10-26-2019, 11:06 | #16 (permalink) | |
No Life Poster Join Date: Nov 2014 Location: Lucknow
Member: 2298369 Status: Offline Thanks Meter: 440 | Quote:
sir can i use this ic it have rpmb partiton 4mb yet above emmc have rpmb 512mb ? Plz reply lyder sir Setting interface to EasyJtag2/E-Socket Setting bus width to 8 Bit Setting frequence to 42 MHz EMMC Device Information : EMMC CID: 150100523331424D4201B499A8C68121 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: R31BMB , HEX: 523331424D42 , S/N: B499A8C6 , rev. 0x01 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 8/2014 EMMC ROM 1 (Main User Data) Capacity: 14910 MB (0003A3E00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: R31BMB_B499A8C6_20191026_153419.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: modem, [000000004400 - 000004004400], size: 000004000000 (64.0 MB) Partition: sbl1, [000004004400 - 000004084400], size: 000000080000 (512. KB) Partition: sbl1bak, [000004084400 - 000004104400], size: 000000080000 (512. KB) Partition: aboot, [000004104400 - 000004204400], size: 000000100000 (1.00 MB) Partition: abootbak, [000004204400 - 000004304400], size: 000000100000 (1.00 MB) Partition: rpm, [000004304400 - 000004384400], size: 000000080000 (512. KB) Partition: rpmbak, [000004384400 - 000004404400], size: 000000080000 (512. KB) Partition: tz, [000004404400 - 000004484400], size: 000000080000 (512. KB) Partition: tzbak, [000004484400 - 000004504400], size: 000000080000 (512. KB) Partition: hyp, [000004504400 - 000004584400], size: 000000080000 (512. KB) Partition: hypbak, [000004584400 - 000004604400], size: 000000080000 (512. KB) Partition: pad, [000004604400 - 000004704400], size: 000000100000 (1.00 MB) Partition: modemst1, [000004704400 - 000004884400], size: 000000180000 (1.50 MB) Partition: modemst2, [000004884400 - 000004A04400], size: 000000180000 (1.50 MB) Partition: misc, [000004A04400 - 000004B04400], size: 000000100000 (1.00 MB) Partition: fsc, [000004B04400 - 000004B04800], size: 000000000400 (1.00 KB) Partition: ssd, [000004B04800 - 000004B06800], size: 000000002000 (8.00 KB) Partition: splash, [000004B06800 - 000005506800], size: 000000A00000 (10.0 MB) Partition: DDR, [000005506800 - 00000550E800], size: 000000008000 (32.0 KB) Partition: fsg, [00000550E800 - 00000568E800], size: 000000180000 (1.50 MB) Partition: sec, [00000568E800 - 000005692800], size: 000000004000 (16.0 KB) Partition: boot, [000005692800 - 000007692800], size: 000002000000 (32.0 MB) Partition: system, [000007692800 - 000067692800], size: 000060000000 (1.50 GB) Partition: persist, [000067692800 - 000069692800], size: 000002000000 (32.0 MB) Partition: cache, [000069692800 - 000079692800], size: 000010000000 (256. MB) Partition: recovery, [000079692800 - 00007B692800], size: 000002000000 (32.0 MB) Partition: devinfo, [00007B692800 - 00007B792800], size: 000000100000 (1.00 MB) Partition: keystore, [00007B792800 - 00007B812800], size: 000000080000 (512. KB) Partition: config, [00007B812800 - 00007B892800], size: 000000080000 (512. KB) Partition: oem, [00007B892800 - 00007F892800], size: 000004000000 (64.0 MB) Partition: userdata, [00007F892800 - 0003A3DFBE00], size: 000324569600 (12.5 GB) GPT header successfully parsed Get firmware version Brand = LYF Manufacturer = LYF Device = TBW5770A2 Model = LS-5502 Phone platform = msm8916 CPU Abi = arm64-v8a Android release = 5.1.1 Firmware version = TBW577012_0003_V010088 Firmware date = Fri Jan 6 14:53:07 CST 2017 | |
