07-15-2020, 08:57 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: inside emmc ufs Age: 19
Member: 221603 Status: Offline Sonork: 100.1581270 Thanks Meter: 6,395 | s1 pro after user lock remove only vibrate here is log Z3X EasyJtag EMMC File Manager v 1.18 at 29/06/2020 Started.. Box API Version: 3401 FS Driver Version: 29062020 SQLite Version: 3.32.0 FSCK Engine Version: 29062020 ESE DB Version: 29062020 System Util Version: 29062020 System: Windows NT 6.1 (Build 7601, Service Pack 1) / 64 BIT CPU: Intel(R) Core(TM) i5-3320M CPU @ 2.60GHz Total RAM: 3.88 GB Telegram Support: https://t.me/z3xefm FRP Apps: Index of /frp Z3X Card Serial: AA8D32D9 EasyJtag Plus Box Found at: COM35 EasyJtag Plus Box Firmware: 2.52.1 Source: EasyJtag Port [UFS] Generation: GPT [QC/SAMS/BCM/INTEL/MTK] UFS Power Mode: LOW Scanner Thread Created.. Running EasyJtag UFS Mode... UFS ISP Mode: OFF UFS Safe Mode: ON Initialize UFS Engine Fail. Code: -56/ERROR_UFS_BOX_INIT_LINK_T0 Scanner Thread Terminated Elapsed: 00:00:03:170 Found 0 Partition(s).. Search Partitions Fail.. Check Socket/UFS Chip and Try Again.. Source: EasyJtag Port [UFS] Generation: GPT [QC/SAMS/BCM/INTEL/MTK] UFS Power Mode: LOW Scanner Thread Created.. Running EasyJtag UFS Mode... UFS ISP Mode: OFF UFS Safe Mode: ON Init UFS Engine: 0/OK EasyJtag Plus S/N: 6EA5A92882750D56 EasyJtag Plus Box FirmWare: 2.52 Box Hardware = EasyJtag 2nd Generation UFS: Socket Info: S/N: 0x0123177B866AC469EE Desc: EasyJTAG UFS Socket 3 in 1 by MOORC 12.07.19 Type: MOORK UFS Socket 3 in 1 ID: 2166 UFS: Voltage Info: Mode: LOW VCC : 3266 mV, VCCQ2: 1926 mV 3v3 : 3338 mV, 1v2: 1208 mV UFS: Memory Info: Connection: Socket BGA-254 Vendor: SAMSUNG Name: KM8V7001JA-B813 S/N: 3bc25c849e0d OEM ID: SAMSUNG_OEM_ID Firm Version: 9.00 Size: 0x001DCC800000/119.20 GB Max LUNs: 8 LUNs Cnt: 6 W-LUNs Cnt: 1 LUNs ReConfig: Enabled UFS Health Info: UFS Life Time A: 0x01 -> 0% - 10% Life Time Used UFS Life Time B: 0x01 -> 0% - 10% Life Time Used UFS Pre-EOL Info: 0x01 -> Used Less 80% of Reserved Blocks UFS: LUNs Info: LUN 0 -> Size: 30939136 Block(s)/118.02 GB LUN 1 (Boot A) -> Size: 2048 Block(s)/8.00 MB LUN 2 (Boot B) -> Size: 2048 Block(s)/8.00 MB LUN 3 -> Size: 16384 Block(s)/64.00 MB LUN 4 -> Size: 262144 Block(s)/1.00 GB LUN 5 -> Size: 16384 Block(s)/64.00 MB W-LUN 0xC4 (REPORT LUNS) -> Size: 65536 Block(s)/16.00 MB UFS Init OK Scanning Data From UFS Chip. Please wait.. Scanning GUID Partition Table from LUN 0 GUID Partition Table is Found. Max Parts: 32 GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB GPT: SSD [000000006000 - 000000002000] Size: 8.00 KB GPT: PERSIST [000000008000 - 000002000000] Size: 32.00 MB GPT: MISC [000002008000 - 000000100000] Size: 1.00 MB GPT: KEYSTORE [000002108000 - 000000080000] Size: 512.00 KB GPT: FRP [000002188000 - 000000080000] Size: 512.00 KB GPT: METADATA [000002208000 - 