03-02-2022, 15:12 | #1 (permalink) |
No Life Poster Join Date: Jan 2009 Location: obamas village
Member: 952862 Status: Offline Thanks Meter: 48 | samsung a127f coonected but no chip name Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 1010FB0XXXXx, ,FW Ver.: 01.63 CMD Pullup Level:3114 mV CMD Active Level:3248 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100303030303030562016061354D0 eMMC CSD : 902701320F5903FFF6DB7FE08A40403A eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 05/2017 Rev.0x56 eMMC NAME: 000000 , S/N: 538314259 eMMC NAME (HEX): 303030303030 EMMC ROM1 (Main User Data) Capacity: 2095982 MB EMMC ROM2 (Boot Partition 1) Capacity: 512 kB EMMC ROM3 (Boot Partition 2) Capacity: 512 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC RPMB is not yet programmed (clear) or RPMB Authentication failure EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: 000000_ 538314259_20220302_1702.extcsd hi team connected like 4 pcs but i get that error Operation: Connect to Z3X EasyJtag Setting Interface to EasyJtag1/ISP Setting IO Levels to 1.8V Setting Frequence to 21 Mhz Setting BusWidth to 1 Bit CMD Pullup Level: 2000 mV CMD Active Level: 2052 mV Setting HS Timing to Enabled Error: Previous operation is not finished yet Error: Previous operation is not finished yet Warning: Failed to set BusWidth. Check eMMC connection EMMC Device Information : EMMC CID: 150100303030303030562016061354D0 EMMC CSD: 902701320F5903FFF6DB7FE08A40403A Manufacturer: SAMSUNG , NAME: 000000 , HEX: 303030303030 , S/N: 20160613 , Rev: 56 Manufacturer ID: 15 , OEM ID: 00 , Device Type: BGA (Discrete embedded) , Date: 5/2017 EMMC ROM 1 (Main User Data) Capacity: 2095982 MB (0x01FFB6E00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 512 KB (0x000000080000) EMMC RPMB Capacity: 128 KB (0x000000020000) , Counter: 0 , Response: Maybe not Clean Extended CSD Information : Extended CSD rev: 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG]: 0x00 , Device not boot enabled Boot Bus Config: 0x00 , x1 (sdr) or x4 (ddr) bus width in boot operation mode H/W Reset Function [RST_N_FUNCTION]: 0x00 , RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x03 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Partition settings [PARTITION_SETTING_COMPLETED]: 0x00 EMMC Init completed Warning: Maybe your EMMC is damaged eMMC is unusable BUt u remove from isp phone can switch on its mdm locked |
03-02-2022, 15:19 | #2 (permalink) |
Member: 952862 Status: Offline Thanks Meter: 48 | trying to dump emmc firmware i get this Backup saved: 000000_ 538314259_20220302_1702.extcsd Blocks Reading Error (0x0 , 1 , Reason: PORT Read Error ) Blocks Reading Error (0x200 , 1 , Reason: PORT Read Error ) Warning! Read error 0 strange behavior now likely! Blocks Reading Error (0x1FFB6DFFE00 , 1 , Reason: PORT Read Error ) Warning! Read error 0 strange behavior now likely! Partition info not found Done. Running:SAMSUNG: eMMC firmware dump... Init OK... Firmware file...C:\Users\PC\Desktop\A127F PROJECT\dump\eMMC_Firmware_hUnknown.bin Running:SAMSUNG: MoviNAND Firmware extraction... Z3X EasyJtag Software ver. 3.7.0.24 Skip loading eMMC Addon Firmware CMD Pullup Level:3114 mV CMD Active Level:3248 mV Box IO Level:3300 mV CLK Rate:14000 kHz Checking eMMC BootROM mode Skip loading eMMC Addon Firmware CMD Pullup Level:3114 mV CMD Active Level:3248 mV Box IO Level:3300 mV CLK Rate:14000 kHz --- EasyJTAG Samsung eMMC Backup Tool --- EMMC CID : 150100303030303030562016061354D0 EMMC CSD : 902701320F5903FFF6DB7FE08A40403A EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 05/2017 Rev.0x56 EMMC NAME: 000000 , S/N: 538314259 EMMC Part Number: Unknown EMMC ROM1 (Main User Data) Capacity: 2095982 MB EMMC ROM2 (Boot Partition 1/2) Capacity: 512 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Reading eMMC Boot Identification Data... BootLoader ID Hash:B2CED2CE5917EB9095030FCC199E7637 Reading eMMC Firmware Identification Data... Firmware ID is wrong , changing mode... Reading eMMC Firmware Identification Data... Firmware alternate ID is wrong , contact support Reading eMMC Firmware Data... Firmware Hash:B6D81B360A5672D80C27430F39153E2C Saving eMMC CID Data... Processing firmware data... Firmware processing done... Done. |
03-02-2022, 15:19 | #3 (permalink) |
03-02-2022, 16:02 | #4 (permalink) |
Freak Poster Join Date: Aug 2010 Location: Russia,Yekaterinburg
Member: 1363017 Status: Offline Thanks Meter: 44 | you have a flash drive in the booth Rev.0x56 Most likely she is already ill The last instance, look at the pair number on the body of the flash drive and write the firmware of the part number.bin to the flash drive |
