kprashant | 11-19-2020 09:16 | Redmi 5 plus (vince) dead after wrong flash Redmi 5 plus (vince) trying to downgrade for unlock bootloader but mistakely flashed redmi note 5 pro and became dead forever
tried flashing many firmware but set not on then tried flashing from jtag from isp pinout still dead Read Info Quote:
2020-10-29 16:01:43>
2020-10-29 16:01:43> eMMC_tool Suite ver. 1.6.3.0 (release date: 23.06.2020)
2020-10-29 16:01:46> Microsoft Windows 10 (64 bit) build 18363 (10.0.18362.1110)
2020-10-29 16:01:46> Looking for EasyJTAG box...
2020-10-29 16:01:46> EasyJTAG API ver. 3401
2020-10-29 16:01:47> OpenUSB returned = 0
2020-10-29 16:01:47> EasyJTAG Box Serial = E068D0196F77AC51
2020-10-29 16:01:48> Card Serial = AAF7F05C
2020-10-29 16:01:48> EasyJTAG Box Firmware = 2.5301
2020-10-29 16:04:36> Looking for EasyJTAG box...
2020-10-29 16:04:36> EasyJTAG API ver. 3401
2020-10-29 16:04:36> Setting IO Levels to 1.8V
2020-10-29 16:04:36> Setting frequence to 18 MHz
2020-10-29 16:04:36> EasyJTAG Box Serial = E068D0196F77AC51
2020-10-29 16:04:36> EasyJTAG Box Firmware = 2.5301
2020-10-29 16:04:38> Setting interface to EasyJtag2/ISP_HiPower
2020-10-29 16:04:38> Setting bus width to 1 Bit
2020-10-29 16:04:38> HiPower mode is ON
2020-10-29 16:04:38> Setting frequence to 18 MHz
2020-10-29 16:04:38> CMD Pullup Level: 1833 mV
2020-10-29 16:04:38> CMD Active Level: 1885 mV
2020-10-29 16:04:39> eMMC Init returned = 0
2020-10-29 16:04:39> EMMC Device Information :
2020-10-29 16:04:39> EMMC CID: 90014A484347386134A22A88CDD815AB
2020-10-29 16:04:39> EMMC CSD: D02701328F5903FFFFFFFFEF8A400027
2020-10-29 16:04:39> EMMC Manufacture : SKHYNIX , EMMC NAME: HCG8a4 , HEX: 484347386134 , S/N: 2A88CDD8 , rev. 0xA2
2020-10-29 16:04:39> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 1/2018
2020-10-29 16:04:39> EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000)
2020-10-29 16:04:39> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
2020-10-29 16:04:39> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 34799 , Response: Not Clean
2020-10-29 16:04:39> EMMC Permanent Write Protection: No
2020-10-29 16:04:39> EMMC Temporary Write Protection: No
2020-10-29 16:04:39> Extended CSD Information :
2020-10-29 16:04:39> Extended CSD rev: 1.8 (MMC 5.1)
2020-10-29 16:04:39> Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area)
2020-10-29 16:04:39> Boot Bus Config: 0x00 , width 1bit
2020-10-29 16:04:39> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
2020-10-29 16:04:39> Supported partition features [PARTITIONING_SUPPORT]: 0x07
2020-10-29 16:04:39> Device supports partitioning features
2020-10-29 16:04:39> Device can have enhanced technological features in partitions and user data area
2020-10-29 16:04:39> Device can have extended partitions attribute
2020-10-29 16:04:39> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
2020-10-29 16:04:39> Backup saved: HCG8a4_2A88CDD8_20201029_160439.extcsd
2020-10-29 16:04:39> EMMC Init completed.
