Old 08-04-2020, 09:29   #1 (permalink)
Member: 2750175
Thanks Meter: 9
read info samsung a31 isp emmc done "!!!
04.08.2020 06:49:27> Z3X EasyJtag EMMC File Manager v 1.18 TEST at 04/04/2020 Started..
04.08.2020 06:49:34> Box API Version: 3308
04.08.2020 06:49:34> FS Driver Version: 11062019
04.08.2020 06:49:34> SQLite Version: 3.30.1
04.08.2020 06:49:34> FSCK Engine Version: 11062019
04.08.2020 06:49:34> ESE DB Version: 11062019
04.08.2020 06:49:34> System Util Version: 11062019
04.08.2020 06:49:34> System: Windows NT 6.2 (Build 9200) / 64 BIT
04.08.2020 06:49:34> CPU: Intel(R) Core(TM) i5-7200U CPU @ 2.50GHz
04.08.2020 06:49:34> !!FOR BETA-TESTERS ONLY!!
04.08.2020 06:49:37> Z3X Card Serial: AA1163DC
04.08.2020 06:49:37> EasyJtag Plus Box Found at: COM4
04.08.2020 06:49:37> EasyJtag Plus Box Firmware: 2.52
04.08.2020 06:50:29> Source: EasyJtag Port [EMMC/SD/MMC]
04.08.2020 06:50:29> Generation: GPT [QC/SAMS/BCM/INTEL/MTK]
04.08.2020 06:50:29> Box Voltage set to: 2800 mV
04.08.2020 06:50:29> Scanner Thread Created..
04.08.2020 06:50:29> Config: 101111111110111
04.08.2020 06:50:29> Setup HiPower CLK: ON
04.08.2020 06:50:30> Connecting To EasyJtag Plus Box: 2800mV/9MHz/1BIT
04.08.2020 06:50:31> EasyJtag Plus Box Found! Result: 0/OK
04.08.2020 06:50:31> CMD Pullup Level: 4 mV
04.08.2020 06:50:31> CMD Active Level: 0 mV
04.08.2020 06:50:32> EasyJtag Plus S/N: 4179E30982F50C31
04.08.2020 06:50:32> EasyJtag Plus Box FirmWare: 2.52
04.08.2020 06:50:32> Box Bus Width = 1 BIT
04.08.2020 06:50:32> Box Hardware = EasyJtag 2nd Generation
04.08.2020 06:50:32> Search EMMC Chip...
04.08.2020 06:50:32> EMMC Chip Found! 0/OK
04.08.2020 06:50:32> EMMC CID: 150100445636444D42000069CCD23767
04.08.2020 06:50:32> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D
04.08.2020 06:50:32> EMMC VENDOR: SAMSUNG
04.08.2020 06:50:32> EMMC NAME: DV6DMB
04.08.2020 06:50:32> EMMC SERIAL: 0069CCD2
04.08.2020 06:50:32> EMMC REVISION: 00
04.08.2020 06:50:32> EMMC ROM1 Size: 244285440 Block(s)/119280 MB
04.08.2020 06:50:32> EMMC ROM2/3 Size: 8192 Block(s)/4096 KB
04.08.2020 06:50:32> EMMC RPMB Size: 32768 Block(s)/16384 KB
04.08.2020 06:50:32> EMMC RPMB Counter: 237
04.08.2020 06:50:32> EMMC RPMB Answer: 0/OK
04.08.2020 06:50:32> Switch To ROM1 Part: 0/OK
04.08.2020 06:50:32> EMMC REV: 1.8 (for MMC v5.1)
04.08.2020 06:50:32> EMMC VER: MMC 5.1
04.08.2020 06:50:32> EMMC DEV Life Time: 0x01 - Normal
04.08.2020 06:50:32> EMMC MLC Life Time: 0x01 - 0% - 10% Life Time Used
04.08.2020 06:50:32> EMMC SLC Life Time: 0x01 - 0% - 10% Life Time Used
04.08.2020 06:50:32> EMMC Boot Config: 0x48/0x02/0x01
04.08.2020 06:50:32> ExtCSD Automatically Saved..
