Old 10-26-2019, 11:06   #16 (permalink)
Member: 2298369
Thanks Meter: 418
Originally Posted by galaxycompue View Post
lyder sir why cpu write data in rpmb partitions, when u not given logs in old version we have no idea to check rpmb partition but now we are watching very few ic clean otherwise maximum ic are waste no enough stock to recover handsets i have one handset lyf ls-5010 hang on logo when i try to flash it give error in last so finally when i check emmc it show rpmb not clean-
after reconnect, make sure that the size of rom1 has been changed.
Setting interface to easyjtag2/e-socket
setting bus width to 8 bit
setting frequence to 42 mhz
emmc device information :
Emmc cid: 150100463732324d420058bfe00bb251
emmc csd: D02701320f5903fff6dbffef8e40400d
emmc manufacture : Samsung , emmc name: F722mb , hex: 463732324d42 , s/n: 58bfe00b , rev. 0x00
emmc manufacture id: 0x15 , oem id: 0x00 , device type: Bga (discrete embedded) , date: 11/2015
emmc rom 1 (main user data) capacity: 7456 mb (0001d2000000)
emmc rom 2/3 (boot partition 1/2) capacity: 4096 kb (000000400000)
emmc rpmb (replay protected memory block) capacity: 512 kb (000000080000) counter: 25 , response: Not clean
emmc permanent write protection: No
emmc temporary write protection: No
extended csd information :
Extended csd rev: 1.7 (mmc 5.0, mmc 5.01)
boot configuration [partition_config]: 0x38 , boot from: Rom1 (main user area)
boot bus config: 0x00 , width 1bit
h/w reset function [rst_n_function]: 0x01, rst_n signal is permanently enabled
supported partition features [partitioning_support]: 0x07
device supports partitioning features
device can have enhanced technological features in partitions and user data area
device can have extended partitions attribute
partition settings [partition_setting_completed]: 0x00
backup saved: F722mb_58bfe00b_20191026_152307.extcsd
emmc init completed.
Scanning soft partitions
gpt header is found and is valid
partition: Fsg, [000004000000 - 000004180000], size: 000000180000 (1.50 mb)
partition: Sbl1, [000008000000 - 000008080000], size: 000000080000 (512. Kb)
partition: Aboot, [000008080000 - 000008180000], size: 000000100000 (1.00 mb)
partition: Rpm, [000008180000 - 000008200000], size: 000000080000 (512. Kb)
partition: Tz, [000008200000 - 000008280000], size: 000000080000 (512. Kb)
partition: Hyp, [000008280000 - 000008300000], size: 000000080000 (512. Kb)
partition: Pad, [000008300000 - 000008400000], size: 000000100000 (1.00 mb)
partition: Modemst1, [000008400000 - 000008580000], size: 000000180000 (1.50 mb)
partition: Modemst2, [000008580000 - 000008700000], size: 000000180000 (1.50 mb)
partition: Misc, [000008700000 - 000008800000], size: 000000100000 (1.00 mb)
partition: Fsc, [000008800000 - 000008800400], size: 000000000400 (1.00 kb)
partition: Ssd, [000008800400 - 000008802400], size: 000000002000 (8.00 kb)
partition: Splash, [000008802400 - 000009202400], size: 000000a00000 (10.0 mb)
partition: Keystore, [000009202400 - 000009282400], size: 000000080000 (512. Kb)
partition: Config, [000009282400 - 000009302400], size: 000000080000 (512. Kb)
partition: Oem, [000009302400 - 00000d302400], size: 000004000000 (64.0 mb)
partition: Sbl1bak, [00000d302400 - 00000d382400], size: 000000080000 (512. Kb)
partition: Rpmbak, [00000d382400 - 00000d402400], size: 000000080000 (512. Kb)
partition: Tzbak, [00000d402400 - 00000d482400], size: 000000080000 (512. Kb)