2020-10-29 16:04:40> Scanning soft partitions
2020-10-29 16:04:40> GPT header is found and is valid
2020-10-29 16:04:40> Partition: modem, [000004000000 - 000009400000], size: 000005400000 (84.0 MB)
2020-10-29 16:04:40> Partition: fsc, [00000C000000 - 00000C000400], size: 000000000400 (1.00 KB)
2020-10-29 16:04:40> Partition: ssd, [00000C000400 - 00000C002400], size: 000000002000 (8.00 KB)
2020-10-29 16:04:40> Partition: sbl1, [00000C002400 - 00000C082400], size: 000000080000 (512. KB)
2020-10-29 16:04:40> Partition: sbl1bak, [00000C082400 - 00000C102400], size: 000000080000 (512. KB)
2020-10-29 16:04:40> Partition: rpm, [00000C102400 - 00000C182400], size: 000000080000 (512. KB)
2020-10-29 16:04:40> Partition: rpmbak, [00000C182400 - 00000C202400], size: 000000080000 (512. KB)
2020-10-29 16:04:40> Partition: tz, [00000C202400 - 00000C402400], size: 000000200000 (2.00 MB)
2020-10-29 16:04:40> Partition: tzbak, [00000C402400 - 00000C602400], size: 000000200000 (2.00 MB)
2020-10-29 16:04:40> Partition: devcfg, [00000C602400 - 00000C642400], size: 000000040000 (256. KB)
2020-10-29 16:04:41> Partition: devcfgbak, [00000C642400 - 00000C682400], size: 000000040000 (256. KB)
2020-10-29 16:04:41> Partition: dsp, [00000C682400 - 00000D682400], size: 000001000000 (16.0 MB)
2020-10-29 16:04:41> Partition: modemst1, [00000D682400 - 00000D802400], size: 000000180000 (1.50 MB)
2020-10-29 16:04:41> Partition: modemst2, [00000D802400 - 00000D982400], size: 000000180000 (1.50 MB)
2020-10-29 16:04:41> Partition: DDR, [000010000000 - 000010008000], size: 000000008000 (32.0 KB)
2020-10-29 16:04:41> Partition: fsg, [000010008000 - 000010188000], size: 000000180000 (1.50 MB)
2020-10-29 16:04:41> Partition: sec, [000010188000 - 00001018C000], size: 000000004000 (16.0 KB)
2020-10-29 16:04:41> Partition: splash, [000014000000 - 000014B00000], size: 000000B00000 (11.0 MB)
2020-10-29 16:04:41> Partition: aboot, [000018000000 - 000018100000], size: 000000100000 (1.00 MB)
2020-10-29 16:04:41> Partition: abootbak, [000018100000 - 000018200000], size: 000000100000 (1.00 MB)
2020-10-29 16:04:41> Partition: boot, [000018200000 - 00001C200000], size: 000004000000 (64.0 MB)
2020-10-29 16:04:41> Partition: recovery, [00001C200000 - 000020200000], size: 000004000000 (64.0 MB)
2020-10-29 16:04:41> Partition: devinfo, [000020200000 - 000020300000], size: 000000100000 (1.00 MB)
2020-10-29 16:04:41> Partition: system, [000020300000 - 0000E0300000], size: 0000C0000000 (3.00 GB)
2020-10-29 16:04:41> Partition: cache, [0000E4000000 - 0000F4000000], size: 000010000000 (256. MB)
2020-10-29 16:04:41> Partition: persist, [0000F4000000 - 0000F6000000], size: 000002000000 (32.0 MB)
2020-10-29 16:04:41> Partition: misc, [0000F6000000 - 0000F6100000], size: 000000100000 (1.00 MB)
2020-10-29 16:04:41> Partition: keystore, [0000F6100000 - 0000F6180000], size: 000000080000 (512. KB)
2020-10-29 16:04:41> Partition: config, [0000F6180000 - 0000F6188000], size: 000000008000 (32.0 KB)
2020-10-29 16:04:41> Partition: oem, [0000F6188000 - 000106188000], size: 000010000000 (256. MB)
2020-10-29 16:04:41> Partition: limits, [000108000000 - 000108008000], size: 000000008000 (32.0 KB)
2020-10-29 16:04:41> Partition: mota, [00010C000000 - 00010C080000], size: 000000080000 (512. KB)
2020-10-29 16:04:41> Partition: dip, [00010C080000 - 00010C180000], size: 000000100000 (1.00 MB)
2020-10-29 16:04:41> Partition: mdtp, [00010C180000 - 00010E180000], size: 000002000000 (32.0 MB)
2020-10-29 16:04:41> Partition: syscfg, [00010E180000 - 00010E200000], size: 000000080000 (512. KB)
2020-10-29 16:04:41> Partition: mcfg, [00010E200000 - 00010E600000], size: 000000400000 (4.00 MB)
2020-10-29 16:04:41> Partition: lksecapp, [000110000000 - 000110020000], size: 000000020000 (128. KB)
2020-10-29 16:04:41> Partition: lksecappbak, [000110020000 - 000110040000], size: 000000020000 (128. KB)
2020-10-29 16:04:41> Partition: cmnlib, [000110040000 - 000110080000], size: 000000040000 (256. KB)
2020-10-29 16:04:41> Partition: cmnlibbak, [000110080000 - 0001100C0000], size: 000000040000 (256. KB)
