01-31-2023, 10:49 | #1 (permalink) |
Freak Poster Join Date: Oct 2020 Location: india
Member: 2970939 Status: Offline Thanks Meter: 50 | realme 5 EMMC Password Locked: Yes.. micron emmc not remove emmc micron remove chip put socket chack emmc Code: ---------- eMMC Device Information ---------- eMMC CID : 0600003136FFFFFFFFFF195C493934EB eMMC CSD : 904F012A0F5903FFF6DBFFEF8A400099 eMMC Manufacturer ID: 0006 , OEM ID: 0000 eMMC Date: 03/2017 Rev.0xFF eMMC NAME: 16 , S/N: 425478457 eMMC NAME (HEX): 313620202020 EMMC ROM1 (Main User Data) Capacity: 59640 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB RPMB Info mmc_init Error, Reason: CARD is Password Locked EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: Yes Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: 16_ 425478457_20230131_1504.extcsd Blocks Reading Error (0x0 , 1 , Reason: DATA RCV Timeout Error ) Blocks Reading Error (0x200 , 1 , Reason: DATA RCV Timeout Error ) Warning! Read error 0 strange behavior now likely! Blocks Reading Error (0xE8F7FFE00 , 1 , Reason: DATA RCV Timeout Error ) Warning! Read error 0 strange behavior now likely! Partition info not found Done. Checking security ... Running:eMMC: Factory Format Fix Z3X EasyJtag Software ver. 3.8.0.1 Skip loading eMMC Addon Firmware Box IO Level:2800 mV CLK Rate:14000 kHz Formatting eMMC card, please wait up to 3 min... Final Stage... eMMC Final Operation Failed. Done. Checking security ... Running:MMC: Password force remove... Z3X EasyJtag Software ver. 3.8.0.1 Skip loading eMMC Addon Firmware Box IO Level:2800 mV CLK Rate:14000 kHz Force erase SD/MMC password, wait up to 3 min... CARD Lock/Unlock Error Force erase SD/MMC password Failed, trying in alternate way Force erase SD/MMC password Operation Failed. Checking security ... Running:eMMC: Factory Format Fix Z3X EasyJtag Software ver. 3.8.0.1 Skip loading eMMC Addon Firmware Box IO Level:2800 mV CLK Rate:14000 kHz Formatting eMMC card, please wait up to 3 min... Final Stage... eMMC Final Operation Failed. Done. |
