01-31-2014, 14:43 | #1 (permalink) |
No Life Poster Join Date: Mar 2013 Location: Nepal Age: 41
Member: 1906979 Status: Offline Sonork: 100.1681049 Thanks Meter: 162 | Efs collections by easy jtag HOW TO BACKUP EFS FILE PLEASE SEE HERE http://forum.gsmhosting.com/vbb/f672...s-etc-1712891/ USE THANKS BUTTON AND SAVE FORUM SPACE |
The Following 4 Users Say Thank You to KE6SOLTI For This Useful Post: |
02-01-2014, 10:17 | #2 (permalink) |
Member: 1906979 Status: Offline Sonork: 100.1681049 Thanks Meter: 162 | I9000 EFS BACKUP FROM WORKING PHONE BY EASY JTAG. Code: Executing: C:\Program Files\Z3X\EASYJTAG\Scripts\Show_Partitions_NAND_PIT.txt Searching for partition tables... Reading 00400000 bytes from NAND adress 00000000 Found PIT partition table (ver.:1) at 0x40000 Short info about 13 partition(s) MMCBLK0P0 : "IBL+PBL" 00000000 00040000 MMCBLK0P1 : "PIT" 00040000 00040000 MMCBLK0P2 : "EFS" 00080000 00A00000 MMCBLK0P3 : "SBL" 00A80000 00140000 MMCBLK0P4 : "SBL2" 00BC0000 00140000 MMCBLK0P5 : "PARAM" 00D00000 00500000 MMCBLK0P6 : "KERNEL" 01200000 00780000 MMCBLK0P7 : "RECOVERY" 01980000 00780000 MMCBLK0P8 : "FACTORYFS" 02100000 11E80000 MMCBLK0P9 : "DBDATAFS" 13F80000 08600000 MMCBLK0P10 : "CACHE" 1C580000 02300000 MMCBLK0P11 : "MODEM" 1E880000 00C80000 Created helper script 'dump_msm_pit_partitions.txt' for dumping all regions in device Created helper script 'write_msm_pit_partitions.txt' for writing all regions in device Presets list on main window has been updated! OK SAMSUNG_GT-I9000_0x00080000_0x00A00000 efs |
02-01-2014, 10:44 | #3 (permalink) |
Member: 1906979 Status: Offline Sonork: 100.1681049 Thanks Meter: 162 | SAMSUNG M110S EFS BACKUP FROM WORKING PHONE BY EASY JTAG Code: Executing: C:\Program Files\Z3X\EASYJTAG\Scripts\Show_Partitions_NAND_PIT.txt Searching for partition tables... Reading 00400000 bytes from NAND adress 00000000 Found PIT partition table (ver.:1) at 0x40000 Short info about 14 partition(s) MMCBLK0P0 : "IBL+PBL" 00000000 00040000 MMCBLK0P1 : "PIT" 00040000 00040000 MMCBLK0P2 : "EFS" 00080000 00A00000 MMCBLK0P3 : "SBL" 00A80000 00140000 MMCBLK0P4 : "SBL2" 00BC0000 00140000 MMCBLK0P5 : "PARAM" 00D00000 00500000 MMCBLK0P6 : "KERNEL" 01200000 00780000 MMCBLK0P7 : "RECOVERY" 01980000 00780000 MMCBLK0P8 : "FACTORYFS" 02100000 136C0000 MMCBLK0P9 : "DBDATAFS" 157C0000 06A40000 MMCBLK0P10 : "CACHE" 1C200000 02300000 MMCBLK0P11 : "MODEM" 1E500000 01000000 Created helper script 'dump_msm_pit_partitions.txt' for dumping all regions in device Created helper script 'write_msm_pit_partitions.txt' for writing all regions in device Presets list on main window has been updated! OK https://forum.gsmhosting.com/vbb/****************************/?kr561yppa13j9gx |
The Following User Says Thank You to KE6SOLTI For This Useful Post: |
05-01-2014, 06:26 | #7 (permalink) | |
Member: 1906979 Status: Offline Sonork: 100.1681049 Thanks Meter: 162 | I8190 EFS BACKUP DOWNLOAD Quote:
The Following 2 Users Say Thank You to KE6SOLTI For This Useful Post: |
05-20-2014, 11:22 | #10 (permalink) |
Cheater -Don't Deal with him- Join Date: Dec 2013 Location: XK Age: 26
Member: 2089356 Status: Offline Sonork: Threema: 3N5W6VV9 Thanks Meter: 520 | i backed up from samsung tool adb Samsung galaxy S3 mini I8190N https://www.dropbox.com/s/e0gj4da3lj...4_14-20-53.bak |
The Following User Says Thank You to BesfortShalaTec For This Useful Post: |