2020-10-29 16:04:41> Partition: cmnlib64, [0001100C0000 - 000110100000], size: 000000040000 (256. KB)
2020-10-29 16:04:41> Partition: cmnlib64bak, [000110100000 - 000110140000], size: 000000040000 (256. KB)
2020-10-29 16:04:41> Partition: keymaster, [000110140000 - 000110180000], size: 000000040000 (256. KB)
2020-10-29 16:04:42> Partition: keymasterbak, [000110180000 - 0001101C0000], size: 000000040000 (256. KB)
2020-10-29 16:04:42> Partition: apdp, [000114000000 - 000114040000], size: 000000040000 (256. KB)
2020-10-29 16:04:42> Partition: msadp, [000114040000 - 000114080000], size: 000000040000 (256. KB)
2020-10-29 16:04:42> Partition: dpo, [000114080000 - 000114082000], size: 000000002000 (8.00 KB)
2020-10-29 16:04:42> Partition: logdump, [000114082000 - 000118082000], size: 000004000000 (64.0 MB)
2020-10-29 16:04:42> Partition: cust, [000118082000 - 00014C082000], size: 000034000000 (832. MB)
2020-10-29 16:04:42> Partition: userdata, [00014C082000 - 000E8F7FBE00], size: 000D43779E00 (53.0 GB)
2020-10-29 16:04:42> GPT header successfully parsed
2020-10-29 16:04:42> Get firmware version
2020-10-29 16:04:46> Brand = xiaomi
2020-10-29 16:04:46> Manufacturer = Xiaomi
2020-10-29 16:04:46> Device = vince
2020-10-29 16:04:46> Model = Redmi 5 Plus
2020-10-29 16:04:46> Phone platform = msm8953
2020-10-29 16:04:46> CPU Abi = arm64-v8a
2020-10-29 16:04:46> Android release = 7.1.2
2020-10-29 16:04:46> Security Patch = 2018-03-01
2020-10-29 16:04:46> Firmware version = ZQL1711-vince-build-20180322161322
2020-10-29 16:04:46> Miui Version = V9.5.3.0.NEGMIFA
2020-10-29 16:04:46> Firmware date = Thu Mar 22 16:13:20 WIB 2018
| Flash from jtag Quote:
2020-10-29 14:21:26> Looking for EasyJTAG box...
2020-10-29 14:21:26> EasyJTAG API ver. 3401
2020-10-29 14:21:26> Setting IO Levels to 1.8V
2020-10-29 14:21:26> Setting frequence to 18 MHz
2020-10-29 14:21:26> EasyJTAG Box Serial = E068D0196F77AC51
2020-10-29 14:21:26> EasyJTAG Box Firmware = 2.5301
2020-10-29 14:21:28> Setting interface to EasyJtag2/ISP_HiPower
2020-10-29 14:21:28> Setting bus width to 1 Bit
2020-10-29 14:21:28> HiPower mode is ON
2020-10-29 14:21:28> Setting frequence to 18 MHz
2020-10-29 14:21:28> CMD Pullup Level: 1834 mV
2020-10-29 14:21:28> CMD Active Level: 1885 mV
2020-10-29 14:21:28> eMMC Init returned = 0
2020-10-29 14:21:28> EMMC Device Information :
2020-10-29 14:21:28> EMMC CID: 90014A484347386134A22A88CDD815AB
2020-10-29 14:21:28> EMMC CSD: D02701328F5903FFFFFFFFEF8A400027
2020-10-29 14:21:28> EMMC Manufacture : SKHYNIX , EMMC NAME: HCG8a4 , HEX: 484347386134 , S/N: 2A88CDD8 , rev. 0xA2
2020-10-29 14:21:29> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 1/2018
2020-10-29 14:21:29> EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000)
2020-10-29 14:21:29> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
2020-10-29 14:21:29> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 34799 , Response: Not Clean
2020-10-29 14:21:29> EMMC Permanent Write Protection: No
2020-10-29 14:21:29> EMMC Temporary Write Protection: No
2020-10-29 14:21:29> Extended CSD Information :
2020-10-29 14:21:29> Extended CSD rev: 1.8 (MMC 5.1)
2020-10-29 14:21:29> Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area)
2020-10-29 14:21:29> Boot Bus Config: 0x00 , width 1bit
2020-10-29 14:21:29> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
2020-10-29 14:21:29> Supported partition features [PARTITIONING_SUPPORT]: 0x07
2020-10-29 14:21:29> Device supports partitioning features
2020-10-29 14:21:29> Device can have enhanced technological features in partitions and user data area
2020-10-29 14:21:29> Device can have extended partitions attribute
2020-10-29 14:21:29> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
2020-10-29 14:21:29> Backup saved: HCG8a4_2A88CDD8_20201029_142129.extcsd
2020-10-29 14:21:29> EMMC Init completed.
2020-10-29 14:21:30> Opening file: G:\Chinese\Redmi\Redmi note 5 globle\vince_global_images_V11.0.2.0.OEGMIXM_20191 108.0000.00_8.1_global\images\rawprogram0.xml
2020-10-29 14:21:30> The size of the last section has been updated
2020-10-29 14:21:47>
2020-10-29 14:21:48> Looking for EasyJTAG box...