10-26-2019, 11:22 | #17 (permalink) |
Member: 2298369 Status: Offline Thanks Meter: 440 | sir i post 16 gb for this sorry i have question if i change 8gb rom and 1gb ram to sam emmc but old emmc rpmb partition 512mb and new same storage and ram emmc rpmb have 4mb can i replace new one |
11-11-2019, 12:12 | #21 (permalink) |
Freak Poster Join Date: Feb 2009
Member: 961313 Status: Offline Sonork: 100.1625300 Thanks Meter: 35 | What about hisilicon ? Like honor 8x . Rpmb must be cleaned ? Or not . ... I use idt program ,give error after write fastboot ... after erase emmc with easy and write again ... the idt program give error befor write fastboot !!! This is means that rpmb is domaged? |
12-04-2019, 07:50 | #22 (permalink) |
Junior Member Join Date: Aug 2018
Member: 2861271 Status: Offline Thanks Meter: 3 | Hi What is this message ? EMMC RPMB is not yet programmed (clear) or RPMB General failure Nokia Lumia 1020 . i changed EMMC new and program dump But i dont have and write ExtCSD file nokia lumia 1020. https://ibb.co/BLJmPHk https://ibb.co/qYjVNzL ---------- eMMC Device Information ---------- eMMC CID : 1501004D424734574107A779533B90CB eMMC CSD : D02701320F5903FFF6DBFFFF8E40406D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 09/2013 Rev.0x7 eMMC NAME: MBG4WA , S/N: 2809746235 eMMC NAME (HEX): 4D4247345741 IC Name: Samsung , KLMBG4WE4A-A001/32GB @FBGA169 EMMC ROM1 (Main User Data) Capacity: 29820 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is not yet programmed (clear) or RPMB General failure EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: MBG4WA_2809746235_20191203_2237.extcsd Caution: invalid backup GPT header, but valid main header! Warning! Main and backup partition tables differ! Warning! One or more CRCs don't match. You should repair the disk! Caution: Found protective or hybrid MBR and corrupt GPT. Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB Disk identifier (GUID): AE420040-13DD-41F2-AE7F-0DC35854C8D7 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,61071326 Partition info successfully found ------ Detected 28 partitions ------ P0 (DPP) [0x200000 0x800000] Size: 8.0MB P1 (MODEM_FSG) [0xa00000 0x300000] Size: 3.0MB P2 (SSD) [0xe00000 0x4000] Size: 16.0KB P3 (SBL1) [0x1000000 0x177000] Size: 1.464MB P4 (SBL2) [0x1200000 0x177000] Size: 1.464MB P5 (SBL3) [0x1400000 0x200000] Size: 2.0MB P6 (UEFI) [0x1600000 0x271000] Size: 2.441MB P7 (RPM) [0x1a00000 0x7d000] Size: 500.0KB P8 (TZ) [0x1c00000 0x7d000] Size: 500.0KB P9 (WINSECAPP) [0x1e00000 0x80000] Size: 512.0KB P10 (BACKUP_SBL1) [0x2000000 0x177000] Size: 1.464MB P11 (BACKUP_SBL2) [0x2200000 0x177000] Size: 1.464MB P12 (BACKUP_SBL3) [0x2400000 0x200000] Size: 2.0MB P13 (BACKUP_UEFI) [0x2600000 0x271000] Size: 2.441MB P14 (BACKUP_RPM) [0x2a00000 0x7d000] Size: 500.0KB P15 (BACKUP_TZ) [0x2c00000 0x7d000] Size: 500.0KB P16 (BACKUP_WINSECAPP) [0x2e00000 0x80000] Size: 512.0KB P17 (UEFI_BS_NV) [0x3000000 0x40000] Size: 256.0KB P18 (UEFI_NV) [0x3200000 0x40000] Size: 256.0KB P19 (PLAT) [0x3400000 0x800000] Size: 8.0MB P20 (EFIESP) [0x4000000 0x4000000] Size: 64.0MB P21 (MODEM_FS1) [0x8000000 0x300000] Size: 3.0MB P22 (MODEM_FS2) [0x8400000 0x300000] Size: 3.0MB P23 (UEFI_RT_NV) [0x8800000 0x40000] Size: 256.0KB P24 (UEFI_RT_NV_RPMB) [0x8a00000 0x20000] Size: 128.0KB P25 (MMOS) [0x8c00000 0x59d1a00] Size: 89.818MB P26 (MAINOS) [0xe800000 0x7d385000] Size: 1.956GB P27 (DATA) [0x8c000000 0x6bbbfbe00] Size: 26.932GB ------------------------------------ Done. https://ibb.co/BLJmPHk Last edited by layder; 12-04-2019 at 09:35. Reason: merge posts |
