05-07-2020, 10:04 | #1 (permalink) |
No Life Poster Join Date: Nov 2014
Member: 2289628 Status: Offline Thanks Meter: 226 | Huawei Mate 20 Lite (SNE-LX1) Backup Modem Security Before dead boot repair I want backup of modem security of this device. 1:- Here is bug when I want to backup of modems files in Partition tab Its failed due to ">" sign in default save name of eMMC. 2:- Then I tried manually save file via ROM1 > MODEMNVM_BACKUP and became successful. Guide me that which files are required for backup for prevent corrupted imei. Code: EasyJtag Suite Classic ver.: 3.6.2.3 / wxWidgets 3.1.3-W-U started. OS ver.: Windows 10 (build 18363), 64-bit edition. Admin rights FAIL Android Explorer ver:1.0.0.13 Autorun Agent ver:1.0.0.0 Crash Reporting ver:1.4.0.3 eMMC Odin ver:1.0.0.6 QUALCOMM Direct ver:1.0.6936.8894 EasyJTAG SPI Plugin ver:1.1.1.11 Android ADB API ver:2.0.0.0 FTDI API ver:3.2.4.0 LibUSB API ver:1.2.6.0 Visual C++ Runtime ver:10.0.30319.1 Setting box Pinout ... Box Drivers version: 10.0.18362.1 Z3X Card Serial : AA79-A19D , ver: 22 Z3X Card Activation [JTAGPLUS] : ACTIVATED Z3X Card Activation [LG] : ACTIVATED Z3X Card Activation [SAMS] : ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED Found 1 serial devices COM13 USB\VID_1781&PID_AAAC&REV_0100&MI_00 USB Serial Device (COM13) Selected pinout: GEN2 High Speed Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.6.2.3 Loading eMMC GEN2 Firmware... IO: 1800 mV Initial pull results: clock: 734mV pin connected ok command: 974mV pin connected ok data0: 972mV pin connected ok data1: 970mV pin connected ok data2: 971mV pin connected ok data3: 971mV pin connected ok data4: 972mV pin connected ok data5: 970mV pin connected ok data6: 971mV pin connected ok data7: 971mV pin connected ok Box S/N: 06942E3DA29E480D, ,FW Ver.: 02.50 Box IO Level:1800 mV CLK Rate:42000 kHz Bus Width:8bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 90014A68433861503E01671665D72601 eMMC CSD : D02700328F5903FFFFFFFFEF8E400043 eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 02/2019 Rev.0x1 eMMC NAME: hC8aP> , S/N: 1729521111 eMMC NAME (HEX): 68433861503E EMMC ROM1 (Main User Data) Capacity: 59640 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 5733 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x02 , width 8bits , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: hC8aP>_1729521111_20200507_1302.extcsd Caution: invalid backup GPT header, but valid main header! EFI Table CRC Check FAIL. Warning! One or more CRCs don't match. You should repair the disk! Caution: Found protective or hybrid MBR and corrupt GPT. Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB Soft (Partitioned) Disk/Image size: 747BFDD sectors 58.2 GiB Disk identifier (GUID): F9F21FFF-A8D4-5F0E-9746-594869AEC34E Logical sector size: 0x200 bytes ,First/Last usable sector: 34,122142719 Partition info successfully found Done. Selected eMMC Interface Caution: invalid backup GPT header, but valid main header! EFI Table CRC Check FAIL. Warning! One or more CRCs don't match. You should repair the disk! Caution: Found protective or hybrid MBR and corrupt GPT. Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB Soft (Partitioned) Disk/Image size: 747BFDD sectors 58.2 GiB Disk identifier (GUID): F9F21FFF-A8D4-5F0E-9746-594869AEC34E Logical sector size: 0x200 bytes ,First/Last usable sector: 34,122142719 ------ Detected 65 partitions ------ P0 (FRP) [0x80000 0x80000] Size: 512.0KB P1 (PERSIST) [0x100000 0x200000] Size: 2.0MB P2 (RESERVED1) [0x300000 0x500000] Size: 5.0MB P3 (RESERVED6) [0x800000 0x80000] Size: 512.0KB P4 (VRL) [0x880000 0x80000] Size: 512.0KB P5 (VRL_BACKUP) [0x900000 0x80000] Size: 512.0KB P6 (MODEM_SECURE) [0x980000 0x880000] Size: 8.500MB P7 (NVME) [0x1200000 0x500000] Size: 5.0MB P8 (CERTIFICATION) [0x1700000 0x100000] Size: 1.0MB P9 (OEMINFO) [0x1800000 0x4000000] Size: 64.0MB P10 (SECURE_STORAGE) [0x5800000 0x2000000] Size: 32.0MB P11 (MODEM_OM) [0x7800000 0x2000000] Size: 32.0MB P12 (MODEMNVM_FACTORY) [0x9800000 0x1000000] Size: 16.0MB P13 (MODEMNVM_BACKUP) [0xa800000 0x1000000] Size: 16.0MB P14 (MODEMNVM_IMG) [0xb800000 0x2200000] Size: 34.0MB P15 (RESERVED7) [0xda00000 0x200000] Size: 2.0MB P16 (HISEE_ENCOS) [0xdc00000 0x400000] Size: 4.0MB P17 (VERITYKEY) [0xe000000 0x100000] Size: 1.0MB P18 (DDR_PARA) [0xe100000 0x100000] Size: 1.0MB P19 (RESERVED2) [0xe200000 0x1b00000] Size: 27.0MB P20 (SPLASH2) [0xfd00000 0x5000000] Size: 80.0MB P21 (BOOTFAIL_INFO) [0x14d00000 0x200000] Size: 2.0MB P22 (MISC) [0x14f00000 0x200000] Size: 2.0MB P23 (DFX) [0x15100000 0x1000000] Size: 16.0MB P24 (RRECORD) [0x16100000 0x1000000] Size: 16.0MB P25 (FW_LPM3_A) [0x17100000 0x40000] Size: 256.0KB P26 (RESERVED3_A) [0x17140000 0x3c0000] Size: 3.750MB P27 (HDCP_A) [0x17500000 0x100000] Size: 1.0MB P28 (HISEE_IMG_A) [0x17600000 0x400000] Size: 4.0MB P29 (HHEE_A) [0x17a00000 0x400000] Size: 4.0MB P30 (HISEE_FS_A) [0x17e00000 0x800000] Size: 8.0MB P31 (FASTBOOT_A) [0x18600000 0xc00000] Size: 12.0MB P32 (VECTOR_A) [0x19200000 0x400000] Size: 4.0MB P33 (ISP_BOOT_A) [0x19600000 0x200000] Size: 2.0MB P34 (ISP_FIRMWARE_A) [0x19800000 0xe00000] Size: 14.0MB P35 (FW_HIFI_A) [0x1a600000 0xc00000] Size: 12.0MB P36 (TEEOS_A) [0x1b200000 0x800000] Size: 8.0MB P37 (SENSORHUB_A) [0x1ba00000 0x1000000] Size: 16.0MB P38 (ERECOVERY_KERNEL_A) [0x1ca00000 0x1800000] Size: 24.0MB P39 (ERECOVERY_RAMDISK_A) [0x1e200000 0x2000000] Size: 32.0MB P40 (ERECOVERY_VENDOR_A) [0x20200000 0x1000000] Size: 16.0MB P41 (KERNEL_A) [0x21200000 0x1800000] Size: 24.0MB P42 (RAMDISK_A) [0x22a00000 0x1000000] Size: 16.0MB P43 (RECOVERY_RAMDISK_A) [0x23a00000 0x2000000] Size: 32.0MB P44 (RECOVERY_VENDOR_A) [0x25a00000 0x1000000] Size: 16.0MB P45 (DTS_A) [0x26a00000 0x1800000] Size: 24.0MB P46 (DTO_A) [0x28200000 0x800000] Size: 8.0MB P47 (TRUSTFIRMWARE_A) [0x28a00000 0x200000] Size: 2.0MB P48 (MODEM_FW_A) [0x28c00000 0x3800000] Size: 56.0MB P49 (RESERVED4_A) [0x2c400000 0xc00000] Size: 12.0MB P50 (PRELOAD_A) [0x2d000000 0x800000] Size: 8.0MB P51 (RECOVERY_VBMETA_A) [0x2d800000 