2020-10-29 14:21:48> EasyJTAG API ver. 3401
2020-10-29 14:21:48> Setting IO Levels to 1.8V
2020-10-29 14:21:48> Setting frequence to 18 MHz
2020-10-29 14:21:48> EasyJTAG Box Serial = E068D0196F77AC51
2020-10-29 14:21:48> EasyJTAG Box Firmware = 2.5301
2020-10-29 14:21:49> Setting interface to EasyJtag2/ISP_HiPower
2020-10-29 14:21:49> Setting bus width to 1 Bit
2020-10-29 14:21:49> HiPower mode is ON
2020-10-29 14:21:49> Setting frequence to 18 MHz
2020-10-29 14:21:49> CMD Pullup Level: 1834 mV
2020-10-29 14:21:49> CMD Active Level: 1885 mV
2020-10-29 14:21:50> eMMC Init returned = 0
2020-10-29 14:21:50> EMMC Device Information :
2020-10-29 14:21:50> EMMC CID: 90014A484347386134A22A88CDD815AB
2020-10-29 14:21:50> EMMC CSD: D02701328F5903FFFFFFFFEF8A400027
2020-10-29 14:21:50> EMMC Manufacture : SKHYNIX , EMMC NAME: HCG8a4 , HEX: 484347386134 , S/N: 2A88CDD8 , rev. 0xA2
2020-10-29 14:21:50> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 1/2018
2020-10-29 14:21:50> EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000)
2020-10-29 14:21:50> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
2020-10-29 14:21:50> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 34799 , Response: Not Clean
2020-10-29 14:21:50> EMMC Permanent Write Protection: No
2020-10-29 14:21:50> EMMC Temporary Write Protection: No
2020-10-29 14:21:50> Extended CSD Information :
2020-10-29 14:21:50> Extended CSD rev: 1.8 (MMC 5.1)
2020-10-29 14:21:50> Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area)
2020-10-29 14:21:50> Boot Bus Config: 0x00 , width 1bit
2020-10-29 14:21:50> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
2020-10-29 14:21:50> Supported partition features [PARTITIONING_SUPPORT]: 0x07
2020-10-29 14:21:51> Device supports partitioning features
2020-10-29 14:21:51> Device can have enhanced technological features in partitions and user data area
2020-10-29 14:21:51> Device can have extended partitions attribute
2020-10-29 14:21:51> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
2020-10-29 14:21:51> Backup saved: HCG8a4_2A88CDD8_20201029_142151.extcsd
2020-10-29 14:21:51> EMMC Init completed.
2020-10-29 14:21:51> Operation: Write by vendor (Qualcomm/HiSilicon/Omap)
2020-10-29 14:21:51> Creating GPT-partitioninig
2020-10-29 14:21:52> Writing PrimaryGPT at address: 000000000000
2020-10-29 14:21:52> Writing BackupGPT at address: 000E8F7FBE00
2020-10-29 14:21:52> GPT-partitioning done
2020-10-29 14:21:52> Partition name: modem
2020-10-29 14:21:52> Filename: NON-HLOS.bin , Offset: 000004000000 , filesize: 88080384 bytes
2020-10-29 14:21:52> eMMC switching to ROM1
2020-10-29 14:21:52> Erasing partition...
2020-10-29 14:21:57> Writing partition...
2020-10-29 14:22:49> Done writing partition. Write speed: 1652.41 KB/s
2020-10-29 14:22:49> Partition name: sbl1
2020-10-29 14:22:49> Filename: sbl1.mbn , Offset: 00000C002400 , filesize: 401392 bytes
2020-10-29 14:22:49> eMMC switching to ROM1
2020-10-29 14:22:50> Erasing partition...
2020-10-29 14:22:51> Writing partition...
2020-10-29 14:22:51> Done writing partition. Write speed: 1368.34 KB/s
2020-10-29 14:22:51> Partition name: sbl1bak
2020-10-29 14:22:51> Filename: sbl1.mbn , Offset: 00000C082400 , filesize: 401392 bytes
2020-10-29 14:22:51> eMMC switching to ROM1
2020-10-29 14:22:51> Erasing partition...
2020-10-29 14:22:52> Writing partition...
2020-10-29 14:22:53> Done writing partition. Write speed: 1512.57 KB/s
2020-10-29 14:22:53> Partition name: rpm
2020-10-29 14:22:53> Filename: rpm.mbn , Offset: 00000C102400 , filesize: 174468 bytes
2020-10-29 14:22:53> eMMC switching to ROM1
2020-10-29 14:22:53> Erasing partition...
2020-10-29 14:22:54> Writing partition...
2020-10-29 14:22:54> Done writing partition. Write speed: 1035.63 KB/s
2020-10-29 14:22:54> Partition name: rpmbak
2020-10-29 14:22:54> Filename: rpm.mbn , Offset: 00000C182400 , filesize: 174468 bytes
2020-10-29 14:22:54> eMMC switching to ROM1
2020-10-29 14:22:54> Erasing partition...
2020-10-29 14:22:55> Writing partition...
2020-10-29 14:22:55> Done writing partition. Write speed: 1535.46 KB/s
2020-10-29 14:22:55> Partition name: tz
2020-10-29 14:22:55> Filename: tz.mbn , Offset: 00000C202400 , filesize: 1551616 bytes
2020-10-29 14:22:55> eMMC switching to ROM1
2020-10-29 14:22:56> Erasing partition...