04.08.2020 06:50:32> Scanning Data From EMMC. Please wait..
04.08.2020 06:50:32> Scanning GUID Partition Table from ROM1
04.08.2020 06:50:32> GUID Partition Table is Found. Max Parts: 57
04.08.2020 06:50:32> GPT: GPT [000000000000 - 000000004400] Size: 17.00 KB
04.08.2020 06:50:32> GPT: BOOT_PARA [000000400000 - 000001A00000] Size: 26.00 MB
04.08.2020 06:50:32> GPT: PARA [000001E00000 - 000000080000] Size: 512.00 KB
04.08.2020 06:50:32> GPT: EFS [000001E80000 - 000000800000] Size: 8.00 MB
04.08.2020 06:50:32> GPT: SEC_EFS [000002680000 - 000000800000] Size: 8.00 MB
04.08.2020 06:50:33> GPT: BOTA [000002E80000 - 000001C80000] Size: 28.50 MB
04.08.2020 06:50:33> GPT: PARAM [000004B00000 - 000000400000] Size: 4.00 MB
04.08.2020 06:50:33> GPT: UP_PARAM [000004F00000 - 000000400000] Size: 4.00 MB
04.08.2020 06:50:33> GPT: EXPDB [000005300000 - 000001400000] Size: 20.00 MB
04.08.2020 06:50:33> GPT: FRP [000006700000 - 000000100000] Size: 1.00 MB
04.08.2020 06:50:33> GPT: NVCFG [000006800000 - 000002000000] Size: 32.00 MB
04.08.2020 06:50:33> GPT: NVDATA [000008800000 - 000004000000] Size: 64.00 MB
04.08.2020 06:50:33> GPT: METADATA [00000C800000 - 000002000000] Size: 32.00 MB
04.08.2020 06:50:33> GPT: PROTECT1 [00000E800000 - 000000800000] Size: 8.00 MB
04.08.2020 06:50:33> GPT: PROTECT2 [00000F000000 - 000000800000] Size: 8.00 MB
04.08.2020 06:50:33> GPT: SECCFG [00000F800000 - 000000800000] Size: 8.00 MB
04.08.2020 06:50:33> GPT: PERSIST [000010000000 - 000003000000] Size: 48.00 MB
04.08.2020 06:50:33> GPT: PERSISTENT [000013000000 - 000000080000] Size: 512.00 KB
04.08.2020 06:50:33> GPT: MISC [000013080000 - 000000780000] Size: 7.50 MB
04.08.2020 06:50:33> GPT: KEYREFUGE [000013800000 - 000001000000] Size: 16.00 MB
04.08.2020 06:50:33> GPT: RECOVERY [000014800000 - 000002000000] Size: 32.00 MB
04.08.2020 06:50:33> GPT: MD_UDC [000016800000 - 000001800000] Size: 24.00 MB
04.08.2020 06:50:33> GPT: SEC1 [000018000000 - 000000200000] Size: 2.00 MB
04.08.2020 06:50:33> GPT: PROINFO [000018200000 - 000000300000] Size: 3.00 MB
04.08.2020 06:50:33> GPT: MD1IMG [000018500000 - 000008000000] Size: 128.00 MB
04.08.2020 06:50:33> GPT: SPMFW [000020500000 - 000000100000] Size: 1.00 MB
04.08.2020 06:50:33> GPT: SCP1 [000020600000 - 000000100000] Size: 1.00 MB
04.08.2020 06:50:33> GPT: SSPM_1 [000020700000 - 000000100000] Size: 1.00 MB
