02-19-2018, 17:58 | #2 (permalink) |
No Life Poster Join Date: Oct 2009 Location: Rajasthan INDIA
Member: 1147254 Status: Offline Sonork: 100.1620677 Thanks Meter: 639 | Just flash With Latest BL File if problem Not Solve Write Latest Latest Flash File With BL, AP, CP, CSC if problem Not Solve Contact Me On Sonork |
02-19-2018, 20:47 | #3 (permalink) |
Crazy Poster Join Date: Oct 2016
Member: 2642997 Status: Offline Thanks Meter: 4 | i try to make JTAG operation because the phone is dead in flash operation,but the log info shows that the GPT partition is not present so how can i restore the GPT partion table? |
02-20-2018, 13:38 | #7 (permalink) | |
Member: 2642997 Status: Offline Thanks Meter: 4 | Quote:
i flash pit file but the issue is not solved Operation: Try to read table from emmc Vendor: Samsung Searching GPT ... GPT header is not found Partition table not found any suggestion please? | |
02-20-2018, 19:47 | #8 (permalink) | |
Member: 1147254 Status: Offline Sonork: 100.1620677 Thanks Meter: 639 | Quote:
& Give Full Info With Screen Shot | |
02-20-2018, 21:07 | #9 (permalink) |
Member: 2642997 Status: Offline Thanks Meter: 4 | Here is the full log: eMMC_tool Suite ver. 1.4.8.0 Microsoft Windows 7 (32 bit) build 7601 (6.1.7600.16385) Looking for EasyJTAG box... EasyJTAG API ver. 2008 Setting IO Levels to 2.8V Setting frequence to 14 Mhz HiPower mode is OFF EasyJTAG Box Serial = 01FFE00D8FE1587C Card Serial = AAA5-808E EasyJTAG Box Firmware = 01.62 Changelog: 08.08.2017 (ver 1.4.8.0) Fix: Bugs that have been found through your crash report Fix: Saving VCF for contacts Add: Multiple file selection for Samsung firmware Add: Write full Extcsd or write only the boot configuration ("Repair Extcsd" button) Add: Intel vendor (for easy read/write ROM2/ROM3/GP1) Add: "Pinouts" tab (taken from the catalog of classic software) Add: Checker for Sony TrimArea Add: Speed graph for "Random verify emmc" Add: Fat16/Fat32/exFat support (Explorer) HiPower mode is OFF Frequence: 14 Mhz CMD Pullup Level: 1773 mV CMD Active Level: 2516 mV EMMC Device Information : EMMC CID: 90014A483447326211014467811652F6 EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacture Name: SKHYNIX EMMC Manufacture ID: 0x90 , OEM ID: 014A EMMC Manufacture Date: 5/2015 , Rev: 01 EMMC NAME: H4G2b , S/N: 44678116 , rev. 01 EMMC NAME (HEX): 483447326211 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H4G2b_44678116_20180220_194142.extcsd EMMC Init completed. Opening file: J13G.pit Pit: J13G.pit Entry count: 29 The size of the last section has been updated J100HXXU0AOA1_J100HLUX0AOA1_J100HXXU0AOA2_Home.tar .md5 The list of files in the firmware: spl.img sboot.bin sboot2.bin boot.img recovery.img system.img sprdcp.img sprddsp.img cache.img hidden.img HiPower mode is OFF Frequence: 14 Mhz CMD Pullup Level: 1773 mV CMD Active Level: 2516 mV EMMC Device Information : EMMC CID: 90014A483447326211014467811652F6 EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacture Name: SKHYNIX EMMC Manufacture ID: 0x90 , OEM ID: 014A EMMC Manufacture Date: 5/2015 , Rev: 01 EMMC NAME: H4G2b , S/N: 44678116 , rev. 01 EMMC NAME (HEX): 483447326211 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H4G2b_44678116_20180220_194156.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Error writing at address: 000000000000 ... Retry #1 Error writing at address: 000000000000 ... Retry #2 Error writing at address: 000000000000 ... Retry #3 Writing PIT at address: 000000080000 GPT-partitioning done Unpacking file: spl.img Unpacking file: sboot.bin Unpacking file: sboot2.bin Unpacking file: sprddsp.img Unpacking file: sprdcp.img Unpacking file: boot.img Unpacking file: recovery.img Unpacking file: cache.img Unpacking file: system.img Unpacking file: hidden.img Partition name: BOOT Filename: spl.img , Offset: 000000000000 , filesize: 32768 bytes eMMC switching to ROM2 Erasing partition... Writing partition... Done writing partition. Write speed: 315,79 Kb/s Partition name: SBOOT Filename: sboot.bin , Offset: 000000400000 , filesize: 1573888 