05-12-2019, 08:35 | #1 (permalink) |
Freak Poster Join Date: Jun 2010 Location: South Azerbaycan Age: 40
Member: 1333047 Status: Offline Sonork: 100.1618775 Thanks Meter: 278 | need redmi s2/y2 full dump I need full EMMC dump for xiaomi redmi S2/Y2 emergency. please share your backups. thanks in advance. |
05-20-2019, 10:13 | #2 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
Redmi S2 backup by vendor w/o system & userdata | |
The Following 5 Users Say Thank You to layder For This Useful Post: |
05-23-2019, 17:15 | #4 (permalink) | |
Member: 1333047 Status: Offline Sonork: 100.1618775 Thanks Meter: 278 | Quote:
06-26-2019, 17:04 | #9 (permalink) |
No Life Poster Join Date: Jan 2010
Member: 1212133 Status: Offline Thanks Meter: 58 | Xiaomi Redmi S2 - eMMC - good or bad? Xiaomi Redmi S2, when connected to a computer, shows QLoader 9008 error. I desolder eMMC and checked with EasyJtag : Setting frequence to 21 Mhz CMD Pullup Level: 3217 mV CMD Active Level: 3310 mV EMMC Device Information : EMMC CID: 0600003136FFFFFFFFFF195C493934EA EMMC CSD: 8C4F012A0F598000F6D801E08A400076 EMMC Manufacture : , EMMC NAME: 16 , HEX: 313600000000 , S/N: 195C4939 , rev. 0xFF EMMC Manufacture ID: 0x06 , OEM ID: 0x00 , Device Type: Device (removable) , Date: 3/2017 EMMC ROM 1 (Main User Data) Capacity: 31596 MB (0007B6C80000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 0 KB (000000000000) EMMC RPMB (Replay Protected Memory Block) Capacity: 0 KB (000000000000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: Yes Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: 16_195C4939_20190626_161702.extcsd EMMC Init completed. Error: EMMC Password Locked Setting frequence to 21 Mhz CMD Pullup Level: 3217 mV CMD Active Level: 3310 mV EMMC Device Information : EMMC CID: 0600003136FFFFFFFFFF195C493934EA EMMC CSD: 8C4F012A0F598000F6D801E08A400076 EMMC Manufacture : , EMMC NAME: 16 , HEX: 313600000000 , S/N: 195C4939 , rev. 0xFF EMMC Manufacture ID: 0x06 , OEM ID: 0x00 , Device Type: Device (removable) , Date: 3/2017 EMMC ROM 1 (Main User Data) Capacity: 31596 MB (0007B6C80000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 0 KB (000000000000) EMMC RPMB (Replay Protected Memory Block) Capacity: 0 KB (000000000000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: Yes Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: 16_195C4939_20190626_161722.extcsd EMMC Init completed. Operation: File Explorer... Scan from: 16 Error reading at address: 000000000000 , error: -206, PORT Read Error ... Retry #1 Error reading at address: 000000000000 , error: -206, PORT Read Error ... Retry #2 Error reading at address: 000000000000 , error: -206, PORT Read Error ... Retry #3 Too many errors. Reading has been stopped Error reading at address: 0007B6C7C000 , error: -206, PORT Read Error ... Retry #1 Error reading at address: 0007B6C7C000 , error: -206, PORT Read Error ... Retry #2 Error reading at address: 0007B6C7C000 , error: -206, PORT Read Error ... Retry #3 Too many errors. Reading has been stopped Vendor: Qualcomm Searching GPT ... Error reading at address: 000000000000 , error: -206, PORT Read Error ... Retry #1 Error reading at address: 000000000000 , error: -206, PORT Read Error ... Retry #2 Error reading at address: 000000000000 , error: -206, PORT Read Error ... Retry #3 Too many errors. Reading has been stopped GPT header is not found Searching MBR ... Error reading at address: 000000000000 , error: -206, PORT Read Error ... Retry #1 Error reading at address: 000000000000 , error: -206, PORT Read Error ... Retry #2 Error reading at address: 000000000000 , error: -206, PORT Read Error ... Retry #3 Too many errors. Reading has been stopped MBR header is not found Partition table not found Is it enough to test that eMMC is OK and the QLoader 9008 error is caused by something else? Thanks for reply |
06-28-2019, 21:22 | #11 (permalink) |
Member: 1212133 Status: Offline Thanks Meter: 58 | Thanks for the reply. Do you mean that eMMC itself ( hardware) is good? But if I flash with dump will it work? It is Xiaomi and eMMC is linked with CPU. Or can you let me know how to resize the partition? |
07-01-2019, 10:39 | #15 (permalink) |
Member: 1212133 Status: Offline Thanks Meter: 58 | Thank you for your replies. @layder: But when using the latest EasyJtag version, it does not reports Password protected Setting frequence to 21 MHz CMD Pullup Level: 3021 mV CMD Active Level: 1815 mV EMMC Device Information : EMMC CID: 0600003136FFFFFFFFFF195C493934EA EMMC CSD: 8C4F012A0F598000F6D801E08A400076 EMMC Manufacture : , EMMC NAME: 16 , HEX: 313600000000 , S/N: 195C4939 , rev. 0xFF EMMC Manufacture ID: 0x06 , OEM ID: 0x00 , Device Type: Device (removable) , Date: 3/2001 EMMC ROM 1 (Main User Data) Capacity: 31596 MB (0007B6C80000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 0 KB (000000000000) EMMC RPMB (Replay Protected Memory Block) Capacity: 0 KB (000000000000) Counter: 0 , Response: Maybe not clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.0 (MMC 4.0) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x00 Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: 16_195C4939_20190627_095207.extcsd EMMC Init completed. Do you have any explanation? I can try to format eMMC and write dump, but isn't eMMC linked with CPU in Xiaomi? And eMMC can not be replaced but only together with CPU from the same mainboard? Can EasyJtag help? Any advice? Thank you for help |
