08-31-2019, 15:36 | #1 (permalink) |
Moderator Join Date: Jan 2008 Location: <jeddah al saudia> Age: 36
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | KMVTU000LM-B503 bugs in v3.6 Z3X EasyJtag Software ver. 3.6.1.15 - eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 08/2012 Rev.0xF1 eMMC NAME: VTU00M , S/N: 1808945721 eMMC NAME (HEX): 56545530304D IC Name: Samsung , KMVTU000LM-B503/16GB @FBGA153 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC RPMB is programmed and written 2 times EMMC Permanent Write Protection: Yes EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00014000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: VTU00M_1808945721_20190831_1714.extcsd Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x005F800000 (2.0GB) Build ID: KOT49H Display Build ID: KOT49H.N7100XXUFND4 Release Incremental ID: N7100XXUFND4 Release Base ID: 4.4.2 Device Model: GT-N7100 Device Name: t03gxx Architecture ABI: armeabi-v7a Device manufacturer: samsung Device Platform: exynos4 Product ID: t03g Build Description: t03gxx-user 4.4.2 KOT49H N7100XXUFND4 release-keys Samsung CPU: smdk4x12 --------------------------------------------- Detected USERDATA USERDATA : 0x0103000000 (10.625GB) Blocks Reading Error (0x103000400 , 2 , Reason: PORT Read Error ) Unable to mount USERDATA , code : 5 Done. --------------------------------------------------------- Setup firmware update mode, wait 2..30 sec... Success! Sending eMMC firmware... Success! Verifying eMMC firmware... Success! Flashing eMMC firmware... Success! Repairing eMMC CID... Success! eMMC firmware is updated now! Please reconnect all eMMC lines before next operation! Please don't forget to repair extCSD from backup! Please don't forget to configure BOOT sizes! Done. Running:SAMSUNG: MoviNAND Reset + Format... Z3X EasyJtag Software ver. 3.5.0.0 |
