05-24-2014, 11:05 | #1 (permalink) |
Freak Poster Join Date: May 2006
Member: 272137 Status: Offline Thanks Meter: 75 | Rom2 can't write 0 kb.... Just change correct rom2/rpmb size if needed Make emmc bootable (set boot config 0x48, boot bus config 0x1) Write rom1 and rom2 partition and phone are ready for odin flashing i have got this problem after repair emmc 0000 to vtu00m smart report normal, but cant write rom2 Z3X EasyJtag Software ver. 1.5.1.0 Loading eMMC Addon Firmware... IO: 1850 mV Box S/N: 16160A05CEC1AAB2, ,FW Ver.: 01.50 CMD Pullup Level:1320 mV CMD Active Level:1773 mV eMMC Device Information EMMC CID : 15010056545530304DF1AD191F706F30 EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 06/2012 Rev.0xf1 EMMC NAME: VTU00M , S/N: 2904104816 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 0 kB EMMC ROM3 (Boot Partition 2) Capacity: 0 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 0 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU00M_2904104816_20140405_1717.extcsd Done. Writing file...D:\z3x jtag repair files\I9300\EMMC_ROM2_00000000_00200000.bin Z3X EasyJtag Software ver. 1.5.1.0 Skip loading eMMC Addon Firmware CMD Pullup Level:1320 mV CMD Active Level:1773 mV Writing 000000200000 bytes to 00000000 ...ROM2 (BOOT1 ROM) Access to current partition forbidden ( size=0 ) Done !!! |
05-24-2014, 11:18 | #2 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,529 | Quote:
you can try repair . but Emmc can dead fully. | |
05-24-2014, 11:37 | #3 (permalink) |
Member: 272137 Status: Offline Thanks Meter: 75 | Repair 0000 to vtum done Many time, before my emmc shows 0000 now after repair it's shows VTUM but rom2 boot partition 0kb ,I guess I done something wrong while I was making boot partition bootable I was confuse to do 0x1 and 0x48 how to do that. |
05-24-2014, 12:01 | #4 (permalink) | |
in your case problem with partition size. and from our experience this cant be solved at this moment. | |
05-25-2014, 06:07 | #7 (permalink) | |
Freak Poster Join Date: May 2014
Member: 2186335 Status: Offline Thanks Meter: 44 | Quote:
couse some time after change boot partition the device either not goes to download mode or stock on logo and cant flash. due to my experience write extcds from working phone if not solve change emmc | |
05-25-2014, 12:17 | #8 (permalink) |
Member: 272137 Status: Offline Thanks Meter: 75 | mostly phone's from 10 out of 8 done via mmc dump after. phone goes in download mode flash with pit and any flash file phone alive ,very rare easyjatg need for boot repair..that's my experience,done nearly 25 phones .22 with mmc dump and 3 with easy jtag. Remember there is certain pit file working You have to check one by one which is working one , This is the only secret is right pit file for flashing to make your phone alive again good luck everyone. |