2020-10-29 14:22:56> Writing partition...
2020-10-29 14:22:57> Done writing partition. Write speed: 1825.57 KB/s
2020-10-29 14:22:57> Partition name: tzbak
2020-10-29 14:22:57> Filename: tz.mbn , Offset: 00000C402400 , filesize: 1551616 bytes
2020-10-29 14:22:57> eMMC switching to ROM1
2020-10-29 14:22:58> Erasing partition...
2020-10-29 14:22:58> Writing partition...
2020-10-29 14:22:59> Done writing partition. Write speed: 1775.54 KB/s
2020-10-29 14:22:59> Partition name: devcfg
2020-10-29 14:22:59> Filename: devcfg.mbn , Offset: 00000C602400 , filesize: 39692 bytes
2020-10-29 14:22:59> eMMC switching to ROM1
2020-10-29 14:23:00> Erasing partition...
2020-10-29 14:23:00> Writing partition...
2020-10-29 14:23:00> Done writing partition. Write speed: 502.15 KB/s
2020-10-29 14:23:00> Partition name: devcfgbak
2020-10-29 14:23:00> Filename: devcfg.mbn , Offset: 00000C642400 , filesize: 39692 bytes
2020-10-29 14:23:00> eMMC switching to ROM1
2020-10-29 14:23:01> Erasing partition...
2020-10-29 14:23:01> Writing partition...
2020-10-29 14:23:01> Done writing partition. Write speed: 623.09 KB/s
2020-10-29 14:23:01> Partition name: dsp
2020-10-29 14:23:01> Filename: adspso.bin , Offset: 00000C682400 , filesize: 16777216 bytes
2020-10-29 14:23:01> eMMC switching to ROM1
2020-10-29 14:23:02> Erasing partition...
2020-10-29 14:23:03> Writing partition...
2020-10-29 14:23:12> Done writing partition. Write speed: 1903.14 KB/s
2020-10-29 14:23:12> Partition name: sec
2020-10-29 14:23:12> Filename: sec.dat , Offset: 000010188000 , filesize: 80 bytes
2020-10-29 14:23:12> eMMC switching to ROM1
2020-10-29 14:23:12> Erasing partition...
2020-10-29 14:23:13> Writing partition...
2020-10-29 14:23:13> Done writing partition. Write speed: 3.20 KB/s
2020-10-29 14:23:13> Partition name: splash
2020-10-29 14:23:13> Filename: splash.img , Offset: 000014000000 , filesize: 927859 bytes
2020-10-29 14:23:13> eMMC switching to ROM1
2020-10-29 14:23:13> Erasing partition...
2020-10-29 14:23:14> Writing partition...
2020-10-29 14:23:15> Done writing partition. Write speed: 1797.13 KB/s
2020-10-29 14:23:15> Partition name: aboot
2020-10-29 14:23:15> Filename: emmc_appsboot.mbn , Offset: 000018000000 , filesize: 649284 bytes
2020-10-29 14:23:15> eMMC switching to ROM1
2020-10-29 14:23:15> Erasing partition...
2020-10-29 14:23:16> Writing partition...
2020-10-29 14:23:16> Done writing partition. Write speed: 1679.99 KB/s
2020-10-29 14:23:16> Partition name: abootbak
2020-10-29 14:23:16> Filename: emmc_appsboot.mbn , Offset: 000018100000 , filesize: 649284 bytes
2020-10-29 14:23:16> eMMC switching to ROM1
2020-10-29 14:23:17> Erasing partition...
2020-10-29 14:23:17> Writing partition...
2020-10-29 14:23:18> Done writing partition. Write speed: 1755.87 KB/s
2020-10-29 14:23:18> Partition name: boot
2020-10-29 14:23:18> Filename: boot.img , Offset: 000018200000 , filesize: 32828746 bytes
2020-10-29 14:23:18> eMMC switching to ROM1
2020-10-29 14:23:18> Erasing partition...
2020-10-29 14:23:21> Writing partition...
2020-10-29 14:23:38> Done writing partition. Write speed: 1905.72 KB/s
2020-10-29 14:23:38> Partition name: recovery
2020-10-29 14:23:38> Filename: recovery.img , Offset: 00001C200000 , filesize: 38399310 bytes
2020-10-29 14:23:38> eMMC switching to ROM1
2020-10-29 14:23:38> Erasing partition...
2020-10-29 14:23:41> Writing partition...
2020-10-29 14:24:01> Done writing partition. Write speed: 1903.64 KB/s
2020-10-29 14:24:01> Partition name: persist
2020-10-29 14:24:01> Filename: persist.img , Offset: 0000F4000000 , filesize: 4972908 bytes
2020-10-29 14:24:01> eMMC switching to ROM1
2020-10-29 14:24:01> Erasing partition...
2020-10-29 14:24:03> Writing partition...
