01-27-2022, 18:13 | #1 (permalink) |
No Life Poster Join Date: Jul 2013 Location: in my company
Member: 1984825 Status: Offline Thanks Meter: 222 | Remove password oppo a7 with easy king OS ver.: Windows 10 (build 19044), 64-bit edition. Admin rights FAIL Autorun Agent ver:1.0.0.0 Crash Reporting ver:1.4.0.3 EasyJTAG SPI Plugin ver:1.1.1.13 Android ADB API ver:2.0.0.0 FTDI API ver:3.2.4.0 LibUSB API ver:1.2.6.0 Visual C++ Runtime ver:10.0.30319.1 Setting box Pinout ... Box Drivers version: 10.0.19041.1202 Z3X Card Serial : AAC7-581A , ver: 22 Z3X Card Activation [JTAGPLUS] : ACTIVATED Z3X Card Activation [LG] : NOT ACTIVATED Z3X Card Activation [SAMS] : NOT ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED For more information press F1 to open local help or visit our wiki Found 4 serial devices COM30 USB\VID_1781&PID_AAAC&REV_0100&MI_00 Périphérique série USB (COM30) COM3 Intel(R) Active Management Technology - SOL (COM3) COM22 root\rimports RIM Virtual Serial Port v2 (COM22) COM23 root\rimports RIM Virtual Serial Port v2 (COM23) Selected pinout: GEN2 High Speed Pinout Change EasyJTAG Pinout OK Setting box Pinout ... Selected pinout: GEN2 ISP Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.7.0.24 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: 00000000000000, ,FW Ver.: 02.53 CMD Pullup Level:869 mV CMD Active Level:1967 mV Box IO Level:2800 mV CLK Rate:24000 kHz Bus Width:1bit,SDR HiPower mode is off! Can't init device, Reason: CMD Timeout Error Done. Z3X EasyJtag Software ver. 3.7.0.24 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: 0000000000000000, ,FW Ver.: 02.53 CMD Pullup Level:2127 mV CMD Active Level:2340 mV Box IO Level:2800 mV CLK Rate:24000 kHz Bus Width:1bit,SDR HiPower mode is off! Can't init device, Reason: CMD Timeout Error Done. Z3X EasyJtag Software ver. 3.7.0.24 Loading eMMC GEN2 Firmware... IO: 1800 mV Box S/N: 000000000000E384, ,FW Ver.: 02.53 CMD Pullup Level:1867 mV CMD Active Level:1862 mV Box IO Level:1800 mV CLK Rate:24000 kHz Bus Width:1bit,SDR HiPower mode is off! Can't init device, Reason: CMD Timeout Error Done. Z3X EasyJtag Software ver. 3.7.0.24 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: 0000000000000000, ,FW Ver.: 02.53 CMD Pullup Level:2127 mV CMD Active Level:2354 mV Box IO Level:2800 mV CLK Rate:24000 kHz Bus Width:1bit,SDR HiPower mode is off! Can't init device, Reason: CMD Timeout Error Done. Z3X EasyJtag Software ver. 3.7.0.24 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: 00000000000004, ,FW Ver.: 02.53 CMD Pullup Level:2128 mV CMD Active Level:2354 mV Box IO Level:2800 mV CLK Rate:24000 kHz Bus Width:1bit,SDR HiPower mode is off! Can't init device, Reason: CMD Timeout Error Done. Z3X EasyJtag Software ver. 3.7.0.24 Loading eMMC GEN2 Firmware... IO: 3000 mV Box S/N: 00000000000004, ,FW Ver.: 02.53 CMD Pullup Level:2139 mV CMD Active Level:2521 mV Box IO Level:3000 mV CLK Rate:24000 kHz Bus Width:1bit,SDR HiPower mode is off! Can't init device, Reason: CMD Timeout Error Done. Z3X EasyJtag Software ver. 3.7.0.24 