11-02-2016, 14:59 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: chennai Age: 38
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | Samsung n7100 emmc repaire done --------------------------------------------- Backup saved: VTU00M_1027180166_20161102_1311.extcsd Done. Running:SAMSUNG: MoviNAND Reset + Format...Z3X EasyJtag Software ver. 2.3.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:763 mVCMD Active Level:2248 mV Box IO Level:2800 mV CLK Rate:21000 khz EMMC ROM2/3 (Boot Partitions) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Sending Internal Reconfiguration Request... Waiting configuration Apply! Restoring configuration... EMMC ROM2/3 (Boot Partitions) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Wiping Card... Please do not touch it! Please don't forget to repair extCSD from backup! Done. Running:SAMSUNG: MoviNAND Factory Reset...Skip loading eMMC Addon Firmware CMD Pullup Level:763 mVCMD Active Level:2248 mV Box IO Level:2800 mV CLK Rate:21000 khz Sending Smart Wipe Request... Wiping Card... Please do not touch it! Please don't forget to repair extCSD from backup! Done. extCSD file...C:\Users\user\Desktop\N7100 EXTCSD\N7100 EXTCSD.extcsd Running:Repair extCSD...Z3X EasyJtag Software ver. 2.3.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:763 mVCMD Active Level:2248 mV Box IO Level:2800 mV CLK Rate:21000 khz Writing... Done. Checking NAND Image : E:\N7100\N7100_ROM1_Alive_Dump_BN\EMMC_00000000_00 200000.bin File successefuly loaded! Checking NAND Image : E:\N7100\N7100_ROM1_Alive_Dump_BN\EMMC_00000000_00 200000.bin File successefuly loaded! Processing file...E:\N7100\N7100_ROM1_Alive_Dump_BN\EMMC_0000 0000_00200000.bin Z3X EasyJtag Software ver. 2.3.0.1Skip loading eMMC Addon Firmware CMD Pullup Level:763 mVCMD Active Level:2248 mV Input file : E:\N7100\N7100_ROM1_Alive_Dump_BN\EMMC_00000000_00 200000.binWriting 0000200000 bytes to 00000000 ...ROM2 (BOOT1 ROM) Full Verify Enabled! Done. Write Speed: 640 kB/s Processing file...E:\N7100\N7100_ROM1_Alive_Dump_BN\EMMC_0000 0000_00200000.bin Z3X EasyJtag Software ver. 2.3.0.1Skip loading eMMC Addon Firmware CMD Pullup Level:763 mVCMD Active Level:2248 mV Input file : E:\N7100\N7100_ROM1_Alive_Dump_BN\EMMC_00000000_00 200000.binWriting 0000200000 bytes to 00000000 ...ROM2 (BOOT1 ROM) Full Verify Enabled! Done. Write Speed: 646 kB/s Z3X EasyJtag Software ver. 2.3.0.1 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 010070222EE63D88, ,FW Ver.: 01.55CMD Pullup Level:763 mV CMD Active Level:2248 mV Box IO Level:2800 mV CLK Rate:21000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 15010056545530304DFC3D39868641FA EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 04/2014 Rev.0xFC EMMC NAME: VTU00M , S/N: 1027180166 EMMC NAME (HEX): 56545530304D00 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: VTU00M_1027180166_20161102_1315.extcsd Done. Checking NAND Image : E:\N7100\N7100_ROM1_Alive_Dump_BN\EMMC_00000000_00 200000.bin File successefuly loaded! Processing file...E:\N7100\N7100_ROM1_Alive_Dump_BN\EMMC_0000 0000_00200000.bin Z3X EasyJtag Software ver. 2.3.0.1Skip loading eMMC Addon Firmware CMD Pullup Level:763 mVCMD Active Level:2248 mV Input file : E:\N7100\N7100_ROM1_Alive_Dump_BN\EMMC_00000000_00 200000.binWriting 0000200000 bytes to 00000000 ...ROM2 (BOOT1 ROM) Full Verify Enabled! Done. Write Speed: 646 kB/s Processing file...E:\N7100\N7100_ROM1_Alive_Dump_BN\EMMC_0000 0000_00200000.bin Z3X EasyJtag Software ver. 2.3.0.1Skip loading eMMC Addon Firmware CMD Pullup Level:763 mVCMD Active Level:2248 mV Input file : E:\N7100\N7100_ROM1_Alive_Dump_BN\EMMC_00000000_00 200000.bin Writing 0000200000 bytes to 00000000 ...ROM2 (BOOT1 ROM) Done. Write Speed: 1305 kB/s Checking NAND Image : E:\N7100\N7100_ROM1_Alive_Dump_BN\N7100_Rom1_Alive _Dump_BN.bin File successefuly loaded! Processing file...E:\N7100\N7100_ROM1_Alive_Dump_BN\N7100_Rom 1_Alive_Dump_BN.bin Z3X EasyJtag Software ver. 2.3.0.1Skip loading eMMC Addon Firmware CMD Pullup Level:763 mVCMD Active Level:2248 mV Input file : E:\N7100\N7100_ROM1_Alive_Dump_BN\N7100_Rom1_Alive _Dump_BN.bin Writing 0020000000 bytes to 00000000 ...ROM1 (USER ROM) Done. Write Speed: 8833 kB/s Z3X EasyJtag Software ver. 2.3.0.1 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 010070222EE63D88, ,FW Ver.: 01.55CMD Pullup Level:752 mV CMD Active Level:2237 mV Box IO Level:2800 mV CLK Rate:21000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 15010056545530304DFC3D39868641FA EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 04/2014 Rev.0xFC EMMC NAME: VTU00M , S/N: 1027180166 EMMC NAME (HEX): 56545530304D00 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: VTU00M_1027180166_20161102_1317.extcsd Done. Running:Change BOOT CONFIG...Z3X EasyJtag Software ver. 2.3.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:752 mVCMD Active Level:2237 mV Box IO Level:2800 mV CLK Rate:21000 khz Writing eMMC Register... Written: REG : 179 VAL :48 Done. Running:Change BOOT WIDTH... Z3X EasyJtag Software ver. 2.3.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:752 mV CMD Active Level:2237 mV Box IO Level:2800 mV CLK Rate:21000 khz Writing eMMC Register... Written: REG : 177 VAL :1 Done. Z3X EasyJtag Software ver. 2.3.0.1 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 010070222EE63D88, ,FW Ver.: 01.55CMD Pullup Level:763 mV CMD Active Level:2258 mV Box IO Level:2800 mV CLK Rate:21000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 15010056545530304DFC3D39868641FA EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 04/2014 Rev.0xFC EMMC NAME: VTU00M , S/N: 1027180166 EMMC NAME (HEX): 56545530304D00 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: VTU00M_1027180166_20161102_1318.extcsd Searching for partition tables... Detected GPT over MBR... Warning: Header Size = 512 (expected 92) Medium UUID: 52444E41-494F-2044-4D4D-43204449534B Warning: Entries Count = 128 MMCBLK0P0 (BOTA0) Range: [0X400000,0X7FFE00] ,Len: 400000 MMCBLK0P1 (BOTA1) Range: [0X800000,0XBFFE00] ,Len: 400000 MMCBLK0P2 (EFS) Range: [0XC00000,0X1FFFE00] ,Len: 1400000 MMCBLK0P3 (M9KEFS1) Range: [0X2000000,0X23FFE00] ,Len: 400000 MMCBLK0P4 (M9KEFS2) Range: [0X2400000,0X27FFE00] ,Len: 400000 MMCBLK0P5 (M9KEFS3) Range: [0X2800000,0X2BFFE00] ,Len: 400000 MMCBLK0P6 (PARAM) Range: [0X2C00000,0X33FFE00] ,Len: 800000 MMCBLK0P7 (BOOT) Range: [0X3400000,0X3BFFE00] ,Len: 800000 MMCBLK0P8 (RECOVERY) Range: [0X3C00000,0X43FFE00] ,Len: 800000 MMCBLK0P9 (RADIO) Range: [0X4400000,0X9BFFE00] ,Len: 5800000 MMCBLK0P10 (TOMBSTONES) Range: [0X9C00000,0X9FFFE00] ,Len: 400000 MMCBLK0P11 (CACHE) Range: [0XA000000,0X5F7FFE00] ,Len: 55800000 MMCBLK0P12 (SYSTEM) Range: [0X5F800000,0XDF7FFE00] ,Len: 80000000 MMCBLK0P13 (HIDDEN) Range: [0XDF800000,0X1027FFE00] ,Len: 23000000 MMCBLK0P14 (OTA) Range: [0X102800000,0X102FFFE00] ,Len: 800000 MMCBLK0P15 (USERDATA) Range: [0X103000000,0X3AAFFFE00] ,Len: 2A8000000 Done...Presets has been updated... Done. perfect done |
The Following 2 Users Say Thank You to umarmsn For This Useful Post: |
11-17-2016, 18:05 | #3 (permalink) |
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | 1)Running:SAMSUNG: MoviNAND Reset + Format. 2)Running:SAMSUNG: MoviNAND Factory Reset 3)extCSD file...C:\Users\user\Desktop\N7100 EXTCSD\N7100 EXTCSD.extcsd 4)Checking NAND Image : E:\N7100\N7100_ROM1_Alive_Dump_BN\EMMC_00000000_00 200000.bin 5)Running:Change BOOT CONFIG...Z3X EasyJtag Software ver. 2.3.0.1 6)Running:Change BOOT WIDTH this my procedure |
