05-07-2021, 12:56 | #1 (permalink) |
Freak Poster Join Date: Jan 2010 Location: mystery city
Member: 1199392 Status: Offline Thanks Meter: 95 | realme 5 flashing error via 254 bga Setting bus width to 8 Bit Setting frequence to 42 MHz EMMC Device Information : EMMC CID: 90014A6843396150330143F16587869F EMMC CSD: D02700328F5903FFFFFFFFEF8E400043 EMMC Manufacture : SKHYNIX , EMMC NAME: hC9aP3 , HEX: 684339615033 , S/N: 43F16587 , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 8/2019 EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 21647 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: hC9aP3_43F16587_20210507_172214.extcsd EMMC Init completed. Opening file: rawprogram0.xml The size of the last section has been updated Setting interface to EasyJtag2/E-Socket Setting bus width to 8 Bit Setting frequence to 42 MHz EMMC Device Information : EMMC CID: 90014A6843396150330143F16587869F EMMC CSD: D02700328F5903FFFFFFFFEF8E400043 EMMC Manufacture : SKHYNIX , EMMC NAME: hC9aP3 , HEX: 684339615033 , S/N: 43F16587 , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 8/2019 EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 21647 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: hC9aP3_43F16587_20210507_172229.extcsd EMMC Init completed. Operation: Write by vendor (Qualcomm/HiSilicon/Omap) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Writing BackupGPT at address: 000E8F7FBE00 GPT-partitioning done Partition name: oppodycnvbk Filename: dynamic_nvbk.bin , Offset: 000000005000 , filesize: 10485760 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 12389.26 KB/s Partition name: oppostanvbk Filename: static_nvbk.bin , Offset: 000000A05000 , filesize: 10485760 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Error writing at address: 000000A05000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #1 Done writing partition. Write speed: 11645.07 KB/s Partition name: persist Filename: persist.img , Offset: 000001805000 , filesize: 33554432 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 26330.09 KB/s Partition name: opporeserve1 Filename: emmc_fw.bin , Offset: 000003805000 , filesize: 4194304 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 26364.15 KB/s Partition name: opporeserve2 Filename: opporeserve2.img , Offset: 000004005000 , filesize: 5300372 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 10 Done writing partition. Write speed: 17098.81 KB/s Partition name: xbl Filename: xbl.elf , Offset: 00000C800000 , filesize: 2877581 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 21988.56 KB/s Partition name: xbl_config Filename: xbl_config.elf , Offset: 00000D000000 , filesize: 49404 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1381.08 KB/s Partition name: tz Filename: tz.mbn , Offset: 00000D800000 , filesize: 1998848 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 25160.18 KB/s Partition name: rpm Filename: rpm.mbn , Offset: 00000DC00000 , filesize: 221380 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 15467.99 KB/s Partition name: hyp Filename: hyp.mbn , Offset: 00000DC80000 , filesize: 369800 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 16563.07 KB/s Partition name: boot Filename: boot.img , Offset: 00000E020000 , filesize: 67108864 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Error writing at address: 00000E020000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #1 Error writing at address: 00000E020000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #2 Error writing at address: 00000E820000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #1 Error writing at address: 00000E820000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #2 Done writing partition. Write speed: 14588.63 KB/s Partition name: keymaster Filename: km4.mbn , Offset: 00001D000000 , filesize: 238037 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 6852.98 KB/s Partition name: cmnlib Filename: cmnlib.mbn , Offset: 00001D080000 , filesize: 393896 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 7897.54 KB/s Partition name: cmnlib64 Filename: cmnlib64.mbn , Offset: 00001D100000 , filesize: 511492 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 9905.09 KB/s Partition name: dsp Filename: dspso.bin , Offset: 00001F580000 , filesize: 33554432 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 25983.60 KB/s Partition name: abl Filename: abl.elf , Offset: 000021580000 , filesize: 217088 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 7558.69 KB/s Partition name: bluetooth Filename: BTFM.bin , Offset: 000021780000 , filesize: 782336 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 22369.73 KB/s Partition name: dtbo Filename: dtbo.img , Offset: 000022002000 , filesize: 25165824 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 25870.99 KB/s Partition name: LOGO Filename: logo.bin , Offset: 000023802000 , filesize: 1259520 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Error writing at address: 000023802000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #1 Error writing at address: 000023802000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #2 Error writing at address: 000023802000 , error: -8, DATA SND CRC Error(Small ROM Size, maybe) ... Retry #3 Too many errors. Writing has been stopped |