partition: Hypbak, [00000d482400 - 00000d502400], size: 000000080000 (512. Kb)
partition: Abootbak, [000010000000 - 000010100000], size: 000000100000 (1.00 mb)
partition: Modem, [000010100000 - 000014100000], size: 000004000000 (64.0 mb)
partition: Ddr, [000014100000 - 000014108000], size: 000000008000 (32.0 kb)
partition: Sec, [000014108000 - 00001410c000], size: 000000004000 (16.0 kb)
partition: Boot, [00001410c000 - 00001610c000], size: 000002000000 (32.0 mb)
partition: System, [00001610c000 - 00009610c000], size: 000080000000 (2.00 gb)
partition: Persist, [00009610c000 - 00009810c000], size: 000002000000 (32.0 mb)
partition: Cache, [00009810c000 - 0000a810c000], size: 000010000000 (256. Mb)
partition: Recovery, [0000a810c000 - 0000aa10c000], size: 000002000000 (32.0 mb)
partition: Userdata, [0000aa10c000 - 0001d1ffbe00], size: 000127eefe00 (4.62 gb)
gpt header successfully parsed
get firmware version
brand = lyf
manufacturer = jsr
device = ls-5010
model = ls-5010
phone platform = msm8916
cpu abi = arm64-v8a
android release = 5.1.1
firmware version = lyf_ls-5010_01_05_15
firmware date = sun may 15 00:31:35 cst 2016
i try to make gp partitions but all same as before this is new trouble for us to repair emmc.
sir can i use this ic it have rpmb partiton 4mb yet above emmc have rpmb 512mb ? Plz reply lyder sir
Setting interface to EasyJtag2/E-Socket
Setting bus width to 8 Bit
Setting frequence to 42 MHz
EMMC Device Information :
EMMC CID: 150100523331424D4201B499A8C68121
EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D
EMMC Manufacture : SAMSUNG , EMMC NAME: R31BMB , HEX: 523331424D42 , S/N: B499A8C6 , rev. 0x01
EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 8/2014
EMMC ROM 1 (Main User Data) Capacity: 14910 MB (0003A3E00000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Clean
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot
Boot Bus Config: 0x00 , width 1bit
H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: R31BMB_B499A8C6_20191026_153419.extcsd
EMMC Init completed.
GPT header is found and is valid
Partition: modem, [000000004400 - 000004004400], size: 000004000000 (64.0 MB)
Partition: sbl1, [000004004400 - 000004084400], size: 000000080000 (512. KB)
Partition: sbl1bak, [000004084400 - 000004104400], size: 000000080000 (512. KB)
Partition: aboot, [000004104400 - 000004204400], size: 000000100000 (1.00 MB)
Partition: abootbak, [000004204400 - 000004304400], size: 000000100000 (1.00 MB)
Partition: rpm, [000004304400 - 000004384400], size: 000000080000 (512. KB)
Partition: rpmbak, [000004384400 - 000004404400], size: 000000080000 (512. KB)
Partition: tz, [000004404400 - 000004484400], size: 000000080000 (512. KB)
Partition: tzbak, [000004484400 - 000004504400], size: 000000080000 (512. KB)
Partition: hyp, [000004504400 - 000004584400], size: 000000080000 (512. KB)
Partition: hypbak, [000004584400 - 000004604400], size: 000000080000 (512. KB)
Partition: pad, [000004604400 - 000004704400], size: 000000100000 (1.00 MB)
Partition: modemst1, [000004704400 - 000004884400], size: 000000180000 (1.50 MB)
Partition: modemst2, [000004884400 - 000004A04400], size: 000000180000 (1.50 MB)
Partition: misc, [000004A04400 - 000004B04400], size: 000000100000 (1.00 MB)
Partition: fsc, [000004B04400 - 000004B04800], size: 000000000400 (1.00 KB)
Partition: ssd, [000004B04800 - 000004B06800], size: 000000002000 (8.00 KB)
