07-31-2018, 13:38 | #1 (permalink) |
Insane Poster Join Date: Apr 2016
Member: 2566585 Status: Offline Sonork: 100.1673331 Thanks Meter: 5 | Sm-j250f dead boot problem. i have sm-j250f for dead boot repair custumer say to me phone dead on flasing. i try to repair with bl+pit 5 difrent frimwaer all prosess done but phone not power on. i write full bekup from working phone all prosess done but phone not power on i change also cpu config but not done . if any budy solve this plz reply. Setting frequence to 21 Mhz CMD Pullup Level: 2010 mV CMD Active Level: 2310 mV EMMC Device Information : EMMC CID: 150100514536364D4200B130D0B5151C EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QE66MB , HEX: 514536364D42 , S/N: B130D0B5 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 1/2018 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QE66MB_B130D0B5_20180731_150959.extcsd EMMC Init completed. Get firmware version Brand = samsung Manufacturer = samsung Model = SM-J250F Phone platform = msm8937 CPU Abi = armeabi-v7a Android release = 7.1.1 Firmware version = NMF26X.J250FXXU1AQL5 Firmware date = Thu Dec 21 18:17:52 KST 2017 |
The Following 2 Users Say Thank You to helpdesk1 For This Useful Post: |
07-31-2018, 18:37 | #2 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
and post full log with write files eMMC info is not a log | |
08-02-2018, 09:00 | #3 (permalink) |
Freak Poster Join Date: Apr 2008 Location: gsmworld
Member: 757297 Status: Offline Thanks Meter: 36 | Sm-j250f dead boot problam. HI SM-J250F DEAD BOOT REPAIR ALL PROSESS DONE BUT STIL PROBLAM NOT SOLVE. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Writing BackupGPT at address: 0003AB3FBE00 Writing PIT at address: 000000004400 GPT-partitioning done Unpacking file: sbl1.mbn Unpacking file: aboot.mbn Unpacking file: rpm.mbn Unpacking file: tz.mbn Unpacking file: devcfg.mbn Unpacking file: sec.dat Unpacking file: keymaster.mbn Unpacking file: cmnlib.mbn Unpacking file: lksecapp.mbn Unpacking file: apdp.mbn Unpacking file: msadp.mbn Unpacking file: boot.img Unpacking file: recovery.img Unpacking file: persist.img.ext4 Unpacking file: adspso.bin Unpacking file: modem.bin Unpacking file: non-hlos.bin Unpacking file: system.img.ext4 Unpacking file: cache.img.ext4 Unpacking file: hidden.img.ext4 Unpacking file: userdata.img.ext4 Partition name: SBL1 Filename: sbl1.mbn , Offset: 000000400000 , filesize: 380100 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 476.81 KB/s Partition name: ABOOT Filename: aboot.mbn , Offset: 000000510000 , filesize: 1195364 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 921.23 KB/s Partition name: RPM Filename: rpm.mbn , Offset: 000000710000 , filesize: 218656 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 812.75 KB/s Partition name: TZ Filename: tz.mbn , Offset: 000000790000 , filesize: 1572352 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 926.29 KB/s Partition name: DEVCFG Filename: devcfg.mbn , Offset: 000000A10000 , filesize: 94428 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 719.09 KB/s Partition name: SEC Filename: sec.dat , Offset: 000000D50000 , filesize: 692 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 74.31 KB/s Partition name: KEYMASTER Filename: keymaster.mbn , Offset: 000000D54000 , filesize: 259032 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 868.26 KB/s Partition name: CMNLIB Filename: cmnlib.mbn , Offset: 000000DD4000 , filesize: 238496 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 838.79 KB/s