09-07-2020, 15:35 | #1 (permalink) |
No Life Poster Join Date: Feb 2010 Location: india
Member: 1246696 Status: Offline Sonork: 100.1681950 Thanks Meter: 650 | samsunf hang on recovery Microsoft Windows 10 (64 bit) build 18363 (10.0.18362.959) Looking for EasyJTAG box... EasyJTAG API ver. 3401 EasyJTAG Box Serial = 6FC4F531CBAD89A1 Card Serial = AAA530D3 EasyJTAG Box Firmware = 2.5204 Changelog: 23.06.2020 (ver 1.6.3.0) Fix: Bugs that have been found through your crash report Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 24 MHz CMD Pullup Level: 2105 mV CMD Active Level: 2297 mV EMMC Device Information : EMMC CID: 1101003530303037330058D21C57B30D EMMC CSD: D07E00320F5903FFFFFFFFE78A4000D1 EMMC Manufacture : TOSHIBA , EMMC NAME: 500073 , HEX: 353030303733 , S/N: 58D21C57 , rev. 0x00 EMMC Manufacture ID: 0x11 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 11/2016 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 13473 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: 500073_58D21C57_20200907_195903.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: sbl1, [000000400000 - 000000480000], size: 000000080000 (512. KB) Partition: sbl1bak, [000000480000 - 000000500000], size: 000000080000 (512. KB) Partition: ddr, [000000500000 - 000000508000], size: 000000008000 (32.0 KB) Partition: limits, [000000508000 - 000000510000], size: 000000008000 (32.0 KB) Partition: aboot, [000000510000 - 000000710000], size: 000000200000 (2.00 MB) Partition: rpm, [000000710000 - 000000790000], size: 000000080000 (512. KB) Partition: tz, [000000790000 - 000000990000], size: 000000200000 (2.00 MB) Partition: hyp, [000000990000 - 000000A10000], size: 000000080000 (512. KB) Partition: fsg, [000000A10000 - 000000D10000], size: 000000300000 (3.00 MB) Partition: sec, [000000D10000 - 000000D14000], size: 000000004000 (16.0 KB) Partition: keymaster, [000000D14000 - 000000D54000], size: 000000040000 (256. KB) Partition: cmnlib, [000000D54000 - 000000D94000], size: 000000040000 (256. KB) Partition: pad, [000000D94000 - 000001800000], size: 000000A6C000 (10.4 MB) Partition: modemst1, [000001800000 - 000001B00000], size: 000000300000 (3.00 MB) Partition: modemst2, [000001B00000 - 000001E00000], size: 000000300000 (3.00 MB) Partition: param, [000001E00000 - 000002800000], size: 000000A00000 (10.0 MB) Partition: efs, [000002800000 - 000003600000], size: 000000E00000 (14.0 MB) Partition: boot, [000003600000 - 000005600000], size: 000002000000 (32.0 MB) Partition: recovery, [000005600000 - 000007600000], size: 000002000000 (32.0 MB) Partition: bota, [000007600000 - 000007D00000], size: 000000700000 (7.00 MB) Partition: fota, [000007D00000 - 000008200400], size: 000000500400 (5.00 MB) Partition: backup, [000008200400 - 0000087FE000], size: 0000005FDC00 (5.99 MB) Partition: fsc, [0000087FE000 - 000008AFE000], size: 000000300000 (3.00 MB) Partition: ssd, [000008AFE000 - 000008B00000], size: 000000002000 (8.00 KB) Partition: persist, [000008B00000 - 00000AB00000], size: 000002000000 (32.0 MB) Partition: persistent, [00000AB00000 - 00000AC00000], size: 000000100000 (1.00 MB) Partition: steady, [00000AC00000 - 00000AD00000], size: 000000100000 (1.00 MB) Partition: keystore, [00000AD00000 - 00000AD80000], size: 000000080000 (512. KB) Partition: config, [00000AD80000 - 00000AD88000], size: 000000008000 (32.0 KB) Partition: mota, [00000AD88000 - 00000AE88000], size: 000000100000 (1.00 MB) Partition: devcfg, [00000AE88000 - 00000AEC8000], size: 000000040000 (256. KB) Partition: dsp, [00000AEC8000 - 00000BEC8000], size: 000001000000 (16.0 MB) Partition: modem, [00000BEC8000 - 000012700000], size: 000006838000 (104. MB) Partition: apnhlos, [000012700000 - 000013F00000], size: 000001800000 (24.0 MB) Partition: persdata, [000013F00000 - 000014800000], size: 000000900000 (9.00 MB) Partition: system, [000014800000 - 00010E800000], size: 0000FA000000 (3.91 GB) Partition: cache, [00010E800000 - 000124600000], size: 000015E00000 (350. MB) Partition: userdata, [000124600000 - 000747BFB000], size: 0006235FB000 (24.5 GB) GPT header successfully parsed Get firmware version Brand = samsung Manufacturer = samsung Device = a9xproltesea Model = SM-A910F Phone platform = msm8952 CPU Abi = arm64-v8a Android release = 6.0.1 Security Patch = 2016-06-01 Firmware version = MMB29M.A910FXXU1APFC Firmware date = Tue Jun 21 22:58:06 KST 2016 i try too man version but set honh on recovery some time hang on logo |