Partition: splash, [000004B06800 - 000005506800], size: 000000A00000 (10.0 MB)
Partition: DDR, [000005506800 - 00000550E800], size: 000000008000 (32.0 KB)
Partition: fsg, [00000550E800 - 00000568E800], size: 000000180000 (1.50 MB)
Partition: sec, [00000568E800 - 000005692800], size: 000000004000 (16.0 KB)
Partition: boot, [000005692800 - 000007692800], size: 000002000000 (32.0 MB)
Partition: system, [000007692800 - 000067692800], size: 000060000000 (1.50 GB)
Partition: persist, [000067692800 - 000069692800], size: 000002000000 (32.0 MB)
Partition: cache, [000069692800 - 000079692800], size: 000010000000 (256. MB)
Partition: recovery, [000079692800 - 00007B692800], size: 000002000000 (32.0 MB)
Partition: devinfo, [00007B692800 - 00007B792800], size: 000000100000 (1.00 MB)
Partition: keystore, [00007B792800 - 00007B812800], size: 000000080000 (512. KB)
Partition: config, [00007B812800 - 00007B892800], size: 000000080000 (512. KB)
Partition: oem, [00007B892800 - 00007F892800], size: 000004000000 (64.0 MB)
Partition: userdata, [00007F892800 - 0003A3DFBE00], size: 000324569600 (12.5 GB)
GPT header successfully parsed
Get firmware version
Brand = LYF
Manufacturer = LYF
Device = TBW5770A2
Model = LS-5502
Phone platform = msm8916
CPU Abi = arm64-v8a
Android release = 5.1.1
Firmware version = TBW577012_0003_V010088
Firmware date = Fri Jan 6 14:53:07 CST 2017
Old 10-26-2019, 11:22   #17 (permalink)
Member: 2298369
Thanks Meter: 418
sir i post 16 gb for this sorry i have question if i change 8gb rom and 1gb ram to sam emmc but old emmc rpmb partition 512mb and new same storage and ram emmc rpmb have 4mb can i replace new one
Old 10-26-2019, 12:12   #18 (permalink)
Member: 2298369
Thanks Meter: 418
LYDER SIR MY QUESTION IS SIMPLE THAT CAN I USE 8gb rom 1gb ram 4mb rpmb in new and old is 8gb rom 1gb ram and 512mb rmpb partition.
Old 10-26-2019, 12:13   #19 (permalink)
Member: 2298369
Thanks Meter: 418
also sir is there any minimum no of count in rpmb section which ic i can use ? plz give detail
Old 10-26-2019, 19:57   #20 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,597
RPMB size not critical, as ROM2/3
The Following 2 Users Say Thank You to layder For This Useful Post:
Old 11-11-2019, 12:12   #21 (permalink)
Member: 961313
Sonork: 100.1625300
Thanks Meter: 34
What about hisilicon ? Like honor 8x . Rpmb must be cleaned ? Or not . ... I use idt program ,give error after write fastboot ... after erase emmc with easy and write again ... the idt program give error befor write fastboot !!!
This is means that rpmb is domaged?
Old 12-04-2019, 07:50   #22 (permalink)
Member: 2861271
Hi
What is this message ?
EMMC RPMB is not yet programmed (clear) or RPMB General failure
Nokia Lumia 1020 . i changed EMMC new and program dump
But i dont have and write ExtCSD file nokia lumia 1020.
https://ibb.co/BLJmPHk
https://ibb.co/qYjVNzL
---------- eMMC Device Information ----------
eMMC CID : 1501004D424734574107A779533B90CB
eMMC CSD : D02701320F5903FFF6DBFFFF8E40406D
eMMC Manufacturer ID: 0015 , OEM ID: 0100
eMMC Date: 09/2013 Rev.0x7
eMMC NAME: MBG4WA , S/N: 2809746235
eMMC NAME (HEX): 4D4247345741
IC Name: Samsung , KLMBG4WE4A-A001/32GB @FBGA169
EMMC ROM1 (Main User Data) Capacity: 29820 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC Password Locked: No
Extended CSD rev 1.5 (MMC 4.41)
Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area)
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38.