Partition name: LKSECAPP Filename: lksecapp.mbn , Offset: 000000E54000 , filesize: 270944 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 859.26 KB/s Partition name: APDP Filename: apdp.mbn , Offset: 000000ED4000 , filesize: 46272 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 603.73 KB/s Partition name: MSADP Filename: msadp.mbn , Offset: 000000F14000 , filesize: 46272 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 684.47 KB/s Partition name: BOOT Filename: boot.img , Offset: 000002E00000 , filesize: 14289168 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 936.35 KB/s Partition name: RECOVERY Filename: recovery.img , Offset: 000004E00000 , filesize: 15868176 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 937.49 KB/s Partition name: PERSIST Filename: persist.img.ext4 , Offset: 000008301000 , filesize: 4743292 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 8 Done writing partition. Write speed: 933.50 KB/s Partition name: DSP Filename: adspso.bin , Offset: 00000ADE9000 , filesize: 16777216 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 938.91 KB/s Partition name: MODEM Filename: modem.bin , Offset: 00000BDE9000 , filesize: 63216384 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 939.74 KB/s Partition name: APNHLOS Filename: non-hlos.bin , Offset: 000011980000 , filesize: 25401088 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 936.81 KB/s Partition name: SYSTEM Filename: system.img.ext4 , Offset: 000013800000 , filesize: 2873971904 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 4195 Error: Previous operation is not finished yet. Done writing partition. Write speed: 931.81 KB/s Partition name: CACHE Filename: cache.img.ext4 , Offset: 0000E5000000 , filesize: 110289116 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 16 Done writing partition. Write speed: 938.56 KB/s Partition name: HIDDEN Filename: hidden.img.ext4 , Offset: 0000F1800000 , filesize: 30503216 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 23 Done writing partition. Write speed: 935.72 KB/s Partition name: USERDATA Filename: userdata.img.ext4 , Offset: 0000F5400000 , filesize: 861674848 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 283 Done writing partition. Write speed: 939.41 KB/s Partition EFS : formatting as EXT4. Please wait ... Formatting completed Check BOOT_PARTITION_EN for the selected vendor All done time: [01:23:26:908] Setting frequence to 21 Mhz CMD Pullup Level: 2021 mV CMD Active Level: 2320 mV EMMC Device Information : EMMC CID: 150100514536364D4200B130D0B5151C EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QE66MB , HEX: 514536364D42 , S/N:******* , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 1/2018 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QE66MB_B130D0B5_20180802_104434.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: sbl1, [000000400000 - 000000480000], size: 000000080000 (512. KB) Partition: sbl1bak, [000000480000 - 000000500000], size: 000000080000 (512. KB) Partition: ddr, [000000500000 - 000000508000], size: 000000008000 (32.0 KB) Partition: limits, [000000508000 - 000000510000], size: 000000008000 (32.0 KB) Partition: aboot, [000000510000 - 000000710000], size: 000000200000 (2.00 MB) Partition: rpm, [000000710000 - 000000790000], size: 000000080000 (512. KB) Partition: tz, [000000790000 - 000000990000], size: 000000200000 (2.00 MB) Partition: hyp, [000000990000 - 000000A10000], size: 000000080000 (512. KB) Partition: devcfg, [000000A10000 - 000000A50000], size: 