2020-10-29 14:24:03> Sparse image found v.1.0 Total chunks: 28
2020-10-29 14:24:06> Done writing partition. Write speed: 1693.95 KB/s
2020-10-29 14:24:06> Partition name: misc
2020-10-29 14:24:06> Filename: misc.img , Offset: 0000F6000000 , filesize: 8192 bytes
2020-10-29 14:24:06> eMMC switching to ROM1
2020-10-29 14:24:06> Erasing partition...
2020-10-29 14:24:07> Writing partition...
2020-10-29 14:24:07> Done writing partition. Write speed: 273.89 KB/s
2020-10-29 14:24:07> Partition name: lksecapp
2020-10-29 14:24:07> Filename: lksecapp.mbn , Offset: 000110000000 , filesize: 57352 bytes
2020-10-29 14:24:07> eMMC switching to ROM1
2020-10-29 14:24:07> Erasing partition...
2020-10-29 14:24:08> Writing partition...
2020-10-29 14:24:08> Done writing partition. Write speed: 881.88 KB/s
2020-10-29 14:24:08> Partition name: lksecappbak
2020-10-29 14:24:08> Filename: lksecapp.mbn , Offset: 000110020000 , filesize: 57352 bytes
2020-10-29 14:24:08> eMMC switching to ROM1
2020-10-29 14:24:09> Erasing partition...
2020-10-29 14:24:09> Writing partition...
2020-10-29 14:24:09> Done writing partition. Write speed: 1153.55 KB/s
2020-10-29 14:24:09> Partition name: cmnlib
2020-10-29 14:24:09> Filename: cmnlib.mbn , Offset: 000110040000 , filesize: 205472 bytes
2020-10-29 14:24:09> eMMC switching to ROM1
2020-10-29 14:24:10> Erasing partition...
2020-10-29 14:24:10> Writing partition...
2020-10-29 14:24:10> Done writing partition. Write speed: 1211.86 KB/s
2020-10-29 14:24:10> Partition name: cmnlibbak
2020-10-29 14:24:11> Filename: cmnlib.mbn , Offset: 000110080000 , filesize: 205472 bytes
2020-10-29 14:24:11> eMMC switching to ROM1
2020-10-29 14:24:11> Erasing partition...
2020-10-29 14:24:11> Writing partition...
2020-10-29 14:24:12> Done writing partition. Write speed: 1352.68 KB/s
2020-10-29 14:24:12> Partition name: cmnlib64
2020-10-29 14:24:12> Filename: cmnlib64.mbn , Offset: 0001100C0000 , filesize: 260320 bytes
2020-10-29 14:24:12> eMMC switching to ROM1
2020-10-29 14:24:12> Erasing partition...
2020-10-29 14:24:13> Writing partition...
2020-10-29 14:24:13> Done writing partition. Write speed: 1403.68 KB/s
2020-10-29 14:24:13> Partition name: cmnlib64bak
2020-10-29 14:24:13> Filename: cmnlib64.mbn , Offset: 000110100000 , filesize: 260320 bytes
2020-10-29 14:24:13> eMMC switching to ROM1
2020-10-29 14:24:13> Erasing partition...
2020-10-29 14:24:14> Writing partition...
2020-10-29 14:24:14> Done writing partition. Write speed: 1408.30 KB/s
2020-10-29 14:24:14> Partition name: keymaster
2020-10-29 14:24:14> Filename: keymaster.mbn , Offset: 000110140000 , filesize: 226008 bytes
2020-10-29 14:24:14> eMMC switching to ROM1
2020-10-29 14:24:15> Erasing partition...
2020-10-29 14:24:15> Writing partition...
2020-10-29 14:24:15> Done writing partition. Write speed: 1479.63 KB/s
2020-10-29 14:24:15> Partition name: keymasterbak
2020-10-29 14:24:15> Filename: keymaster.mbn , Offset: 000110180000 , filesize: 226008 bytes
2020-10-29 14:24:15> eMMC switching to ROM1
2020-10-29 14:24:16> Erasing partition...
2020-10-29 14:24:16> Writing partition...
2020-10-29 14:24:17> Done writing partition. Write speed: 1476.05 KB/s
2020-10-29 14:24:17> All done time: [00:02:24:596]
2020-10-29 14:24:21> Looking for EasyJTAG box...
