Redmi 4x emmc replacement process need Redmi 4x emmc replacement process need and what is diffrence between csd file i seen both emmc csd is different need to know layder sir replay plz 4x emmc log Code: eMMC CID : 150100525831424D4207E692D45DC3DB i have y1 emmc is it comfortable in 4x y1 emmc log eMMC CID : 150100474436424D42015742D0D9B403 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 11/2017 Rev.0x1 eMMC NAME: GD6BMB , S/N: 1463996633 eMMC NAME (HEX): 474436424D42 EMMC ROM1 (Main User Data) Capacity: 29820 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: GD6BMB_1463996633_20190407_1630.extcsd Partition table scan: GPT: present Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 First usable sector: 34 Last usable sector: 61071326 Partition info successfully found Found Data areas (firmware parts) count is: 48 --------------------------------------------- P0 (MODEM) [0x4000000 0x5400000] Size: 84.0MB P1 (FSC) [0xc000000 0x400] Size: 1.0KB P2 (SSD) [0xc000400 0x2000] Size: 8.0KB P3 (SBL1) [0xc002400 0x80000] Size: 512.0KB P4 (SBL1BAK) [0xc082400 0x80000] Size: 512.0KB P5 (RPM) [0xc102400 0x80000] Size: 512.0KB P6 (RPMBAK) [0xc182400 0x80000] Size: 512.0KB P7 (TZ) [0xc202400 0x200000] Size: 2.0MB P8 (TZBAK) [0xc402400 0x200000] Size: 2.0MB P9 (DEVCFG) [0xc602400 0x40000] Size: 256.0KB P10 (DEVCFGBAK) [0xc642400 0x40000] Size: 256.0KB P11 (DSP) [0xc682400 0x1000000] Size: 16.0MB P12 (MODEMST1) [0xd682400 0x180000] Size: 1.500MB P13 (MODEMST2) [0xd802400 0x180000] Size: 1.500MB P14 (DDR) [0x10000000 0x8000] Size: 32.0KB P15 (FSG) [0x10008000 0x180000] Size: 1.500MB P16 (SEC) [0x10188000 0x4000] Size: 16.0KB P17 (SPLASH) [0x14000000 0xb00000] Size: 11.0MB P18 (ABOOT) [0x18000000 0x100000] Size: 1.0MB P19 (ABOOTBAK) [0x18100000 0x100000] Size: 1.0MB P20 (BOOT) [0x18200000 0x4000000] Size: 64.0MB P21 (RECOVERY) [0x1c200000 0x4000000] Size: 64.0MB P22 (DEVINFO) [0x20200000 0x100000] Size: 1.0MB P23 (SYSTEM) [0x20300000 0xc0000000] Size: 3.0GB P24 (CACHE) [0xe4000000 0x10000000] Size: 256.0MB P25 (PERSIST) [0xf4000000 0x2000000] Size: 32.0MB P26 (MISC) [0xf6000000 0x100000] Size: 1.0MB P27 (KEYSTORE) [0xf6100000 0x80000] Size: 512.0KB P28 (CONFIG) [0xf6180000 0x8000] Size: 32.0KB P29 (OEM) [0xf6188000 0x10000000] Size: 256.0MB P30 (LIMITS) [0x108000000 0x8000] Size: 32.0KB P31 (MOTA) [0x10c000000 0x80000] Size: 512.0KB P32 (DIP) [0x10c080000 0x100000] Size: 1.0MB P33 (MDTP) [0x10c180000 0x2000000] Size: 32.0MB P34 (SYSCFG) [0x10e180000 0x80000] Size: 512.0KB P35 (MCFG) [0x10e200000 0x400000] Size: 4.0MB P36 (CMNLIB) [0x110000000 0x40000] Size: 256.0KB P37 (CMNLIBBAK) [0x110040000 0x40000] Size: 256.0KB P38 (CMNLIB64) [0x110080000 0x40000] Size: 256.0KB P39 (CMNLIB64BAK) [0x1100c0000 0x40000] Size: 256.0KB P40 (KEYMASTER) [0x110100000 0x40000] Size: 256.0KB P41 (KEYMASTERBAK) [0x110140000 0x40000] Size: 256.0KB P42 (APDP) [0x114000000 0x40000] Size: 256.0KB P43 (MSADP) [0x114040000 0x40000] Size: 256.0KB P44 (DPO) [0x114080000 0x2000] Size: 8.0KB P45 (LOGDUMP) [0x114082000 0x4000000] Size: 64.0MB P46 (CUST) [0x11c000000 0x34000000] Size: 832.0MB P47 (USERDATA) [0x150000000 0x5f7c00000] Size: 23.871GB ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0020300000 (3.0GB) Build ID: N2G47H Display Build ID: N2G47H Release Incremental ID: V9.2.1.0.NDKMIEK Release Base ID: 7.1.2 Device Model: Redmi Note 5A Device Name: ugg Architecture ABI: arm64-v8a Device Platform: msm8937 Product ID: ugg Build Description: ugg-user 7.1.2 N2G47H V9.2.1.0.NDKMIEK release-keys Device manufacturer: Xiaomi --------------------------------------------- Done. Selected eMMC Interface |
for most new xiaomi, you need flash service firmware after replacement eMMC. without service firmware phones newest after Redmi 4x is freezing at boot |
sir plz tell about more about service firmware and from we get it ? |
is service firmware is different from those firmware from which we flash mi handsets ? |
Aftet write service firmware via vender set is not on That's why i need to know what mistake Both emmc excsd is different is it issue What is excsd explain plz |
you need to appeal to those from whom you took it. we are not a Xiaomi Autorized Service Center and we do not know all the features of their use |
Both emmc is excsd is different |
RX1BMB_3868382301_20190407_1627.extcsd Y1 ok emmc excsd GD6BMB_1463996633_20190407_1630.extcsd Both is different excsd I want to known can i put y1 emmc in 4x board |
extсsd - is a individual eMMC data you should not be worried that they are different, they do not have to be the same. |
Factory Firmware For Your Model ,Blank Yur eMCP AND Instal by UMT Recommended Mido = https://drive.google.com/file/d/10sq...ZFmr4PIuVk0iXo Santoni = https://drive.google.com/file/d/18cJ...Cl5atgo9w4QN_Q Pass =SIX Time Space |