000001000000] Size: 16.00 MB GPT: VGC [000003208000 - 00000C800000] Size: 200.00 MB GPT: OEM [00000FA08000 - 000004000000] Size: 64.00 MB GPT: SEED [000013A08000 - 000000400000] Size: 4.00 MB GPT: APANIC [000013E08000 - 000000A00000] Size: 10.00 MB GPT: BACKUP [000014808000 - 000000A00000] Size: 10.00 MB GPT: RESERVED [000015208000 - 000000A00000] Size: 10.00 MB GPT: RECOVERY [000015C08000 - 000006000000] Size: 96.00 MB GPT: SURVIVAL [00001BC08000 - 000006000000] Size: 96.00 MB GPT: SYSTEM [000021C08000 - 000160000000] Size: 5.50 GB GPT: VENDOR [000181C08000 - 000080000000] Size: 2.00 GB GPT: CACHE [000201C08000 - 000010000000] Size: 256.00 MB GPT: USERDATA [000211C08000 - 001B6FBF3000] Size: 109.75 GB GPT: BACKUP_GPT [001D817FB000 - 000000005000] Size: 20.00 KB Reading Table Completed Scanning GUID Partition Table from LUN 1 GUID Partition Table is Found. Max Parts: 32 GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB GPT: XBL [000000006000 - 000000380000] Size: 3.50 MB GPT: XBL_CONFIG [000000386000 - 000000020000] Size: 128.00 KB GPT: LAST_PARTI [0000003A6000 - 000000455000] Size: 4.33 MB GPT: BACKUP_GPT [0000007FB000 - 000000005000] Size: 20.00 KB Reading Table Completed Scanning GUID Partition Table from LUN 2 GUID Partition Table is Found. Max Parts: 32 GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB GPT: XBLBAK [000000006000 - 000000380000] Size: 3.50 MB GPT: XBL_CONFIGBAK [000000386000 - 000000020000] Size: 128.00 KB GPT: LAST_PARTI [0000003A6000 - 000000455000] Size: 4.33 MB GPT: BACKUP_GPT [0000007FB000 - 000000005000] Size: 20.00 KB Reading Table Completed Scanning GUID Partition Table from LUN 3 GUID Partition Table is Found. Max Parts: 32 GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB GPT: ALIGN_TO_128K_1 [000000006000 - 00000001A000] Size: 104.00 KB GPT: CDT [000000020000 - 000000020000] Size: 128.00 KB GPT: DDR [000000040000 - 000000100000] Size: 1.00 MB GPT: LAST_PARTI [000000140000 - 000003EBB000] Size: 62.73 MB GPT: BACKUP_GPT [000003FFB000 - 000000005000] Size: 20.00 KB Reading Table Completed Scanning GUID Partition Table from LUN 4 GUID Partition Table is Found. Max Parts: 64 GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB GPT: RPM [000000006000 - 000000080000] Size: 512.00 KB GPT: TZ [000000086000 - 000000400000] Size: 4.00 MB GPT: HYP [000000486000 - 000000080000] Size: 512.00 KB GPT: MODEM [000000506000 - 00000B400000] Size: 180.00 MB GPT: BLUETOOTH [00000B906000 - 000000100000] Size: 1.00 MB GPT: MDTPSECAPP [00000BA06000 - 000000400000] Size: 4.00 MB GPT: MDTP [00000BE06000 - 000002000000] Size: 32.00 MB GPT: ABL [00000DE06000 - 000004000000] Size: 64.00 MB GPT: DSP [000011E06000 - 000002000000] Size: 32.00 MB GPT: KEYMASTER [000013E06000 - 000000080000] Size: 512.00 KB GPT: BOOT [000013E86000 - 000006000000] Size: 96.00 MB GPT: CMNLIB [000019E86000 - 000000080000] Size: 