H/W reset function [RST_N_FUNCTION]: 0x00
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x03
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: MBG4WA_2809746235_20191203_2237.extcsd
Caution: invalid backup GPT header, but valid main header!
Warning! Main and backup partition tables differ!
Warning! One or more CRCs don't match. You should repair the disk!
Caution: Found protective or hybrid MBR and corrupt GPT.
Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB
Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB
Disk identifier (GUID): AE420040-13DD-41F2-AE7F-0DC35854C8D7
Logical sector size: 0x200 bytes ,First/Last usable sector: 34,61071326
Partition info successfully found
------ Detected 28 partitions ------
P0 (DPP) [0x200000 0x800000] Size: 8.0MB
P1 (MODEM_FSG) [0xa00000 0x300000] Size: 3.0MB
P2 (SSD) [0xe00000 0x4000] Size: 16.0KB
P3 (SBL1) [0x1000000 0x177000] Size: 1.464MB
P4 (SBL2) [0x1200000 0x177000] Size: 1.464MB
P5 (SBL3) [0x1400000 0x200000] Size: 2.0MB
P6 (UEFI) [0x1600000 0x271000] Size: 2.441MB
P7 (RPM) [0x1a00000 0x7d000] Size: 500.0KB
P8 (TZ) [0x1c00000 0x7d000] Size: 500.0KB
P9 (WINSECAPP) [0x1e00000 0x80000] Size: 512.0KB
P10 (BACKUP_SBL1) [0x2000000 0x177000] Size: 1.464MB
P11 (BACKUP_SBL2) [0x2200000 0x177000] Size: 1.464MB
P12 (BACKUP_SBL3) [0x2400000 0x200000] Size: 2.0MB
P13 (BACKUP_UEFI) [0x2600000 0x271000] Size: 2.441MB
P14 (BACKUP_RPM) [0x2a00000 0x7d000] Size: 500.0KB
P15 (BACKUP_TZ) [0x2c00000 0x7d000] Size: 500.0KB
P16 (BACKUP_WINSECAPP) [0x2e00000 0x80000] Size: 512.0KB
P17 (UEFI_BS_NV) [0x3000000 0x40000] Size: 256.0KB
P18 (UEFI_NV) [0x3200000 0x40000] Size: 256.0KB
P19 (PLAT) [0x3400000 0x800000] Size: 8.0MB
P20 (EFIESP) [0x4000000 0x4000000] Size: 64.0MB
P21 (MODEM_FS1) [0x8000000 0x300000] Size: 3.0MB
P22 (MODEM_FS2) [0x8400000 0x300000] Size: 3.0MB
P23 (UEFI_RT_NV) [0x8800000 0x40000] Size: 256.0KB
P24 (UEFI_RT_NV_RPMB) [0x8a00000 0x20000] Size: 128.0KB
P25 (MMOS) [0x8c00000 0x59d1a00] Size: 89.818MB
P26 (MAINOS) [0xe800000 0x7d385000] Size: 1.956GB
P27 (DATA) [0x8c000000 0x6bbbfbe00] Size: 26.932GB
Done.
Old 12-04-2019, 09:36   #23 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,597
Originally Posted by Danial10 View Post
Hi
you need read sticked topics http://forum.gsmhosting.com/vbb/f672...at-do-2587891/
The Following User Says Thank You to layder For This Useful Post:
Old 12-14-2019, 09:05   #24 (permalink)
Member: 2298369
Thanks Meter: 418
lyder sir i'm very confused abput rpmb partition, i here giving log of redmi 4x (santoni firmware), when i doing software via usb cable it give error in last not i'm giving log here rpmb area is not clean(set is stop hang on logo) what i can do with jtag in this case can we recover this handset ?
eMMC_tool Suite ver. 1.6.2.0 (release date: 30.06.2019)
Microsoft Windows 7 (32 bit) build 7601 (6.1.7600.16385)
Looking for EasyJTAG box...