2020-10-29 14:24:21> EasyJTAG API ver. 3401
2020-10-29 14:24:21> Setting IO Levels to 1.8V
2020-10-29 14:24:21> Setting frequence to 18 MHz
2020-10-29 14:24:21> EasyJTAG Box Serial = E068D0196F77AC51
2020-10-29 14:24:21> EasyJTAG Box Firmware = 2.5301
2020-10-29 14:24:23> Setting interface to EasyJtag2/ISP_HiPower
2020-10-29 14:24:23> Setting bus width to 1 Bit
2020-10-29 14:24:23> HiPower mode is ON
2020-10-29 14:24:23> Setting frequence to 18 MHz
2020-10-29 14:24:23> CMD Pullup Level: 1831 mV
2020-10-29 14:24:23> CMD Active Level: 1885 mV
2020-10-29 14:24:23> eMMC Init returned = 0
2020-10-29 14:24:23> EMMC Device Information :
2020-10-29 14:24:23> EMMC CID: 90014A484347386134A22A88CDD815AB
2020-10-29 14:24:23> EMMC CSD: D02701328F5903FFFFFFFFEF8A400027
2020-10-29 14:24:23> EMMC Manufacture : SKHYNIX , EMMC NAME: HCG8a4 , HEX: 484347386134 , S/N: 2A88CDD8 , rev. 0xA2
2020-10-29 14:24:23> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 1/2018
2020-10-29 14:24:23> EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000)
2020-10-29 14:24:23> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
2020-10-29 14:24:23> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 34799 , Response: Not Clean
2020-10-29 14:24:24> EMMC Permanent Write Protection: No
2020-10-29 14:24:24> EMMC Temporary Write Protection: No
2020-10-29 14:24:24> Extended CSD Information :
2020-10-29 14:24:24> Extended CSD rev: 1.8 (MMC 5.1)
2020-10-29 14:24:24> Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area)
2020-10-29 14:24:24> Boot Bus Config: 0x00 , width 1bit
2020-10-29 14:24:24> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
2020-10-29 14:24:24> Supported partition features [PARTITIONING_SUPPORT]: 0x07
2020-10-29 14:24:24> Device supports partitioning features
2020-10-29 14:24:24> Device can have enhanced technological features in partitions and user data area
2020-10-29 14:24:24> Device can have extended partitions attribute
2020-10-29 14:24:24> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
2020-10-29 14:24:24> Backup saved: HCG8a4_2A88CDD8_20201029_142424.extcsd
2020-10-29 14:24:24> EMMC Init completed.
2020-10-29 14:24:25> Scanning soft partitions
2020-10-29 14:24:25> GPT header is found and is valid
2020-10-29 14:24:25> Partition: modem, [000004000000 - 000009400000], size: 000005400000 (84.0 MB)
2020-10-29 14:24:25> Partition: fsc, [00000C000000 - 00000C000400], size: 000000000400 (1.00 KB)
2020-10-29 14:24:25> Partition: ssd, [00000C000400 - 00000C002400], size: 000000002000 (8.00 KB)
2020-10-29 14:24:25> Partition: sbl1, [00000C002400 - 00000C082400], size: 000000080000 (512. KB)
2020-10-29 14:24:25> Partition: sbl1bak, [00000C082400 - 00000C102400], size: 000000080000 (512. KB)
2020-10-29 14:24:25> Partition: rpm, [00000C102400 - 00000C182400], size: 000000080000 (512. KB)
2020-10-29 14:24:25> Partition: rpmbak, [00000C182400 - 00000C202400], size: 000000080000 (512. KB)
2020-10-29 14:24:25> Partition: tz, [00000C202400 - 00000C402400], size: 000000200000 (2.00 MB)
2020-10-29 14:24:25> Partition: tzbak, [00000C402400 - 00000C602400], size: 000000200000 (2.00 MB)
2020-10-29 14:24:25> Partition: devcfg, [00000C602400 - 00000C642400], size: 000000040000 (256. KB)
2020-10-29 14:24:25> Partition: devcfgbak, [00000C642400 - 00000C682400], size: 000000040000 (256. KB)
2020-10-29 14:24:25> Partition: dsp, [00000C682400 - 00000D682400], size: 000001000000 (16.0 MB)
2020-10-29 14:24:25> Partition: modemst1, [00000D682400 - 00000D802400], size: 000000180000 (1.50 MB)
2020-10-29 14:24:25> Partition: modemst2, [00000D802400 - 00000D982400], size: 000000180000 (1.50 MB)
2020-10-29 14:24:25> Partition: DDR, [000010000000 - 000010008000], size: 000000008000 (32.0 KB)
2020-10-29 14:24:25> Partition: fsg, [000010008000 - 000010188000], size: 000000180000 (1.50 MB)
2020-10-29 14:24:25> Partition: sec, [000010188000 - 00001018C000], size: 000000004000 (16.0 KB)
2020-10-29 14:24:25> Partition: splash, [000014000000 - 000014B00000], size: 000000B00000 (11.0 MB)