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1157,70 Kb/s Partition name: SBOOT2 Filename: sboot2.bin , Offset: 000000600000 , filesize: 1573888 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1154,50 Kb/s Partition name: WDSP Filename: sprddsp.img , Offset: 000000C00000 , filesize: 1968128 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1225,55 Kb/s Partition name: MODEM Filename: sprdcp.img , Offset: 000001000000 , filesize: 7375844 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 869,46 Kb/s Partition name: KERNEL Filename: boot.img , Offset: 000004500000 , filesize: 5663744 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 876,16 Kb/s Partition name: RECOVERY Filename: recovery.img , Offset: 000005500000 , filesize: 6994944 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 879,27 Kb/s Partition name: CSC Filename: cache.img , Offset: 000006500000 , filesize: 19312912 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 15 Done writing partition. Write speed: 1017,59 Kb/s Partition name: SYSTEM Filename: system.img , Offset: 000012D00000 , filesize: 955488064 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 1650 Error writing at address: 00002F988000 ... Retry #1 Error writing at address: 0000447DA000 ... Retry #1 Error writing at address: 00004B382000 ... Retry #1 Done writing partition. Write speed: 839,38 Kb/s Partition name: HIDDEN Filename: hidden.img , Offset: 000053D00000 , filesize: 7762160 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 13 Done writing partition. Write speed: 1195,02 Kb/s All done |
02-21-2018, 06:26 | #10 (permalink) | |
After Write All Files Give Detect Info | |
06-11-2021, 22:09 | #11 (permalink) |
No Life Poster Join Date: Feb 2003 Location: africa Age: 54
Member: 22284 Status: Offline Thanks Meter: 81 | Me too i have the same message on a8 2018 SM-A530FD 32GB Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 24 MHz CMD Pullup Level: 434 mV CMD Active Level: 1370 mV EMMC Device Information : EMMC CID: 150100424A54443452000684ECE174F9 EMMC CSD: 902701320F5903FFF6DB7FE08A40403B EMMC Manufacture : SAMSUNG , EMMC NAME: BJTD4R , HEX: 424A54443452 , S/N: 0684ECE1 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 7/2017 EMMC ROM 1 (Main User Data) Capacity: 29804 MB (000746C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 0 KB (000000000000) EMMC RPMB (Replay Protected Memory Block) Capacity: 0 KB (000000000000) Counter: 0 , Response: Maybe not clean EMMC GP1 (GP Partition 1) Capacity: 8 MB , WR_REL (000000800000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: BJTD4R_0684ECE1_20210611_230553.extcsd EMMC Init completed. Scanning soft partitions Error reading at address: 000000000000 , error: -4, DATA RCV CRC Error ... Retry #1 Error reading at address: 000000000000 , error: -4, DATA RCV CRC Error ... Retry #2 Error reading at address: 000000000000 , error: -4, DATA RCV CRC Error ... Retry #3 Error reading at address: 000000000000 , error: -4, DATA RCV CRC Error ... Retry #4 Error reading at address: 000000000000 , error: -4, DATA RCV CRC Error ... Retry #5 Too many errors. Reading has been stopped |
06-12-2021, 08:47 | #12 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
try to reflash eMMC firmware, it may be work some time | |
06-12-2021, 09:53 | #13 (permalink) |
Member: 22284 Status: Offline Thanks Meter: 81 | Where to get the eMMC firmware,Below is my chip info ,if anybody has send me Please SEC 846 R041 KLMBG2JETD S7RT5AZTE I have the backup for this this phone but i do not know which file is ROM 1,ROM2,ROM3 and GP1 if anyone can identify from the this picture attached i would appreciate Last edited by chitawira; 06-12-2021 at 10:00. |
06-12-2021, 16:26 | #14 (permalink) | |
06-12-2021, 17:43 | #15 (permalink) |
Member: 22284 Status: Offline Thanks Meter: 81 | i read that data i have before i messed up and now i want to rewrite but i do not know which file to load as Rom 1,2,3 plus GP1 that is why am asking from the attached which are those files? May check this attachment and see what am asking Last edited by chitawira; 06-12-2021 at 17:49. |
