01-04-2021, 21:27 | #61 (permalink) |
Junior Member Join Date: May 2016
Member: 2572931 Status: Offline Thanks Meter: 0 | Is rpmb partition is important or not I remove emcp and check in easy jtag plus then the emcp health status is very bad , so according to the solution the repair process is backup rom2/3 and security partition, i did it well I can't take backup RPMB partition because when i try to read emcp in easy jtag classic suite the tool stopped working I universal factory emcp and erase all rom after erase emcp and create gp partition emcp health staus is normal now. So write back ROM 2 , ROM 3 firmware and security backup as well and there is no backup of RPMB partition so emcp will work or not. I solder again emcp to pcb but phone can't boot up it show only Qualcomm port 9008. Is RPMB partition is important for boot up or not if yes so now how to write previous or new rpmb partition even i have no file for them. |
01-05-2021, 20:58 | #62 (permalink) | |
No Life Poster Join Date: Nov 2014
Member: 2289628 Status: Offline Thanks Meter: 226 | Quote:
But according your description there is need more detail about 2 things. 1:- Health Report (Before GPT Partition) Share your Log on new post. 2:- RPMB Program detail (counter etc) | |
The Following User Says Thank You to hafiz4saqib For This Useful Post: |
01-06-2021, 06:00 | #63 (permalink) |
Member: 2572931 Status: Offline Thanks Meter: 0 | Thanks for reply... Health report status is very bad before create gpt partition RPMB status not clean and counter 17934 ( dont remember exact no. ) I just want to know ROMB partion is need for boot or not likes rom 2/3 . Because i did not backup rpmb partition before universal factory format |
01-06-2021, 11:31 | #64 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
some devices store at RPMB boot lock status Last edited by layder; 01-06-2021 at 12:47. | |
The Following User Says Thank You to layder For This Useful Post: |
02-12-2021, 20:09 | #65 (permalink) |
Insane Poster Join Date: Sep 2018 Location: India
Member: 2868909 Status: Offline Thanks Meter: 36 | Hello masters , I need a quick tip from y’all about RPMB , Foe understanding this better please have a look on below example. I know some phone boots normally irrespective of the RPMB status but most of them do creates issue so please have a look on my Little post. Suppose I have a phone ‘X’ with its original emmc ‘1’ and it has no juice left , and on reading info if it’s says RPMB Status is not clean then can I change it’s replace it’s emmc from Phone ‘Y’ with emmc ‘2’ who’s RPMB status is clean OR the emmc ‘1’ from phone ‘X’ should also have Clean RPMB status 0R Emmc of phone ‘X’ should be clean and the emmc ‘2’ from the Phone ‘Y’ can also be not clean or clean . Please Masters it’s my humble request to clarify my little doubt . Thank you . |
02-13-2021, 08:27 | #66 (permalink) | |
If you device have RPMB clean, you can yse any eMMC to replace And sometime devices wirh ysed RPMB can work witk used (not Clean) RPMB | |
The Following 2 Users Say Thank You to layder For This Useful Post: |
03-23-2021, 11:35 | #67 (permalink) |
Junior Member Join Date: Mar 2021 Location: iran Age: 25
Member: 2982883 Status: Offline Thanks Meter: 0 | i have a qe63mb b318 16gig i want to use it for redmi 5a the rpmb isnt clear. my question is easy jtag havent b318 frimware. can i change cid to emmc that i have its frimware and write frimware and clean rpmb and after that i bring b318 cid back? if i cant what should i do? |
03-23-2021, 21:36 | #68 (permalink) | |
It's a brand? I can not find it at Google | |
12-27-2021, 03:50 | #71 (permalink) |
Junior Member Join Date: Nov 2014
Member: 2289167 Status: Offline Thanks Meter: 0 | EMMC ROM1 (Main User Data) Capacity: 59640 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 0 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 i write a rpmb but say clean and dont work is qualcomm .. the phone is dead is a02s |
12-27-2021, 21:09 | #72 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Allah is Greatest
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 994 | A217f I got this phone stuck on recovery. I saw with easy jtag RPMB not clean. I updated emmc firmware. Now phone only detect as exynos.. How can I fix |