512.00 KB GPT: CMNLIB64 [000019F06000 - 000000080000] Size: 512.00 KB GPT: DEVCFG [000019F86000 - 000000020000] Size: 128.00 KB GPT: QUPFW [000019FA6000 - 000000010000] Size: 64.00 KB GPT: VBMETA [000019FB6000 - 000000010000] Size: 64.00 KB GPT: DTBO [000019FC6000 - 000001800000] Size: 24.00 MB GPT: IMAGEFV [00001B7C6000 - 000000200000] Size: 2.00 MB GPT: UEFISECAPP [00001B9C6000 - 000000200000] Size: 2.00 MB GPT: DEVINFO [00001BBC6000 - 000000001000] Size: 4.00 KB GPT: DIP [00001BBC7000 - 000000100000] Size: 1.00 MB GPT: APDP [00001BCC7000 - 000000040000] Size: 256.00 KB GPT: SPUNVM [00001BD07000 - 000000800000] Size: 8.00 MB GPT: SPLASH [00001C507000 - 0000020A4000] Size: 32.64 MB GPT: LIMITS [00001E5AB000 - 000000001000] Size: 4.00 KB GPT: TOOLSFV [00001E5AC000 - 000000100000] Size: 1.00 MB GPT: LOGFS [00001E6AC000 - 000000800000] Size: 8.00 MB GPT: CATELOADER [00001EEAC000 - 000000200000] Size: 2.00 MB GPT: RAWDUMP [00001F0AC000 - 000008000000] Size: 128.00 MB GPT: LOGDUMP [0000270AC000 - 000004000000] Size: 64.00 MB GPT: STORSEC [00002B0AC000 - 000000020000] Size: 128.00 KB GPT: MULTIIMGOEM [00002B0CC000 - 000000008000] Size: 32.00 KB GPT: MULTIIMGQTI [00002B0D4000 - 000000008000] Size: 32.00 KB GPT: UEFIVARSTORE [00002B0DC000 - 000000080000] Size: 512.00 KB GPT: SECDATA [00002B15C000 - 000000007000] Size: 28.00 KB GPT: CATEFV [00002B163000 - 000000080000] Size: 512.00 KB GPT: CATECONTENTFV [00002B1E3000 - 000000100000] Size: 1.00 MB GPT: LAST_PARTI [00002B2E3000 - 000014D18000] Size: 333.09 MB GPT: BACKUP_GPT [00003FFFB000 - 000000005000] Size: 20.00 KB Reading Table Completed Scanning GUID Partition Table from LUN 5 GUID Partition Table is Found. Max Parts: 32 GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB GPT: ALIGN_TO_128K_2 [000000006000 - 00000001A000] Size: 104.00 KB GPT: MODEMST1 [000000020000 - 000000200000] Size: 2.00 MB GPT: MODEMST2 [000000220000 - 000000200000] Size: 2.00 MB GPT: FSG [000000420000 - 000000200000] Size: 2.00 MB GPT: FSC [000000620000 - 000000020000] Size: 128.00 KB GPT: LAST_PARTI [000000640000 - 0000039BB000] Size: 57.73 MB GPT: BACKUP_GPT [000003FFB000 - 000000005000] Size: 20.00 KB Reading Table Completed Partition #4 mount as [/mnt/vendor/persist] -> 32.00 MB Partition #8 mount as [/dev_8] -> 16.00 MB Partition #10 mount as [/dev_10] -> 64.00 MB Partition #17 mount as [/dev_17] -> 5.50 GB Partition #18 mount as [/dev_18] -> 2.00 GB Partition #19 mount as [/cache] -> 256.00 MB Partition #20 mount as [/USERDATA] -> 109.75 GB Partition #46 mount as [/MODEM] -> 180.00 MB Partition #47 mount as [/BLUETOOTH] -> 1.00 MB Partition #51 mount as [/dev_51] -> 32.00 MB Partition #69 mount as [/LOGFS] -> 8.00 MB EmptyCheck: EMPTY -> #2 - [SSD] EMPTY -> #5 - [KEYSTORE] EMPTY -> #8 - [VGC] EMPTY -> #10 - [SEED] EMPTY -> #11 - [APANIC] EMPTY -> #13 - [RESERVED] EMPTY -> #25 - [LAST_PARTI] EMPTY -> #31 - [LAST_PARTI] EMPTY -> #35 - [ALIGN_TO_128K_1] EMPTY -> #36 - [CDT] EMPTY -> #38 - [LAST_PARTI] EMPTY -> #47 - [MDTPSECAPP] EMPTY -> #48 - [MDTP] EMPTY -> #62 - [DIP] EMPTY -> #63 - [APDP] EMPTY -> #64 - [SPUNVM] EMPTY -> #65 - [SPLASH] EMPTY -> #66 - [LIMITS] EMPTY -> #67 - [TOOLSFV] EMPTY -> #69 - [CATELOADER] EMPTY -> #70 - [RAWDUMP] EMPTY -> #71 - [LOGDUMP] EMPTY -> #73 - [MULTIIMGOEM] EMPTY -> #74 - [MULTIIMGQTI] EMPTY -> #77 - [CATEFV] EMPTY -> #78 - [CATECONTENTFV] EMPTY -> #79 - [LAST_PARTI] EMPTY -> #83 - [ALIGN_TO_128K_2] EMPTY -> #87 - [FSC] EMPTY -> #88 - [LAST_PARTI] EmptyCheck: Done ================================= Warning! Device Blocked by FRP For Reset FRP Try to Tools Tab Press Reset FRP Button Partition #7 -> FRP ================================= Android Info: Brand = vivo Vendor = vivo Device = PD1945F_EX Model = vivo 1920 Product = trinket CPU ABI = arm64-v8a Android Version = 9 Firm Version = PKQ1.190626.001 release-keys Inc. Version = compiler04111849 Firm Date = Sat Apr 11 18:48:25 CST 2020 Security Patch = 2020-04-01 Error Reading Inode. Invalid Inode Number.. Android Info: Platform = trinket Scanner Thread Terminated Elapsed: 00:00:14:329 Found 90 Partition(s).. Scan Done. Init Main Engine... Use EasyJtag UFS Device: KM8V7001JA-B813 Reader Engine Initialized.. 0/OK Source: EasyJtag Port [UFS] Power Mode: LOW Generation: GPT [QC/SAMS/BCM/INTEL/MTK] Config: 1011111111101111 Operation Done: [Init Engine], Elapsed: 00:00:00:026 Reading Android Info Partition #17 is '/system'. Mount.. Reading data.. Vendor = vivo Brand = vivo Model = vivo 1920 Device ID = PD1945F_EX Name ID = PD1945F_EX Android version = 9 Firm version = PKQ1.190626.001 release-keys Firm date = Sat Apr 11 18:48:25 CST 2020 SDK version = 28 Locale = en-US ID = PKQ1.190626.001 CPU ABI = arm64-v8a CPU ABI LIST = arm64-v8a,armeabi-v7a,armeabi CPU ABI LIST32 = armeabi-v7a,armeabi CPU ABI LIST64 = arm64-v8a Product = trinket Inc. Version = compiler04111849 Security Patch = 2020-04-01 Flavor = trinket-user Desc. = trinket-user 9 PKQ1.190626.001 compiler04111849 release-keys Reset User Locks v 2.0 Partition '/data' Not Found, Try Extended Search.. Partition #17 is '/data'. Mount.. ReMount to R/W Done.. Clear Step #1 -> 2 -> No File or Dir Clear Step #2 -> 2 -> No File or Dir Clear Step #3 -> 2 -> No File or Dir Clear Step #4 -> 2 -> No File or Dir Clear Step #5 -> 2 -> No File or Dir Clear Step #6 -> 2 -> No File or Dir Clear Step #7 -> 2 -> No File or Dir Clear Step #8 -> 2 -> No File or Dir Clear Step #9 -> 2 -> No File or Dir Clear Step #10 -> 2 -> No File or Dir Clear Step #11 -> 2 -> No File or Dir Clear Step #12 -> 2 -> No File or Dir Clear Step #13 -> 2 -> No File or Dir Clear Step #14 -> 2 -> No File or Dir Clear Step #15 -> 2 -> No File or Dir Clear Step #16 -> 2 -> No File or Dir FileSystem Closed.. Reset User Locks Done Reset