0x200000] Size: 2.0MB P52 (ERECOVERY_VBMETA_A) [0x2da00000 0x200000] Size: 2.0MB P53 (VBMETA_A) [0x2dc00000 0x400000] Size: 4.0MB P54 (MODEMNVM_UPDATE_A) [0x2e000000 0x1000000] Size: 16.0MB P55 (MODEMNVM_CUST_A) [0x2f000000 0x1000000] Size: 16.0MB P56 (PATCH_A) [0x30000000 0x2000000] Size: 32.0MB P57 (VERSION_A) [0x32000000 0x2000000] Size: 32.0MB P58 (VENDOR_A) [0x34000000 0x2f800000] Size: 760.0MB P59 (PRODUCT_A) [0x63800000 0xc000000] Size: 192.0MB P60 (CUST_A) [0x6f800000 0xc000000] Size: 192.0MB P61 (ODM_A) [0x7b800000 0xb000000] Size: 176.0MB P62 (CACHE) [0x86800000 0x6800000] Size: 104.0MB P63 (SYSTEM_A) [0x8d000000 0x160000000] Size: 5.500GB P64 (USERDATA) [0x1ed000000 0xca2800000] Size: 50.539GB ------------------------------------ Read partitions dump: Selected eMMC Interface Checking security ... Z3X EasyJtag Software ver. 3.6.2.3 Skip loading eMMC Addon Firmware Box IO Level:1800 mV CLK Rate:42000 kHz Bus Width:8bit,SDR Reading 0x000000880000 (8.500MB) from 0x000000980000 ...ROM1 ( USER ROM) Can't create output file C:\Users\Rayyan\Desktop\SNE-LX1\Modem\EMMC_hC8aP>_1729521111_ROM1_0x980000_MODEM_SECURE_0x880000.bin Done. Checking security ... Z3X EasyJtag Software ver. 3.6.2.3 Skip loading eMMC Addon Firmware Box IO Level:1800 mV CLK Rate:42000 kHz Bus Width:8bit,SDR Reading 0x000000500000 (5.0MB) from 0x000001200000 ...ROM1 ( USER ROM) Can't create output file C:\Users\Rayyan\Desktop\SNE-LX1\Modem\EMMC_hC8aP>_1729521111_ROM1_0x1200000_NVME_0x500000.bin Done. Checking security ... Z3X EasyJtag Software ver. 3.6.2.3 Skip loading eMMC Addon Firmware Box IO Level:1800 mV CLK Rate:42000 kHz Bus Width:8bit,SDR Reading 0x000002000000 (32.0MB) from 0x000007800000 ...ROM1 ( USER ROM) Can't create output file C:\Users\Rayyan\Desktop\SNE-LX1\Modem\EMMC_hC8aP>_1729521111_ROM1_0x7800000_MODEM_OM_0x2000000.bin Done. Checking security ... Z3X EasyJtag Software ver. 3.6.2.3 Skip loading eMMC Addon Firmware Box IO Level:1800 mV CLK Rate:42000 kHz Bus Width:8bit,SDR Reading 0x000001000000 (16.0MB) from 0x000009800000 ...ROM1 ( USER ROM) Can't create output file C:\Users\Rayyan\Desktop\SNE-LX1\Modem\EMMC_hC8aP>_1729521111_ROM1_0x9800000_MODEMNVM_FACTORY_0x1000000.bin Done. Checking security ... Z3X EasyJtag Software ver. 3.6.2.3 Skip loading eMMC Addon Firmware Box IO Level:1800 mV CLK Rate:42000 kHz Bus Width:8bit,SDR Reading 0x000001000000 (16.0MB) from 0x00000A800000 ...ROM1 ( USER ROM) Can't create output file C:\Users\Rayyan\Desktop\SNE-LX1\Modem\EMMC_hC8aP>_1729521111_ROM1_0xa800000_MODEMNVM_BACKUP_0x1000000.bin Done. Checking security ... Z3X EasyJtag Software ver. 3.6.2.3 Skip loading eMMC Addon Firmware Box IO Level:1800 mV CLK Rate:42000 kHz Bus Width:8bit,SDR Reading 0x000002200000 (34.0MB) from 0x00000B800000 ...ROM1 ( USER ROM) Can't create output file C:\Users\Rayyan\Desktop\SNE-LX1\Modem\EMMC_hC8aP>_1729521111_ROM1_0xb800000_MODEMNVM_IMG_0x2200000.bin Done. Checking security ... Z3X EasyJtag Software ver. 3.6.2.3 Skip loading eMMC Addon Firmware Box IO