12-04-2019, 09:36 | #23 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Online Thanks Meter: 2,948 | Quote:
The Following User Says Thank You to layder For This Useful Post: |
12-14-2019, 09:05 | #24 (permalink) |
Member: 2298369 Status: Offline Thanks Meter: 440 | lyder sir i'm very confused abput rpmb partition, i here giving log of redmi 4x (santoni firmware), when i doing software via usb cable it give error in last not i'm giving log here rpmb area is not clean(set is stop hang on logo) what i can do with jtag in this case can we recover this handset ? eMMC_tool Suite ver. 1.6.2.0 (release date: 30.06.2019) Microsoft Windows 7 (32 bit) build 7601 (6.1.7600.16385) Looking for EasyJTAG box... EasyJTAG API ver. 3307 EasyJTAG Box Serial = DF206405518F2085 Card Serial = AAC5E063 EasyJTAG Box Firmware = 2.48 Changelog: 30.06.2019 (ver 1.6.1.0) Fix: Bugs that have been found through your crash report Setting interface to EasyJtag2/E-Socket Setting bus width to 8 Bit Setting frequence to 14 MHz EMMC Device Information : EMMC CID: 13014E51334A39375610048D5A8B2487 EMMC CSD: D07F01328F5913FFFFFFFFEF9240009F EMMC Manufacture : MICRON , EMMC NAME: Q3J97V , HEX: 51334A393756 , S/N: 048D5A8B , rev. 0x10 EMMC Manufacture ID: 0x13 , OEM ID: 0x4E , Device Type: BGA (Discrete embedded) , Date: 2/2017 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 29231 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: Q3J97V_048D5A8B_20191214_132759.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: modem, [000004000000 - 000009400000], size: 000005400000 (84.0 MB) Partition: fsc, [00000C000000 - 00000C000400], size: 000000000400 (1.00 KB) Partition: ssd, [00000C000400 - 00000C002400], size: 000000002000 (8.00 KB) Partition: sbl1, [00000C002400 - 00000C082400], size: 000000080000 (512. KB) Partition: sbl1bak, [00000C082400 - 00000C102400], size: 000000080000 (512. KB) Partition: rpm, [00000C102400 - 00000C182400], size: 000000080000 (512. KB) Partition: rpmbak, [00000C182400 - 00000C202400], size: 000000080000 (512. KB) Partition: tz, [00000C202400 - 00000C402400], size: 000000200000 (2.00 MB) Partition: tzbak, [00000C402400 - 00000C602400], size: 000000200000 (2.00 MB) Partition: devcfg, [00000C602400 - 00000C642400], size: 000000040000 (256. KB) Partition: devcfgbak, [00000C642400 - 00000C682400], size: 000000040000 (256. KB) Partition: dsp, [00000C682400 - 00000D682400], size: 000001000000 (16.0 MB) Partition: modemst1, [00000D682400 - 00000D802400], size: 000000180000 (1.50 MB) Partition: modemst2, [00000D802400 - 00000D982400], size: 000000180000 (1.50 MB) Partition: DDR, [000010000000 - 000010008000], size: 000000008000 (32.0 KB) Partition: fsg, [000010008000 - 000010188000], size: 000000180000 (1.50 MB) Partition: sec, [000010188000 - 00001018C000], size: 000000004000 (16.0 KB) Partition: splash, [000014000000 - 000015400000], size: 000001400000 (20.0 MB) Partition: aboot, [000018000000 - 000018100000], size: 000000100000 (1.00 MB) Partition: abootbak, [000018100000 - 000018200000], size: 000000100000 (1.00 MB) Partition: boot, [000018200000 - 00001C200000], size: 000004000000 (64.0 MB) Partition: recovery, [00001C200000 - 000020200000], size: 000004000000 (64.0 MB) Partition: devinfo, [000020200000 - 000020300000], size: 000000100000 (1.00 MB) Partition: system, [000020300000 - 0000E0300000], size: 0000C0000000 (3.00 GB) Partition: cache, [0000E4000000 - 0000F4000000], size: 000010000000 (256. MB) Partition: persist, [0000F4000000 - 0000F6000000], size: 000002000000 (32.0 MB) Partition: misc, [0000F6000000 - 0000F6100000], size: 000000100000 (1.00 MB) Partition: keystore, [0000F6100000 - 0000F6180000], size: 000000080000 (512. KB) Partition: config, [0000F6180000 - 0000F6188000], size: 000000008000 (32.0 KB) Partition: oem, [0000F6188000 - 0000FA188000], size: 000004000000 (64.0 MB) Partition: limits, [0000FC000000 - 0000FC008000], size: 000000008000 (32.0 KB) Partition: mota, [000100000000 - 000100080000], size: 000000080000 (512. KB) Partition: dip, [000100080000 - 000100180000], size: 000000100000 (1.00 MB) Partition: mdtp, [000100180000 - 000102180000], size: 000002000000 (32.0 MB) Partition: syscfg, [000102180000 - 000102200000], size: 000000080000 (512. KB) Partition: mcfg, [000102200000 - 000102600000], size: 000000400000 (4.00 MB) Partition: lksecapp, [000104000000 - 000104020000], size: 000000020000 (128. KB) Partition: lksecappbak, [000104020000 - 000104040000], size: 000000020000 (128. KB) Partition: cmnlib, [000104040000 - 000104080000], size: 000000040000 (256. KB) Partition: cmnlibbak, [000104080000 - 0001040C0000], size: 000000040000 (256. KB) Partition: cmnlib64, [0001040C0000 - 000104100000], size: 000000040000 (256. KB) Partition: cmnlib64bak, [000104100000 - 000104140000], size: 000000040000 (256. KB) Partition: keymaster, [000104140000 - 000104180000], size: 000000040000 (256. KB) Partition: keymasterbak, [000104180000 - 0001041C0000], size: 000000040000 (256. KB) Partition: apdp, [000108000000 - 000108040000], size: 000000040000 (256. KB) Partition: msadp, [000108040000 - 000108080000], size: 000000040000 (256. KB) Partition: dpo, [000108080000 - 000108082000], size: 000000002000 (8.00 KB) Partition: cust, [000108082000 - 000128082000], size: 000020000000 (512. MB) Partition: userdata, [000128082000 - 000747BFBE00], size: 00061FB79E00 (24.5 GB) GPT header successfully parsed Get firmware version Brand = Xiaomi Manufacturer = Xiaomi Device = santoni Model = Redmi 4X Phone platform = msm8937 CPU Abi = arm64-v8a Android release = 7.1.2 Firmware version = N2G47H Miui Version = V10.3.1.0.NAMMIXM Firmware date = Thu Apr 11 20:05:35 WIB 2019 Setting interface to EasyJtag2/E-Socket Setting bus width to 8 Bit Setting frequence to 14 MHz EMMC Device Information : EMMC CID: 13014E51334A39375610048D5A8B2487 EMMC CSD: D07F01328F5913FFFFFFFFEF9240009F EMMC Manufacture : MICRON , EMMC NAME: Q3J97V , HEX: 51334A393756 , S/N: 048D5A8B , rev. 0x10 EMMC Manufacture ID: 0x13 , OEM ID: 0x4E , Device Type: BGA (Discrete embedded) , Date: 2/2017 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 29231 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: Q3J97V_048D5A8B_20191214_132812.extcsd EMMC Init completed. Operation: Reading S.M.A.R.T Report ... Device Life Time Estimation (MLC) [269]: 0x01 0% - 10% device life time used Device Life Time Estimation (SLC) [268]: 0x02 10% - 20% device life time used Pre EOL information [267]: 0x01 Normal Optimal Read Size [266]: 0x01 4 KB Optimal Write Size [265]: 0x06 24 KB Optimal Trim Unit Size [264]: 0x01 4 KB |
12-14-2019, 10:12 | #25 (permalink) | |
RPMB at Xiaomi is store eMMC-based boot pretect info | |
