02-16-2020, 11:20 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Allah is Greatest
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 994 | G318H Dead By Myself I tried to write by vender but still not writing. I format it and erase it also but still same error.. I couldnt find DUMP file. Please easy Team help me. Check Emmc eMMC_tool Suite ver. 1.6.2.0 (release date: 30.06.2019) Microsoft Windows 7 (32 bit) build 7601 (6.1.7601.18015) Looking for EasyJTAG box... EasyJTAG API ver. 3307 EasyJTAG Box Serial = 00000000000 Card Serial = AA9C8FF8 EasyJTAG Box Firmware = 2.48 Changelog: 30.06.2019 (ver 1.6.1.0) Fix: Bugs that have been found through your crash report Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 36 MHz CMD Pullup Level: 1785 mV CMD Active Level: 1855 mV EMMC Device Information : EMMC CID: 90014A483447326211014390EED9C21F EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DB EMMC Manufacture : SKHYNIX , EMMC NAME: H4G2b , HEX: 483447326200 , S/N: 4390EED9 , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 12/2015 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H4G2b_4390EED9_20200216_121622.extcsd EMMC Init completed. Write By Vender Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 36 MHz CMD Pullup Level: 1784 mV CMD Active Level: 1855 mV EMMC Device Information : EMMC CID: 90014A483447326211014390EED9C21F EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DB EMMC Manufacture : SKHYNIX , EMMC NAME: H4G2b , HEX: 483447326200 , S/N: 4390EED9 , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 12/2015 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H4G2b_4390EED9_20200216_121832.extcsd EMMC Init completed. Opening file: VIVALTO_ML_4GB_20150210.pit Pit: VIVALTO_ML_4GB_20150210.pit Entry count: 30 The size of the last section has been updated BL_G318HJPS0API1_CL1054706_QB10923123_REV03_user_l ow_ship.tar.md5 The list of files in the firmware: spl.img sboot.bin sboot2.bin param.lfs Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 36 MHz CMD Pullup Level: 1784 mV CMD Active Level: 1856 mV EMMC Device Information : EMMC CID: 90014A483447326211014390EED9C21F EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DB EMMC Manufacture : SKHYNIX , EMMC NAME: H4G2b , HEX: 483447326200 , S/N: 4390EED9 , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 12/2015 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H4G2b_4390EED9_20200216_121925.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Error writing at address: 000000000000 , error: 34 , 34 Unknown error ... Retry #1 Error writing at address: 000000000000 , error: 34 , 34 Unknown error ... Retry #2 Error writing at address: 000000000000 , error: 34 , 34 Unknown error ... Retry #3 Too many errors. Writing has been stopped |
02-17-2020, 07:25 | #2 (permalink) |
No Life Poster Join Date: Aug 2011
Member: 1630066 Status: Offline Sonork: 520074 Thanks Meter: 215 | you did wrong to format EMMC and as you told you do not have DUMP now you need to make GP PARTITION and write BL+PIT by vender if faile to boot than arrange DUMP file |