Google FRP v1.0 Search FRP Partition.. Partition #7 -> 'FRP' is FRP. Erasing Partition. Please Wait.. Erasing Done Backup Saved as: C:\Program Files\Z3X\EmmcManager\Backup\FRP_BACKUP_0x00000218 8000_0x000000080000_20200715_123836.bin Reset FRP Done Elapsed Time: [00:00:02:030] Operation Done: [RESET FRP], Elapsed: 00:00:02:044 Reading Android Info Partition #17 is '/system'. Mount.. Reading data.. Vendor = vivo Brand = vivo Model = vivo 1920 Device ID = PD1945F_EX Name ID = PD1945F_EX Android version = 9 Firm version = PKQ1.190626.001 release-keys Firm date = Sat Apr 11 18:48:25 CST 2020 SDK version = 28 Locale = en-US ID = PKQ1.190626.001 CPU ABI = arm64-v8a CPU ABI LIST = arm64-v8a,armeabi-v7a,armeabi CPU ABI LIST32 = armeabi-v7a,armeabi CPU ABI LIST64 = arm64-v8a Product = trinket Inc. Version = compiler04111849 Security Patch = 2020-04-01 Flavor = trinket-user Desc. = trinket-user 9 PKQ1.190626.001 compiler04111849 release-keys Source: EasyJtag Port [UFS] Generation: GPT [QC/SAMS/BCM/INTEL/MTK] UFS Power Mode: LOW Scanner Thread Created.. Running EasyJtag UFS Mode... UFS ISP Mode: OFF UFS Safe Mode: ON Init UFS Engine: 0/OK EasyJtag Plus S/N: 6EA5A92882750D56 EasyJtag Plus Box FirmWare: 2.52 Box Hardware = EasyJtag 2nd Generation UFS: Socket Info: S/N: 0x0123177B866AC469EE Desc: EasyJTAG UFS Socket 3 in 1 by MOORC 12.07.19 Type: MOORK UFS Socket 3 in 1 ID: 2166 UFS: Voltage Info: Mode: LOW VCC : 3264 mV, VCCQ2: 1925 mV 3v3 : 3337 mV, 1v2: 1207 mV UFS: Memory Info: Connection: Socket BGA-254 Vendor: SAMSUNG Name: KM8V7001JA-B813 S/N: 3bc25c849e0d OEM ID: SAMSUNG_OEM_ID Firm Version: 9.00 Size: 0x001DCC800000/119.20 GB Max LUNs: 8 LUNs Cnt: 6 W-LUNs Cnt: 1 LUNs ReConfig: Enabled UFS Health Info: UFS Life Time A: 0x01 -> 0% - 10% Life Time Used UFS Life Time B: 0x01 -> 0% - 10% Life Time Used UFS Pre-EOL Info: 0x01 -> Used Less 80% of Reserved Blocks UFS: LUNs Info: LUN 0 -> Size: 30939136 Block(s)/118.02 GB LUN 1 (Boot A) -> Size: 2048 Block(s)/8.00 MB LUN 2 (Boot B) -> Size: 2048 Block(s)/8.00 MB LUN 3 -> Size: 16384 Block(s)/64.00 MB LUN 4 -> Size: 262144 Block(s)/1.00 GB LUN 5 -> Size: 16384 Block(s)/64.00 MB W-LUN 0xC4 (REPORT LUNS) -> Size: 65536 Block(s)/16.00 MB UFS Init OK Scanning Data From UFS Chip. Please wait.. Scanning GUID Partition Table from LUN 0 GUID Partition Table is Found. Max Parts: 32 GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB GPT: SSD [000000006000 - 000000002000] Size: 8.00 KB GPT: PERSIST [000000008000 - 000002000000] Size: 32.00 MB GPT: MISC [000002008000 - 000000100000] Size: 1.00 MB GPT: KEYSTORE [000002108000 - 000000080000] Size: 512.00 KB GPT: FRP [000002188000 - 000000080000] Size: 512.00 KB GPT: METADATA [000002208000 - 000001000000] Size: 16.00 MB GPT: VGC [000003208000 - 00000C800000] Size: 200.00 MB GPT: OEM [00000FA08000 - 000004000000] Size: 64.00 MB GPT: SEED [000013A08000 - 