000000040000 (256. KB) Partition: fsg, [000000A50000 - 000000D50000], size: 000000300000 (3.00 MB) Partition: sec, [000000D50000 - 000000D54000], size: 000000004000 (16.0 KB) Partition: keymaster, [000000D54000 - 000000DD4000], size: 000000080000 (512. KB) Partition: cmnlib, [000000DD4000 - 000000E14000], size: 000000040000 (256. KB) Partition: cmnlib64, [000000E14000 - 000000E54000], size: 000000040000 (256. KB) Partition: lksecapp, [000000E54000 - 000000ED4000], size: 000000080000 (512. KB) Partition: apdp, [000000ED4000 - 000000F14000], size: 000000040000 (256. KB) Partition: msadp, [000000F14000 - 000000F54000], size: 000000040000 (256. KB) Partition: pad, [000000F54000 - 000001000000], size: 0000000AC000 (688. KB) Partition: modemst1, [000001000000 - 000001300000], size: 000000300000 (3.00 MB) Partition: modemst2, [000001300000 - 000001600000], size: 000000300000 (3.00 MB) Partition: param, [000001600000 - 000002000000], size: 000000A00000 (10.0 MB) Partition: efs, [000002000000 - 000002E00000], size: 000000E00000 (14.0 MB) Partition: boot, [000002E00000 - 000004E00000], size: 000002000000 (32.0 MB) Partition: recovery, [000004E00000 - 000006E00000], size: 000002000000 (32.0 MB) Partition: bota, [000006E00000 - 000007500000], size: 000000700000 (7.00 MB) Partition: fota, [000007500000 - 000007A00400], size: 000000500400 (5.00 MB) Partition: backup, [000007A00400 - 000007FFF000], size: 0000005FEC00 (6.00 MB) Partition: fsc, [000007FFF000 - 0000082FF000], size: 000000300000 (3.00 MB) Partition: ssd, [0000082FF000 - 000008301000], size: 000000002000 (8.00 KB) Partition: persist, [000008301000 - 00000A301000], size: 000002000000 (32.0 MB) Partition: persistent, [00000A301000 - 00000A381000], size: 000000080000 (512. KB) Partition: steady, [00000A381000 - 00000A781000], size: 000000400000 (4.00 MB) Partition: keystore, [00000A781000 - 00000A801000], size: 000000080000 (512. KB) Partition: config, [00000A801000 - 00000A809000], size: 000000008000 (32.0 KB) Partition: mota, [00000A809000 - 00000A889000], size: 000000080000 (512. KB) Partition: dpo, [00000A889000 - 00000A8C9000], size: 000000040000 (256. KB) Partition: mdtp, [00000A8C9000 - 00000A8D9000], size: 000000010000 (64.0 KB) Partition: dip, [00000A8D9000 - 00000A9D9000], size: 000000100000 (1.00 MB) Partition: oem, [00000A9D9000 - 00000A9E9000], size: 000000010000 (64.0 KB) Partition: mcfg, [00000A9E9000 - 00000ADE9000], size: 000000400000 (4.00 MB) Partition: dsp, [00000ADE9000 - 00000BDE9000], size: 000001000000 (16.0 MB) Partition: modem, [00000BDE9000 - 000011980000], size: 000005B97000 (91.5 MB) Partition: apnhlos, [000011980000 - 000013580000], size: 000001C00000 (28.0 MB) Partition: reserved2, [000013580000 - 000013800000], size: 000000280000 (2.50 MB) Partition: system, [000013800000 - 0000E5000000], size: 0000D1800000 (3.27 GB) Partition: cache, [0000E5000000 - 0000F1800000], size: 00000C800000 (200. MB) Partition: hidden, [0000F1800000 - 0000F5400000], size: 000003C00000 (60.0 MB) Partition: userdata, [0000F5400000 - 0003AB3FBE00], size: 0002B5FFBE00 (10.8 GB) GPT header successfully parsed Get firmware version Brand = samsung Manufacturer = samsung Model = SM-J250F Phone platform = msm8937 CPU Abi = armeabi-v7a Android release = 7.1.1 Firmware version = NMF26X.J250FXXS2ARE1 Firmware date = Thu May 24 17:01:21 KST 2018 |
08-02-2018, 09:23 | #4 (permalink) |