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: 000000000000000, ,FW Ver.: 02.53 CMD Pullup Level:2128 mV CMD Active Level:2355 mV Box IO Level:2800 mV CLK Rate:36000 kHz Bus Width:1bit,SDR HiPower mode is off! Can't init device, Reason: CMD Timeout Error Done. Z3X EasyJtag Software ver. 3.7.0.24 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: 000000000000, ,FW Ver.: 02.53 CMD Pullup Level:358 mV CMD Active Level:1027 mV Box IO Level:2800 mV CLK Rate:36000 kHz Bus Width:1bit,SDR HiPower mode is off! Can't init device, Reason: CMD Timeout Error Done. Z3X EasyJtag Software ver. 3.7.0.24 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: 000000000000000, ,FW Ver.: 02.53 CMD Pullup Level:2105 mV CMD Active Level:2268 mV Box IO Level:2800 mV CLK Rate:36000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100524836344142055B1C9A15B5EF eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 11/2018 Rev.0x5 eMMC NAME: RH64AB , S/N: 1528601109 eMMC NAME (HEX): 524836344142 IC Name: Samsung , KMRH60014A-B614 , Firmware is Updatable EMMC ROM1 (Main User Data) Capacity: 59640 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 62163 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: RH64AB_1528601109_20220127_1730.extcsd The protective MBR's 0xEE partition is oversized! Auto-repairing. Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB Soft (Partitioned) Disk/Image size: 747BFBC sectors 58.2 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,122142686 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x003E800000 (3.968GB) Short EXT fs info: Size: 3.905GB Block size: 4.0KB Inode size: 256 Inodes: 256000 Short Android info: Build ID: OPM1.171019.026 Release Base ID: 8.1.0 Security Path: 2021-03-05 Architecture ABI: arm64-v8a Device manufacturer: OPPO Build Description: msm8953_64-user 8.1.0 OPM1.171019.026 eng.root.20210307.122638 release-keys Backup saved: BuildProp_20220127_1730.txt --------------------------------------------- Detected USERDATA USERDATA : 0x017E800000 (52.264GB) Unable to mount USERDATA , code : 95 Userdata Superblock contents:: DCDD263B 909B6A7E 2CEE5D62 F1987696 2C8A5E92 14F00DB4 EBD489F3 CEC1BA8B ÜÝ&;.›j~,î]bñ.v–,Š^’.ð.´ëÔ‰óÎÁº‹; 1C03BBB8 9BB6A4CF D899C079 2A43FDA1 67C15403 FAD3A464 1EF84D51 D626EC19 ..»¸›¶¤ÏØ.Ày*Cý¡gÁT.úÓ¤d.øMQÖ&ì.; D44CD5FC DEDF8B9D 75E3275D 15124422 B44DAFC4 ADC157EC 7DD5818A 8EC81B61 ÔLÕüÞß‹.uã']..D"´M¯Ä*ÁWì}Õ.ŠŽÈ.a; D96384F0 BAD1C1E7 C76D70F9 CEBEDDEC D44A4C4E 7B4689E9 BC67290C 82588A4A Ùc„ðºÑÁçÇmpùξÝìÔJLN{F‰é¼g).‚XŠJ; D1602025 9AE2AF20 59E76E2C 743325DD CFCABE98 1662E596 C2833C90 3AC5ADF0 Ñ` %šâ¯ Yçn,t3%ÝÏʾ..bå–ƒ<.:Å*ð; 2803CC26 61CF2372 08110D51 25E64E63 E82FCB3C 6E4C150D 077F56CD ECD11D9E (.Ì&aÏ#r...Q%æNcè/Ë<nL....VÍìÑ.ž; 50C876AD 23722367 C575AF94 8A391CD3 AFCF68D0 A459C511 F4BE055C B341D04D PÈv*#r#gÅu¯”Š9.Ó¯ÏhФYÅ.ô¾.\³AÐM; DF54318D 117F67B6 0362AA39 BA0A0BA6 95691B82 4313EED7 600C7AE1 5C628EA9 ßT1...g¶.bª9º..¦•i.‚C.