EasyJTAG API ver. 3307
EasyJTAG Box Serial = DF206405518F2085
Card Serial = AAC5E063
EasyJTAG Box Firmware = 2.48
Changelog:
30.06.2019 (ver 1.6.1.0)
Fix: Bugs that have been found through your crash report
Setting frequence to 14 MHz
EMMC CID: 13014E51334A39375610048D5A8B2487
EMMC CSD: D07F01328F5913FFFFFFFFEF9240009F
EMMC Manufacture : MICRON , EMMC NAME: Q3J97V , HEX: 51334A393756 , S/N: 048D5A8B , rev. 0x10
EMMC Manufacture ID: 0x13 , OEM ID: 0x4E , Device Type: BGA (Discrete embedded) , Date: 2/2017
EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 29231 , Response: Not Clean
Extended CSD rev: 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area)
Backup saved: Q3J97V_048D5A8B_20191214_132759.extcsd
Partition: modem, [000004000000 - 000009400000], size: 000005400000 (84.0 MB)
Partition: fsc, [00000C000000 - 00000C000400], size: 000000000400 (1.00 KB)
Partition: ssd, [00000C000400 - 00000C002400], size: 000000002000 (8.00 KB)
Partition: sbl1, [00000C002400 - 00000C082400], size: 000000080000 (512. KB)
Partition: sbl1bak, [00000C082400 - 00000C102400], size: 000000080000 (512. KB)
Partition: rpm, [00000C102400 - 00000C182400], size: 000000080000 (512. KB)
Partition: rpmbak, [00000C182400 - 00000C202400], size: 000000080000 (512. KB)
Partition: tz, [00000C202400 - 00000C402400], size: 000000200000 (2.00 MB)
Partition: tzbak, [00000C402400 - 00000C602400], size: 000000200000 (2.00 MB)
Partition: devcfg, [00000C602400 - 00000C642400], size: 000000040000 (256. KB)
Partition: devcfgbak, [00000C642400 - 00000C682400], size: 000000040000 (256. KB)
Partition: dsp, [00000C682400 - 00000D682400], size: 000001000000 (16.0 MB)
Partition: modemst1, [00000D682400 - 00000D802400], size: 000000180000 (1.50 MB)
Partition: modemst2, [00000D802400 - 00000D982400], size: 000000180000 (1.50 MB)
Partition: DDR, [000010000000 - 000010008000], size: 000000008000 (32.0 KB)
Partition: fsg, [000010008000 - 000010188000], size: 000000180000 (1.50 MB)
Partition: sec, [000010188000 - 00001018C000], size: 000000004000 (16.0 KB)
Partition: splash, [000014000000 - 000015400000], size: 000001400000 (20.0 MB)
Partition: aboot, [000018000000 - 000018100000], size: 000000100000 (1.00 MB)
Partition: abootbak, [000018100000 - 000018200000], size: 000000100000 (1.00 MB)
Partition: boot, [000018200000 - 00001C200000], size: 000004000000 (64.0 MB)
Partition: recovery, [00001C200000 - 000020200000], size: 000004000000 (64.0 MB)
Partition: devinfo, [000020200000 - 000020300000], size: 000000100000 (1.00 MB)
Partition: system, [000020300000 - 0000E0300000], size: 0000C0000000 (3.00 GB)
Partition: cache, [0000E4000000 - 0000F4000000], size: 000010000000 (256. MB)
Partition: persist, [0000F4000000 - 0000F6000000], size: 000002000000 (32.0 MB)
Partition: misc, [0000F6000000 - 0000F6100000], size: 000000100000 (1.00 MB)
Partition: keystore, [0000F6100000 - 0000F6180000], size: 000000080000 (512. KB)
Partition: config, [0000F6180000 - 0000F6188000], size: 000000008000 (32.0 KB)
Partition: oem, [0000F6188000 - 0000FA188000], size: 000004000000 (64.0 MB)
Partition: limits, [0000FC000000 - 0000FC008000], size: 000000008000 (32.0 KB)
Partition: mota, [000100000000 - 000100080000], size: 000000080000 (512. KB)
Partition: dip, [000100080000 - 000100180000], size: 000000100000 (1.00 MB)