2020-10-29 14:24:26> Partition: aboot, [000018000000 - 000018100000], size: 000000100000 (1.00 MB)
2020-10-29 14:24:26> Partition: abootbak, [000018100000 - 000018200000], size: 000000100000 (1.00 MB)
2020-10-29 14:24:26> Partition: boot, [000018200000 - 00001C200000], size: 000004000000 (64.0 MB)
2020-10-29 14:24:26> Partition: recovery, [00001C200000 - 000020200000], size: 000004000000 (64.0 MB)
2020-10-29 14:24:26> Partition: devinfo, [000020200000 - 000020300000], size: 000000100000 (1.00 MB)
2020-10-29 14:24:26> Partition: system, [000020300000 - 0000E0300000], size: 0000C0000000 (3.00 GB)
2020-10-29 14:24:26> Partition: cache, [0000E4000000 - 0000F4000000], size: 000010000000 (256. MB)
2020-10-29 14:24:26> Partition: persist, [0000F4000000 - 0000F6000000], size: 000002000000 (32.0 MB)
2020-10-29 14:24:26> Partition: misc, [0000F6000000 - 0000F6100000], size: 000000100000 (1.00 MB)
2020-10-29 14:24:26> Partition: keystore, [0000F6100000 - 0000F6180000], size: 000000080000 (512. KB)
2020-10-29 14:24:26> Partition: config, [0000F6180000 - 0000F6188000], size: 000000008000 (32.0 KB)
2020-10-29 14:24:26> Partition: oem, [0000F6188000 - 000106188000], size: 000010000000 (256. MB)
2020-10-29 14:24:26> Partition: limits, [000108000000 - 000108008000], size: 000000008000 (32.0 KB)
2020-10-29 14:24:26> Partition: mota, [00010C000000 - 00010C080000], size: 000000080000 (512. KB)
2020-10-29 14:24:26> Partition: dip, [00010C080000 - 00010C180000], size: 000000100000 (1.00 MB)
2020-10-29 14:24:26> Partition: mdtp, [00010C180000 - 00010E180000], size: 000002000000 (32.0 MB)
2020-10-29 14:24:26> Partition: syscfg, [00010E180000 - 00010E200000], size: 000000080000 (512. KB)
2020-10-29 14:24:26> Partition: mcfg, [00010E200000 - 00010E600000], size: 000000400000 (4.00 MB)
2020-10-29 14:24:26> Partition: lksecapp, [000110000000 - 000110020000], size: 000000020000 (128. KB)
2020-10-29 14:24:26> Partition: lksecappbak, [000110020000 - 000110040000], size: 000000020000 (128. KB)
2020-10-29 14:24:26> Partition: cmnlib, [000110040000 - 000110080000], size: 000000040000 (256. KB)
2020-10-29 14:24:26> Partition: cmnlibbak, [000110080000 - 0001100C0000], size: 000000040000 (256. KB)
2020-10-29 14:24:26> Partition: cmnlib64, [0001100C0000 - 000110100000], size: 000000040000 (256. KB)
2020-10-29 14:24:26> Partition: cmnlib64bak, [000110100000 - 000110140000], size: 000000040000 (256. KB)
2020-10-29 14:24:26> Partition: keymaster, [000110140000 - 000110180000], size: 000000040000 (256. KB)
2020-10-29 14:24:26> Partition: keymasterbak, [000110180000 - 0001101C0000], size: 000000040000 (256. KB)
2020-10-29 14:24:26> Partition: apdp, [000114000000 - 000114040000], size: 000000040000 (256. KB)
2020-10-29 14:24:26> Partition: msadp, [000114040000 - 000114080000], size: 000000040000 (256. KB)
2020-10-29 14:24:26> Partition: dpo, [000114080000 - 000114082000], size: 000000002000 (8.00 KB)
2020-10-29 14:24:26> Partition: logdump, [000114082000 - 000118082000], size: 000004000000 (64.0 MB)
2020-10-29 14:24:26> Partition: cust, [000118082000 - 00014C082000], size: 000034000000 (832. MB)
2020-10-29 14:24:26> Partition: userdata, [00014C082000 - 000E8F7FBE00], size: 000D43779E00 (53.0 GB)
2020-10-29 14:24:26> GPT header successfully parsed
2020-10-29 14:24:26> Get firmware version
2020-10-29 14:24:29> Brand = xiaomi
2020-10-29 14:24:29> Manufacturer = Xiaomi
2020-10-29 14:24:30> Device = vince
2020-10-29 14:24:30> Model = Redmi 5 Plus
2020-10-29 14:24:30> Phone platform = msm8953
2020-10-29 14:24:30> CPU Abi = arm64-v8a
2020-10-29 14:24:30> Android release = 7.1.2
2020-10-29 14:24:30> Security Patch = 2018-03-01
2020-10-29 14:24:30> Firmware version = ZQL1711-vince-build-20180322161322
2020-10-29 14:24:30> Miui Version = V9.5.3.0.NEGMIFA
2020-10-29 14:24:30> Firmware date = Thu Mar 22 16:13:20 WIB 2018
| i also tried XIAOMI_REDMI_5_Plus_emmc_dump_ROM1_10GB
ENG FIRMWARE Redmi 5 plus _Factory_ENG_E7_edl_erase_V26
Xiaomi_Redmi_5_Plus_vince_9.2.0.2_NEGMIEI_vietnam full readout
may be i am doing something wrong. please guide me |