04.08.2020 06:50:33> GPT: EFUSE [000020800000 - 000000080000] Size: 512.00 KB
04.08.2020 06:50:33> GPT: NVRAM [000020880000 - 000004000000] Size: 64.00 MB
04.08.2020 06:50:33> GPT: RESERVED2 [000024880000 - 000000780000] Size: 7.50 MB
04.08.2020 06:50:33> GPT: VBMETA [000025000000 - 000000010000] Size: 64.00 KB
04.08.2020 06:50:33> GPT: VBMETA_SAMSUNG [000025010000 - 000000010000] Size: 64.00 KB
04.08.2020 06:50:33> GPT: KEYDATA [000025020000 - 000001000000] Size: 16.00 MB
04.08.2020 06:50:33> GPT: METADATA [000026020000 - 000002000000] Size: 32.00 MB
04.08.2020 06:50:33> GPT: BOOT [000028020000 - 000002000000] Size: 32.00 MB
04.08.2020 06:50:33> GPT: DTBO [00002A020000 - 000000800000] Size: 8.00 MB
04.08.2020 06:50:33> GPT: STEADY [00002A820000 - 000000400000] Size: 4.00 MB
04.08.2020 06:50:33> GPT: RESERVED3 [00002AC20000 - 0000003E0000] Size: 3.88 MB
04.08.2020 06:50:33> GPT: GZ1 [00002B000000 - 000001000000] Size: 16.00 MB
04.08.2020 06:50:33> GPT: GZ2 [00002C000000 - 000001000000] Size: 16.00 MB
04.08.2020 06:50:33> GPT: LK [00002D000000 - 000000200000] Size: 2.00 MB
04.08.2020 06:50:33> GPT: UH [00002D200000 - 000000200000] Size: 2.00 MB
04.08.2020 06:50:33> GPT: TEE1 [00002D400000 - 000000600000] Size: 6.00 MB
04.08.2020 06:50:33> GPT: RESERVED [00002DA00000 - 000000600000] Size: 6.00 MB
04.08.2020 06:50:33> GPT: SUPER [00002E000000 - 000195000000] Size: 6.33 GB
04.08.2020 06:50:34> GPT: PRISM [0001C3000000 - 00002BC00000] Size: 700.00 MB
04.08.2020 06:50:34> GPT: OPTICS [0001EEC00000 - 000001400000] Size: 20.00 MB
04.08.2020 06:50:34> GPT: CACHE [0001F0000000 - 00000C800000] Size: 200.00 MB
04.08.2020 06:50:34> GPT: CARRIER [0001FC800000 - 000002D00000] Size: 45.00 MB
04.08.2020 06:50:34> GPT: OMR [0001FF500000 - 000003200000] Size: 50.00 MB
04.08.2020 06:50:34> GPT: SPU [000202700000 - 000003200000] Size: 50.00 MB
04.08.2020 06:50:34> GPT: USERDATA [000205900000 - 001B19300000] Size: 108.39 GB
04.08.2020 06:50:34> GPT: BACKUP_GPT [001D1EFFBE00 - 000000004200] Size: 16.50 KB
04.08.2020 06:50:34> Reading Table Completed
04.08.2020 06:50:34> GPT Backup Header is Invalid
04.08.2020 06:50:34> Scanning GUID Partition Table from ROM2
04.08.2020 06:50:34> GPT Signature Not Found. Break..
04.08.2020 06:50:34> Scanning GUID Partition Table from ROM3
04.08.2020 06:50:35> GPT Signature Not Found. Break..