Level:1800 mV CLK Rate:42000 kHz Bus Width:8bit,SDR Reading 0x000003800000 (56.0MB) from 0x000028C00000 ...ROM1 ( USER ROM) Can't create output file C:\Users\Rayyan\Desktop\SNE-LX1\Modem\EMMC_hC8aP>_1729521111_ROM1_0x28c00000_MODEM_FW_A_0x3800000.bin Done. Checking security ... Z3X EasyJtag Software ver. 3.6.2.3 Skip loading eMMC Addon Firmware Box IO Level:1800 mV CLK Rate:42000 kHz Bus Width:8bit,SDR Reading 0x000001000000 (16.0MB) from 0x00002E000000 ...ROM1 ( USER ROM) Can't create output file C:\Users\Rayyan\Desktop\SNE-LX1\Modem\EMMC_hC8aP>_1729521111_ROM1_0x2e000000_MODEMNVM_UPDATE_A_0x1000000.bin Done. Checking security ... Z3X EasyJtag Software ver. 3.6.2.3 Skip loading eMMC Addon Firmware Box IO Level:1800 mV CLK Rate:42000 kHz Bus Width:8bit,SDR Reading 0x000001000000 (16.0MB) from 0x00002F000000 ...ROM1 ( USER ROM) Can't create output file C:\Users\Rayyan\Desktop\SNE-LX1\Modem\EMMC_hC8aP>_1729521111_ROM1_0x2f000000_MODEMNVM_CUST_A_0x1000000.bin Done. Selected eMMC Interface Caution: invalid backup GPT header, but valid main header! EFI Table CRC Check FAIL. Warning! One or more CRCs don't match. You should repair the disk! Caution: Found protective or hybrid MBR and corrupt GPT. Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB Soft (Partitioned) Disk/Image size: 747BFDD sectors 58.2 GiB Disk identifier (GUID): F9F21FFF-A8D4-5F0E-9746-594869AEC34E Logical sector size: 0x200 bytes ,First/Last usable sector: 34,122142719 ------ Detected 65 partitions ------ P0 (FRP) [0x80000 0x80000] Size: 512.0KB P1 (PERSIST) [0x100000 0x200000] Size: 2.0MB P2 (RESERVED1) [0x300000 0x500000] Size: 5.0MB P3 (RESERVED6) [0x800000 0x80000] Size: 512.0KB P4 (VRL) [0x880000 0x80000] Size: 512.0KB P5 (VRL_BACKUP) [0x900000 0x80000] Size: 512.0KB P6 (MODEM_SECURE) [0x980000 0x880000] Size: 8.500MB P7 (NVME) [0x1200000 0x500000] Size: 5.0MB P8 (CERTIFICATION) [0x1700000 0x100000] Size: 1.0MB P9 (OEMINFO) [0x1800000 0x4000000] Size: 64.0MB P10 (SECURE_STORAGE) [0x5800000 0x2000000] Size: 32.0MB P11 (MODEM_OM) [0x7800000 0x2000000] Size: 32.0MB P12 (MODEMNVM_FACTORY) [0x9800000 0x1000000] Size: 16.0MB P13 (MODEMNVM_BACKUP) [0xa800000 0x1000000] Size: 16.0MB P14 (MODEMNVM_IMG) [0xb800000 0x2200000] Size: 34.0MB P15 (RESERVED7) [0xda00000 0x200000] Size: 2.0MB P16 (HISEE_ENCOS) [0xdc00000 0x400000] Size: 4.0MB P17 (VERITYKEY) [0xe000000 0x100000] Size: 1.0MB P18 (DDR_PARA) [0xe100000 0x100000] Size: 1.0MB P19 (RESERVED2) [0xe200000 0x1b00000] Size: 27.0MB P20 (SPLASH2) [0xfd00000 0x5000000] Size: 80.0MB P21 (BOOTFAIL_INFO) [0x14d00000 0x200000] Size: 2.0MB P22 (MISC) [0x14f00000 0x200000] Size: 2.0MB P23 (DFX) [0x15100000 0x1000000] Size: 16.0MB P24 (RRECORD) [0x16100000 0x1000000] Size: 16.0MB P25 (FW_LPM3_A) [0x17100000 0x40000] Size: 256.0KB P26 (RESERVED3_A) [0x17140000 0x3c0000] Size: 3.750MB P27 (HDCP_A) [0x17500000 0x100000] Size: 1.0MB P28 (HISEE_IMG_A) [0x17600000 0x400000] Size: 4.0MB P29 (HHEE_A) [0x17a00000 0x400000] Size: 4.0MB P30 (HISEE_FS_A) [0x17e00000 0x800000] Size: 8.0MB