î×`.zá\bŽ©; Done. Z3X EasyJtag Software ver. 3.7.0.24 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: 000000000000000, ,FW Ver.: 02.53 CMD Pullup Level:2106 mV CMD Active Level:2348 mV Box IO Level:2800 mV CLK Rate:36000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100524836344142055B1C9A15B5EF eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 11/2018 Rev.0x5 eMMC NAME: RH64AB , S/N: 1528601109 eMMC NAME (HEX): 524836344142 IC Name: Samsung , KMRH60014A-B614 , Firmware is Updatable EMMC ROM1 (Main User Data) Capacity: 59640 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 62163 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: RH64AB_1528601109_20220127_1732.extcsd The protective MBR's 0xEE partition is oversized! Auto-repairing. Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB Soft (Partitioned) Disk/Image size: 747BFBC sectors 58.2 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,122142686 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x003E800000 (3.968GB) Short EXT fs info: Size: 3.905GB Block size: 4.0KB Inode size: 256 Inodes: 256000 Short Android info: Build ID: OPM1.171019.026 Release Base ID: 8.1.0 Security Path: 2021-03-05 Architecture ABI: arm64-v8a Device manufacturer: OPPO Build Description: msm8953_64-user 8.1.0 OPM1.171019.026 eng.root.20210307.122638 release-keys Backup saved: BuildProp_20220127_1732.txt --------------------------------------------- Detected USERDATA USERDATA : 0x017E800000 (52.264GB) Unable to mount USERDATA , code : 95 Userdata Superblock contents:: DCDD263B 909B6A7E 2CEE5D62 F1987696 2C8A5E92 14F00DB4 EBD489F3 CEC1BA8B ÜÝ&;.›j~,î]bñ.v–,Š^’.ð.´ëÔ‰óÎÁº‹; 1C03BBB8 9BB6A4CF D899C079 2A43FDA1 67C15403 FAD3A464 1EF84D51 D626EC19 ..»¸›¶¤ÏØ.Ày*Cý¡gÁT.úÓ¤d.øMQÖ&ì.; D44CD5FC DEDF8B9D 75E3275D 15124422 B44DAFC4 ADC157EC 7DD5818A 8EC81B61 ÔLÕüÞß‹.uã']..D"´M¯Ä*ÁWì}Õ.ŠŽÈ.a; D96384F0 BAD1C1E7 C76D70F9 CEBEDDEC D44A4C4E 7B4689E9 BC67290C 82588A4A Ùc„ðºÑÁçÇmpùξÝìÔJLN{F‰é¼g).‚XŠJ; D1602025 9AE2AF20 59E76E2C 743325DD CFCABE98 1662E596 C2833C90 3AC5ADF0 Ñ` %šâ¯ Yçn,t3%ÝÏʾ..bå–ƒ<.:Å*ð; 2803CC26 61CF2372 08110D51 25E64E63 E82FCB3C 6E4C150D 077F56CD ECD11D9E (.Ì&aÏ#r...Q%æNcè/Ë<nL....VÍìÑ.ž; 50C876AD 23722367 C575AF94 8A391CD3 AFCF68D0 A459C511 F4BE055C B341D04D PÈv*#r#gÅu¯”Š9.Ó¯ÏhФYÅ.ô¾.\³AÐM; DF54318D 117F67B6 0362AA39 BA0A0BA6 95691B82 4313EED7 600C7AE1 5C628EA9 ßT1...g¶.bª9º..¦•i.‚C.î×`.zá\bŽ©; Done. Checking security ... Z3X EasyJtag Software ver. 3.7.0.24 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: 00000000000000, ,FW Ver.: 02.53 CMD Pullup Level:2105 mV CMD Active Level:2349 mV Box IO Level:2800 mV CLK Rate:36000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100524836344142055B1C9A15B5EF eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 11/2018 Rev.0x5 eMMC NAME: RH64AB , S/N: 1528601109 eMMC NAME (HEX): 524836344142 IC Name: Samsung , KMRH60014A-B614 , Firmware is Updatable EMMC ROM1 (Main User Data) Capacity: 59640 MB , 0x747C000 pages , 0xE8F800000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 62163 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Writing Recovery Command to MISC Done. Checking security ... Z3X EasyJtag Software ver. 3.7.0.24 