checking LU0 for partitioning The protective MBR's 0xEE partition is oversized! Auto-repairing. LUN0 Have 10 partitions The protective MBR's 0xEE partition is oversized! Auto-repairing. LUN1 Have 2 partitions The protective MBR's 0xEE partition is oversized! Auto-repairing. LUN2 Have 2 partitions The protective MBR's 0xEE partition is oversized! Auto-repairing. LUN3 Have 3 partitions LUN4 Have 59 partitions Caution! After loading partitions, the CRC doesn't check out! Invalid partition data! LUN5 Have no partitions Read SYSTEM from LUN0. Caution! After loading partitions, the CRC doesn't check out! EFI Table seems to be corrupted (sizeOfPartitionEntries!=128) sizeOfPartitionEntries = 0 Invalid partition data! Read USERDATA from LUN0. Caution! After loading partitions, the CRC doesn't check out! EFI Table seems to be corrupted (sizeOfPartitionEntries!=128) sizeOfPartitionEntries = 0 You will need to delete this partition or resize it in another utility. Done. |
09-05-2020, 17:34 | #12 (permalink) |
Member: 2346548 Status: Offline Thanks Meter: 36 | i think my problem on lun 4 cant even read it Read UFS LUN4, Address: 0x0 ,Length: 0x100000000 Output file :C:\Users\Shady\Desktop\CPH1933_11_A.16_191026_cb4 610de\backup\UFS_MT128GASAO4U21_LUN4_00000000_1000 00000.bin Start Can't read address 0x0, Code: -403, Reason: UAP SCSI: Command sense: MEDIUM_ERROR Done. |
09-06-2020, 07:09 | #13 (permalink) | |
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
09-06-2020, 12:26 | #14 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: inside emmc ufs Age: 19
Member: 221603 Status: Offline Sonork: 100.1581270 Thanks Meter: 6,395 | Quote:
Regards | |