Partition: mdtp, [000100180000 - 000102180000], size: 000002000000 (32.0 MB)
Partition: syscfg, [000102180000 - 000102200000], size: 000000080000 (512. KB)
Partition: mcfg, [000102200000 - 000102600000], size: 000000400000 (4.00 MB)
Partition: lksecapp, [000104000000 - 000104020000], size: 000000020000 (128. KB)
Partition: lksecappbak, [000104020000 - 000104040000], size: 000000020000 (128. KB)
Partition: cmnlib, [000104040000 - 000104080000], size: 000000040000 (256. KB)
Partition: cmnlibbak, [000104080000 - 0001040C0000], size: 000000040000 (256. KB)
Partition: cmnlib64, [0001040C0000 - 000104100000], size: 000000040000 (256. KB)
Partition: cmnlib64bak, [000104100000 - 000104140000], size: 000000040000 (256. KB)
Partition: keymaster, [000104140000 - 000104180000], size: 000000040000 (256. KB)
Partition: keymasterbak, [000104180000 - 0001041C0000], size: 000000040000 (256. KB)
Partition: apdp, [000108000000 - 000108040000], size: 000000040000 (256. KB)
Partition: msadp, [000108040000 - 000108080000], size: 000000040000 (256. KB)
Partition: dpo, [000108080000 - 000108082000], size: 000000002000 (8.00 KB)
Partition: cust, [000108082000 - 000128082000], size: 000020000000 (512. MB)
Partition: userdata, [000128082000 - 000747BFBE00], size: 00061FB79E00 (24.5 GB)
Brand = Xiaomi
Manufacturer = Xiaomi
Device = santoni
Model = Redmi 4X
Phone platform = msm8937
CPU Abi = arm64-v8a
Android release = 7.1.2
Firmware version = N2G47H
Miui Version = V10.3.1.0.NAMMIXM
Firmware date = Thu Apr 11 20:05:35 WIB 2019
Backup saved: Q3J97V_048D5A8B_20191214_132812.extcsd
Operation: Reading S.M.A.R.T Report ...
Device Life Time Estimation (MLC) [269]: 0x01 0% - 10% device life time used
Device Life Time Estimation (SLC) [268]: 0x02 10% - 20% device life time used
Pre EOL information [267]: 0x01 Normal
Optimal Read Size [266]: 0x01 4 KB
Optimal Write Size [265]: 0x06 24 KB
Optimal Trim Unit Size [264]: 0x01 4 KB
Old 12-14-2019, 10:12   #25 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,597
Most Xiaome deviced can simpe flash by 9008 port and testpoint
RPMB at Xiaomi is store eMMC-based boot pretect info
Old 12-14-2019, 12:04   #26 (permalink)
Member: 2298369
Thanks Meter: 418
Originally Posted by layder View Post
most xiaome deviced can simpe flash by 9008 port and testpoint
rpmb at xiaomi is store emmc-based boot pretect info
lyder sir what you said i cant understand plz clear second line
Old 12-14-2019, 19:11   #27 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,597
Xiaomi phones at Qualcomm CPU is store boot protectiton at RPMB
If you change eMMC, Xiaomi phones will not be start, without write secure data to RPMB.
The Following 4 Users Say Thank You to layder For This Useful Post:
Old 02-22-2020, 07:28   #28 (permalink)
ishant's Avatar
Member: 1763238
Thanks Meter: 367
@layder Sir
Can i Change Brand new eMCP RPMB is Clean any Xiaomi Phnoes
without change SOC ??
Old 02-22-2020, 18:09   #29 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,597
Originally Posted by ishant View Post
@layder Sir
only for Xiaomi at MTK and some old model
Old 02-27-2020, 22:38   #30 (permalink)
Member: 93334
Thanks Meter: 2
Hi lads
layder , any news about RPMB partition to access to write ?
Thx.
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.26157 seconds with 7 queries