04.08.2020 06:50:36> Partition #7 mount as [/mnt/vendor/efs] - 8.00 MB
04.08.2020 06:50:36> Partition #8 mount as [/efs] - 8.00 MB
04.08.2020 06:50:36> Partition #14 mount as [/mnt/vendor/nvcfg] - 32.00 MB
04.08.2020 06:50:36> Partition #15 mount as [/mnt/vendor/nvdata] - 64.00 MB
04.08.2020 06:50:36> Partition #17 mount as [/mnt/vendor/protect_f] - 8.00 MB
04.08.2020 06:50:36> Partition #18 mount as [/mnt/vendor/protect_s] - 8.00 MB
04.08.2020 06:50:36> Partition #20 mount as [/mnt/vendor/persist] - 48.00 MB
04.08.2020 06:50:36> Partition #23 mount as [/keyrefuge] - 16.00 MB
04.08.2020 06:50:36> Partition #25 mount as [/metadata] - 24.00 MB
04.08.2020 06:50:37> Partition #37 mount as [/keydata] - 16.00 MB
04.08.2020 06:50:37> Partition #50 mount as [/prism] - 700.00 MB
04.08.2020 06:50:37> Partition #51 mount as [/optics] - 20.00 MB
04.08.2020 06:50:37> Partition #52 mount as [/cache] - 200.00 MB
04.08.2020 06:50:37> Partition #54 mount as [/omr] - 50.00 MB
04.08.2020 06:50:37> Partition #55 mount as [/spu] - 50.00 MB
04.08.2020 06:50:37> Partition #56 mount as [/USERDATA] - 108.39 GB
04.08.2020 06:50:37> EmptyCheck:
04.08.2020 06:50:38> EMPTY - #4 - [BOOT_PARA]
04.08.2020 06:50:38> EMPTY - #8 - [BOTA]
04.08.2020 06:50:39> EMPTY - #11 - [EXPDB]
04.08.2020 06:50:39> EMPTY - #12 - [FRP]
04.08.2020 06:50:39> EMPTY - #15 - [METADATA]
04.08.2020 06:50:39> EMPTY - #20 - [PERSISTENT]
04.08.2020 06:50:40> EMPTY - #25 - [SEC1]
04.08.2020 06:50:40> EMPTY - #26 - [PROINFO]
04.08.2020 06:50:41> EMPTY - #37 - [METADATA]
04.08.2020 06:50:41> EMPTY - #41 - [RESERVED3]
04.08.2020 06:50:42> EMPTY - #43 - [GZ2]
04.08.2020 06:50:42> EMPTY - #47 - [RESERVED]
04.08.2020 06:50:43> EMPTY - #52 - [CARRIER]
04.08.2020 06:50:43> EmptyCheck: Done
04.08.2020 06:50:46> Samsung S/N = RF8N50RH2BM
04.08.2020 06:50:46> Scanner Thread Terminated
04.08.2020 06:50:46> Elapsed: 00:00:16:241
04.08.2020 06:50:46> Found 57 Partition(s)..
04.08.2020 06:50:46> Scan Done. Init Main Engine...
04.08.2020 06:50:46> Resetting EasyJtag Box. Wait..
04.08.2020 06:50:47> CMD Pullup Level: 4 mV
04.08.2020 06:50:47> CMD Active Level: 0 mV
04.08.2020 06:50:48> Reader Engine Initialized.. 0/OK
04.08.2020 06:50:48> Source: EasyJtag Port [EMMC/SD/MMC]
04.08.2020 06:50:48> Generation: GPT [QC/SAMS/BCM/INTEL/MTK]
04.08.2020 06:50:48> Bus Mode: 1BIT
04.08.2020 06:50:48> Operation Done: [Init Engine], Elapsed: 00:00:02:055
The Following User Says Thank You to isix For This Useful Post:
Old 08-04-2020, 19:28   #2 (permalink)
NoName®'s Avatar
Member: 129885
Sonork: 100:1603514
Thanks Meter: 6,162
Thanks for successful report;-) Its amazing)
The Following User Says Thank You to NoName® For This Useful Post:
Old 08-20-2020, 00:02   #3 (permalink)
Member: 2266065
Sonork: comzipper
Thanks Meter: 2
i need full dump, device brick after replace emmc
Old 08-25-2020, 00:25   #4 (permalink)
Member: 603138
Thanks Meter: 92
please the isp for repair
Page generated in 0.24449 seconds with 7 queries