Member: 757297 Status: Offline Thanks Meter: 36 | j250f dead boot done but not power on I ALSO CHANE CPU CONFIG BUT STILL SAME. Compression is ON Z3X EasyJtag Software ver. 3.0.0.0 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 0C0C17118AA3D768, ,FW Ver.: 01.63 CMD Pullup Level:2031 mV CMD Active Level:2310 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100514536364D4200B130D0B5151C eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 01/2018 Rev.0x0 eMMC NAME: QE66MB , S/N: ************* eMMC NAME (HEX): 514536364D42 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: QE66MB_2972766389_20180802_1120.extcsd Partition table scan: GPT: present Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 1D5A000 sectors 14.7 GiB Soft (Partitioned) Disk/Image size: 1D59FBC sectors 14.7 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 First usable sector: 34 Last usable sector: 30777310 Found Data areas (firmware parts) count is: 48 Partition info successfully found --------------------------------------------- P0 (SBL1) [0x400000 0x80000] Size: 512.0KB P1 (SBL1BAK) [0x480000 0x80000] Size: 512.0KB P2 (DDR) [0x500000 0x8000] Size: 32.0KB P3 (LIMITS) [0x508000 0x8000] Size: 32.0KB P4 (ABOOT) [0x510000 0x200000] Size: 2.0MB P5 (RPM) [0x710000 0x80000] Size: 512.0KB P6 (TZ) [0x790000 0x200000] Size: 2.0MB P7 (HYP) [0x990000 0x80000] Size: 512.0KB P8 (DEVCFG) [0xa10000 0x40000] Size: 256.0KB P9 (FSG) [0xa50000 0x300000] Size: 3.0MB P10 (SEC) [0xd50000 0x4000] Size: 16.0KB P11 (KEYMASTER) [0xd54000 0x80000] Size: 512.0KB P12 (CMNLIB) [0xdd4000 0x40000] Size: 256.0KB P13 (CMNLIB64) [0xe14000 0x40000] Size: 256.0KB P14 (LKSECAPP) [0xe54000 0x80000] Size: 512.0KB P15 (APDP) [0xed4000 0x40000] Size: 256.0KB P16 (MSADP) [0xf14000 0x40000] Size: 256.0KB P17 (PAD) [0xf54000 0xac000] Size: 688.0KB P18 (MODEMST1) [0x1000000 0x300000] Size: 3.0MB P19 (MODEMST2) [0x1300000 0x300000] Size: 3.0MB P20 (PARAM) [0x1600000 0xa00000] Size: 10.0MB P21 (EFS) [0x2000000 0xe00000] Size: 14.0MB P22 (BOOT) [0x2e00000 0x2000000] Size: 32.0MB P23 (RECOVERY) [0x4e00000 0x2000000] Size: 32.0MB P24 (BOTA) [0x6e00000 0x700000] Size: 7.0MB P25 (FOTA) [0x7500000 0x500400] Size: 5.0MB P26 (BACKUP) [0x7a00400 0x5fec00] Size: 5.995MB P27 (FSC) [0x7fff000 0x300000] Size: 3.0MB P28 (SSD) [0x82ff000 0x2000] Size: 8.0KB P29 (PERSIST) [0x8301000 0x2000000] Size: 32.0MB P30 (PERSISTENT) [0xa301000 0x80000] Size: 512.0KB P31 (STEADY) [0xa381000 0x400000] Size: 4.0MB P32 (KEYSTORE) [0xa781000 0x80000] Size: 512.0KB P33 (CONFIG) [0xa801000 0x8000] Size: 32.0KB P34 (MOTA) [0xa809000 0x80000] Size: 512.0KB P35 (DPO) [0xa889000 0x40000] Size: 256.0KB P36 (MDTP) [0xa8c9000 0x10000] Size: 64.0KB P37 (DIP) [0xa8d9000 0x100000] Size: 1.0MB P38 (OEM) [0xa9d9000 0x10000] Size: 64.0KB P39 (MCFG) [0xa9e9000 0x400000] Size: 4.0MB P40 (DSP) [0xade9000 0x1000000] Size: 16.0MB P41 (MODEM) [0xbde9000 0x5b97000] Size: 91.589MB P42 (APNHLOS) [0x11980000 0x1c00000] Size: 28.0MB P43 (RESERVED2) [0x13580000 0x280000] Size: 2.500MB P44 (SYSTEM) [0x13800000 0xd1800000] Size: 3.273GB P45 (CACHE) [0xe5000000 0xc800000] Size: 200.0MB P46 (HIDDEN) [0xf1800000 0x3c00000] Size: 60.0MB P47 (USERDATA) [0xf5400000 0x2b5ffbe00] Size: 10.842GB ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0013800000 (3.273GB) Build ID: NMF26X Display Build ID: NMF26X.J250FXXS2ARE1 Release ID: 7.1.1 Device Model: SM-J250F Product ID: j2y18lte Device Name: j2y18ltejx Architecture ABI: armeabi-v7a Device manufacturer: samsung Device Platform: msm8937 Build Description: j2y18ltejx-user 7.1.1 NMF26X J250FXXS2ARE1 release-keys Samsung CPU: MSM8937 --------------------------------------------- Done. |