P31 (FASTBOOT_A) [0x18600000 0xc00000] Size: 12.0MB P32 (VECTOR_A) [0x19200000 0x400000] Size: 4.0MB P33 (ISP_BOOT_A) [0x19600000 0x200000] Size: 2.0MB P34 (ISP_FIRMWARE_A) [0x19800000 0xe00000] Size: 14.0MB P35 (FW_HIFI_A) [0x1a600000 0xc00000] Size: 12.0MB P36 (TEEOS_A) [0x1b200000 0x800000] Size: 8.0MB P37 (SENSORHUB_A) [0x1ba00000 0x1000000] Size: 16.0MB P38 (ERECOVERY_KERNEL_A) [0x1ca00000 0x1800000] Size: 24.0MB P39 (ERECOVERY_RAMDISK_A) [0x1e200000 0x2000000] Size: 32.0MB P40 (ERECOVERY_VENDOR_A) [0x20200000 0x1000000] Size: 16.0MB P41 (KERNEL_A) [0x21200000 0x1800000] Size: 24.0MB P42 (RAMDISK_A) [0x22a00000 0x1000000] Size: 16.0MB P43 (RECOVERY_RAMDISK_A) [0x23a00000 0x2000000] Size: 32.0MB P44 (RECOVERY_VENDOR_A) [0x25a00000 0x1000000] Size: 16.0MB P45 (DTS_A) [0x26a00000 0x1800000] Size: 24.0MB P46 (DTO_A) [0x28200000 0x800000] Size: 8.0MB P47 (TRUSTFIRMWARE_A) [0x28a00000 0x200000] Size: 2.0MB P48 (MODEM_FW_A) [0x28c00000 0x3800000] Size: 56.0MB P49 (RESERVED4_A) [0x2c400000 0xc00000] Size: 12.0MB P50 (PRELOAD_A) [0x2d000000 0x800000] Size: 8.0MB P51 (RECOVERY_VBMETA_A) [0x2d800000 0x200000] Size: 2.0MB P52 (ERECOVERY_VBMETA_A) [0x2da00000 0x200000] Size: 2.0MB P53 (VBMETA_A) [0x2dc00000 0x400000] Size: 4.0MB P54 (MODEMNVM_UPDATE_A) [0x2e000000 0x1000000] Size: 16.0MB P55 (MODEMNVM_CUST_A) [0x2f000000 0x1000000] Size: 16.0MB P56 (PATCH_A) [0x30000000 0x2000000] Size: 32.0MB P57 (VERSION_A) [0x32000000 0x2000000] Size: 32.0MB P58 (VENDOR_A) [0x34000000 0x2f800000] Size: 760.0MB P59 (PRODUCT_A) [0x63800000 0xc000000] Size: 192.0MB P60 (CUST_A) [0x6f800000 0xc000000] Size: 192.0MB P61 (ODM_A) [0x7b800000 0xb000000] Size: 176.0MB P62 (CACHE) [0x86800000 0x6800000] Size: 104.0MB P63 (SYSTEM_A) [0x8d000000 0x160000000] Size: 5.500GB P64 (USERDATA) [0x1ed000000 0xca2800000] Size: 50.539GB ------------------------------------ Checking security ... Z3X EasyJtag Software ver. 3.6.2.3 Skip loading eMMC Addon Firmware Box IO Level:1800 mV CLK Rate:42000 kHz Bus Width:8bit,SDR Reading 0x000001000000 (16.0MB) from 0x000009800000 ...ROM1 ( USER ROM) Output file :C:\Users\Rayyan\Desktop\SNE-LX1\Modem\EMMC_ROM1_hC8aP_1729521111_09800000_01000000_MODEMNVM_FACTORY.bin Done, time taken: 0.725 sec. Average Read Speed: 23366 kB/s Checking security ... Z3X EasyJtag Software ver. 3.6.2.3 Skip loading eMMC Addon Firmware Box IO Level:1800 mV CLK Rate:42000 kHz Bus Width:8bit,SDR Reading 0x000001000000 (16.0MB) from 0x00000A800000 ...ROM1 ( USER ROM) Output file :C:\Users\Rayyan\Desktop\SNE-LX1\Modem\EMMC_ROM1_hC8aP_1729521111_0A800000_01000000_MODEMNVM_BACKUP.bin Done, time taken: 0.719 sec. Average Read Speed: 23334 kB/s |
05-31-2020, 10:28 | #2 (permalink) |
Member: 2289628 Status: Offline Thanks Meter: 226 | Add Feature for Modem Security Backup Could Easy-Jtag team add highlighted feature or add new tab/option for Modem Security Backup same like as other box. It will became more easier newbie users ....... |
The Following User Says Thank You to hafiz4saqib For This Useful Post: |
