Old 09-15-2020, 10:38   #1 (permalink)
-=jeovel=-'s Avatar
Member: 1604158
Sonork: 100.1614304
Thanks Meter: 110
Samsung A10s (A107F) hang After android clear FRP
i received this phone FRP problem
after i select the android clear FRP it Become hang
in samsung logo only..
Selected pinout: GEN2 ISP Pinout
Change EasyJTAG Pinout OK
Running:Format FRP Partition...
Z3X EasyJtag Software ver. 3.7.0.17
Loading eMMC GEN2 Firmware... IO: 2800 mV
Box S/N: 0E18952ECE3F4D73, ,FW Ver.: 02.52
CMD Pullup Level:2095 mV
CMD Active Level:2253 mV
Box IO Level:2800 mV
CLK Rate:24000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
---------- eMMC Device Information ----------
eMMC CID : 150100514436334D4203DCA5D384863B
eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D
eMMC Manufacturer ID: 0015 , OEM ID: 0100
eMMC Date: 08/2019 Rev.0x3
eMMC NAME: QD63MB , S/N: 3701855108
eMMC NAME (HEX): 514436334D42
EMMC ROM1 (Main User Data) Capacity: 29820 MB , 0x3A3E000 pages , 0x747C00000 bytes
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB
EMMC RPMB is programmed and written 652 times
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x02 , width 8bits , Partition config [179]: 0x48.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Partition info successfully found
Formatting FRP...
Detected LINUX(Android) FRP : 0x0008700000 (1.0MB) formatting...
Done.
Detected LINUX(Android) PERSISTENT : 0x0015000000 (512.0KB) formatting...
Done.
Detected LINUX(Android) CACHE : 0x0134000000 (400.0MB) , formatting...
Done.
Detected LINUX(Android) USERDATA : 0x0150000000 (23.867GB) , formatting...
Done.
Done.
Done.
Pls. Help me to recover the phone thanks
Old 09-15-2020, 14:09   #2 (permalink)
rebainoor's Avatar
Member: 231728
Thanks Meter: 1,589
You think userdata partition its an ext4 file system !
Page generated in 0.20595 seconds with 7 queries