000000400000] Size: 4.00 MB GPT: APANIC [000013E08000 - 000000A00000] Size: 10.00 MB GPT: BACKUP [000014808000 - 000000A00000] Size: 10.00 MB GPT: RESERVED [000015208000 - 000000A00000] Size: 10.00 MB GPT: RECOVERY [000015C08000 - 000006000000] Size: 96.00 MB GPT: SURVIVAL [00001BC08000 - 000006000000] Size: 96.00 MB GPT: SYSTEM [000021C08000 - 000160000000] Size: 5.50 GB GPT: VENDOR [000181C08000 - 000080000000] Size: 2.00 GB GPT: CACHE [000201C08000 - 000010000000] Size: 256.00 MB GPT: USERDATA [000211C08000 - 001B6FBF3000] Size: 109.75 GB GPT: BACKUP_GPT [001D817FB000 - 000000005000] Size: 20.00 KB Reading Table Completed Scanning GUID Partition Table from LUN 1 GUID Partition Table is Found. Max Parts: 32 GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB GPT: XBL [000000006000 - 000000380000] Size: 3.50 MB GPT: XBL_CONFIG [000000386000 - 000000020000] Size: 128.00 KB GPT: LAST_PARTI [0000003A6000 - 000000455000] Size: 4.33 MB GPT: BACKUP_GPT [0000007FB000 - 000000005000] Size: 20.00 KB Reading Table Completed Scanning GUID Partition Table from LUN 2 GUID Partition Table is Found. Max Parts: 32 GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB GPT: XBLBAK [000000006000 - 000000380000] Size: 3.50 MB GPT: XBL_CONFIGBAK [000000386000 - 000000020000] Size: 128.00 KB GPT: LAST_PARTI [0000003A6000 - 000000455000] Size: 4.33 MB GPT: BACKUP_GPT [0000007FB000 - 000000005000] Size: 20.00 KB Reading Table Completed Scanning GUID Partition Table from LUN 3 GUID Partition Table is Found. Max Parts: 32 GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB GPT: ALIGN_TO_128K_1 [000000006000 - 00000001A000] Size: 104.00 KB GPT: CDT [000000020000 - 000000020000] Size: 128.00 KB GPT: DDR [000000040000 - 000000100000] Size: 1.00 MB GPT: LAST_PARTI [000000140000 - 000003EBB000] Size: 62.73 MB GPT: BACKUP_GPT [000003FFB000 - 000000005000] Size: 20.00 KB Reading Table Completed Scanning GUID Partition Table from LUN 4 GUID Partition Table is Found. Max Parts: 64 GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB GPT: RPM [000000006000 - 000000080000] Size: 512.00 KB GPT: TZ [000000086000 - 000000400000] Size: 4.00 MB GPT: HYP [000000486000 - 000000080000] Size: 512.00 KB GPT: MODEM [000000506000 - 00000B400000] Size: 180.00 MB GPT: BLUETOOTH [00000B906000 - 000000100000] Size: 1.00 MB GPT: MDTPSECAPP [00000BA06000 - 000000400000] Size: 4.00 MB GPT: MDTP [00000BE06000 - 000002000000] Size: 32.00 MB GPT: ABL [00000DE06000 - 000004000000] Size: 64.00 MB GPT: DSP [000011E06000 - 000002000000] Size: 32.00 MB GPT: KEYMASTER [000013E06000 - 000000080000] Size: 512.00 KB GPT: BOOT [000013E86000 - 000006000000] Size: 96.00 MB GPT: CMNLIB [000019E86000 - 000000080000] Size: 512.00 KB GPT: CMNLIB64 [000019F06000 - 000000080000] Size: 512.00 KB GPT: DEVCFG [000019F86000 - 000000020000] Size: 128.00 KB GPT: QUPFW [000019FA6000 - 