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: 0000000000000000, ,FW Ver.: 02.53 CMD Pullup Level:2108 mV CMD Active Level:2351 mV Box IO Level:2800 mV CLK Rate:36000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100524836344142055B1C9A15B5EF eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 11/2018 Rev.0x5 eMMC NAME: RH64AB , S/N: 1528601109 eMMC NAME (HEX): 524836344142 IC Name: Samsung , KMRH60014A-B614 , Firmware is Updatable EMMC ROM1 (Main User Data) Capacity: 59640 MB , 0x747C000 pages , 0xE8F800000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 62163 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Writing Recovery Command to MISC Done. Z3X EasyJtag Software ver. 3.7.0.24 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: 000000000000000, ,FW Ver.: 02.53 CMD Pullup Level:2106 mV CMD Active Level:2349 mV Box IO Level:2800 mV CLK Rate:36000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100524836344142055B1C9A15B5EF eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 11/2018 Rev.0x5 eMMC NAME: RH64AB , S/N: 1528601109 eMMC NAME (HEX): 524836344142 IC Name: Samsung , KMRH60014A-B614 , Firmware is Updatable EMMC ROM1 (Main User Data) Capacity: 59640 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 62163 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: RH64AB_1528601109_20220127_1733.extcsd The protective MBR's 0xEE partition is oversized! Auto-repairing. Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB Soft (Partitioned) Disk/Image size: 747BFBC sectors 58.2 GiB Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,122142686 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x003E800000 (3.968GB) Short EXT fs info: Size: 3.905GB Block size: 4.0KB Inode size: 256 Inodes: 256000 Short Android info: Build ID: OPM1.171019.026 Release Base ID: 8.1.0 Security Path: 2021-03-05 Architecture ABI: arm64-v8a Device manufacturer: OPPO Build Description: msm8953_64-user 8.1.0 OPM1.171019.026 eng.root.20210307.122638 release-keys Backup saved: BuildProp_20220127_1733.txt --------------------------------------------- Detected USERDATA USERDATA : 0x017E800000 (52.264GB) Unable to mount USERDATA , code : 95 Userdata Superblock contents:: DCDD263B 909B6A7E 2CEE5D62 F1987696 2C8A5E92 14F00DB4 EBD489F3 CEC1BA8B ÜÝ&;.›j~,î]bñ.v–,Š^’.ð.´ëÔ‰óÎÁº‹; 1C03BBB8 9BB6A4CF D899C079 2A43FDA1 67C15403 FAD3A464 1EF84D51 D626EC19 ..»¸›¶¤ÏØ.Ày*Cý¡gÁT.úÓ¤d.øMQÖ&ì.; D44CD5FC DEDF8B9D 75E3275D 15124422 B44DAFC4 ADC157EC 7DD5818A 8EC81B61 ÔLÕüÞß‹.uã']..D"´M¯Ä*ÁWì}Õ.ŠŽÈ.a; D96384F0 BAD1C1E7 C76D70F9 CEBEDDEC D44A4C4E 7B4689E9 BC67290C 82588A4A Ùc„ðºÑÁçÇmpùξÝìÔJLN{F‰é¼g).‚XŠJ; D1602025 9AE2AF20 59E76E2C 743325DD CFCABE98 1662E596 C2833C90 3AC5ADF0 Ñ` %šâ¯ Yçn,t3%ÝÏʾ..bå–ƒ<.:Å*ð; 2803CC26 61CF2372 08110D51 25E64E63 E82FCB3C 6E4C150D 077F56CD ECD11D9E (.Ì&aÏ#r...Q%æNcè/Ë<nL....VÍìÑ.ž; 50C876AD 23722367 C575AF94 8A391CD3 AFCF68D0 A459C511 F4BE055C B341D04D PÈv*#r#gÅu¯”Š9.Ó¯ÏhФYÅ.ô¾.\³AÐM; DF54318D 117F67B6 0362AA39 BA0A0BA6 95691B82 4313EED7 600C7AE1 5C628EA9 ßT1...g¶.bª9º..¦•i.‚C.î×`.zá\bŽ©; Done. |