000000010000] Size: 64.00 KB GPT: VBMETA [000019FB6000 - 000000010000] Size: 64.00 KB GPT: DTBO [000019FC6000 - 000001800000] Size: 24.00 MB GPT: IMAGEFV [00001B7C6000 - 000000200000] Size: 2.00 MB GPT: UEFISECAPP [00001B9C6000 - 000000200000] Size: 2.00 MB GPT: DEVINFO [00001BBC6000 - 000000001000] Size: 4.00 KB GPT: DIP [00001BBC7000 - 000000100000] Size: 1.00 MB GPT: APDP [00001BCC7000 - 000000040000] Size: 256.00 KB GPT: SPUNVM [00001BD07000 - 000000800000] Size: 8.00 MB GPT: SPLASH [00001C507000 - 0000020A4000] Size: 32.64 MB GPT: LIMITS [00001E5AB000 - 000000001000] Size: 4.00 KB GPT: TOOLSFV [00001E5AC000 - 000000100000] Size: 1.00 MB GPT: LOGFS [00001E6AC000 - 000000800000] Size: 8.00 MB GPT: CATELOADER [00001EEAC000 - 000000200000] Size: 2.00 MB GPT: RAWDUMP [00001F0AC000 - 000008000000] Size: 128.00 MB GPT: LOGDUMP [0000270AC000 - 000004000000] Size: 64.00 MB GPT: STORSEC [00002B0AC000 - 000000020000] Size: 128.00 KB GPT: MULTIIMGOEM [00002B0CC000 - 000000008000] Size: 32.00 KB GPT: MULTIIMGQTI [00002B0D4000 - 000000008000] Size: 32.00 KB GPT: UEFIVARSTORE [00002B0DC000 - 000000080000] Size: 512.00 KB GPT: SECDATA [00002B15C000 - 000000007000] Size: 28.00 KB GPT: CATEFV [00002B163000 - 000000080000] Size: 512.00 KB GPT: CATECONTENTFV [00002B1E3000 - 000000100000] Size: 1.00 MB GPT: LAST_PARTI [00002B2E3000 - 000014D18000] Size: 333.09 MB GPT: BACKUP_GPT [00003FFFB000 - 000000005000] Size: 20.00 KB Reading Table Completed Scanning GUID Partition Table from LUN 5 GUID Partition Table is Found. Max Parts: 32 GPT: GPT [000000000000 - 000000006000] Size: 24.00 KB GPT: ALIGN_TO_128K_2 [000000006000 - 00000001A000] Size: 104.00 KB GPT: MODEMST1 [000000020000 - 000000200000] Size: 2.00 MB GPT: MODEMST2 [000000220000 - 000000200000] Size: 2.00 MB GPT: FSG [000000420000 - 000000200000] Size: 2.00 MB GPT: FSC [000000620000 - 000000020000] Size: 128.00 KB GPT: LAST_PARTI [000000640000 - 0000039BB000] Size: 57.73 MB GPT: BACKUP_GPT [000003FFB000 - 000000005000] Size: 20.00 KB Reading Table Completed Partition #4 mount as [/mnt/vendor/persist] -> 32.00 MB Partition #8 mount as [/dev_8] -> 16.00 MB Partition #10 mount as [/dev_10] -> 64.00 MB Partition #17 mount as [/dev_17] -> 5.50 GB Partition #18 mount as [/dev_18] -> 2.00 GB Partition #19 mount as [/cache] -> 256.00 MB Partition #20 mount as [/USERDATA] -> 109.75 GB Partition #46 mount as [/MODEM] -> 180.00 MB Partition #47 mount as [/BLUETOOTH] -> 1.00 MB Partition #51 mount as [/dev_51] -> 32.00 MB Partition #69 mount as [/LOGFS] -> 8.00 MB EmptyCheck: EMPTY -> #2 - [SSD] EMPTY -> #5 - [KEYSTORE] EMPTY -> #6 - [FRP] EMPTY -> #8 - [VGC] EMPTY -> #10 - [SEED] EMPTY -> #11 - [APANIC] EMPTY -> #13 - [RESERVED] EMPTY -> #25 - [LAST_PARTI] EMPTY -> #31 - [LAST_PARTI] EMPTY -> #35 - [ALIGN_TO_128K_1] EMPTY -> #36 - [CDT] EMPTY -> #38 - [LAST_PARTI] EMPTY -> #47 - [MDTPSECAPP] EMPTY -> #48 - [MDTP] EMPTY -> #62 - [DIP] EMPTY -> #63 - [APDP] EMPTY -> #64 - [SPUNVM] EMPTY -> #65 - [SPLASH] EMPTY -> #66 - [LIMITS] EMPTY -> #67 - [TOOLSFV] EMPTY -> #69 - [CATELOADER] EMPTY -> #70 - [RAWDUMP] EMPTY -> #71 - [LOGDUMP] EMPTY -> #73 - [MULTIIMGOEM] EMPTY -> #74 - [MULTIIMGQTI] EMPTY -> #77 - [CATEFV] EMPTY -> #78 - [CATECONTENTFV] EMPTY -> #79 - [LAST_PARTI] EMPTY -> #83 - [ALIGN_TO_128K_2] EMPTY -> #87 - [FSC] EMPTY -> #88 - [LAST_PARTI] EmptyCheck: Done Android Info: Brand = vivo Vendor = vivo Device = PD1945F_EX Model = vivo 1920 Product = trinket CPU ABI = arm64-v8a Android Version = 9 Firm Version = PKQ1.190626.001 release-keys Inc. Version = compiler04111849 Firm Date = Sat Apr 11 18:48:25 CST 2020 Security Patch = 2020-04-01 Android Info: Platform = trinket Scanner Thread Terminated Elapsed: 00:00:09:214 Found 90 Partition(s).. Scan Done. Init Main Engine... Use EasyJtag UFS Device: KM8V7001JA-B813 Reader Engine Initialized.. 0/OK Source: EasyJtag Port [UFS] Power Mode: LOW Generation: GPT [QC/SAMS/BCM/INTEL/MTK] Config: 1011111111101111 Operation Done: [Init Engine], Elapsed: 00:00:00:025 need sos help Regards |
07-24-2020, 20:29 | #4 (permalink) |
Junior Member Join Date: Dec 2008
Member: 929468 Status: Offline Thanks Meter: 4 | я НЕ собираюсь переводить, - сами переведете. Используйте гугл переводчик. Зачем было жать куда не следует???? Partition '/data' Not Found, Try Extended Search.. Partition #17 is '/data'. Mount.. ReMount to R/W Done.. Partition #17 mount as [/dev_17] -> 5.50 GB GPT: SYSTEM [000021C08000 - 000160000000] Size: 5.50 GB вы ПОВРЕДИЛИ раздел систем. и что то хотите? Вам нужно было снять пароль? Ну так отформатируйте юзердату, а потом, когда вернете UFS на место - сделайте вайп из рекавери. в чем проблема? Зачем своими кривыми ручонками жать на кнопки совсем не предназначенные для этого??? Запишите раздел систем из прошивки в /system и телефон включится. |
The Following User Says Thank You to antinachai For This Useful Post: |
07-24-2020, 22:01 | #5 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | I was discuss you problem with EFM support You are pressed randomly buttons at software and you damage system partitition, and you device not start You need to learn to understand the situation and do only what you have already understood. If you press all the buttons in a software, you will get a non-working device |
07-25-2020, 18:09 | #6 (permalink) | |
Member: 221603 Status: Offline Sonork: 100.1581270 Thanks Meter: 6,395 | Quote:
and reset google frp for reset google id what else..? i did not press all the button help me to alive this phone please Regards | |
07-26-2020, 14:47 | #7 (permalink) | |
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
If you open access to system partition - device may be can't be verify security to run (boot) Last edited by layder; 07-26-2020 at 14:58. | |
